View Full Version : Touring Models
- Cooler Weather?
- 2006 FLHX Yaffe Monkey Bars Install Help
- 2008 Road Glide with SE 103
- joined the fugly crowd today
- Follow up to my previous tread on Red Line
- What to have on hand for clutch cable swap
- BCT Baffle help?
- 3rd gear problem
- Instructions for heated grips?
- It's a good day to be me.
- Airfoil Saddlebag Guard Rails
- No cruise...help dawg
- Question HD center mount aux. light
- Need a power source
- Bike out of time/tune...why?
- That's a horn?
- No Throttle Response
- Goodbye sporty
- Khrome Werks Hitches
- electra glide standard 2001 stereo install
- Windsplitter vs. Stock
- 2007 Street Glide-how many miles per tank (5 gallon tank)
- Need Help Limp Mode
- FLHX Owners with a Tour Pak- Extra lighting
- New Fender or Extended Fender for 4" Stretched Bags
- 2009 flhp for 11.5$
- 2012 Ultra Limited 1200 Watt Sound Sytem install
- Passenger/Rider comms only?
- 2006 stock cam in 2001 RK?
- installation of the primary cover
- Put in trailer or back of pick-up ?
- Accessory wires to battery terminal
- Anybody Using a Sena SMH10?
- Low profile gel seat pad?
- Vibration after oil change?
- 06 SG Value?
- Why does it take so long ?
- 2003 RK engine light with codes. HELP!
- Apes biting me in the Ass!!
- RGU starting over again
- Silly question.
- ERT oil pressure kit review
- RK/FLHRI 2002 Upgrade in plan
- Replacing fuel filter, anything else?
- My new C&C solo seat
- Out For Delivery
- i'm doing it, i'm buying a 2012 cvo rk
- What do you think of my plugs??
- Cleaning the white walls
- Road Glide Fairings
- 2 into 1 headers WITHOUT mufflers?
- RF300x4 Speaker Choice
- re - tune?
- Question for Road Glide Ultra Folks
- PN for '07 Ultra R Handlebar Sw Assembly
- 2008 electra glide ultra heatshield
- 120r Owners
- Custom seat
- metal shavings
- Security problem?
- Whats up with the lights??
- RC or Fatcat
- Softail vs Touring Gas Milage
- Damaged fairing
- Electra glide ultra versus Street glide
- 2011 FLHX Street Glide Rear Turn Light Problems
- Need advise on 12' ultra Classic
- New 2008 Electra Glide Ultra Classic, Mods, Add Ons
- Leather Pro Lowers RKC
- LA Choppers cable kits for Bagger Apes?
- Jackpot sound clip
- I must bid adieu......
- Now what??!!!!!
- Tire Direction
- Head pipes, ceramic vs non-ceramic coated
- Clunk clunk at shut down. Primary chain?
- installing digital gages
- HD 54157-10 adjustable passenger pegs???
- Wanted: A good vender!
- Blinker Malfunction
- Anyone have a Mustang Cyclone seat?
- Special editions badging ??? Peace Officer/ Fire Fighter
- Will a new rear tire?
- What Happen to the 2013 CVO STREET
- Stop and go commuting on an UC....
- 01 RK Stock tire size?
- HD Road Zeppelin Seat Pad
- Dielectric grease yes/no maybe
- Blistered tires on the dragon!
- how hard???????
- Did I overheat ?? Never happened before
- RG won't start, question?
- Ever heard of this?????
- SE 120R or S&S 124
- New to the forum--former Marine
- Decent '13 SG Bike Cover?
- Frame already rusting on 2009 SG
- Last ditch warranty appointment today...
- RC Xhaust
- Overheated Wife
- High idle on 09 FLHP with 103
- Looking for a local mechanic....Northern Illinois
- 07road king transmision(10k servicing)
- Chrome hand controls
- Extended Bags and Wheels
- Deal or no Deal 13,750 for 09 Ultra 65,000 miles
- Exhaust Leak, Popping and Pinging
- Vance and Hines, rinehart or....???
- floorboard question
- Which Guard bag should I get?
- 07 FLHTC with & without tourpac
- Anyone with a 2 1/4" trans mainshaft socket?
- Motor Running Hot
- Harleys starter issues. technical explanation why so many fail
- Tri-glide low speed handlebar wobble
- popping trouble
- 17 vs 18 rear tire
- Put deposit down on 110 anniversary limited BUT....
- Confused about passenger backrest
- 21/18 wheel tire setup
- Stock head pipe cracked in half
- 117" and above lets see your build sheets and dyno charts
- Installed Hogtunes
- Touring Ownership Experience...% Happy
- best extended bags?
- help please!!
- Zumo 665 w/ XM radio?
- who has best online price on dunlop 402`s
- '05 RKC worth the $$$
- Zen lifetime starter clutch is junk.
- no charge
- HD electrical: unreal
- Brake pad glue
- Rt 66 HD in Tulsa sevice dept sucks
- Newbie
- Indy in Twin Falls
- Wrong D&D head pipe
- Why wont 54383-11 fit a 2008?
- Minor, but rider-focused upgrades coming
- New tires wierd smell
- Who all subscribes to Road Iron?
- Has anyone installed a remote fuse panel?
- 76694 / 76695 On It's Way!!!!
- Thinking of RC Components Excalibur Slipons???? Yes or No???
- Finally took the plunge
- exhaust question ???
- ordering bars from HHI
- Front brake lever shocking me
- Bluetooth....Need Advice
- Harley's being stolen in Indianapolis area
- Long Core? Short Core? Whats the difference in restriction?
- Iron Cross Ipod
- Tall Sissy Bar
- Replacing back tire. What else should I check/do?
- Engine rebuild
- Airhawk Cushion Question
- Tour box
- pitbull jack question
- Got a new old bike
- New kind of risers. At least for me...
- problem with dealer
- If you had 7,000 for winter mods???
- Painting and Air Brushing in Houston
- 411: Custom Dynamics Plasma Rods install - 2012 FLHX
- Lower Fairings Quandry - which one
- Exhaust problem v. bracket issue
- Oil at air cleaner
- Using a battery tender on a 2013 FLHTK
- mustang sport touring 76032
- Lost clutch question
- Rocker Switch and Weird Things
- exhaust
- Replacing Brake Pads
- Tranny Noise
- Tunes on my Road King
- clutch disks
- FLHP build-start to finish
- Idle issue
- Silverish slime in chaincase
- looking for custom exhaust
- 2008 CVO RK-long cranking intial start?
- Making a Permanent GPS Mount Removable
- lower fairings snap covers
- Diesel Oil in your harley
- Street Glide to Fugly Conversion Underway!!!
- JES Fangs
- Leaking shock '11 RGU... just one, or replace both?
- Fugly - Here I come!
- Best place for extended bags
- Problem with paint on inner fairing
- Rush Seat
- Carlini Design Question
- Sundowner vs Stock Seat ('05 Ultra)
- What is out there for model 2000 upgrades?
- Issue after install of Touring Bullet Turn Signal Kit
- 2010 and Newer FLHX with 18" Front Wheels
- Street Glide Air Shock question
- Does anyone have these (not chrome) on their late model SG? (pics would be good)
- Factory cam specs for an 11 Street Glide
- Ignition Switch Plate---Replacement??
- Wife says it has to go!
- So pissed at my dealership....
- Ordered a Dragula Today
- Harbor Freight Motorcycle Dolly
- Advice needed, Re:blow by
- If oil not leaking then why do I have to top off?
- HK and JL Audio amp & speaker upgrade issues
- 99 Road King Classic handlebar change
- TW-6-6 vs TW-222
- Chrome windshield trim on Ember red SG...pic please
- Good oil value
- Changing bars on Street Glide
- best SE exhaust
- Blown j&m 7.25's what to do?
- Security Light Comes on During Ride
- TopShop bags and fender done. PICS
- Simple, cost effective motor mods for '05 TC88?
- Long stem mirrors
- Let's see some pix of the wheels on your rides
- Clutch adjustment nut.
- 2009 Later Seat on 2008 Earlier Ultra???
- no blink in my blinkers
- Newby checking in to say THANK YOU
- Air Filter question...
- Best shocks under $600 RK
- Anyone runnig a Baker Oil Pan?
- 08 Road king electrical issue?
- Keep dropping the damn bike!
- trying to decide on new bike.....help
- Got to meet the local law enforcement this weekend.....
- 2011 Ultra Classic noise on sharp bumps
- Vance & Hines Twin Slash Cut Rounds
- New JackPot headpipes
- Las Vegas BikeFest or Bikes, Blues and BBQ?
- Paint job
- Help! Clutch issues
- Color matched inter faring
- Streetvibes 2012
- 2011 Street Glide OEM mufflers
- Air/Fuel Ratio Recommendation
- Touchy Throttle / U1016
- Bye bye softail,hello road king !!!
- V Logo turn signal indicator
- Questions about baffles
- Driving by knucles - another handlebar thread
- What size tires to replace on 07 RK
- First major trip with Ultra.
- Arlen Ness Big Sucker to HD Heavy Breather
- Breaks when it's really hot?
- proper tie down locations on an Ultra Classic
