View Full Version : Touring Models
- buying a rental
- CAM's
- Can't fing neutral
- 30,000 Miles
- Fork Oil Change Question
- Happy Dance!!!
- Radio flash for rear speakers???
- Anyone know the size for the oil drain plug? (NOT the o'ring)
- Biketronics BT2180
- Help with hand grips
- Short Dude Windshield?
- fork oil leaking--
- Looking at a Road Glide and have a loaded question...
- WWW's '12 Road King Classic
- Thrills brought to you by Fuel Moto!
- 50,000 in 50 Months
- Change the Oil/Trans Pan on 2005 HD Road King Custom FLHRSI
- Would stock 96 cylinders fit my TC88 cases?
- Please help..How much is a perfect low mile 2008 Road king Classic worth??
- PM contour XL grips
- Any Good Indie Shops in Knoxville, TN area
- Having seperation anxiety lol
- looking for chopperdan fairing bracket man
- Ipod Interface
- Drive pulley change question??
- Lithium Ion battery. Tried it yet?
- Heated Grips or Heated Gloves
- HD Extended service plan
- Agitator wheel balancing
- bagger bars
- Seat fit question 2008 vs 2010
- Max voltage should read?
- Anybody ever mount a mechanical oil pressure gauge in their fairing??
- cams
- air cleaner
- Road Glide bars
- Better pic lowering kit at 2" position
- 2008 guages on 2007 tourer
- George Anderson Kit has no torque specs
- Air suspension
- Accessory Junction Location on TK
- Is this right??
- Front rotors
- Hesitation warming up 2011 FLHTK
- New bike first ride today 30 degrees!
- Help Identify These Bars!
- Trouble with Bi-xenon install 2009 Streetglide
- Sumax Extended Bag feedback please...
- Cams
- Any J&M radio wiz's out here?
- 0ne day closer for the buy what should look for???
- I bought some new oil...
- Input needed pro/ con after install WildOne 515 bars Roadking ?
- Very Frustrated
- Seat question for day trippers
- v-ieds-10 settings
- What is this bike worth
- Oil Draining out of Tank??
- Question????
- Question of the day...for me at least.
- 110 build results
- Light Conversion kit installation question
- What kind of lights are in the dash of my 2000 RK?
- 2013 Ultra Classic ... naked bike
- Fairing radio
- Rinhart pipes and baffles
- Gerbing's 12 Volt DC Plug Adaptor
- SE Pipes for Street Glide
- 103 Build Questions
- Saddle Bags Stolen Today!
- Throttle grip sticking.
- Fork Wind Deflector Question
- Picked up a Streetglide a few days ago...
- Lyndall Rotors
- After 155 views
- Input on Purchasing 2008 103 S.E. Street Glide
- Ive joined the Dark side, Touring that is
- Extended Bags Help??
- Hidden Antenna and ignition
- Inner cam bearing
- Just coated some stock touring shields
- Stereo
- Need advise on straps when trailering.
- Road King/Street Glide Rear Signal Swap?
- Best Out-the-Door Price on a new one???
- Inverted Bar And Shield?
- SE Heavy Breather Question
- Boom! Audio for Street Glide - reviews??
- Drive belt contacting tire?
- Just curious...
- Softail Cables on a Road King?
- Can anyone identify this air filter???
- PPU 82883 Error Code
- 1998 RoadGlide Questions
- Road king w/ABS - front brake line?
- Avg engine temp
- Cracked Handelbars
- How much real power differance in 2 into 1 and slip on mufflers
- Help with an install of a front bumper
- Oil thread-Real data
- Seat to lower a "short" person
- What's My 2005 EGC Worth???
- Fuel moto micro tuner
- Headlight '99 Ultra Classic
- 2012 SG handlebars
- Anyone done Fuel Moto with stock air cleaner?
- Wheel Hub Kit Question
- Making a Road King feel like an Ultra?
- Handle bars..how high
- Tire Monitoring Systems
- Road King 81 K Miles.
- Woods new cam
- PYO 14"s installed
- Is this a good deal?
- 10000 mile service
- Changing out side trans cover questions.
- Crashed tonight what is bike worth
- Relocating RK turn signals.
- Thinking of swapping exhaust...have a question?
- LED Running lights/connector/wire reversal
- Ultra Limited Heated Grips
- Half Helmet & Intercom/Headset
- Topshop fender and bags...so it begins
- Hydraulic cam shoe question
- PSI for Read Gas Shock for smoothest ride
- Exhaust
- iPod (7th Gen) Mount?
- Dakota volt gauge
- Gear drive cams
- battery in or out for winter
- I put the Ultra on a diet.
- Stock Exhaust... Any Value?
- Help. Headlight install
- Clutch replacement?
- Which Wheels Do You Like?!?
- Power Coating Stock Rims
- windshields
- RK Windshield making a whistling sound
- Gas cap clicks when tightening
- Tour Pack Conversion Question
- What is the weight of a 103ci 110ci engine?
- Forward Controls Question
- cam tensioner issue
- Seat Options
- Sold the sporty this evening!! Ready for the road king Classic!
- Saddleman Road Sofa fit and quality?
- Oil From Air Filter: S&S's Take
- Slip ons
- Bought a Dragula 2-1 Exhaust!
- Anyone got Wild1 Outlawz on a Road King
- High frequency vibration between 2800 and 2900 rpm.
- Kicker Powersports iPod/iPhone Solution
- RKC with MS fairing, options for apes?
- Big Bore Kit
- Intermittent Missing Problem - Please Help
- Switching inner fairing
- Santee handle bar ???
- Got lucky x2
- Early morning ride in Sendai(pics)
- Engine Quit on the Hi-Way
- Leather overpants
- A or B Motor
- Saddlebag Security
- Service manual torque value....THIS CAN'T BE RIGHT
- Front MH90-21 Tire vs 120/70/21 Tire
- Blue dye on end of crank
- Your opinion is appreciated
- FLTRX-Harsh Ride and Changing Shocks
- Fox Creek Jacket Help
- roadking front suspension upgrade ???
- Brake video
- K&P Engineering Oil Filter, Anyone running one on a Touring Bike?
- '12 FLHTC Wheel Swap
- Inner Primary Bearing Fail
- The Worlds Most Traveled Motorcycle!
- Repair to a FLHTCU Front fender
- Former Gold Wing owners
- Biketronics Reto Radio wiring question?
- 2013 SG Tail Light Modification
- What front suspension do you prefer?
- ABS fuse removal
- clutch
- Rattling/banging noise in primary 2009 Streetglide
- Mobil 1 synthetic in trans
- Driving Lights
- Dead (91) connector? Combo Speedo/Tach Install issues
- Anyone done this? Will the wiring allow it?
- Oil Cooler Rotational issues?
- Lowering Kit
- Just about finished
- Anyone in San Antonio/Austin area
- tensioners
- Any 30 something's in NC on touring bikes
- Factory speaker connectors
- PCV Retro fit!
- How much ticking noise should there be?
- 170/70/16 on a 09+ chassis?
- SG w/ HD Anarchy Wheels
- Bunghole Help
- 2007 ultra classic brake issue
- exhaust help
- Rineharts - weird comments from dealer
- Help Starter Clutch for Big Twin
- Stuff for sale
- Bike Pro Stands
- Tips Pics SE Race Clutch Hub
- 08 Electra tins to 06 Electra....will they fit?
- Phase 7 Trucklight/'06 FLHTCUSE/Install
- Gauge fitment 2010 to 2007 Ultra
- Saddle Bag Falls Off
- Loose Rear Shift Linkage Arm
- Question for Denim Black owners
- brawler seat with rack or bib?
- Dyno tuner & engine builder needed
- Zumo 660/665 Handlebar Wiring?
- 2001 Ultra Classic Black Smoke
- Lower 09 Streetglide Easily
- New 02 Electra glide classic
- Ultra has no power two up. Please help
- 2 Questions On My New Bike
- 6 Speakers with PBR 300x4 Amp on a Road Glide-What's your thoughts?
- New seat cover
- Bars, gauges, cd player installed
- y-pipe or seperate exhuast.
- new rubber what do you call it
- Heated gear
- Tour-Pak part #s
- Which brand and where to buy the best brakes
- Narrowed my speaker choices down to 3, need imput on each Please !!!!
- Replacement for usless air temp gauge.
- my first dyno pull
- So...what would you do?
- Passenger Footboard Install: 09 and earlier
- Wanna See My New 2013 Street Glide?
- 100th anniversary air cleaner insert question
- It's Home
- 6.5 Klockwerks or 7" Windsplitter
- Radio
- Oil Temp Gauge, Oil Temp Dipstick or "who cares"
- Battery Change?
- '11 Road Glide Ultra (107 location?)
- Garage door opener problems
- Painting the Ultra
- 2012 Street Glide and Road Tech Zumo 665
- Bike suddenly runs bad
- Struggling ABS
- Headset for 2008 Ultra Classic
- Problem - I want WWW Tires on my 2012 Ultra but can't find the correct size
- rotor choice
