View Full Version : Touring Models
- Get-A-Grip hand grips, any good???
- Yes, you can rock out at 80mp
- Mega Plasma Rods: FLHX a slightly different way to mount
- Santee 11" Dresser Apes on my 2010 Limited
- This is interesting
- New seat for the Street Glide
- J&M amp blowing fuses!
- Klock Works Flare or National Cycle V Stream?
- Finally Back On-Line and Other Stuff
- Remap, stage 1 or do nothing
- I rode my Glide yesterday. Oh yeah, Osama bin Laden dead too
- Electrical - Battery Draw Issue
- 10 mm Phat plug wires and SE performance spark plugs??
- where can I buy a tube with right angle valve stem?
- Oil temperature?
- Choke down problem gone
- Wet, too wet
- Magnum Chromite Issue
- battery voltage at battery
- Stator ?
- Fuel Gauge
- What tire size Elite 3
- Electra Glide Stalled and wont start
- Freedom Wings???????
- Ignition Switch Glitch
- 2011 FLHP (cop road king) tour pak?
- Mounts for Sissy Bar on 2009 FLHX
- Identify
- TBW Thundermax!
- hogtunes highway kit
- New Pics of the Ultra and SG
- Dual halogen replacecment bulbs
- Front brake switch ?
- Anyone with S&S Power Tune Headers on a 2010 + Touring ?
- Radio in my FLHT
- Cool GPS featuer find. HD waypoints.
- Cures for the shiny black screw?
- Arc mini amp question
- 2009 street glide- stock radio problem
- Simple no cut wire mod 4 high w/ passing lamps
- couple pictures added
- RSD Slip ons & head pipes
- ride quality on aftermarket touring air ride?
- Wild1 515 and Wire Extensions
- Adjustable Auxiliary Passenger Footpeg
- How Much Life In Your REAR Brake Pads? (esp. '09 FLHX Owners)
- Just my 2 cents
- Rear Brake Light Switch
- bad gas
- Shifter Bushings
- J&M Speaker Tone Settings
- LRS Ultra Flat Top
- sg seat
- Batwing without windscreen
- No More Mobil1 15-50 Now what??
- yee-ha!
- Riding in the South
- front brakes
- Difference between '03 and '05 FLTR
- J&M amp, NO SOUND!
- Will power dual for a 2009 fit on a 2010
- Try it again-your thought,s
- need help tssm junk?
- Florida to Memphis Gas Shortage?
- Is the 103 a gas guzzler?
- Valve Noice
- Will 09 SG wheels fit??
- Squeaking from front end of Road king
- Progressive Monotube Install
- HD LED Headlight Mounting Ring Issue
- detachable Tour Pak causes seat to Vibrate, help
- just got that sick feeling
- Your thought?
- 1584 engine milage
- Flush LED Fuel Gauge on '04 Road King Custom
- primary/rocker box noise?
- Dearlership Honors
- Gps help
- Need Help, Performance and Temp
- Throttle free play help
- Best Tool Kit
- Kuryakyn Run Turn Brake light controller???
- My New Scoot!!
- Monster Rounds Installed
- FLHX forward mount controls.
- Another Dumb Monkey Bar Question, Sorry
- car back into my new 2011 SG
- Mustang Solo on 2011 FLHX
- Anyone using the "new" 2up tour pak QR mount.
- New cam plate and oil press question
- Fairing Screw Question
- How badly will I screw up my new bike?
- Klock Werks video for detachable windshields
- What I do not like about my SG, buffeting! Help!
- Jackpot Quiet Baffle Users ?
- Trouble with Kury/Truck lite passing lamps
- Motorcycle Trailer Tie Down ????
- Passenger Highway Pegs?
- 2011 SG 200 miles and oil on the garage floor
- Problem With GPS Install
- I pulled the trigger last night
- I went and did something stupid today...
- Chick bike?
- E-Z Up Center Stand & J & S Lift
- do you lube a nylon coated clutch cable?
- Clymers manual wiring diagram help
- Need Options for Air Cleaner Cover
- Titan 6.5 for batwing
- Replacement Windshield for RoadGlide
- Custom paint........
- Jackpot question
- For All the Mechanical Gurus Here
- Do I really need to remove the fuel tank?
- Quieter mufflers
- 03' ultra headlight question
- Vance and Hines Dresser Duals
- Driver Backrest Bracket - Mustang WideTripper
- Highway Pegs
- turn signal problem now general problem
- vibration
- Odd qst..
- Halo Ring Installed
- Nice Weather!!
- Intermittent Clicking when starting
- Need quieter but keep the rumble
- Servicing an Electra Glide
- Sissy bar/pad vs. Tour Pack on RKC
- New idea
- Installed Powerlet - right to my battery
- Possible abs problem
- oil blow by
- Low Seat
- Do passenger handles interfere with saddlebag lid guards?
- Which Fairing windshield bag?
- 2011 Limited Just Dyno Results
- Oil pressure gauge on a Electra glide standard
- dyno/power commander ?
- Tools
- Easter ride choke down REVISITED
- Wily Shiny wheel exchange / MCC seat (Pictures)
- relocation of turn signals
- ABS Brakes...Food for Thought
- RK front brake lever adjustment
- slip-on won't slip on...
- kuryakyn led turn,brake lights
- 2011 seat part # help
- Kit to remove tourpack on 2010
- Where Can I Find Used OEM Swich Housings and Wiring
- Engine View
- Best Road Glide Speakers???
- Custom Ear Plugs - Suggestions
- need help with wiring
- This seems neat
- 2012's
- Removing dipstick, 04 Road King Classic
- To Dyno or not to Dyno
- HK Advanced Audio FLASH?
- my 2011 UC Shrine Edition
- Screaming Eagle versus V&H Monster Ovals
- Longterm Feeback on Legend Air Suspension
- Ultra Vs Road Glide
- Front fender accent
- Trade in 09' streetglide for an 11' Streetglide
- What happened?
- HELP!! Cruise Control Conundrum
- V&H headers w/stock or Rush mufflers?
- Power vision
- avs questions with a kenwood radio flht
- Who makes these bars?
- highway pegs
- CAM Question
- 01 RK Classic 2 Up seat attachment
- J&S lift oil collection tray
- Street Glide seat help
- Exhaust Baffles Question
- Fuses for tool kit
- 2010 SG pops on deceleration
- SERT question
- Throttle Up Industries Stabilizer Install Problem
- License plate - vanity
- looking for input on vance and hines big radius exhaust
- 85 PSI oil pressure after cam change
- Reach Seat and Adjustable Back Rest
- Correct monotube fork oil
- 19" Longride Windshield on a Road King
- Best aftermarket tires (2011 Road King)
- hidden antenna
- Chrome Primary flaking inside
- ARC audio MPAK kits
- 2008 Road Glide
- Who Has A Tallboy Seat With Rider Backrest
- How many RK owners have swapped out their seat for a SG or RG seat?
- where to go from here
- Video of my 2010 Street Glide exhaust
- Pinging on a 2011 Ultra Limited
- Se compensator befor and after
- Help with Road 6 Customs parts.......
- cutting football
- Well.... made up my Mind, going 26" on the Road glide.
- Well Harleys do hold their value a bit better.............
- End Caps for Stock Pipes
- Lightbulb swap, headlight--highest watts
- Tie Down
- Handlebar Removal & the '08 FLHX fairing
- First Ride
- Couple of pics from Mt. Scott
- What would you consider must have mods?
- Elite 3 Tires sale?
- Need some help with what kind of exhaust to buy
- 02 Ultra Classic
- 2012 Radio Issues
- Sneak Peek
- Retune,yes or no?
- Anybody with 1st hand knowledge.. ( Adding Cruise Question )
- my first dealer service experience ...
- Contemplating Road Trip
- Anyone know what this Rack might fit?
- FLHX fender struts?
- "Kidney belt" for back support?
- Get a grip?
- I have searched and Searched "RK CUSTOM" Aftermarket fairing
- Part # Help
- Air Valve Stem/Who would have guessed
- Anyone with an aftermarket batwing fairing install their own tach / gauges??
- Help with connector location
- single caliper on front, street glide
- Very Proud Father
- Wanting to get new exhaust, but....
- Windshield or Fairing... which gives the "smoothest" air flow?
- Spark plug wire mangement - clips
- First ride with upgrades
- Help, no start no fuel pump after changing handlebars.
- Comfort
- Flush Mount Tank LED Lights Out
- 2011 CVO Exhaust Question
- Kuryakan windshield mount mirrors
- 03 RKC Pearl White paint match????
- Rear Drive Belt
- TW-555 install and Fuel Moto Map issue
- FBI flush axel end cap arrow in or out???
- trip to tennesse
- Changing Pipes on 05 roadglide
- Slip-on mod?
- ??? stage 3
- 07 flhp abs light staying on
- Screaming Eagle EFI Race Tuner
- New Bars = No Throttle snap
- Replacing that worthless air temp guage
- H-D universal helmet lock
- Will this TP quick release work on my RKC
