View Full Version : Touring Models
- sissy bar
- Exhaust on the glide
- Tip Sensor?
- oil pressure or guage
- 89 Ultra Brake Issues
- Hello
- Please help me decide - 2011 RGU CVO or 2018 Ultra Limited ...
- How hard is it to install cams?
- Passed my MSF course this weekend!
- Old style twin cam, cam plate upgraded drive chains.
- 200 rear tire
- Need Map
- Harmon-Kardon Radio, no sound
- Camera mounts on fairing bolts
- Custom dynamics or ciro bag lights
- Garmin Zumo 595 wiring
- Can the ECM be damaged by a lose connection
- EZ Up Kickstsnd
- 3 pins of 4 pin diagnostic port
- Idles Weird - Why?
- 1/4" Allen bolt securing intake manifold is frozen
- Wire question
- 10in bar swap
- 2017 and 2018 Road King windshield differences
- 07 road king no 6th gear
- speedometer street rod 2006
- "Awesome" all purpose cleaner
- Sitting with bad fuel and tank is full of crap
- Which seat is this??
- BellRay
- Hogworkz Halomaker Install Problem
- Unfamiliar Sound
- Anyone know if this will fit 09 Road king??
- Speed Bleeders for 2015 CVO Road Glide
- Dyna to Touring engine swap?
- 2013 FLHTK Bar Swap...retain heated grips?
- Where is the best place to get rear speaker pods 07 flhx tour?
- Engine vibration starts around 2000RPM.
- New Member
- watch out on center stand
- Did everyone get this email from Harley for a discount?
- Burnt clutch cable
- Fairing info
- 2003 Road King Question
- Seat Question
- Ok, let's play..."What Is It!"
- Rear Light bar On Touring
- 2013 RK oil cooler worth the cost?
- Throttle hand going numb after swithcing from SG to RG
- AIr intake and exhaust need a computer flash
- Power Commander setup
- How do we inspect the compensating sprocket assembly cover?
- Suggestions for bore kit, cams, throttle body, and...?
- Cam Plate: Assy & Inspection differences between stock and SE
- OK enabled EITMS -- what do I need to know
- Enforcer wheel for 2008 ultra classic
- HD Key Found
- Driver's CB plug weather cap replacement?
- ABS delete
- Contrast Cut Wheels....
- Rear seat hole cover options on road glide
- eBay Integrated LED brake light and security fuse.
- tire replacement
- GoPro Mount on Wind Shield
- windshield bag
- Ultra Limited Brake Material
- Hidden antenna static question
- 2018 RGS kickstand
- Inverted front end
- 2013 Touring Service Manual
- steering head
- Where to find MSF course?
- Speed sensor?!
- Baffle-ing Question.....
- Installed the Mini Beast horn
- Trouble getting in Neautral
- Replacing Battery After 5 years-Will I Need to Reset Security PIN?
- steering head bearings
- 15 amp fuse blown
- Accessory Door wont stay closed, 2017 FLHXS
- New tire vibration
- 2003 Road King slight exhaust knock
- 2009 Road King Spedo Condensation
- 2006 Road King Police ABS Relocation?
- Rushmore Lower Fairing Fitment
- 15 Ultra REAR AIR SHOCK replacement
- Fp3 Not Autotuning 08 Harley-Davidson Models
- Factory stereo issues
- Kick stand
- Chopped tour packs???
- Seat replacement
- Do the lids interchange?
- Volt meter reading stays at 10.5
- Auto Shut Down?
- Gear indicator
- Rinehart True Duels - Starter Bracket Weld Crack
- 60 PSI oil pressure
- Best way to clean bottom of Motor area
- GPS center mount
- What happened to the forum?
- Scissor Jack
- Annoying oil leak since 103 upgrade build
- DK Custom
- Ultra Glide Classic Ride
- Intercom Problem
- 2013 dyna p&a fuse, 15a keeps blowing
- SoundStream Picasso Amp?
- 91 electra glide
- New to the group and need some knowledge!!!!
- Want to borrow retaining ring tool
- New Road King - 09 - need some advice please :)
- 2012 Ultra Limited - Radio Mode Select Switch
- Seat fit
- Yelvington Front Suspension
- Oil use after rebuild
- 2006 FLHTP Police only starts if jump Solenoid
- Speedo stopped under full bore.
- Cruise scare 😑
- 2009 Street Glide Turn Signal/Brake Light Issue
- 2011 ultra clutch safety switch
- le pera kickflip
- power vision tunes
- Alternative to whip antenna's?
- Will a '11 Streetglide seat for my '12 Ultra?
- First time HD owner!! Brake Issue?
- About to make the switch to a heavy bike and need advice
- Putting Oil in filter during oil change
- Pipe Discoloring
- 06 FLHT cruise control PN help
- Fender question for 21" wheel
- Kst mayhem bars
- Speedo Refurb?
- OPT7 XP-1 Halo Projector Headlight
- Clutch issue 1986 electra glide classic
- 2011 Electra glide classic oil pressure
- struggling with low speed right hand tight turns.
- Brake peddle height
- code B2176...open antenna???
- Brown vs Black, seat for a Limited
- Headset Recommendations?
- Capacity
- hesitation when not under load
- CB antenna thread locker
- 07 vented lowers
- 2003 RKC Cruise Control light
- 2018 CVO seat on 2015 Street Glide
- TBW issue after new bars
- Ultimate Seat for 2018 Road King
- The tuning MAP - after de-catting header
- Myrtle Beach Bike Week
- Cheaper option to make my tourpak detachable?
- 2015 motor in a 2012 frame?
- Question about Magneti Martelli fuel line connection
- Road King nacelle and Sunpie LED headlight
- 2014 Road King Issue need help
- New Throttle cables a tad stiff
- Break squeal
- Electra Glide Classic cruise add-on?
- 2003 Corbin Classic Solo Installation Instructions
- Help removing a Magneti Marelli fuel injector
- 201 flhtcu
- This sucks
- 2014-2018 touring radio wiring info
- What Seat Is This?
- fuel light
- Help, pulley bearing 08 streetglide
- LowRng error after changing battery
- Highway pegs
- Aftermarket sidecases for tourers
- 2014 Road King
- Wireless music/intercom options
- HogWorkz Headlight
- Alaska Sheepskin Question
- 2018 M8 Ultra Glide blew out spark plug?
- 21” swap
- Anyone found a windshield for RK Special?
- 10" bars for a '10 Street Glide
- 07` Road King problems
- Is the CB built into the AM/FM radio? 2000 Ultra
- SVT Boneshakers
- 1997 Electra Glide Classic
- extensions needed for 12 inch bars
- 09 Road King dash/console
- Highway pegs - yet again
- Tuning Tips for '18 FLHRS, Stage 1
- 1998 Road king, tranny exhaust mount part number
- front locked with normal
- Input on slip ons needed
- rocker box chatter
- Asheville, Maggie Valley and Dragon's Tail
- 660 GPS fairing mount as shown in the picture
- Won't start
- New Rear Tire Needed, Help Me Please!!!
- TTS vs. SEPST - Dyno Comparison
- Tank Lift Kit - 2003 RKC
- 2010 Ultra Classic 7pin headset port
- Street glide seat on a road king
- Device mount on Electra Glide? Suggestions welcomed
- Polishing Paint - WTF am I doing wrong
- Big radius pipes on a bagger
- Vance and Hines stage 1
- headset speakers too large comfort issue
- About to buy a RK Classic
- Alright you Efers im in it now
- Power Commander V map for TW-222 cams
- Oil coolers with lowers ?
- ACR problem
- 2010 Street Bob starts then dies
- Newer lids on older bag
- Tour Pak LED Lights
- Clutch recommendations for 6k mile road trip
- Having trouble with manual security 2006 RG
- Showa 54532
- how 2 and cost to lower Road Glide ?
- Jiffy Stand Rattles against Frame
- RK bars on a Street Glide
- HD detachables
- Road King Nacelle Accessory Switch
- Suggestions
- New Member with Questions
- How to tell the difference in oil filters.
- Road King Fairing - 2018 Opinions
- Quick question on stage 1 download
- new slipper clutch
- Got my J&S Jack! (review)
- 21" front on Road King--how much clearance req?
- chain drive gearing 07 ultra classic
- RKC leather bags getting torn up
- Can't Remove Fork Tube Plugs
- Windshield help request!
- Rear tire 2000 electra glide
- Waterless Wash
- Using PV vs a Factory Flash
- Tour Pack Speaker Pods Drilling Template
- Pipe change - 3000 RPM stutter
- Huffy or Harley luggage rack
- Oil leaking from pushrod tubes
- M8 cool fan
- Street cannons without Cat. Anybody found a way to tame the sound?
- 1996 ultra classic electra glide radio
- Street Glide front shock travel
- Using a Torin Lift
- Street Glide seat ?
- Road King tool kit?
- Clutch Help
- Cam Identification
- Black hills gold road glide
- Silver Fortune
- Nothing "Premium" about these shocks...
- My Road Glide Engine Bounces and Shakes More Than Stock
