View Full Version : Touring Models
- Color
- 2005 RK speedo issue
- Ignition Switch problem with video
- Anyone try reach seat from 2024+ model on Rushmore bike yet ?
- 2000 FLHTCUI starter.....
- Gear indicator not working
- Stock seat modification service?
- Owners Manual
- Gauges
- Flat Out style crash bar for (up to) ‘07 Touring?
- Oil Temp on FP4
- Low RPM stutter very hard
- 2016 FLTRU rear brake wear
- clutch adjustment
- 2025 Road King Audio
- I won a 2025 Street Glide - Crazy
- Static test for ACR's while on the bike?
- P1655 code, ACR open all the time
- 2013 / 2014 Street Glide
- Looking for starter advice 2008 ultra
- Fuel Gauge issue after rebuild - and my dumbness
- 2024 street glide rear fend on 2006 harley-davidson flhtcu
- How and the Heck do you remove the CB plug from the tank Console???
- Oil in manifold.
- Fat Front Tire
- Voltage Regulator OEM or Aftermarket?
- 24 Gen 1 M8 114cid Engine. TIMING PING.
- Bluetooth Connections
- 2003 FLHRC check engine light allways on
- 2007 FLHX - NEW EXHAUST
- Help!! 02 Road King Luggage rack/mount kit/back rest
- M8 Police Road King Voice Recognition switch
- Brake line keepers how to remove them?
- Extending brake line with abs
- Bike not tracking straight? Help?
- Audio upgrade help?
- Lowering Kits
- Handlebars for a Road King
- battery up-grade to 500 CCA question
- Battery question on my 2005 Road King
- RK Suspension Rambling
- Tire plug kit
- Road King Phone Mount - from The YouTubes
- Added a permanent mounted receptacle for my trickle charger
- Wheel Swap
- 2009 Ultra HL Strobe no start
- Strange startup on 2022 Ultra Limited (FLHTK)
- trade up twin cam 88?
- 2003 ultra classic big bore kit
- everyone post phoyos of your 100th anniversary rides here
- E Glide with shorty pipes
- Relocate batwing mirrors
- Running a bag on pillion seat between rider and tour pack?
- James Gaskets Fork Seal Kit
- Black box with 5 -6 wires coming out of it behind fuse block
- Heated gear broken wire.
- 07 road king not charging
- 2020 RG Fork oil Level
- What is your favorite oil?
- Lift failures!? Has your bike ever fell off your lift??
- Rubber mounts and torque
- Draining an EFI Fuel Tank - sometimes I have good ideas
- Which slip ons for 103
- Drop in fork springs. Something not right
- BRAKE LIGHT
- What is your ‘least favorite’ work task on your motorbike?
- Limp mode issue
- Jack Accessory Info
- Partially Solved: Oil Leak
- 14 SGS Battery AGM or Lithium
- Year Model.
- Heated gloves
- Aftermarket Driving Light Wiring
- Hi oil pressure
- Who actually has their aftermarket shocks rebuilt and when?
- 2011 flhp 12v add
- Replacement seat for my flhx 1540 streetglide 2007
- Cold Weather Start
- EVO stock intake manifolds
- Mountains w/trailer
- Backrest pad for King Tour Pack Solo Set Up
- 2024 Handlebars
- Early model drop in cams advise needed
- 2006 FLHX Street Glide front axle nut size
- BRIGHT ASS HEADLIGHT ?
- 2023 radio doesn’t work
- Your favorite color ?
- Headlight
- Tourer Panniers
- Batteries
- Chrome trim vs Black trim resale value
- Taller bars on 2002 EGC
- Chrome T-40 Screws
- Question about 23 ultra limited
- Cheap backrest for king tour pack?
- Olins
- Boards to peg conversion question
- Wannaryd
- Electra Glide or Road King?
- 2013 Harley Street Glide Issue.
- antifreeze leaking by raditor cap - low outside temp
- 2025 new gas caps ?
- Rotors ?
- Question on derby cover gasket
- Police seat with mountain bike shock
- Fat front tire kit
- 2014 and up front fender on a 2013 Ultra?
- 2008 Road Glide ignition switch broken
- OK, where are we getting our Touring Ohlin's rebuilt/serviced now?
- Fairing fitment
- Rpm’s going up on idle
- S&S Slip Ons
- Lowers: HD or ?
- Wheels
- Shoie helmet good resources?
- Fair price to install rewired bars ?
- Craigslist
- Saddlebag Guards for Stretched Bags
- Exhaust is way off Center
- Update boom box gts and paid for updated maps... now issues!
- Can a Tune wait a little bit without damage something?
- 2004 FLHRS Road king Custom rear tire choise
- HD oil temp gauge and where to find one
- Best Leather Saddlebags?
- 08+ rear subframe graft onto older touring?
- To true dual or not to true dual
- Advanblack tour pack and saddleman backrest
- Best Year Road King?
- hogworks vs harley parts
- Road King Classic tire and rim fitament
- New Bikes at the dealership today.
- Need assistance..
- What compels people to sell bike?
- King of Touring Models
- Color marched lowers ?
- Exhaust gaskets
- 2025 bikes are posted
- Road King Windshield Storage?
- Tackform Drink Holder
- 2021 Road Glide Special wire question
- Advanblack ST Faring Install on 24 RKS
- 21 street glide
- Brake Line and Clutch Clips/Clamps
- Wheel swap
- Little to no pullback handlebars?
- Thunder Torque Inserts
- 2021 Ultra exhaust question
- Bluetooth helmet volume
- 2019 Ultra Limited Air Cleaner Changeout Question
- Vivid Black OR Scorched Orange ?
- Tour Pack compatibility ('11 StreetGlide vs. '14 Electra Glide)
- 2012 FLHTP Heated Passenger Pillion
- New to the forum 1000 Mile service questions
- 2000 Road King HOSE, crankcase to tank vent
- Old Bagger ECM's
- 2025 FLHXU
- Socket size for rear axle nut
- Facebook Parts group pages experience?
- Beware of eagle lights tour pac lights!
- Need to know diameter of Legend Arch remote reservoir
- 2018 Ultra- Audio curiosity
- '09 frame upgrades question
- No Power of Any Kind
- Last year of the Road King with carburator
- Shocks Progressive
- 2011 street glide hydraulic or mechanical clutch?
- Street Glide seats
- New(er) Inner Shifter Lever
- zumo gps
- 2006 Ultra 96ci FLHTCUI
- Air breather question
- 2009 road king an upgrade for an 06 heritage
- Just picked up a clean 1997 Road King
- Fairing supports
- 2007 Street Glide Electrical Issues
- Windshield and fairing fitment
- 2024 Road Glide Limited
- 07 electrical, no cruise, brake,etc.
- Weird nioise
- Over voltage tripping heated gear controllers
- Road King Lighting Upgrades ?
- Push Rod Tube and Case
- HD Defiance Hand Grips
- Heated grips for 2014 CVO Limited
- Water proof amp inside fairing
- AMBER WHISKEY
- HD Cardo Headsets
- Cam plate roller bearing 2004 FLHRSI screaming eagle
- C&C Seats
- Fall away test
- Alright, 'fess up. Who bought this?
- Nice, INEXPENSIVE rear strobe/brake light!
- 2009 FLHTCU Dominators Meat hook
- FP3: what’s the most “potato-potato” tune?
- Buying a used Roadglide, what do I look out for, years to avoid?
- Looking for advice to install radio/speakers in 05 cop glide
- Daily commuting
- TC 96" cam swap
- Police Model Security Siren?
- RoadGlide Head Light Upgrade
- "Wide" rear tire on 07 SG?
- Issue with my Python slip-on's
- little help...
- Fuel sending unit
- Clutch feels super tight to pull
- Vented Dipstick & Extenal Breather
- Slow start
- Still chasing the rear steer wobble. Slop in between collar and housing
- '24+ Tank console/Fuel Fill Door fit on '14-'23?
- 1996 Road king
- 2-1 pcx pro pipe HELP
- Anyone recently purchase NastyHog CVO fender and 4.5" stretched bags
- My 1978 FLH
- Would you consider buying a 2006 FLHX?
- Spare parts
- 2020 CVO Trike
- Storing bike with rear Legends Air Shocks
- Air Pressure Gauge
- Saddlebag lid trim - where can I find?
- Handle Bars for 2013 Electra Glide Ultra Classic
- Lost in fuel tank
- igition lock
- Front disc warp
- 03 Ultra Classic Gold Key Radio specs
- ARP stainless bolts
- Sharkroad True Duels passenger left floor board
- Rear shocks 2000 Ultra
- Wild 1's WO575 8" Bagger Bar for 2007 Street Glide
- Can FL nacelle be fitted to Electra Glide?
- V&H Slip Ons 2016 and earlier value ?
- 2008 Flhtcu Headlight not working
- Bar height and cable length
- Karma #2 give away
- center jack
- CVO 2019 Ultra - Radio options
- I need some advice!
- Confused about fluids
- 1993 Tour Glide Windshield
- FLHX 2011. cylinder head gasket replacement
- Geometry
- Any experience with Carbon Fiber brake pads or EBC with Chrome Backing
- Street glide geometry for touring
- Strobe rear lights other then CD?
- 2003 Electra Glide Std
- Road Glide Handlebars
- Winter Project tear down and install-Rockers, lifters, pushrods and cams ect.
- Brake light stays on
- Added cruise to the road king
