View Full Version : Touring Models
- Prescription riding glasses?
- Sedona Orange SG or Rootbeer RKC
- Exhaust and setup on a 2011 FLHX 103
- Fatbaggers flush mount axle cap question
- widest rear tire on 07 Street Glide?
- Slightly Used Cams
- Custom Dynamics - They deserve your business
- Best high out-put Alt. / Rotor assembly
- 2011 Road King Classis handlebars
- Transmission Noise?
- 1000 mile service ?
- Stage 1 and effects on exhaust sound
- Toy Hauler Loading
- SE 255 new lifters required?
- So I'm looking at a 2008 FLHTP...
- Now whats this new noise?
- bike chirps while accelerating
- Metzler, Avon? how wide can I go?
- Excessive Tranny Runout...@#%&!!!
- Bagger Nation Batwing “House Party” Stereo System??
- Stock Mufflers, my sorta Baffleotomy
- Riser shroud on 2010 RKC
- Changed out RH true duals baffles
- how many miles on your stock front tire?
- Is it a Lemon?
- Problems with Taillights
- pipes
- Broken terminal pin
- fairing speakers??
- 2000 Road King - Fuel Gage
- yeah the king is still fun!
- 2010 roadglide tail lights
- no tail/license/brake lights after 1K service
- jackpot dyno tuned slip on mufflers
- Bearing burned out.
- Pipes/Power Commander Done...next....
- Dealer closing up!!!!!!
- sticky ignition switch help
- alarm install question
- 99 flhtcui engine swap ===s&s vs 120r vs jims
- 150 miles...1 afternoon, a love story begins...
- Dyna Bead ??
- 9-11 Ride August 2011
- 2006 road king questions
- Handlebar Chrome
- Apehangers with mirrors mounted on bottom.....
- Tell tale signs of cam chain issues
- 07 FLHT Heat Shield Chrome Flaking
- First wash job and a new signature pic!
- 2 up fender hole
- Passanger Peg/Floorboard Question
- throttle stuck
- Colorada Customs Wheels??
- Brembo Brakes
- Can I use the HD Double windshield pouch with the Klock Werks 8.5" Shield?
- Help New tires which ones? 2009 serg ?
- freedom Performance 2 into 1
- sedona orange or black denium ?
- Grip glue? What type
- 21 and stock fender
- 2009 EC Ultra, is there a cat in the pipe?
- any reason not to get abs?
- V Rod motor on Touring bike
- dyno run
- Screaming Eagle pipes
- Monkey bars 10" or 12"
- Need help with new shocks please??
- EIMTS Question
- Well enabled the EITMS and the weirdest thing happened....
- Solo Seat for 2010 Street Glide
- PCV tinkering
- Windsheild Brass Insert Pulled Out (one of three)
- throttle by wire grips
- 10 Deg Lower Oil Temps in a Minute.
- fairing gasket advice
- Fuel Moto 107 in my 09 Streetglide continued
- AM-FM CD player to in-fairing satellite
- Hella headlight question
- Roadside help needed
- What Size Airhawk (or Airhawk 2) for 09+ EG?
- Harley Packable rain gear vs Harley Overpass or others
- Good deal on '11 RK?
- Wind-X on windsheilds
- Installed Vance & Hines ThrottlePak and now have No Throttle…Anyone help with codes?
- Question about removing rear "bumper" on 00 RK
- Why the small Slide feel when using rear Brake?
- Tire reccomendations for 2005 Ultra Glide
- My New Upgrades
- Motherwell 2up quick detach for tourpak
- Built my own mc lift
- 2010 RK .. Bars and Seat Question.
- Warranty Question
- Change tires
- 2010 SG, gutted cat or Propipe, any performance difference?
- 2011 RKC Rhinehart pass.footboard adj. problem
- What Bike cover???
- V&H Power Duals ... Crappy Heat Shield or ...
- 2010 streetglide slip-on muffler recommendations.
- thinking about removing the cat
- Lost Heel Shifter
- 2005 hd radio
- 2002 Electra Glide Ultra Classic
- Front Wheel Noise
- True duals better sound? How? Why?
- Have a question for you Phoenix guys.
- cat out of pipe
- HD curcalation pad
- volt meter jumping
- Back to Stock Pipes?
- 1998 FLTRI Road Glide Fuel and Oil pressure issues
- Wreck 2
- Do You Like These Speakers?
- re-tune needed?
- Change of bike Electra Glide Ultra to Road Glide Ultra?
- Higher Handlebar Risers On A RoadKing?
- Baffle install/wrap job
- Best group ride to date
- wheel weights came off?
- Vance and Hines Big Shot Duals
- V&H Monster Ovals or Rounds
- Installing Back Off flasher on Street Glide
- HELP Diag Codes/ECM/TCA/Limp Mode WTF??!!
- Now our dealer closed up shop
- New tires for my road king
- Shock Tubing
- Same rusty water issue on 10s as 09
- Lost Cop bag "Hocky Puck"
- Removing Rear O2 Sensor
- Powder Coating Engine
- Detaching Tour Pack/addin passenger backrest
- Avise on pre '06 RK
- New Street Glide
- Need A Bit of help
- Thinking out loud (stage 1)
- Best price for tires
- 2011 RK arrived
- Confused! At stage one, remove cat, do I need to retune?
- I can all but guarantee that next years bikes will be liquid cooled :)
- Rebuild or Buy new???
- She is home.. Just took delivery of my 2010 RK Police.. :)
- carb conversion for MM EFI
- PCIII map for RK
- Primary chain
- Ignition Switch Removal
- Exhaust Bracket
- Congrats to Z & M Cycle Greensburg, PA
- Screaming Eagle filter element vs K&N
- handle bar mount analog oil temp/pressure gauges for RK
- map question for road king with true duals to a 2 into 1
- throttle body help part #
- harley backrest
- Shifting issue...funny one
- Yes, I AM opening this can of worms! (HD Stage 1 Download)
- Stick on balance weights won't stay on SG wheels
- Double Check dealers service "ALWAYS"
- Airbrush ideas
- HELP PLEASE rider adjustable backrest
- Deka Battery 400 cca's
- Stock headpipe to dual?
- RK Rear Brake ~ Leaver B Question
- Is 3/16" to tight when hot?
- Night riding glasses
- ROAD RAGE ll OR FATCAT ??
- 2001 Road King bag question
- Progressive kit...Drop in My A##!
- Worst service department - best service department
- Best Tint Match
- Ipod Nano 6th gen. Mount
- Slip-on end caps?
- Thank You FM & MCC
- Braided oil lines on Limited
- IronBut ride
- Weird brake/lights problem I need help with!
- Pulled The Trigger On A New RKC
- 6 Way System, Rectangle Plug adapter
- 21" 2009 FLHX high speed wobble.
- I know...Cam Tensioners Again!
- Are the days of a few cheap horsepower gone?
- Air/Cleaner install Question ,,
- Which s&s air filter for an '02 RKC
- Street Glide Seat and Air Ride
- 01 Security code
- Rear Shock Dust covers for 08 ultra
- What out for them Left Turners!
- Security / Turn Signal Question
- Fishtails
- Blade Wheel
- Red Hot Rear exhaust? HELP!?!?!
- 2007 FLh CEL
- How to Adjust Clutch to Make Finding Neutral Easier?
- Clutch cable
- Bad master cylinder?
- Spark plugs
- Vivid Black
- Metal Shavings in oil filter
- diagnostic codes
- 11 RKC handlebar issue
- True-Track for 2009-2011
- Tell me what you think??!!
- wire connectors
- Security question
- Rear Lowering brackets + an - 's
- Vega XTS...No More Mushroom Head
- Cruise works too good. Won't release with brake or clutch...
- Question?
- Need a 103 Timing cover...
- Pigeon Forge TN question
- Finally got Cruise working...
- Saddle Bag Lock
- Anybody have the HD 3/4 w/ retractable shield?
- clicking sound from primary
- Hello from Stratford CT.
- Front turn signals always on
- Remove Cat without cutting Header?
- STRIP down RG Ultra or buy a Road Glide Custom?
- Is it worth doing a Stage 1 on bike with cat?
- Stage one fuel moto
- Cleaning Bike- Give this a try!
- Oil cooler parts
- Another "Windsplitter" thread...
- Time to replace the Fatcat??
- screamin'eagle race tuner
- 6-speaker 700w CVO Ultra (how to connect
- 2011 Ultra Classic Exhaust question
- Hillside Cycles and My Stage II Headwork...
- Gas Tank, question about "Reserve"
- Oil Cooler for 2:1 and WB Sensors?
- What's the difference with "international" mufflers?
- Anyone Use Revolution Performance EMS
- changing oil in a 2008 Ultra
- Mounting Ideas tomtom 930 to 10 Ultra
- 90 Thousand on a 2009 Street Glide!!!
- Exhaust Sniffer???
- Replacing Factory Amplifier With J&M 500 Watt
- Advice to the guys doing apes
- PC V setting...help
- Opinion on what year/bike to buy since I may have totalled mine
- How much lower is the Road King Custom?
- Anyone know a good engine guy/custom guy in South Florida?
- What effect does changing the spark plug gap have?
- Air shocks lost 8lbs in a day and a half.
- Kudos to Cardo Systems
- 2005 Road King Classic Primary Leak
- Ultra Limited or Street Glide?
- "desperately seeking cruise control"
- Brake pedal feel
- Best bet for quieter aftermarket headpipe and slip-ons
- Bagger Apes
- look at what you can buy with $14K
