View Full Version : Touring Models
- Clutch cable 2012 SG
- Does anyone NOT like their C&C seat
- Oil leak, is it ok to tighten 1 crankcase bolt?
- Need input on my choices..
- Paint job on my tank
- 1997 Radio Volume Control by Speed Problem
- Road King Classic questions...
- Harbor Freight High Position Lift
- Clutch problem....maybe...
- Go with a backrest on C&C purchase or not?
- Jackpot or Fullsac
- clutch lever
- Went and did it - new Ultra in the garage
- 2006 UC 5-Speed - Best Economy Shift Points?
- 08 FLHX Overlay Harness Removal
- exhaust popping
- Finally, the King
- Do I Need A Tuner?
- Of all the bonehead effin' things to do!!!!!
- Help...Tire fitment
- Name this sound....
- Fullsac heat shield question...
- Lay down License Plate
- If I only had the garage space
- Another stupid paint question
- Speed/Power fix
- custom passing lamp bracket kit
- Arm 2 Cycle Works Contaminated Oil Removal System
- Lepera villian DL?
- HD Break-in
- Harbor freight chock
- Can I install new front speakers myself? Tell me how please.
- my Ultra!
- how much down between oil changes?
- Installed the Sony DSXS310BTX, Pandora & Bluetooth!
- Parts compatibility 07-11
- My first bling on the new bike
- Custom Street Glide Completed!!BadDad,Arlen Ness, Yaffe,Etc
- Progressive Suspension (Kyle) top notch service.
- dash lights?
- Ebay Chrome Center Stand
- 08 street glide radio problems
- Gut check before pulling trigger on new SG
- Gound location pics
- 107" installation? A DIY job?
- Headlight removal on Street glide
- dealership picked up bike tomorrow
- Roadglide fairing mount
- 2008 road glide starting issues
- I have a PING... Can you help?
- Tweeters
- Bike will not start after radio install
- Installing 16" apes on a 03 Road King.
- New radio install issue..
- Hard to start when hot
- Recommend a Pickup Ramp...???
- Dragos scs4 2into1 w/dyno sheet
- Adding Custom Dynamics Plasma Rods to 09 FLHX, Part-1
- FXD air cleaner cover on FLH???
- 5 speed trans and 6 speed trans ratios
- Finally got around to replacing the transmission shift shaft today
- adding forward engine brace to an 07 ultra
- How to decrease buffeting from gas tank
- Specifications
- Vance & Hines Twin Slash 2 into 1 slip on exhaust review
- Royal Purple Question
- transmission oil leak
- Can't believe this great weather...
- Daytona Photo Shoot
- Help please...Spot light mod...
- K&N v Screaming Eagle heavy breather
- What's the best way to run amp wires?
- HD OEM plugs, are they NJK's
- Oil Pump upgrade?
- Anyone going to Laughlin?
- Volar Motorsport Kevlar Carbon Brake Pads
- how does a oil pump gear break?? and keyway fall off
- C&C or LePera (Looking to be about 1" lower)
- pesky primary oil seal leak
- New tunes on an old bike
- Enough to make a man happy!!
- Parts Canada...no Truck Lite available?
- The most Iconic touring motorcyclist... Painting a picture of ourselves.
- Pandora Radio
- Couple of quick questions...clutch adjustment?, front wheel spin?
- Front Fork Fluid level FLHX
- Best quiet slip on pipe
- Switch housing and rubber trim with 1 1/4 bars ?
- newer wheels on 06 FLHX
- love my HD leds
- 2001 ultra accessory plug hookup
- Mac apple sound help?
- Sensor for McEwen Temperature Gauge
- New Bike, No Security system?
- Need some help with curved license
- New Member Gone to the Bagger World with Questions already???
- redshift 575 vs. tman 625
- Rinehart 4"er Baffles...What's Better Than Original?
- New Limited in the garage
- Crank/no start... PCV??
- Finally got out for a test ride
- Maybe Im just a dumbass
- I am new here.
- Just installed QQ Thunder Monster baffles in my rineharts...WOW!
- Aftermarket Fender and Aftermarket Tail Lights, Need Help With Wiring.
- Finally....
- Biketronics Stereo Kits for Harley
- Torn between the models
- Reflash ECM Question?
- Michelin Commander II vs. Dunlop D407/8
- Running Lamp replacement bulbs GE 898
- Fairing wind deflectors
- Need softer seat
- Hey Everyone
- Noob question about A/C
- read these spak plug pictures and give me your expert opinion
- question on fishtail slip ons
- Radio volume cutting out
- Klock Werks Discount?
- internal wiring of apes - do i NEED all these wires?
- Exhaust-aholic
- Who has stripped down?
- winter project
- Quick question on a exhaust
- Andrews 54h in 103 Road Glide Ultra
- PC-V tune
- Rain Cover for FLHX Seat?
- C&C owners....sporttour as is or should I have em shave it back a bit??
- How much does your dealer or Indy charge
- PC-V Milage Map?
- Another Satisfied Biketronics Customer
- Speedo Cable ?
- How long have u waited
- chrome whores
- touring manual
- Hogpro(hdf sponcer) 21" Vivid Black Shelby on my 09flhx
- Night rider xieds,vieds oil temp results???
- Advance Auto parts Sale oil change
- should I buy 2008 Road King Classic
- Khrome werks Dual header for older bikes?
- Head light Reflector Housing
- ultracool oil cooler
- My (un-named) 2012 Black Street Glide
- Bullet Front Turn Signals for Road King
- Added another Horse to the Stable
- New Hard Bag HD Speakers
- Please Help me Identify these touring shocks
- Progressive Monotube install question...
- Are there any deals out there on a TBW Thundermax?
- Does Fuel Moto Offer Discounts for Forum Members?
- Backrest Adjustment
- Throttle cable question
- 2012 Road King Rear Turn Signals Removal
- How do your 4" V&H Slash Rounds Sound?
- need help to fix
- Air Cleaner For 09 Ultra Classis For Stage 1
- ETX-30L Powersports Battery
- Cam for stock 96" with stage 1
- Odd noise from primary
- I'm the only one that fk'ed up!
- Hidden antenna?
- Vance and Hines Headers
- Saddle Bag Lid Strap
- True Duels VS Stock Y joint???
- Boom Fairing Speakers
- RK 2000 Fuel Gauge
- Polk MM651 vs J&M vs Rokker vs Other "High End" Speakers
- Need Help! Brake light, cruise issue
- evo model road kings
- Taller Bars??
- Saddlemen Solo Seat
- Will they fit? (2010 FLHTP header on a 2012 FLHTK)
- Thinking about monotubes, few questions
- Street glide ?
- Aior Suspension questions....
- hidden tow hitch
- Decel poping
- Decel Poping
- Exhaust
- Tires Tires
- Newgie washing question
- electrical codes
- Hog tunes customer service - great experience!
- Road Tar
- Hypercharger
- Amp Question
- Cost to Paint Saddlebags
- All I can say is...WOW!!!
- front axel frozen
- Chrome Lower Wind Deflectors
- LED's For Ground Lighting
- Amp kit for pbr300x4
- 2 ohm speakers in an 03. Will they work?
- What could this be?
- 2010 RK Vibration Resonance at 75MPH Fixed
- Will my Ultra fit in the back of a van?
- Can I put street slammers on a Classic?
- LED Gauges from LED Gauge Mods installed! Looks Hot!
- Need 2011 FLHRC stock handlebar PN
- Impress Chrome Exchange
- S&S Teardrop fitment?
- Looking for new seat....
- DOT Helmet that doesn't make you look like a shroom head
- Just intalled my Polk MM 651s. Wow!
- Paint
- oil filteer trick...
- MODS FINALLY DONE! (yes a pic too)
- Great day for a ride
- Legend Air Suspension question
- Pushrod Tube help ???
- Which would you buy?
- Turn Signal Problem - Updated with new info (help Please)
- A/C what you got?
- Stock carb cough?
- New Ohlins Questions
- Kewlmetal 13.5 degree rake kit
- Just installed my new Hawg Wired system....
- Winter Mods Done!!
- RG Ultra-now I want one..
- Options for polished (or chrome) front rotors?
- Where is the acc. Wire?
- HD Oil Cooler Installtion Question
- FLHX, Hammock & Adjustable Backrest
- Intermitten Break lights???
- Engine Pinging!!!!
- Tuner question
- What do we have here?
- Happy Birthday Howard
- 10" Monkey Bars.....who's got 'em ?
- Check out the lift I got as a gift! No more bending to work on my RK.
- Turn signals Ultra question
- cruse control trouble
- What is the clicking noise I hear? & Tuning question
- Stage 1
- air deflector
- Replaced bars, heated grips dead...
- 2012 Ultra shifting and tappet/injector noise
- RKC...Custom Sound System...AMP and iPod Integration
- wheelies
- Intercom dash buttons? Need ideas
- Power Vision - uneven RPM @ highway
- Good Seat
- Just added an '04 Road King to my stable!!
- Help! How do you stop the old lady from scuffing the saddlebags lid?
- Tips on Buying a Harley
- Moisture in guages
- 2012 Ultra CVO
- Avon Grips Poor Fit
