View Full Version : Softail Models
- 200mm tire conversion ?
- Slip-on suggestions for 04 Fatboy
- 2000 Deuce-Dot 4 or Dot 5?
- 2005 Heritage Softail Engine Upgrade?
- 32 ford tail light issues
- 2-Pin Multilock Connector (Front & Rear Turn Signal Connectors) - Removing Pins
- Avon Ganster WWW tires
- Nameless. is back.
- hard bags for 14 Heritage
- Was told 6-8 weeks wait time on Samson longtails.
- Internal brake line question
- Saddlebag brackets and exhaust
- Radiantz Lighted Frame & Softbrake Relocation Write-Up
- shotgun V legend
- redline vs syn-3 in tranny
- [FXS/Blackline] Michelin Commander II 120/70-21 original rim and fender
- Vance & Hines - Fat Boy Lo
- Cutting Vance and Hines?
- 14 vs. 15 Heritage Classic
- Questions about a Deluxe
- Heat shields
- Original connector dis-assembly.
- so torn on what front end for my bike
- 16" Carlini gangster apes
- Fuel guage Question
- Canada HD Parts Supplier
- quick detach passenger back rest mounting hardware?
- Tuning question
- Where to hide signal stabilizer and Run/Brake/Turn modules?
- Best way to Remove Warning Stickers
- S&S 98" big bore kit
- 2014 Heritage Softail Classic Start Issues
- Slim with Ripsaws
- I deserve ridcule
- Why Syn3 over a alternative full Syn?
- Inverted forks on a Breakout???
- Se pro super tuner/download
- Narrow Glide on Fatboy
- Elegant windshield mount for 1999 Custom
- Front signal mounts
- 14" Cyclesmith Banana Boards...
- Screamin Eagle long shots?
- Shift linkage removal
- 1993 springer softail
- Episodes 7 & 8 - Project Softail SpeedFreaktv
- Dropped tins off for paint
- Coil relocation complete
- Detachable Saddlebags on Heritage?
- medallion gauges?
- any tips or tricks on exhaust install?
- DK customs breather bolts
- Rotor size on Deluxe.
- 2004 flstc efi spitting and sputtering
- SS Jam Nut and Rea rfender Rail
- X- Bones VS Softail Slim?
- Rsd 200mm 2up
- About to build out a new tank for my Slim
- 2005 Heritage Question
- heartland 250 conversion
- Who here names their bikes?
- Sturgis 2015...Who's Going?
- best rear tire
- Sat on a Softail Slim today...
- Dang It...I Thought I Was Done!!
- RS 12" vintage bars on 2013 slim
- Progressive drop ins on Heritage
- Viking Saddle Bags for my Deluxe
- 23" softail photos
- Calling all Fatboy lo owners with apes
- It's a non-starter!
- Need help with seat fastner.
- FuelMoto 107 stalled, Heads next?
- swaping lowers
- Loose spokes
- Dreaming... and Jealous!
- Wheel question
- 21" front wheel for Softail Deluxe
- 3m clear bra application to swing arm?
- Springer Owners-anyone use Wild 1 Chubby Stubby Springer Risers?
- Added a second bike! 1st question...
- 89 fxstc
- Detachable Saddlebags with Detachable sissy bar
- Floorboards on Breakout
- Help: Need Tool Measurement
- Possible to install a new cam cover without removing the exhaust?
- Another Swing arm bag mount thread
- Rocker C Passenger Pad
- CVO Breakout Service Manual - Softail or Supplement
- Got her back after the accident
- DIY Heritage trunk for less than $150
- Left Turn Signal Indicator and High Beam Indicator Not Working
- Opinion- tank swap, as is or paint?
- Mounting a saddlebag on a Slim
- 2009 Heritage Softail
- V&H Big Shot Performance?
- Samson cholo exhaust?
- Show me your 14" Carlini Flying Apes
- Your thoughts
- Where I can buy a "carpet" like the deluxe low rider style
- Turn signals occasionally continue to flash after I turn off 2014 Slim
- Heritage owners running w out bags
- Air Ride Suspension - Best way to park it
- lowering bolts
- Fenderless...
- 07 Deluxe,...front forks
- Winter changes have started
- How to remove a 2014 Fatboy Lo Gas tank
- Custom swingarm bag, custom mount
- Thinking about RK classic leather bags on fat boy, will they fit? Bracket?
- No rear brake light
- 09 fatboy wheel on 06 standard
- Lining up the Winter Purchases....
- need help with tombstone backing plate removal
- front running lights
- Quarter Fairing
- Flh bags on heritage
- 2014 Softail Slim blackout project.
- Handle bar riser on Rocker FXCW
- '05 Night Train 200mm conversion
- Deluxe rider floorboard brackets
- shotgun shocks switch placement
- Softail Slim with a front hub cap?
- A little help w Heritage tail light wiring
- Chrome swingarm covers
- License plate relocation and the dreaded 3 holes
- Deluxe - One Piece Upright with Stock Rack and Luggage?
- New to the forum
- audio questions
- Brake wire splice on a 2014 Heritage Classic
- Chrome Bolts on Softail
- Adding Fringe/Braid to Grips
- brake lights locked ON (2014 Breakout)
- finally ordered my exhaust!
- 1987 heritage
- bouly's softail 1340
- Started Installing Apes Last Night...Couple Q's
- Need advice
- New wheels for an older softail
- Brake Dust
- 2010 FLSTC Fuel Pump
- Need ideas on gas cap cover/replacement on my Breakout
- freedom performance true dual mufflers
- Fuel pump not priming
- installing heated grips
- Samson Cholo Exhaust: 1st month of waiting down
- Springer Baggertail Project
- Night train mods for comfort riding
- Hello All
- New Bear Trap pegs installed
- Thankful to be alive
- Brake Running Light / Turn Signal Conversion Kits
- fatboy/delux lowering question
- Breakout Mirrors - "Post your pics"
- lowering with progressive
- Wolo Big Boy Air Horn on Breakout
- Heritage rear turn signal relocation
- Project softail | speedfreaktv
- Carlini Apes: Anyone with 10"-12"?
- jockey shift
- the deluxe was in the international motorycle show!!
- Breakout SS Rear Axle?
- grinding noise out of Primary
- Another Bag Thread
- Olathe+ heritage+ fat boy or beach bars?
- Front brake squeaks
- control swap, fat boy for standard
- Breakout owners: Front tire issue
- Can H-D 4" Straight Risers be used on a Heritage Softail Classic?
- Putting a 103 in a 2001 fatboy with a TC 88 EFI ?
- ABS Light Flashing After New Speedo Install
- Mexican Chrome
- Any soft ail owners having trouble with the leather tank strap coming up?
- Harley Davidson 7" Daymaker Led Projector Style Headlight
- Need wheel help
- '15 vs '14 Front Master Cylinder Bore
- Oil kits? (Milwaukee Twins)
- Install HD Security System on a Heritage
- heritage windshield
- Front brakes
- V&H Fat Boy exhaust on Rocker
- '04 Night Train Owners: A Favor Please
- deluxe tin fitment
- Softbrake Recent Issues?
- Selling the Project Rocker
- Arlen Ness by Magnaflow Lowdon on Breakout
- ABS shotgun shock compressor mount?
- Lower Front End Too???
- Heritage wheels
- Help! My 2010 FLSTC won't start!
- Flush mount fuel caps question
- 4.25" Wheel for Slim??
- Lifters/Tappets and rocker arms quality?
- 2015 Heritage
- Sissy bar design essentials?
- 1998 Heritage Softail
- Slim winter mods.
- Im sure not, but I going to ask. fatboy + hardbag
- Tank lift, before and after pics
- difference between springer and heritage
- Used Alarm and New FOB programming?
- Ape Hangers?
- PM 6 speed tranny cover
- HD 2000 Night Train... Wide Tire Kit Phatail Kit
- recomendation for 09 Heritage tank bib
- fiscal control
- Any tips on installing Dynojet Autotune on a softail?
- Do I need to port my throttle body?
- front turn signal offset mount
- Ride wright rims???
- switch board tragedy Softail Slim
- New from Needles,Ca
- Fuel Tank Custom Paint- QUESTIONS
- Gettin ready for paint
- EVO softail FLSTC Raked Cups pics inside
- Who's using a swing arm bag?
- Woody's Fairing on my CVO Deluxe done.
- Mustache Vs Standard Engine Guard
- Vance and Hines competition baffle
- One of Pope Benedict XVI's Harley-Davidsons Sold for More than $50,000
- Difficulty removing brake cable?
- Springer front end on a Rocker C ?
- On my 05 Deluxe
- Heritage Springer Saddlebags
- New Softtail Owner with Questions
- DNA Fat spoke wheels???
- Cell Phone Charging
- How to do a tank lift
- do the windshields work well on softails?
- Need ghost brackets help please
- Check these out...
- My new ride... 2007 Softail Custom
- LA Chopper Twin Peaks?
- Deluxe seat bolts
- 2007 FLSTSC Dash and speedo
- 2 up Breakout seat - not a lot of choice
- Chopped rear fender for Fatboy Lo - Which one?
- Discounts from vendors
- painting the tins
- fork tube length
- What's happened to the Blackline owners?
- MPG and the cold
- Samson Longtails 39" - Anymore delays?
- Pipes recommendation.
- Springer/Cross Bones Frame?
- 2012 Softail Slim
- Running 68 tooth rear sprocket on late model Softail
- 08-09 night train vs. '14 street Bob
- Break Out front end on FXSTC
- Tuner in Kansas?
- Coil and horn relocation today
