View Full Version : Touring Models
- Cruise control kit for Road Kings
- neutral starting switch
- Turn Signals Malfunctioning
- Variable Speed Sensor, 06 Road King, FLHRCI
- Happy-Trails Tour Pack
- iphone 6 plus
- Show off your Street Glide!
- Searching for my old Road King!
- MA785 shock experience?
- Stock headpipe-don't give up on it just yet
- Advise please, installing new motor in 15 RoadGlide
- CB antenna
- Fork mounted wind deflectors on a 2005 FLHRSI?
- 6.6 gallon tank on '06, mods needed?
- Front end help
- painting parts of the bike
- 1-1/4" Bars on 2005 Road King
- Sunset Ramble
- Road king fat bars.
- When is 13 inches not 13 inches???
- Horny Problem
- 06 or 07 electra glide
- road peg flops down
- Ohlin Shock Boot?
- Street-Glide 2006 with Double DIN
- 12 limited QD license plate question
- Thunderheader fitment
- HELP With FLHRS Raod King Custom Dash part !
- Seat Covers for Tourning Models
- purge tank
- mp3 CD , will it play in the 04 radio
- Baker Compensator
- PCV MAP Review/Thoughts, experience
- rear cylinder does not fire
- Road Glide Fairings '11 - '13 movin' 'em?
- Heat Shields on CVO Mufflers??????
- Rear turn signal bar removal
- Rinehart 2 inch Exhaust to 1.75 Headers?
- Hot 107
- fuel gauge
- Heat Demon Grip Warmers
- illuminated fairing mirror covers not working
- Question on seat mounting for stretch fenders
- Chrome Switch Housing Kit-70228-96C
- Extra Warranty opinions
- Where to buy Cyco cam chain tensioner assy?
- new owner
- Compensator Failing
- OEM Street Glide seat ??
- Faring, Dead Center Faring vs Woody
- Ape Hanger Installation
- Tour Pak Chopped or Razor Questions? ??
- Bike value,2007 roadking classic
- Bike value
- abs wheels on non abs
- Chrome wheels/forks with black cables?? Pics?
- 2016 Electra Glide ultra classic low
- 12 RKC Ride Height
- timing covers
- High output charging system?
- eBay saddlebag liner kit
- A little tour pack help from those in the know
- 08 Road King
- 08 Road King Spoke wheels
- Taking the black off chrome 28 spoke knuckle wheels?
- Need Help:2015 Fuel Pump Assembly question:
- Whats the big deal between 2014/2016
- Screaming Eagle Heavy Breather Questions?
- 2006 Street Glide Gets A Full Winter Mod!
- Tuning Cause Hotter Cat?
- Road King Ape Handlebar Help
- Quality of Gauges
- jiffy stand strength
- Gas Mileage
- road king handlebar question
- Axtell 117" drop on kit
- Changing front turn signals
- Any other halo options for phase 7 besides kuryakyn
- 14 Ultra Headlight bezel trim
- What is the hydraulic brake reservoir sight glass about?
- Progressive Monotube Fork Lowering Kit '97-2013 Top Out Spring Lenght
- Help with Power Comander 3 mapping
- Ultima Aftermarket Starters Beware
- Jiffy Stand interlock
- swapping soft bags for hard bags
- Hill country customs
- Tires
- Been away a while, some changes to the bike while i was gone...
- Chrome vs black durability
- Clutch cover
- 2007 SG Gllide-Pro and suspension
- tax time dreaming
- My bike is beeping at me!!! HELP
- who's running XIEDS /VIEDS ?
- FP3 on 2012 FLHT?
- "What Would Harley Do"... Pre '09 Bagger Wobble Stabilizer
- Upgrading to S&S 106 Big Bore and 551 Cams
- front fender
- Wiring for heated gear otions.
- help
- Powder coating
- mabe good deal for someone
- A/ B Mode button on Odometer not working
- A loud BZZZZZZZZZZZZZ while riding?
- True Duals = how much low end is really lost ??
- Best way to remove metal tank emblems
- EG outer fairing threaded inserts
- 1985 flh S&S ? plus oil leak!
- Dipstick temperature gauge.
- My new street glide
- 2002 Ultra - can metric speedo switch to miles?
- Carbureted air filters - watcha got?
- Hogpro
- Carlini apes
- FM107, Hillside 107 or SE110 kit
- Extended arm backrest
- Transmission Sprocket removal
- Lowering Blocks w/Longer Shocks?
- Opinions on dealer replacing a bad radio with a refurbished instead of new.
- Older style cruise and new cruise control swap
- A year away
- Review Sta-Bo EDD-16/ All Balls Wheel Bearings
- No rear brakes
- What do you do with your Helmet?
- TTS Mastertune single bike licensing ?
- **DONATE 02 ROAD KING parts>>>Help**
- ride on wheel chock
- (Torque x RPM) ÷ 5,250 = Horsepower
- FreeWheeler seat same as StreetGlide seat??
- 2007 FLHP build thread...
- Heritage stock bars for rkc
- Easy Docking Point Question
- Adding OEM heated grips to a '15 Limited Low
- S&S Pipes
- Transmission curiousity
- 21" Spoke Options for Front Rim
- Deal on "Battery Tender" Power plus 3 at Costco!! Worth Checking Out!!!
- 2003 Harley Electra Glide Inner Primary 60k miles
- New throttle cable questions
- Wiring help please...
- Switch Wiring
- Fork Sliders...chrome or polished
- Opinions and I know you have them!
- batteries
- Reflex Braking System, do you like it?
- best option for LED turn signals
- $200 hardware kit for 2014+ bags?
- road king or electra glide? need help
- Request for measurement - Road King fork lock cylinder
- Great Day For A Ride
- Questions about installing a Rushmore Air Cleaner Cover on a 2013 Ultra Limited....
- Tools for 06 and 08 Ultra
- 2006 EG Classic ignition key switch install
- B&w biker bar or wherldock
- Lowered brake lines
- Fork Brace on a Street Glide!!!
- Getting The Right Bars
- Oil cooler return and feed line?
- 03 stock seat on 11
- Tour pak dust cover
- opinions on heavy breather replacement
- 2016 Limited wheels on 2010 Limited?
- GPS Navigation help
- Stabilizer for newer Bagger?
- Dreaming...
- Street Glide Rear Light Bar on a 2009 Electra Glide
- Lowering a 2012 Ultra
- Twin Peaks
- Old Rubber Fuel Lines
- 2012 street glide
- New exhaust, rear air ride , other misc installed
- Memphis Shades Batwing on Road King Police
- Extended bags and fender- stock height 07 SG
- Rear light issue
- Removing road salt
- andrews 57
- Aux Light Ground
- Road king Excessive Vibrations
- oil everywhere
- Gauge size
- If you HAD to choose just ONE......
- Enforcers on older bikes. Who has them?
- Hogworkz lower fairing
- Mute radio function
- daymaker
- blacking out
- System to flush remaining 24oz + of dirty oil out of the motor when changing oil
- Starter made a 'grinding sound' but started...
- Question about my rim. Video posted
- Stock wire routing under the rear fender for a street glide tri bar.
- Clearview XL
- Ebay LED Headlamp and Auxiliary Lights?
- Clean radar detector mount?
- Power Vision / Tuning question
- Cam chain tensioner pad questions.
- Is my bike a "Power Pak" bike?
- Help saddle bag rack
- Help identifying hand grips
- MIA - Danny Gray Seats!
- I really want a 19 or 21" front wheel! What do I need?
- My mechanic passed away - now my service options
- rush power duals
- New chrome lowers
- cam tensioner failure
- All ready thinking about removing the Tour Pack
- Need help finding a motorcycle tuner in Pittsburgh
- batwing bars
- Washed the bike today
- Freedom Exhaust
- Will a 2011 throttle body work on a 2010
- Fork Stabilizer??
- I need a new tuner Colorado Springs, who do you go to?
- Roller rockers on a touring bike???
- fairing mirror
- Leather tour pack quick release straps replacement
- Rinehart True Duals, Big Sucker, SEPST
- Ultima Kool Kat Wheels
- Rushmore Road Glide fairing better than 2013 and earlier?
- What mirrors with apes?
- Will harley's throttle body cover work w/ big sucker I?
- What do you think of your Tire Shredder Kit
- Anyone install Ohlins FKC-101 Front Cartridge Kit?
- help me see around corners
- Mainshaft oil seal leak
- Turn signals solid and bike won
- Trike trees for 23?
- Road King tank Question
- 103 breather
- What part in a machine shop would you like made?
- Re-key HD Tourpak
- Good tuner in central NC?
- Led Headlight and passing lights
- Anyone have the burst collection grips?
- 2007 Road Glide starting problem?
- Roll off connector for TBW?
- Quality Rear Wheel Bearings 02-07??
- 2015 SGS suspension?
- 2014 Street Glide rear fender on a 2009 Road King??? Will it fit??
- Unused powered "ACC" button
- Hard saddlebag Question
- 2005 road king rims size
- 13 and under tourpak lock matched to a 14+ key help
- D&D Exhaust doesn't use circlips like design
- Oil question, dont want to start a war.
- new owner handlebar question
- Need Your Ideas for TourPac antenna holes
- Headlight Replacement for Road King
- Finally replacing Tensioners - Borrow the tools from someone?
- Spring vs Hydraulic tensioners
- Dealer stepped up!!!
