View Full Version : Touring Models
- Putting together a deal on this bad boy!
- Tire Prices
- Engine temp sensor removal
- Speedometer and Check Engine Light
- 2000 RK FLHRCI Fueling up on rear cylinder
- Anyone make a passanger floor board "Lowering-Kit" 2014 Road King-
- FXR extra large tank
- Street Glide Special 'mini' apes
- Heated Seat???
- 2009 Ultra running rich.
- My experience with Long Ride Shields
- check engine light
- Ultra classic shuts off while riding
- Hard rear brake pedal
- Shout Out to Dan @ Ragan Fab Works
- Mystery Squeak diagnosis assistance
- Brake light switch help
- 2014 Ulta Limited. Wind coming from under fuel tank is choking me!
- Gas Milage - Pleasantly Suprised
- 2012 FLHTK Drive belt alignment question
- 2000+ wheels on a 1999?
- Lower kit for my 2011 flhx
- 2017 Road Glide Ultra colors?
- 2004 Road King new speedo/tach will not install
- Would you buy new again?
- police style helmet chin strap
- 2018 colors for ultra classic?
- Radio static
- So I bought a Motherwell fender rack on eBay...
- Would you consider this RGU?
- Spyke inverted forks
- Route Suggestions
- Suggestions with a 2010 Ultra top speed
- Low rear tire pressure - help finding cause??
- Best looking tunes set up for road king with no fairing?
- cruise control not working
- Cheapest easiest way to make stock radio Bluetooth?
- Stator or regulator?
- Crotch Cooler......great!
- Break light conversion... what license plate frame to run?
- Short on ultra limited...
- RK backrest: fixed or adjustable?
- Do I need a 2nd oil cooler?
- Carb hose location
- 2003 Road King Handle Bar Cover
- 2005 Ultra Classic "Upgrades"
- 4 slot Connectors on front turn signal wiring 2012 FLHX
- Need cam ideas
- 2017 road king oil cooler fan kit
- LED Headlight- trim ring options
- Any suggestions or experience with this issue
- So Here is my new Ultra
- Finished
- Exhaust header bolts
- Road King Clutch Adjustment
- 2008 Ultra 8k
- Add XM to my 2012 CVO Streetglide
- Road king help or anyone
- Lost signals,radio ecttt
- windshield replacement for road king flhrci
- oil blowing out of head breathers and Harley oil cooler filter adapter
- Which fans to cool engine in FL??
- Rides near fort collins Colorado
- Odometer
- Ultra Electrical Issue
- 2002 Ultra Classic: 2013 Air Strike front wheel Install
- m8 stage 1 suggestions
- engine cleaning
- Flashing brake light
- Wanting an honest opinion on buying a high mileaged King...
- CB Not working problem
- Help me with this RG windshield (?)
- FLHTCI Handle Bars are too loose
- Wheel swap??
- 2010 Street Glide Wiring Terminal Help
- Streetglide like front blinkers?
- Cobra speedster short swept duals
- Sissy bar passenger backrest loose.
- Hail blanket/cover suggestions.
- Looking for hand controls with extra buttons
- street glide seat for tall rider
- codes on 2014 road king
- Touring seats
- front abs sensor
- Street Glide buying tips for $10K budget
- Daytona oil pump
- New rear tire
- Possible clutch problem?
- Frt light ideas..16 SG
- Throttle body
- Extended warranty?
- Engine oil in Starter
- State Park sticker holder
- odometers
- Windshield Help
- Interstate Battery Question
- German Maps
- New Shocks
- Kuryakyn Hypercharger
- Patriot defender shorty
- Canberra Harley Davidson Service Department ROCKS!
- Texas Riders- Hwy 90? W to E
- Tri lights
- Head Bearing help.....check video
- My muffler clamps on my slip ons aren't working any longer.
- 2006 Ele. Glide Classic efi
- Got so bored so...
- Saddelbags
- The Dreaded ABS Light
- Best Helmets ?
- tuner SEPRT, powervision ,thunder max
- Need picture of choke cable bracket
- Price
- 2012 RK Throttle Sticking
- Air cleaner
- Soon To Be Retired
- Removing Dash panel adhered with double sided tape
- RickRak GoPro Mount
- Tour pak power plug connector help
- clutch upgrade question
- Possible clutch issue?
- Speedo Sensor
- New from SC..Ultra Classic help
- Flickering brake light
- Deciding on A New Ride!
- New to me 2015 ultra limited: What should i upgrade?
- UC left me stranded
- Fullsac DX pipe
- Need TMAP sensor plug - female side -12 Street Glide
- Question for the Experienced?
- Plugging antenna into stereo
- anyone know a godd deal on master cylinder lid/gasket??
- Roland Sands Air cleaner ?
- ECM Connector
- Street Glide Special Rear fender fascia replacement?
- Muffler clamp issue
- Most comfortable Grips
- DTC code P2101
- Clock keeps resetting on speedometer, anyone know a fix?
- Engine problem pushrod noise
- Using the Speaker Switch Location for 2nd Spot Light
- 2010 Tour pack questions,,
- Shifter Shaft Snapped Off!
- Landing Gear?
- LJ Frame Mount Kit-Horn Bracket Install
- Oil Catch Can
- 2005 FLHTPI Detachable Sissy bar help
- Different kind of windshield.
- St glide limited idle mode
- Finally in paint! Fender and Tour Pack
- Front Brake rotor question
- hi jack
- Fuel Moto Super Duals
- Black or chrome?
- Rcx-celerator fuel management system
- 05' Ultra security system troubles need help
- Street Glide Mirrors
- Dtc r97
- Changed out passing lamp bar
- harley fxdi
- Fork Slider Cover Torque
- 3 Volts on "extra" wire in the headlight harness
- Saddlebag parts
- Regular saddlebag removal
- Hammock seat w Adj backrest
- help with electracal greminlins
- Starter doesn't work when warm...and I'm on a road trip
- Removing heat shields?
- EMI/RFI electronic noise. Killing C.B. and Radio. Help
- Stock spark plugs ?
- dripping sound
- Bikes, Blues and BBQ?
- Pick a color...
- mbbw
- Load equalizer question
- Changing tranny oil
- 2017 Electra Glide limited low
- Bummer
- Why the bolt on rear frame?
- Warped rocker box base
- 2013 vs 2015 Touring
- Kuryakyn HALOS
- Need To ID This
- seats
- Did a search but I still have a question about which clutch.
- 1992 flhtc oil line question
- 2015 Street Glide Special Won't Start
- Long Ride Shields Question
- 1974 ironhead clutch replace
- Harley LED windshield trim question
- 1989 electra glide low profile seat where and how?
- New Saddle
- 01 RK Sundowner seat?
- Extended side covers?
- Daymaker 7" Projector LED Advice
- Clutch
- 510 Cams 2003 RKC
- Harley turn,run,brake module
- 2016 FLTRXS Wheel Issues
- New Regulator
- Avon Cobras ???
- Dash Conversions (Road King)
- Mid frame heat deflectors
- Found the reason for my limp mode problem
- Canbus Joe Florida and Custom Dynamics
- New Road King Rear Brake Issue Help
- 8" Twin Peaks Review
- radio doesn't turn off
- Stupid Y-Pipe Broken on RKC
- Mid frame heat deflector mounting
- 2016 Road King Stage 1 - Advice
- Can I move floorboard forward and wider?
- Age of tires, how much of a risk?
- 12 Electra Glide Classic, witch rear shocks and why?
- My helmet feel tight on jaws
- 2006 Road King dash lights
- Blue puff of smoke
- 14 Road King rear fender swap
- thoughts on Progressive 412's?
- Post deployment Street Glide project
- 2015 street glide warning lights.
- Feedback on Top Custom Baggers Parts
- Rpm's
- Installed Screamin Eagle clutch plates and steels. Friction zone gone!
- Oil difference
- Talk me out of wanting a new bike
- Rear Brake Line help
- CVO Leather Tour Pak
- Cruise Control
- Surdyke?
- FLHR Fuel Level Sender
- air canister fitment
- HD Security HELP
- Got a code
- Install Boom Audio Lower Fairing Speakers
- Howdy
- 2002 Road King - Best Wheel Bearings?
- extra wires in the headlight housing
- Installing independent control harness
- 2011 Street Glide - Need Advice
- Mesh Riding Jacket
- Calling all road kings
- FLHXXX Upright Sissy Bar
- shipping my bike
- A Review - UltraCool Reefer 2.0
- Heritage heat deflector
- speedo problems
