View Full Version : Touring Models
- puncture prevention
- ANy thoughts about using brass nuts on the exhaust
- Will a Street Glide tail light assembly fit on an Ultra Ltd fender?
- Reasons why I'm an idiot, part XXVIII
- Too Much Heat....
- New replacement stereo option
- special vs ? not special
- Black V&H propipe rusting?
- Street Glide seat question
- Progressive 444 shocks for 2009 SG
- 2001 Road King Question
- Cam Shaft Upgrade
- Dunlop Elite 2 2nd Gen 130/60/19
- Rat Wax?
- Thinking about a Road King
- Lean Angle Feelers / Street Glide
- Custom Rear Fender on 2014 SGS
- Occasional scraping sound at start up?
- radio issues
- Jackpot exhaust with quiet baffle?
- 1998 flht white faced gauges
- Metzler ME880's to Michelin Commander II's ?
- Will softail drivetrain swap into a evo ultra?
- Front axle studs
- Biketoberfest 2014
- Michelin Commander wear
- shifting clunk into first
- power commander v start up
- Installing street glide fender on 14 limited
- Handle Bar Suggestions?
- iPod interface HD vs Iron Cross ???
- fork wind deflectors
- P0577 high cruise input w/cruise switch off?
- Harley Davidson 20% off
- Engine noise - '97 FLHTCI
- how do you check crank run out for gear drive cams
- Engine guard differences between 2008 models and 2009-2013 models
- Chrome VS Black
- TC88 top end rattle/tick
- Noise on start up primary side.
- Suggestions
- 08 vs 09+ RK
- CB causes engine misfire
- Paul Yaffe Monkey Bar 10", chrome, for Street Glide in stock anywhere?
- Harley Ignition Plate Decal
- Need Some Exhaust Recommendations Please
- Ape Pic thread, I cant find it
- monroe air shocks
- Buffing Chrome Scratches
- kury driving lights road king?
- How is ride/handling without tour pack?
- Keep my 1999 RKC or upgrade to 2014 Ultra Limited ?
- 2010 CVO Lowered Need Kickstand to Fit
- Clearview with or without vent or LRS
- 09 front rim on 08
- Saddlebag Hinge Screw Size/Spec Needed
- Changing 2014 brake lever
- Hogtunes Gen 3 Big Ultra
- new nacelle grommet install with blurry pics
- Inner cam bearings with cam upgrade - which ones?
- How many hrs to remove rocker covers?
- Ordering paint from Harley ?????
- road king nacell fit. 94 on an 08????
- Tuner Question
- stretched bags
- Inner Cam bearing failed
- first 1000 mile service 2014 Road King - overfilled motor oil
- FL-ViED-10.... They are the bomb!!!
- Scala Rider Issues
- Rocker Arm suggestion
- Looking for a quality set of 2" wider and 4" stretched bags
- 07 street glide has the rear suspension of a log truck...
- Passenger grab rails/handles
- BaggerBags.com
- saddle bag trays for 14 street glide
- newbie exhaust question
- security light
- can you tell if the ecu was flash tuned?
- inner fairing antnnae
- progressive 944
- Anyone have these lowers?
- Harley Cycle Worx Exhaust
- CVO Muffler-Cycle Shack baffles
- ECM tray
- New bike, used? Decisions, decisions........
- stock street glide tri bar light, is there a bulb?
- Tired of brake dust!
- Cobra Exhaust
- '99 Road King Classic gets caught in 'neutral' between 3rd and 4th gear
- Ohlins S36E
- dirty air, air ride?
- LED Tail lamp for 2014 FLHTK
- '07 IDS Sprocket Question
- any difference in size of light
- Anyone use break grease on their pads
- where is fuel pump fuse on 07 street glide?
- 2014 103 Ho upgrades
- HD Chrome dress up rings
- Love My New Fuel Moto Stage 1 Tune!
- Idles rough and dies after warm
- Suspension suggestions
- water spots, cloudy fiberglass pieces
- Another seat question....Touring seats for larger guys
- Vance and Hines Dresser Duals
- It dumped on me
- Does your dealer offer free install and balance on tire purchase?
- Cam chest noise again
- Bike Barely turns over
- t-man 577 cam
- After Market Tour-Paks
- Oil Change Mystery
- Adding Tour-Pak
- Ship to Your Door Tires
- Spark plug question
- Yep, Another Happy Fuel Moto Customer
- Finally Starting
- Need a Power Vision Map for 117"
- street glide to road glide
- cam upgrade question
- How low to go for a shield?
- lower fairings
- Trouble with badlands load equalizer?
- Mobil1 15-50 syn on-sale at O'Reily Auto Parts
- fuel filter, shell & top plate
- Difference in FLHX handlebar width from 2012 and 2014?
- New battery ruined?
- Lost Oil
- Complete fluid change, that big of difference, or mind games?
- Adjustable Backrest Install Question
- 21 front wheel road king and lower rear
- pre 2009 saddlebag support failure permanent fix
- Hard Saddlebags - what year did they come stock or option on a bike?
- O2 Sensor question
- RG windshield trim
- My best friend left the cave and jumped head first into the tank!
- Picked up a 2014 Road King today
- My road glide crash bar mounted wind deflectors finally arrived
- Seat question
- Can anyone tell me if these shocks are good
- spark plugs
- There's a new Shark in town
- XM Radios
- V&H Monster round ?
- **Superchips Vigilante EZ Review**
- 2010 Ultra Classic with 10" apes
- Manual for '73 EG
- Primary case scratches....
- Fugly tour pack delete
- clutch cover o-ring
- i picked up a 99 Electra Glide
- Question about solo seat on ultra
- Shock blew
- Updated pics after gorgeous midwest morning.....
- Question about Cats and Road Kings
- Charging System Or Something Else?
- Road Glide Front Brake Travel
- 08 Street Glide and Salty air aint a good mix...
- Attitude Custom Painting
- Open you Garage Door w/your phone
- chrome abrasion rust prone?
- Bought New 2014 Limited, First Impressions
- Anyone use Cycle Services in Hyannis MA
- stock or aftermarket head pipe?
- Rear brake rotor & pulley compatability
- Crash Bar
- Quick Oil Filter Change
- 32" 34" 36" fishtails. show em if you got em
- Finish the Road Glide or go back to the Road King Custom?
- Bar Install/Stereo issue
- Does anyone run a Road King without passing lamps?
- Fork mounted fairing
- Headers and slipons
- Custom Street Glide
- Installed wild 1 wo576 chubbies
- Idle issue
- OEM Mufflers on 2014 StreetGlide Question
- Shorted rear lights, now it wont start
- Harmon/Kardon radio Aux Jack.
- Where did you mount your GoPro?
- Gotta give my dealer a shout out
- Akprovic 2 into 1
- check engine light no speedometer
- Burst Collection Hand Grips
- Our New 2105 Roadglide Build!
- Wow! De-Cat and Bad A$$ on the cheap
- Already dragged my Power Duals
- Loose metal sound when light throttle
- Galfer Wave Rotors for 2014 and newer front wheels
- How to get more room on a 14sg between rider and passenger??
- Soundstream 4.520D Shutting Down
- New (to me) wheels!!!
- replacing the HK radio
- TBW/Switch question
- 2009 SE RG throttle issues
- WO577 handle bar swap
- New Lady
- Rear fender width's ontouring bikes
- Cable length for apes
- 2012 Road Glide Ultra
- HK radio playin quiet from aux port???
- Cut the baffles out today!
- My new Drag Specialties seat arrived
- How Much Would You Charge a Friend?
- Screamin Eagle tuner question
- fuel moto xpipe
- What are the benefits of stage one on a 103.
- Understanding Roadking
- Tour Pack Adjustment
- Tranny dipstick broke in tranny, removal ideas?
- PM Torque Mirrors
- Best in fairing am/fm/wb antenna
- Pic request - saddlebag charging port - where did you mount it?
- Road King Maintenance
- American Custom Exhaust- Top Notch
- Looking for feedback on header pipes. 2010 FLHTK
- Harmen Karden Radio shutting off.
- Road king to Road glide
- Location of starter relay 02 Ultra
- When and Why did heat Issues Arise?
- Diy painted inner fairing
- My Road King with 23" Fat Spoke
- My Latest Project.
- Help with fuel gauge
- Harley Premium Ride Single Cartridge Fork Kit For 14 And Newer Touring Bikes
- Rode a 14 Low Rider today, then a 15 Road Glide...
- Rinehart Install - So Easy a 3rd Grader Can Do It!
- What are these 2 holes for ?
- Enclosed trailer
- 1989 Electroglyde
- Cleaning just the fairing
- What's your guess on the numbers? Finally getting tuned tomorrow.
- Floorboard rubbing header help.
- Ultra Limited Low
- Backrest ??
- Cush drive pulley fell apart....
- Diagostic Help needed
- 21" Yaffee "Thicky" Fender?
- Looking at a 2014 SGS. Is this a good deal or should I try for better?
- Harley performed warranty work, now won't start/idle cleanly.
- Touring LED Driving Light Input
- Is bigger always better ?
- Showa rear shocks, oil weight?
- road 6 10" HOLEY ROLLER bagger bars
- 09 Road Glide - Stator Replacement - Done
- MapQuest and Garmin Nuvi 760
- Has anyone swapped SG fairing for RG
- Heading to Denver this weekeng
