View Full Version : Touring Models
- Clear Vinyl Protective Film
- 06 gas guage
- assemebly lube
- Does anyone own a harbor freight ........
- 04 Ultra passing lights
- Just able to post since 7_5_16
- "U1095" diagnostic code
- New style bags on older models
- Possible Brake-Failure 08 to 11 Harley
- Brake problems
- Handlebar Help
- Cruise control module
- Navigation interface module-NIM
- Road Glide Police Model ????
- Another cam question (I'm sorry!)
- 2009 96" streetglide up grade
- Docking confusion
- Exhaust color match
- Exhaust
- Need help with backrest and rear lights 06 FLHT
- Chain drive conversion
- LED light bar on Street Glide
- Small oil leak
- unsettled
- Rushmore Street Glide + Long Ride Shield = buffeting??
- Apes installed !!!
- Drivetrain Troubles
- Tour pack bracket broke 99
- Custom fit D&D exhaust on 16 RG..
- Inertia WRX RKC saddlebag lock springs...
- Whos gone mega miles on stock comp?
- S&S 124" Crate Motor
- New Ultra or Limited Rear Fender
- Shout out to LRS
- Bad Backs and Riders Backrest
- Mini Beast Horn Review
- HD investigated for for brake failure?
- Infotainment CB problems
- Headlight Question
- Opening Saddle bags with Hammock Seat?
- Broken Valve Spring
- se 117 cvo sg
- Anyone running a 26" wheel?
- Know a good Indie?
- Starting issues, Thoughts on whats happening
- Truckmall
- Better Heat Shield Clamps or Process
- New 2015 Road Glide Special, corrupt GPS
- Outstanding Dealership Experience (Not HD)
- information, please
- Bars an extended wires an cables
- Pre-Rushmore LED conversion.
- input on exhaust 2016 cvo RG
- 2016 Clutch issue
- Mileage on cam'd engines
- Using High Beam
- Fairing mirrors
- Speaking of Paint Problems
- Brake pads
- DTC p2135 & p1511
- JW Speaker 8700 Evo2 (Daymaker) cheap at Amazon right now
- Need Advice on What Bike to Buy
- Headlamp
- Looks like i have to sell my bike
- Paint versus brake fluid
- derby cover gasket same as Dyna?
- Ward Werks FCS customer service
- 2005 road king dropped frame damage?
- '06 Electra-Glide, Bank Angle Sensor clicks, does not start
- Derby cover torx screw head rounded
- Crankcase Vent By-Pass Mod - Opinions??
- FMB Choppers, My experience...
- Light question
- Dash interchange
- 2016 radio issue
- Passenger footboard installation
- Wheel interchangeability chart/post
- Fork drain screws
- Eitms
- Can anyone ID this wheel fender ?
- Road king ran like crap
- Wards fans
- Danny gray tourist air seat feedback
- 2011 streetglide apehangers
- "Auto-Tune" explained ( poorly)
- Sena 20s
- Tri Bar Light Question
- Road King Fender Support Bracket
- cams=hotter engine
- Finished Bars and inner fairing
- Engine Temp Sensor code 14
- 1996 Ultra EFI / Stage 1 options??
- LRS Ultra Wide or Flat Top
- Ping with Sudden Throttle
- Just removing slipon cones
- front brake question
- No rear brakes?!?
- Cruise control disengages going up hill.
- strange noise when clutch engages from take off
- Should i replace my clutch plates?
- 2010 w/Harley 106 big bore kit.
- 2015 cb
- Baker Built air deflectors
- Rotors -2003 Road King- Where to order?
- 2009 street glide cams up grade
- EBC Floating Rotor failed after 20K miles
- Police solo seat hand rail
- 2" up; 2" Back Handlebar Suggestions
- Saddlebag r/t/b light help (67800241A)
- StreetGlide cams
- Spectro Tranny Lube
- Bike shutting down when put into first gear....please help, no way home..
- Oil temperature sensor (72357-04)
- The "Cruise cut-out" saga continues.....Advise on codes.
- Seat info help
- Road King advice
- Security
- Rear wheel on 08' glide
- Exhaust Scraping on Lowered Bike
- Mustang seats
- Stereo Banner
- 21" PM Virtue wheel
- King Tourpak Question
- Bar Swap 2008 Ultra Classic To 2010 CVO Ultra Classic
- Weird issue with ohlins
- Just a quick thank you
- Premium Hand adjustable 13" shocks!
- 2016 Street Glide.
- CVO Street Glide Seat
- New Member
- Dumb screw
- Now I know what "lopey" means. S&S 509 Series CAM replacements
- Olins shock set up by Howard
- Solo Tour Pack Stereo Question
- Highway Pegs Flopping around
- engine case seepage
- 2" inlet mufflers
- 2011 Lowers vent rattles?
- Electra Glide over the years
- Speedometer failure
- 6x12 trailer...will 2 baggers fit?
- Front Wheel Opinions
- SG without bags?
- 107" build comments/suggestions
- On the road need help!
- Cruise control will not turn on!!!!
- Aftermarket radio
- So You Like Wild Paint Jobs - Completed!
- Cable grips on TBW?
- 2002 Road King passing lamps
- Interference with garage door opener
- Baker attitude adjustor and the stock comp oil tray
- Removing 02 sensors frm cat
- Seat Recommendations
- Mud flap material
- X tended Warrantee Purchase ??? Any Deals out Here???
- Long Ride Shields....
- left side speakers not working
- 2015 FLHR dies....
- new member with 08 electra glide issues
- Harley service put dent in my bike
- Siren install
- Dresser Duals Question
- Came home yesterday
- 06 rk wont start please help
- Main fuse 'looks good' but nothing, NOTHING
- Evolution Industries noisy primary?
- Road King trouble starting with smoke
- Yaffe bars, powder coating, and paint on the 2013 RK
- Enforcer 19" Front Wheel Swap Questions
- Wheel chocks
- Cooling fans?
- clutch cable advice again
- From older to newer
- Bike just died.
- Cam Change Trouble shooting
- Bolt? Wind deflectors for fairing
- What an honor!
- 4.5" Truck Lites passing lights
- Torque & Back Pressure, how does it work
- What would you do?
- V&H or other exhaust system?
- I need an ignition switch.. 12 road king?
- Will changing header on '16 bagger do anything?
- What is up with Fat Baggers Inc.
- Baker compenator after 8000 miles w/ pics
- Looking for a new ride for the wifey
- new exhaust question
- Starter pinion gear question
- Hustin waterproof boots
- Street Glide - rough idle - need advice
- UGH!!! Rust Sucks
- Progressive 412 review
- Taller Rider Backrest/Sissy Bar/ Emblem
- Do I have Brembo Brake Calipers? 2012 FLHTC
- Saddle bag lids, new style
- 96 Injected Ultra
- Target Tune?
- Brake Caliper Springs ??
- Progressive 412 vs Harley premium shocks
- Gps
- 87 Electra Glide Charging Woes
- Whats available to cover these bolts?
- Gonna leave this right here and call it good
- 07 Streetglide stalling out
- Sponsor with outstanding Customer service
- First out of warranty fault
- What are the best sunglasses?
- another seat question
- My new bagger.....2016 Road Glide
- '06 RK wheel bearings
- Replacing a starter on a 2002
- wont start...battery?
- Accurate tire pressure gauge
- Welding Y pipe
- Change your fuel filter?
- Helmets
- Anyone tried the LED 1157 bulb replacement?
- Transmission issues, Help!
- Question to Heated Hammock seat owners
- Shoulder issues From Ohio
- Aftermarket seat based on a hammock?
- Exhaust 2016 Road Glide Special
- Magnetic Traffic Light Changer
- Custom tender panel & relocation.
- SE 110 vs CVO motor
- Dohertry mistfree breather
- Losing air from rear shocks ultra limited2016
- fl-xied-10
- Anybody have these handlebars
- Seat problems
- Having to resist the urge
- no forum member discounts from Baker for compensators
- Brake fluid
- Most comfortable SOLO
- Analog Speedometer/Tachometer on a Road King
- please pray for my friend
- RG bars
- 2015 Limited GVWR/Shocks
- Some pics from Thunder in the Valley - Johnstown, PA
- rear shocks??
- Front Suspension Upgrade
- Soft Splash Guards
- Oil seal at stator
- Passenger back rest too upright
- How to secure Ram Mounts base to handlebars
- Tour Pack / Passenger advice
