View Full Version : Softail Models
- Dash Panel Mount for PV Tuner
- 06 Night Train
- LA chopppers risers on a slim???
- FXCW Rocker Passenger seat question
- I need help. 2003 Heritage Softail
- Bike doesn't want to run!
- What kind of Seat is this?
- Pulsating/Chatter during acceleration on Fat Boy
- Need help with dimensions Deluxe front fender
- Need advice on selling a 2002 FXSTD
- Squeaky Belt or bigger problem?
- 2017 Heritage Red color Pics..please..
- fatboy tank and fenders
- 2006 soft tail deuce
- Paint peeling
- I'm back baby, I'M BACK!!
- Softail Slim Extended Bars
- Cam questions
- Tmax o2 sensor install on 13 Slim, Fatboy, Heritage
- 1995 Heritage a sound purchase?
- windshield cleaner
- Shifter and spacer
- Valve train noise.
- Price Check
- 2016 Softtail oil capacity findings
- Thinking about getting a breakout - opinions please
- Fuel level issue on breakout
- 2017 Softail Slim exhaust
- New Guy Intro - Fatboy Wheel Info
- cam options
- Adjustable floorboards for Softail Slim
- Anybody know what kind of apes this is?
- Dunlop Tire Question for '05 Heritage
- 2007 Heritage Pricing
- A couple questions about fuelpak autotune
- Headache electrical
- 2007 Fatboy Stage 1 options
- I was told it wouldn't run right
- What choices do I have for a loud, retro-looking horn for a Deluxe?
- Rubber stops
- Riser kit needed for Freight Train Nacelle?
- 2014 BO Fork Tube Caps Question
- Contol Panel dead on Heritage
- Potiential Problem? Stripped Out Screw
- Changing rear brake pads on Fatboy Lo 2015
- '99 Fat Boy... suspension options
- Been sitting for awhile, what to do?
- SLIM S Military Green with White Walls
- Anything new on 2017 softail? Just the price
- Look what I find on my ride...
- Underwhelmed with the touring choices, so
- wheel torque
- Good 107" kit for Breakout?
- Help with hardbags on Heritage
- slim S 2017 worth $500.00 more then 2016
- FXSTC driving lights
- How do I mount a Harley nostalgic horn for a Springer on the side of a Deluxe
- Softail custom
- Changing Slim up. (slowly) Need some input
- Tour Pak and mount for a Heritage
- Rocker /Breakout rear fender swap
- Reckless bags on Heritage
- 2002 Heritage dipstick blows out
- Harley Heritage speedo lens fogging
- Crossbones Springer to Wide glide front end
- Anybody have the Harley white pegs and shifter?
- 2008 Crossbones cutting out and backfiring under acceleration
- Heritage Softail Classic Stage 1 upgrade
- could someone measure fatboy wheel spacers for me?
- 2013 breakout rattle under console
- Softail Slim S Rear Cylinder Cutout. Fans worth it?
- 1991 heritage softail sissy bar
- 2009 Heritage - anything to look out for?
- peg advice for a newbie
- Pop up gas cap question
- Front Master Cylinder Rebuild Kit
- Swap to 10" mini Apes not going good
- Fuel Gauge - Light
- 2002 Heritage front brake questions
- Don't lug yer motor...
- Open primary help
- RWD longshot first look
- Sturgis, what a ripoff
- Softail Slim front brake Master Cylinder banjo bolt size??
- New Harley Rider Review
- Sissy bar
- Custom Laser Etched Heritage Recurve
- 2016 harley fatboy s
- Ultimate seat to fender pic
- Pulling blinker wire thru bars on 2014 Slim
- Fatboy front end on fxst
- If you want a HD tuner ...
- Some Summer Mods
- Advice On Saddlebags
- 2000 Heritage - 44000 miles
- Looking for advice on a solo seat for my 16 slim
- 07 fxst
- The new member of the family
- Rear 190 Tire On Deuce
- Converting Heritage Front Turn Signals to Bullet?
- Rineharts
- Battery or starter?
- V&H Fuel Pack vs. SERT
- Tank Front brake oil leak
- Intermittent Engine Stalling
- Oil Change?
- 2001 Deuce fairing help
- 2008 rocker daymaker headlight
- Leaking air
- Scatches on denim paint
- Springer Rocker Arm Adjustment Tool?
- raked trees and raked neck cups
- 2009 fxstc
- Progressive 422s: Preload... huh!
- Springer rebound springs
- Bike runs like crap
- DOT 5 to DOT 4 Change
- Question about Springer Saddlebag Guards
- Passenger floor boards
- Elite 3 250s on breakout
- 34 fronet drive pulley
- New Tires - What a difference!
- Done adjustments on my clutch before, but...
- weird...
- Springer parts availability sources?
- Wife bought a Deluxe, weird question
- model question
- help cleaning 03 Heritage Bags
- Compensater Gear
- Heritage 6 speed transmission
- model question
- Dislike ABS cable tension created by engine guard on Fatboy...
- electrical issue with softail deluxe 2013
- Heritage softail 2016 - heat
- Rocker
- Fitting a Switchback fender on my Slim
- S&S motor in a 2001 FXST
- High mileage breakout
- Rider Floorboard kit for 2003 FXSTS
- trail adjustment question
- Installing 2014 hard bags on a Softail (FLSTC)
- 2010 harley fatboy lo
- 2013 110th Anniversary finish name?
- For those who have 30 / 68 pullies on a six speed
- All Dressed up!
- dealer show
- Alarm sounding while riding
- breakout bug spoiler
- 69735-05 5-3/4 h/lamp trim ring fit
- Aftermarket Derby cover
- 1991 FXSTS Wheel replacemnet - Duece Rear?
- 2000 fatboy NO SPARK
- Bought another
- 2004 Fatboy Exhaust Brackets
- Torn on if I should get FP3
- Trading in a 2004 Fatboy for a 2016 or 17 Fatboy
- Prostreet breakout seat part numbers
- breakout fork stem nut covers
- clutch grip
- What have you done to your Deluxe to make it look more retro?
- Dyno $$$$
- Hard lowers on Fatboy
- How can I learn what's been done to my bike
- 2005 Deluxe Bag Mount
- ethanol free gas
- Springer Wheels
- Look for Map For my power commander
- 1996 fatboy brake upgrade?
- Backrest for 2012 Heritage
- Softail Slim S 117 upgrade
- What color is it?
- Fatboy S: the perfect touring bike !
- How do you know if Slim S shocks are adjusted properly?
- Solo seat for Heritage
- Lockable gas cap - lock broken!
- Help picking seat
- Cant believe we are thinking about winter mods already
- 2017 Harley Davidson Softail Slim S Design and Features
- rear docking cover kit
- Breakout paint suggestions
- Softail controls
- Mohawk Valley Sunset
- Dead Battery. Flashing signals
- Protective tape rear fender
- Finally received my Danny Gray seat for the Breakout
- Any recent experience with Bassani fishtails?
- QUESTION??? Rebuild or NEW???
- EFI block off plate part number?
- Which EFI tuner on Softail Slim S?
- Sodtail Blown Fuse, No Signal Lights, Speedo, & Horn.
- Softail cruise control
- Pictures from my son's first bike ride
- 2016 slim s, or wait for 2017 models
- floorboard spacers
- Stuck Derby Cover
- Boom speakers on FLS
- What happened to the nostalgic derby covers???
- New Sinister Wheels on my Deluxe
- double backrest seat recomendations
- Harley treats the Slim like a red headed step child
- Battery
- Fat Boy upper fork sliders/tins
- ingition wire
- Saddlebag Guard Cup Holder or Passenger Cup Holder for Heritage?
- Aux. Light recommendations
- FatCat Exhaust Installed!
- Stock Swingarm Dimensions
- 2001 fatboy red key light is on
- Windshield for Breakout
- Excessively high idle on startup
- Air shocks- how smooth a ride?
- Help with leather US stamped hand grips
- My Fatboy Lo cranks longer than usual to start.. HELP
- Front Brake Light Switch
- Fuel sending unit problem? Help
- Gas poured out exhaust!
- Help with LED turn signals
- How do i erase LO RNG code on my fatboy Lo
- Stupid ethanol!!!
- Changed up the Slim some
- Holy Cow I just bought a 1998 Heritage Springer!
- Picture of my new (to me) 2013 FLSTC
- Took my son out on his first bike ride
- Big Sucker Installation Questions
- 95 heritage soft tail classic
- Brake and turn signal issues
- 2015 breakout
- Tapping in engine.
- Harley Newbie question
- Engine power cut off while riding
- Softail Slim seats - what I've learned...
- FLSTC Tank Console
- Breakout turns 50
- First Time Heritage Oil Change Help?
- Breakout Upper Triple Tree - Factory Defect?
- top motor mount adjustment on a softail deluxe
- feeling bummed!
- Show me your Stretched fender
- tuner needed for slip on ..slim s model ??
- V&H Pro Pipe 2in1 Won't Seal
- New guy...Breakout problem
- Reduced Reach for controls
- Any rumors on a new slim s model ?
- Last dollar spend at Eastern Performance after Magnum Cable issue!!!
- Breakout rear tire heating
- New (to us) Heritage Softail Classic for the wife
- My new slim
- 2000 Fatboy Petcock Question
- Looking for S&S E carb install tips
