View Full Version : Touring Models
- How big can you go with stock stroke and cases (96")?
- Warning lights?
- Mystery Sound
- Quick detach kit
- Time for a new battery. Any suggestions
- 2010 Street Glide Turn Signal Issues
- new owner of 2012 street glide looking for peice of mind
- woods 555's
- Progressive Shocks to Stiff
- Pulling the trigger on a 2012 Street Glide
- Luxury Red color?
- Another oil leak
- New RK owner
- WWW Replacement Tire For 09 Road King Classic
- Speaker OHM and WATT Question
- S&S Power Tune Duals
- sound, supertrapp supermeg vs SE Nightsticks
- Accessary fuse blows, no turnsignals or horn
- from WW's to black ?
- Regular & Synthetic Oil
- Seat Cover
- Help me with my odometer
- Whats my colour????
- New Guy
- Bonus time at work...what to do, what to do???
- Recognize these wheels?
- Saddleman Explorer Seat
- speaker adaptors (WTB)
- Cam Swap and Warranty
- Help me understand ABS brake lines
- Question for those of you that have removed Tour Pack from your Ultra
- Going to do a little touring and go 1 mile UP
- Oil blowing out air cleaner
- True Duals & SE mufflers
- Spring broke on latch in Hard bags!
- Headlight/Fuse/Electrical issue...help.
- Scorpion EXO-700 Helmet?
- Just ordered a Pitbull Standard Manual Lift jack
- HOG towing question
- Polk MM tweeter mounting
- Road King Owners... (21" Wheel opinions!)
- Gauge Swap
- Went down this morning
- HD Ultra Chrome Indicator (N) Lamp Bezel Cover
- Street Glide owners
- Primary Chain Slapping
- Highway pegs
- Someone is knocking!
- SuperTrapp on it's way!!
- Put my new Lowers on today
- Need Advise Installing V&H Pro Pipe
- Highway Pegs Scratched my Chrome. Arghhh!!
- stuck!!help with inner shifter p/n and tools needed
- My audio review after 1300 miles (JL audio/Focal/Polk Audio/Sony)
- Water bottle holder
- stereo, day time
- First big adventure
- air front end help
- Heat
- How do I you bypass factory alarm
- '08 ElectraGlide idle problem... H E L P!
- Replacing My Own Voltage Regulator Questions
- Transporting items on your Ultra Classic
- true dules
- Tour Pak Hole Templates
- direct harley parts?
- Service manual for RK 11
- rear brakes sticking
- Brukus saddle secure
- Headlight vibration
- pulls left
- reremoving forks without removing ignition switch
- Issues with TBW on 2009 Ultra
- Soon to own a StreetGlide
- Mustang Lowdown Touring comments needed
- rebuild wiring help
- Street Glide Battery Post Issue
- Street glide tour trunk
- 120r running on one cylinder at idle, too hot?
- Headed to Sturgis in JUly/August - Lowers??
- TN riders...how is highway 1 from Nashville East?
- Stock sissy bar installation
- Can you tell me which V&H these are?
- stereo
- Oil Analysis
- C&C seats??
- 07 vs 08 touring swing arm's
- Anyone run a V&H Big Radius 2 into 1 on a 2009 and up?
- H8 vs H11 Running Lights
- 6th Gear Indicator
- 2012 FLHX cams
- Vance and Hines Twin Slash Monsters
- Help with Throttle Body Cupping sound on NEW Bike
- Harley Stock Seats !@#@!
- Gas Mileage
- sirus xm portable radio
- SS Exhaust
- Rode "our" new bike for the first time!
- Exhaust and remap question
- Pinging
- Drive Pulley/Trans Question
- Clutch cable replacement question
- Spark Plugs changed - Lean?
- Toy Thread
- is it still my battery???
- New drive train noise???
- Hint to installing Mid Frame Air Deflectors
- Question about HD Tour-Pak Brake Light/Running Light/Turn Signal Conversion Kit Part#
- New 2012 Street Glide
- Rear facia
- Need Key For Road King 2010
- Street Glide runs like crap after picking up from service
- decent buy?
- What kind of lieage should i expect out of the original tires?
- What oil in all 3 holes?
- Frogg Toggs Suit, Cheap
- spark plug gap
- AM Reception Problems
- Light up your arse...
- Kuryakyn backrest review - bad
- What bike lift do you have
- Progressive monotube
- pm fastair w/ lower fairings
- Good way to check squish?
- Stage one issues?
- Need Help With TTS Base Map
- Which Windshield For The Electra Glide?
- Road King or Ultra Classic????
- New guy checking in...
- Changing oil in rear shocks
- XIED's with TTS or SEPST or SERT
- Running light on but no dual intensity
- Found a nice suprise inside my fairing! also did some powdercoating :)
- Best Deal
- Harley or aftermarket iPod adapter??
- Jackets for Normal Size OL
- Fairing Supports repair
- Rear saddle bag crash bars
- Wild Pigs or American Custom?
- For those who have a wife that rides
- Dumb hardbag question.
- Power duals install
- Volt meter issues
- Tuners - conflicting recommendations
- Found the streetglide buzz
- Best Tour-Pak Luggage Rack Bag?
- Trying to save a few bucks
- LEDs on the fairing
- 97 flht no spark and fuel pump doesn't turn on
- Help Cruise Control Not Working 2011 FLHR
- True Track & A/F Mod Feedback
- Utopia Backrest
- Bars to reduce lower back pain
- OEM Part Number for Tour Pak Bracket
- 01 Roadking Auxiliary power connnetion? Please help...
- 4 point docking problem
- Squeaky Exhaust
- Vance and Hines big radius 2 into 2
- Securing Ultra Classic on NL Ferry
- Grindered roads?
- CAM Question - T-Man 555 vs. Others???
- New to site looking for Darkside info
- Going to order new exhaust I've decided on Dragos
- Removal of the Catalytic Converter with PIC
- fuel filter
- Crusin' with the Wife
- 2010 Street Glide Trike rear brakes
- '09 Street Glide -Fairing vibration, motor mounts, engine shake???
- Have You Skidded or Tumbled after falling off
- The noise is getting to me.
- What's the best and loudest horn to replace stock?
- Danny gray big "brick"
- 1982 FLTC Fork Sliders
- wire extensions for w0502 handlebars
- Intake valve noise thru throttle body and filter?
- 2012 Road King Classic handlebar swap?
- Primary chain adjuster anyone running Baker's?
- True duals or not
- can anyone give me a definite answer
- RF amp and adapter question
- Wide White Walls - I like 'em (with pic)
- Best high quality oil cooler??
- Pinging at interstate speed
- Progressive Monotubes for Street Glide: How Many Pre-Load Spacers, 1 or 2?
- Loud Pop(EXPLOSION) after sitting 15 minutes
- Bike to bike Comm.
- Preferred Head Pipe
- Mena Ar to Deals gap suggestions
- Made the jump from FLSTN to FLHR....WOW what great bike!!!
- Oil temp - Food for thought and curiousity
- how do you clean the Idle Air Control 06 SG
- Anyone using the PC-V with auto tune?
- no gauges, bike runs HELP
- Too Hot to ride
- Seats: Badlander vs La Pera
- Wyoming - Those who know
- Why do you have to re map puter?
- 1000 Mile Checkup Question
- Sweet freebie...
- ok short vid of my v&h twin slash
- Does anyone check tire temps ??
- WO577 and wobble
- You Know Summer is Finally Here When...
- Sounds like fuel pinging to me
- K&N Question
- how tall apes with stock cables/wire
- 01 Carb Road King Cam chain, oil pump
- Dragula 2:1 or V&H Pro Pipe
- 12 inch v stream shield
- dual beam install instructions
- Pics Of my 2012 Street Glide
- help with roadking and shoulder pain
- 2007 FLHTCU Radio display contrast
- Any Ideas As To What Might Be Wrong?
- Canada Border Crossing
- Exhaust fitment question
- Hard bag lid protective covers?(film)
- Jack question
- Life is so good on a Harley
- Who has a dragula 2-1 ?
- New exhaust
- Newbie Passenger Back-Rest Question.
- HELP - About to buy used Street Glide - What to do
- Cruise quit...Sup?
- Harley Throttle body cover question
- 02 Ultra Classic Front Axle Fork Studs
- What is this piece under the seat for?
- paul yaffe classic apes
- mini apes
- SMW Octane wheels
- J&M rockers
- New to me 2010 Road King
- American Custom Header & Mufflers with no Remap?
- Jackpot 4.5" Pro Touring mufflers
- brake pads at 43 k
- 70k mile FLHS?!?!?
- Loud Rattle Lt Side
- Front motor mount with 128,000 miles on it
- Calling all Tuners
- Heavy Breather
- Pay Attention When Reading the Shop Manual
- I might have found the wobble today
- Dumb fluid draining question
- TourPak value questions.
- xm onyx mounting
- Filling up the gas tank?
- FLHTK Engine Noise
- Anyone add Wild Pigs (or other) mufflers and not headers?
- Used SG needs tires - recommend?
- want to buy 07 R/G lower fork tubes
