View Full Version : Touring Models
- I need to slow down
- Touch up Paint?
- Road Kings with Rider Backrest. C&C - Sheild burning the backrest.
- Replacing the drive belt.
- HDPDplus 2 Questions
- Apes installed & chrome legs!!
- Lift compatibility with V&H Power Duals
- Front motor mount
- Newly Modified 12 Sharknose
- Tallboy seat and Commensurate Handlebars?
- Lift for a 13 Ultra limited with V&H Power Duals
- Need help on Leather Saddlebag Lid Covers
- Seafoam In The Gas Tank
- My Weekend Project
- Chattanooga TN riders, I need a little info
- Comfort profile saddlebag guards?
- Drilling the Cat = Photo Proof!
- Dealer installed options on a New Bike
- Expanding the Air Cleaner Choices
- harley air wing luggage rack uh-oh
- 96 vs 103 SG?
- Axtel bypass oil pressure
- Finally getting the work started...
- Replacing Brass Ferrules for Windshield
- Picking up my FLTRU today!
- How do You Really know
- Headlamp bulb
- Out with the old and in with the not quite so old
- Road King: To upgrade or not-Advice Needed
- 6 piston front brakes
- headlight doesnt always come on
- New Road King sitting in the garage...here we go again.
- Any tips
- could use some help troubleshooting a megaflame kit
- 04 clutch cable replacment.
- New Power Vision Tuner
- Barnett HD in El Paso, TX
- 99 RKC engine guard options opinions
- I got a P0108 code after cam swap
- Fenders Off: What to Do?
- Adding Stereo hand controls flhtpi 2007?
- Jason Ward's cooling fans installed with pictures
- LSHD1 order question
- 09 Streetglide pinging under load
- Electra glide fat tire
- Buffeting gone!
- Do you have to sit on heated seat to feel it?
- WTF is this???
- Looking for a specific bike
- Ultra Classic vs. Limited
- Won't start in gear!!
- thank god for engine and bag guards
- auto tune 2011 RGc
- What's the largest CI Motor can be put on my Bike?(04 EG)
- 07 Street glide misses after gets warm!!!
- part numbers
- Has Anyone Upgraded Rear Light Bar??
- 1999 Road King with 16" Fairing Yaffer OEM or MBB?
- My $25 WalMart Audio Upgrade
- apes on the ultra
- New SG. Best Shock Replacement?
- Mustang Wide Touring vs Sport Touring
- Need to upgrade my stereo on the Road Glide. Whats the BEST setup?
- Front Suspension - Need Help
- Color on this Street Glide
- High idle issues
- EVO trans upgrade
- Ok, stage one just ordered. Have to install...
- 103 Heavy Breather
- h-k radio
- Need help bike keeps shutting off on its own
- Need your help!
- Winter mods done!!!!!
- Harley Davidson Helmets
- Can't stand dirt parking lots
- Touch up paint
- buying a Mustang seat....
- Cleaning White Wall Tires
- dolly for bike...
- Throttle Blip Clunk, any ideas??
- From FatBob to Road Glide - WOW
- advise on buying 05 FLHCTUI
- New manual chain adjuster. Any thoughts?
- Harley Goodies...
- Powdercoater review
- Converting FLHTK toTour-Pak to quick disconnect
- parade fan turned on by accessory switch
- front wheel bearings shims and spacer
- New C&C seat came in
- spot switch problems no low beam working
- Help on blowing 'lights' fuse
- Brake Light Problems
- Moved into to Touring Section
- New take on Streetglide or Roadglide wheels.
- Sound not as loud
- Has anyone experieced this?
- BOOM! XM Module - Just added
- RG Tour Pak for Driver
- Road King ABS light stays ON... ABS code 6-4
- does a D and D 2 into one have to get "burned in"?
- replacing IPB, what grease to use??
- Touring Mufflers
- Duals, SE Tuner Pro, what a difference , No Heat
- 2011 Street Glide w Thunder Max
- 1st Ride and Opinion '13 Street Glide
- Gypsy Judge 12,000 mile ride
- Red Line's Cam Evans- Carolla Carcast
- diamond in the rough #2, rebuild of a FLHS
- PCV (5)auto tune installation instructions
- diamond #2? any interest in my resto of a FLHS?
- Non color matched inner
- Put a tire on the new tubeless spoked rim??
- Adjusting M@M fuel injection idle.,,
- Harley Compression Bag for travelling
- Discontinued models
- Handle bars
- Mp3 cd's get damaged in cd player
- Tank emblem on FLHX change
- Which O2 sensor is the front one?
- 2010 Ultra 96" Does it have a ACR Harness?
- New 2013 Street Glide 103 Cylinders leaking
- Finally got the Street Glide
- 93 electra glide ultra classic upgrade
- Exhaust gasket issues with MVA Heads
- Tilt device location
- does anyone know how to wire road king gas cap
- Desperate for help - what size tire do I put on 18x5.5 wheel?
- just finished my road king make over
- JM Elite vs Performance
- What y'all think of these
- 3.5 inch for 4 inch Rhineharts.
- 2005 power commander maps?
- Key Fob
- Killing the sputter demon.....finally
- Transmission Fluid Color
- My phone holder ideal
- Need a bolt size
- Looking for headset mount
- 2013 Street Glide
- 12 street glide woods 555 cams s&s 106
- Just venting.....
- Finally!!
- A Well Worn Dresser !
- 220/50/18 same overall diameter as a stock harley 16 tire?
- Riding gloves
- Hesitating When Accelerating
- Rear wheel shopping and I am so confused. 18x5.5 won't plug & play?
- A little disappointed in Krome Werks plus 2
- Solo seats
- Back from 3 Months Away
- how much lift can stock springs handle? 2011 103 motors
- 12" MBB and painted inner fairing installed! PICS
- Harley 1/2 helmet - Flame Spoiler
- Chrome throttle servo cover
- 2004 Road King EFI performance upgrades?
- Upper cowbell covers
- novelty helmets
- Fairing mounted amp
- Changing rear brake pads 2012 touring w/ABS
- Wild Pig/Rush slip ons
- HD cutting six models for 2014
- (Harmon) Left front speaker works with iPod
- How do these grips come off??
- Street Glide vs Electra Glide Classic
- Audio Upgrade Help
- Gasahol vs RealGas
- Lower hard bag part number?
- Another shortass seat question
- How long do you data log Power Vision in for auto-tune?
- Vibration when hot
- Need wiring help: Install run/brake Tri-bar 68358-07A on '07 RK Custom with SG fascia
- 120r numbers
- Harleys are noisy, but ...
- I can't believe I'm gonna say this...
- Start up noise
- ? for those with stitch patterned seats
- Head Temp?
- swaping out ignition module 2010 flhx
- biketronics work with Harley amp
- Power Vision vs Power Commander V
- engine burning my ankle
- A tale of two saddlebags...
- Handlebars
- Braided Brake Lines
- Floorboard brackets, yet again...
- First roadkill today ...
- Drive Belt Tension
- 12" Carlini Flying Apes What Size Cables
- Heated vest
- One speaker cuts out...
- Rinehart Slip-ons
- Meguiars is my friend.
- '12 RKC - Rear Brake Squeak
- Corbin Dual Tour verses C & C Sport Tour ?
- Stage One - Screaming Eagle vs. After Market
- MGS. True Duals verses Fuel Moto 2-1-2
- upgrade mile markers
- Updating Headquarters 103 ST setup w/ new cams
- 20k Service, Chunk drained from transmission
- Any luck restoring warped leather saddle bag lids?
- Engine Light
- 2013 Road Glide Custom Color Change?
- StreetGlide stock chrome factory wheels
- Throttle "Slippage"?????
- Fuel Lines 2000 FLHRI
- Biketronics bt-1005 avc volume goes down, won't go back up ?
- FuelMoto Power Vision Tune, Should I run an auto tune still?
- Fork Lowers vs. Engine Guard Lowers
- Windsplitter windsheild
- 95 Road King rear fender
- Strange Weather
- 120/70/21 rubbing fender. Can I use 110/60/21 safely to create room?
- How do you store your fairing
- Todd Cycle 1 1/4 Bagger Bar
- Sputtering
- Zumo 665 install question
- 12 volt outlet install
- Crankcase question
- Exhaust questions... Not your typical ones...
- Starting hiccups
- no end play
- Upcoming setup-am I off?
- Drag Specialty's "Predator" 2 up
- ABS in live Action
- Dealers price on a 13 Road King. Am I getting stiffed?
- Saddlebag L bracket lengths? (Quick release mount bracket)
- Nicest flush mount front axle??
- Serious Question...and don't blast me...LOL
- 2003 Road King questions about rear fender area
- CVO exhaust vs Stock non CVO
- Progressive 440 set up question
- Stoplights - Neutral or Clutch?
- Engine Guard Electra Glide 2005 Fitment with 2010 Street Glide
- Fork oil changed with a pic
- How Far would you travel to have your engine build done ?
- Rinehart to V&H= new tune?
- Power Commander Quick Shifter
- Drilling Template for TOUR-PAK WRAP-AROUND LED LIGHT KITS 67914-10
- Mod Mustang Seat off 04 Ultra for 13 Ultra
- Shortass rider and electraglide
- FYI : Security System SNAFU
- Boom audio road king install question.
- Gutted Header, AC Exhaust, Fuel Moto PV = Holy Sh!t
- Fairing Pouch Spacers - Needed?
- Travel bag
- Heated seat plug part #
- Seat Mod
- Fuel Moto Visit Today with Jamie
- MCC Super Narrow Mod
- Anyone know where I can get one of these...?
