View Full Version : Touring Models
- Fork Mount Air Deflectors
- Started the process of selling my 07 FLHTC, gut wrenching process.
- Road King VS Road Glide Handling
- KOSO temp dipstick is it accurate and worth it?
- Larger T-Pak Wiring Cover?
- Kyle Racing East
- Not enough throttle cable for Ultra Classic
- Wheel spacer help
- Considering a caliper upgrade - is there a good source for them that anyone can recommend?
- Compensator oiling tray
- Clutch Cable Broke
- K&L vs Redline Wheeled Dolly
- 2010 Electra glide police edition
- Was not too happy today,my Road King in the shop
- Voltage regulator 2006 harley davidson streetglide flhxi
- 09-13' Ultra to Street Glide/Road King rear turn signal bar?
- Freedom Shields
- break light problem
- Cush Drive
- clutch issue after installing easy pull clutch 1fngr
- Saddlemen Pro Series SDC Performance Gripper Seat witH backrest
- Is this normal?
- Stator grommet o-ring part numbers?
- Is it possible to replace outer cam tensioner without removing rods, etc?
- Seat Pads
- Permacap part number
- Oil seepage around transmission screw - 17 SGS
- Crossthread adjustable brake arm
- Let's see your Solo tour pack set-ups!
- 08 Ultra rear shock question
- RickRak Gas Kap Saver
- Empty wiring harness behind headlight?
- DTC P0131 experience
- A couple of questions - heated grip issue and fairing spoiler color match
- Quieter exhaust = more noises
- Sturgis 2023 Advanblack
- tire pressure
- 2018 RG handlebar shake
- Road King 2006 Starter Issues - Jack Shaft- Corrected
- building a RGS
- 1990 fltc
- To paint inside/under speaker grilles or not, that is the question
- Trike - Convert 2012 FLTRU or Buy New
- Baja Designs LP6/Stock side-by-side - Road Glide
- License plate relocation kit
- Which cruise control wire goes where?
- Fuel Sending Unit
- Handlebar problem
- 2012 cvo misfires when warm
- 2011 Street Glide
- 08 Electraglide Classic Oil cooler Recommendations
- Changing Exhaust
- Info on this Rinehart Air Clearner
- Help??
- The coolest OEM mirror hole fillers Ever! LOL
- Heated grips for 2010-2013 with internal wiring
- Preload
- Shark nose fairing
- 05 ElectraGlide Ultra Classis Trunk Latch
- "Correct" batwing cable routing
- Speckled rust/orange on heat shields on daily rider
- recon
- My bike is tracing to the left when I remove hands from handlebar
- Ignition Cover Screw?
- Exhaust stud
- New Battery
- Custom Dynamics
- Belt tension adjustment question
- Thoughts on Cobra speedster dual exhaust
- Road King 2006 Starter Issues - Jack Shaft?
- anyone paint their exhaust pipes?
- Cruise Control Adjustment?
- Road glide handling issues
- Trouble finding a tour pak quick release with license plate relocation for 2013 Ultra Classic
- ‘08 Ultra - Saddleman seat fitment issue
- Looking for Road King Fuel MAP
- Passenger backrest
- 30 tooth compensator. LOVE IT!
- Compensator for an 09
- Helmet resonance - through seat? 2007 Road King
- Mustache/Highway pegs + SE Heavy Breather
- Antenna
- Alaskan Leather Discount Code
- 2005 Road King custom seat question
- Better Bag Guards
- Kst kustom 10 inch 6 bend kickers
- Short girlfriend
- 2007 flhrs
- Aquatics verse Rockford Fosgate
- Tire wear
- 08 electra glide ultra classic original exhaust
- Battery for 2005 Road King classic
- Arrival of my Revival
- Clutch cable
- Bolt Size and Thread Size?
- fitting a shovelhead fairing to a late model road king
- Applecarplay plug a no go on RF equipped SGS
- Pulled the Trigger - 103 to 110
- Inner fairing (boombox gts) area not lining up
- 13 inch hand adjustable shocks
- Saddlebag Accessory Wire Routing
- Batwing tallboy handlebars 55800591
- CB issues
- Dealer issues
- 23 cvo
- Sena Intercom Headsets
- Highway King Windshield
- Clatter
- Signs your voltage regulator is quitting on you.,,
- suspension
- Bassani Down Under True Dual Exhaust , your opinion ?
- My 150,000 mile experience (long post)
- New seat
- electric center stand
- Throttle grip squeaks when i let off
- Ultra Classic 12" Ape Hanger Question!?!?
- Road Glide ST build thread
- Temp sensor
- Red thunder db killer specs/dimensions
- Tapping Noise After Strapped Down On Trailer
- Stolen Bike
- Help me choose which Ciro highway peg mounts please
- Plug coming from under tank?
- Dominator Industry Bars
- ultra classic bars
- Fuel delivery problems?
- Harley-Davidson Street Glide VS Indian/BMW/ Turbo Road Glide
- 2023 Harley-Davidson CVO Road Glide. It wasn't love at first sight
- 2011 ultra classic stock bars
- Looking to use the obsolete PTT button to enable a garage door opener
- State border prompts
- Sissybar for 2001 Electraglide Classic
- Subscriptions?
- 2020 SGS possible twist grip sensor issue
- Front brake clunk
- Question Regarding EITMS use w/ HP Cam
- Suggest a slip-on
- Finally
- Verifying Proper Operation of Master Cylinder
- flush mount gas cap issue
- Legends Revo A's on 23 Road King Special
- Intercom/CB port Question
- 2015 flhtk oil cooler.
- Boom GTS Home Screen
- antifreeze out the over flow tube
- Problems after Wide band Autotune install
- Help me Choose EG Police or Revival
- 2019 Road Glide Ultra info?
- SG ST M8 117 - Stage1+2 upgrade (advice sought)
- Brake Pads, What brand and where do you order from?
- Installing 7 in. Visor Headlamp Trim Ring with Aux lights
- I went to visit “El Chapo” today on his anniversary
- Too hot to ride (Infrared Therm gun results)
- Mirror thread pitch on 2020 SGS
- 2018 Ultra rear fender trim needed
- Loud ticking after woods tw-222 cam install.
- What color blue is this bike?
- What a difference an Ultimate Seat makes
- Cam Chain Tensioners 2000 Ultra
- Couple of product question for the new ride.
- shorten handlebar turn radius
- front rotors 2011 roadglide
- Abandoning Harley Ride Planner, and factory nav on the GTS radio in favor of Apple Carplay. Couple of questions
- Rockford Fosgate mono amp PM100x install
- primary oil in starter
- Is there an even further footboard extension than tall boy cycles?
- GoPro windshield mount options for Road King?
- 2011 FLHTK Fork Oil Change
- 2012 Road King Classic: Front brake help
- 2013 Stock Ultra Limited stalling
- 1996 Road King no oil pressure
- Ready to rip my hair out 🤬
- Red tail light lens fell off — “not uncommon”
- 11 Ultra classic no start
- Super loud ticking noise after cam install.
- Touring in heat wave
- Engine Guard Torque Check
- New seat vs MCC Mod for taller riders
- 2023 CVO - Cycle World Video "Review"
- Bassani Road Rage 3 Stainless Question - Bagger
- Tire Plugs
- Fuel light
- How do ya'll determine good exhaust for a bagger? (Stage 1)
- Would a bad battery cause this?
- Stock 2020 Street Glide With Graphics ?
- Enforcer wheels conversion
- Road King - Seat for Short Rider
- Rebuilding 11/16 master cylinder, any tricks or special tools required?
- 2011 SG rear brake lights harness pin diagram
- SE pro street tuner
- Security System Lamp
- Rear Brake Caliper Rebuild Kit
- 2010 Ultra Classic near shut down
- 1991 flhs
- D&D Billet cat or Bassani
- oil holes in the backing plate...
- Highway pegs that fit stock SGS crashbars?
- My (Iron Butt Association) Saddle Sore 1000 ride experience
- 2002 Ultra Classic with 3 wheels flhtcui
- Lost Speedo, turnsignal cnxl, and cruise control
- Street glide performance 2 into 1
- Battery issues
- Handlebar cover insert
- Throttle hard to turn
- Accessory plug and Kuryakyn speakers question
- Is this pin-striping factory?
- How do I fix this button? As always dealer f@&k things up
- Check Your Brake Pads - WORST CASE
- throttle body pin fretting..
- 2012 Touring belt guard/shroud available? "gravel road"
- Looking for a particular set of pipes
- '06 Ultra codes
- Trying to identify this sensor...
- Traded my '22 Heritage in on a '20 SGS
- HD Longblock lead time?
- Cost For Cam Chain Tensioner Replacement
- Aftermarket batwing & lower fairing or factory?
- Front air suspension
- 2007 road king police
- Seat Suggestions?
- Vicla/Cholo/Gangster Road Kings
- Khrome Werks Outlaw pipe
- Wheel weights
- Outdoor bike cover from hd - worth it? Lightweight?
- My gear indicator keep disappearing
- Flo Motorsports V5 Floorboard Question
- Any Opinions on HD 'Polished' Rotors?
- Let's see your wiring for speakers and accessories inside the saddlebags
- Road Glide Ultra bars on the Road King
- ANYBODY do ape hangers on a 2008 Road King..?
- star racing torkstar 577
- Rider backrest ….
- Stage1 for SG ST 2022 - who's done and did it help with the heat?
- Saddlemen SDC Performance Pro Series Seat With Lumbar (Gripper)
- POLICE hockey puck question
- New Bikes!!!!!
- HELP! 08 road king clutch cover removal???
- Cooling fans.
- clackity clack what do I check first???
- Big Bear Performance
- No Restart Immediately After Shutdown
- Hogworks quality
- Sometimes, danger can jump out of the shadows
- Fairing whistle on Road Glide
- GT Screen Peeling
- getting harder to find neutral, potential causes?
- Road Glide to Road King comparison
- 2007 Street Glide Check Engine Light
- Adjusting Brake Pedal Height
