View Full Version : Touring Models
- Dash Storage ideas?
- heal//toe shift lever for my ultra classic
- I need two windshields
- Seatback rest
- Primary noise
- Looking to add car play to my 15 RG
- Just needing advise. Injectors.
- Done with this bike
- Seat studs falling out
- Dates on your tires
- Repaint or replace?
- Clutch Cable Adjustment.
- Narrow street glide apes
- Front tire
- Riding with bad compensator
- I love my bike
- Ecm
- No spark
- Steering damper
- Want to connect Zumo XT power to 2021 SGS
- Question for Road King Riders
- Right Side Aux Connector Plug
- Aggressive tire for 2017 ultra
- Bike works, turn signals dont
- Hydraulic clutch
- Which is better to use a deutsch connector or a multi lock
- Apple carplay
- Knock off CVO seat opinion
- Header fitment question
- Goodridge Fuel Lines
- Fairing fitment question
- 2009 SG - 96" to 107" Build Complete
- 2007 RK Custom - Primary Overhaul
- Saddlebag rattle
- '13 Street Glide Rear Fender on '11 Ultra - tri bar
- Rattling mutazu tourpack
- Problems with rear lights
- Feedback and estimate for Stage I from local dyno guy
- '99 RK speedometer quit today...
- Audio with No Windshield
- FLHTC No Start
- Stage 2 or stage 3 or stage 4 tuning ?
- stage II upgrade
- 124" Questions
- Disabling the Security system
- SOLO seat: Lowdown seat vs BIG IST seat vs Airhawk
- Occasional “CUNK!” sound when starting hot engine
- Fairing for Road King
- Electrical overload....
- Intermittent Primary Leak
- Stretched bags with tour pack
- What to look for buying a 1996 Ultra Classic Electra Glide
- Shorty needs airflow during hot days. 05 EG Ultra
- Kuryakyn Thunder Soundbar
- Fuel tank medallion
- No key or FOB
- High beam issue
- Seats,seats,seats Arrgghh
- Snake bit me, very strong venom!
- PSA- Ultimate is all snafu'd, looks like a Dominator
- Performance programmer
- Tall boy seat Part#
- Thinking of doing Stage I. Looking for quietest exhaust.
- Road King Lowers vs Fangs
- Had to pull the trigger on a new 2021 Road Glide
- Anyone know what size these cover bolts are?
- Kinetic Motor Mount 08 SG ?s
- Looking for matching backrest pad to match HD solo seat
- 2011 Ultra Classic Electra Glide Exhaust suggestions please
- Air cleaner rain sock question
- Foot pegs mounted to crash bar ....screws for mounting clamps rusted and stripped
- Concerned of cost
- Rear fender not straight after install
- Parts Backordered - Advice Please
- New to HD...What are the basics?
- Sena 20S and HD Boom Audio Sena 30k Intercom Multi-functions
- Quick Release Solo Luggage Rack
- 03 Ultra wheels - cast 9 spoke
- 2020 rdrs problems
- Manual or electric center stand, compatible with alarm?
- Service/parts book online?
- Primary fluid
- Looking at this seat can you tell if it fits
- power train issue ?
- OMG...it turned PURPLE!
- 01 Ultra Front Spring Rate
- 2007 Ultra issues?
- Stainless Dowel - Any thoughts?
- Unusual Tire Question
- Help
- Tour-pak light kit template
- FLHRS Seat Options
- Gas Cap Leaking 2012 Road King
- changed front brake pads and now no brake lever
- Crash Bar And Sliders hitting
- Twin Cam Stage 1 Kit Install
- 2016 Electra Glide Ultra Classic Security *HELP*
- 2014 review
- Heated grips rubber
- 2014 Streetglide Cruise Control Issue
- Recommendations for touring short antenna
- Looking for windshield recommendation
- Feedback needed on Saddlemen Dominator solo seat
- Engine and transmission light
- 08' E Glide Front Rotor Upgrade
- Transmission Dipstick
- Help!!! 2021 Roadglide Special not turning on
- Key fob intermittent after radio update
- 2009 Electra Glide Classic - saddlebag stud & clip upgrade
- Ultra Classic Shutting Off
- Complete shutdown
- Front shift lever question...
- Screamin eagle slip ons
- Batwing Windshield ?
- 2004 FLHRCI ( RKC ) Questions
- Properly packing the bagger for me and the missus
- Temp in display?
- 96 build options
- Running lights
- Road Glide Inner Fairing Trim....This Cant Be Right?
- Road Glide Custom Dynamics vs stock LEDs
- Dominator vs. Ultimate
- Curious to know , at what speed / rpm do you use 6th gear .
- Road king windshield height
- Losing clutch free play
- ABS Chattering at Low Speed and Low Brake Pressure
- 19 SGS Bogs down
- One Piece Inner Fairing Edge Trim Road Glide?
- HD Tie Down Brackets for a Street Glide?
- 1K mile ride this weekend
- Need a wire identified
- 2005 Harley Davidson Electra glide having problems
- Brake light on all the time.... Fixed
- Looks of Street Glide vs Road Glide.
- 2014 saddlebag latch
- Holy mother of God...survived a "Death Wobble" tonight!!!
- Bluetooth adapter for 2012
- Headlight Not Working
- No spark after replacing crank position sensor
- custom auxilliary passing lamp brackets
- Performance bagger build 10k
- 2017 Limited TPMS upgrade
- Old Man seat
- Pit Bull question
- Fuelpak LED expectations
- Touring - Bent Oil Pan Gaurd
- Help: From Classic Leather Bags to Hard Bags
- Question on Boom GTS Update
- 2010 Street Glide Taller bars
- What size rear tire for a 2008 Electraglide Classic
- What length heel shifter to get ?
- Power Commander 5 has intermittent 'skips'...how to diagnose??
- Tools to remove 4 point docking system-Street Glide
- Road King lost rear brake - Very HOT
- 2019 Limited. Adding the tire pressure monitoring sensors.
- Saddlebag hardware
- New York or other state EZPass toll reader question
- need some major help please
- RK-Most lights went out
- What’s the deal with the hydraulic clutch?
- Where is my oil going?
- Brake Rotor replacement
- Instead of buying a new bike...
- Is the 2018 107 motor reliable?
- My New R&R Cycles Overflow Air Cleaner
- Oil temp sensor
- Greetings! Trying to revive 89 Ultra
- Rear brake caliper mounting bolt
- Radio install FLHR
- 2012 Road Glide no start
- Looking for thoughts on my next bike
- TC88 is fine but suspension sucks
- Avon SS Grips
- Rapping/rattling noise on 2002 Twim Cam 103
- Something a little different....
- chirpless??
- MCC for street glide special
- Passenger cup holders compatible with Harley swing arm rests on tour pack - not atached to arm rest, but just can exist at the same time?
- Exhaust upgrade to 2021 Road Glide Limited
- Harley wheels
- Fuel leak but from where?
- Notice oil dripping off the top of my head on my exhaust
- Need help identifying OEM head pipe
- Wheel Cleaning
- 2012 Road Glide Double Din
- Tour Pack
- Windshield bag with Yaffe's and Klockwerks
- FLHX 2012 Lower forks powdercoated black?
- Red Battery Light on Volt meter
- Speedometer Readings off, Why?
- CVO kit installation on Roadking
- Finally finished up the FLHXS Project
- Ciro Passenger Peg Mounts
- Battery and New Load Tester
- Gear Indicator
- Date Naviextras updates maps
- What happens when hydraulic fluid is too low?
- Carlini Gangsters for Street Glides
- Identify this wheel
- 2021 Street Glide Handlebar upgrade clutch line question
- Boom Audio Default or Favorite to INFORMATIOn
- 2021 114 M8 Stage II or III Upgrade
- 01 ultra transmission issues
- 01 Ultra Front Fork Recommendations
- What feature would HD have to come up with to make you buy a new Touring bike?
- C&C seat fitment
- Dash insert
- Dash insert
- Lower triple tree wind deflector and head buffeting
- Reman vs Longblock
- Revo A question
- Passenger backrest help
- throttle position sensor pinout
- Custom dynamics taillight delete problems
- Solo Luggage Rack
- Electrical help
- 2017 road king led passing lamps
- Upgrade Throttle Body w/stage 2 upgrade???
- Just noticed this😳
- Need new bars. Any suggestions?
- Best for touring street or road glide and why?
- comments on 2009 Road King
- New to forum and first Harley. Need help bike won’t start
- Corbin seat, bike to bike
- 2020 Touring rear axle cone nut torque
- Shifters Not Tightening
- H-D Fairing Dash Auxiliary Switch Kit
- A buddy of mine doing a helluva solo ride.
- Bushing
- CV40 jetting ?
- Over heating issues.
- 08-Later Seat adapted to fit 97-07 Bike
- touch up paint needed
- Fork Lock removal issues
- Rectangular Tip Exhaust
- Brakelight blues
- Screen won’t go past HD logo - help
- Oil pressure problem
- '11 RG Ultra - plate/fender fillers
- Electrical oddities
- Batwing fairing vs RoadKing windshield.
- Adjusting front suspension?
- 130/60/b-19
- Busted Front Fork Axle Stud Road Glide....Put a Bolt in!!
- Noise that was never there
- HD Layback LED Taillight #67800355 won't light up
- Scary
- 2020 Street Glide Throttle issue
- 2010 road glide
- Oil pressure light on in neutral then goes out in gear
