View Full Version : Touring Models
- 50,000 miles \ Bad Rings??
- Prime Apes and Heated Handgrips are No-Go
- '12 RK won't fire after washing
- Good cams for a high comp bagger
- How to tell if Compensator is worn out?
- Need a Roadking dash wiring diagram
- Guard Dawg Alarm
- 2 into 1 for my RK
- Memorial Day
- Eyes open for slobs
- New FLHX
- You would think Harley would put saddle bag rails on limited's...
- Quick detach backrest/rack for "07 Road King
- Happy Memorial Day!!!
- Check your nuts
- Floor board boot guard
- New to HD
- heritiage bars for rgc, part number?
- bike ready for memorial ride, photo, thanks
- Push rod or tapet cover? Oil leak
- Need Help Finding Part Number for Trim Ring
- 02 EG Classic to a 13 Ultra Liminted...WOW
- New pics of the King
- My jacket dilemma
- Arm rests for ultra classic passenger
- Slip on exhaust '13 Street Glide
- Clutch "popped" when. trying to. disengage
- Great Day at Rolling Thunder
- Which Polk Speakers? Im confused!
- Cut out cat today now looking at a power vision
- Oil blowing out of pushrod tube
- Saw a crazy 2 into 1 exhause today
- Stage 1?
- Swapping out 2008 Front Wheel on Street Glide to 2010 or later 18" front wheel. Easy?
- electra glide classic
- Oil Temp Sending Unit # 72357-04
- Knock?
- fairing factory bags??? or sinister
- Baker DD6
- switch removel street glide
- What yall think about...
- Dash pouch
- Wrapper Fender on 2013 Street Glide
- passanger backrest too far forward!
- Redi Gas Can
- Rear facia on 100th RKC with fender tip pictures
- Headset question
- Is 4oz to balance new rear tire too much?
- 2013 street glide with questions
- a little bit closer
- black puck?
- Cold tire pressure question
- City horn
- Where can I get cheap passenger pegs?
- Some loss of power
- Bad day at the dealership
- Howard's HID passing lamps
- Spill proof gas cap
- Rolling Thunder 2013
- New upgrade might be too fast!
- Street Glide...Before and after
- Led lights and footboards
- Voltage regulator gave up.
- Quick EITMS Question...
- Need a Shop in Bay Area to install 12" monkey bars ...
- juat a couple photos
- Mirrors: Fairing vs stock
- Engine cutting out going uphill
- Extended heel shifter
- Leg Braker
- Old link, old info... but is it true, or fake info?
- 2013 Screaming Eagle Road Glide Custom
- Does a 1996 Road King Classic have Cruise Control?
- Reflector on the forks
- Arc Audio Amp question?
- riding Rolling Thunder tomorrow
- Vivid Black Paint, With Flat Black Powdercoat.
- Where To Lube?
- Just lowered my 2013 Street Glide...
- Any better clutch cable?
- Help with hardbag bars
- "New" bike for under $500
- Need to upgrade to a bagger, i need some experienced help
- Riding Motorcycles
- Just did the 1000 mile service on the new Road King...
- Drained battery
- Primary oil capacity question
- FOr those having high idle and/or surging issues
- Getting intimate with your bike
- Screaming Eagle Air Filter 2011 FLHTK
- Rolling thunder
- noise somewhere
- royal purple
- '13 Ultra Limited Saddle options?
- Cap for gas, dumb ass!
- Boom audio speakers
- who has 2006 FLHTi Blue ?
- speakers
- loctite on compensator
- Dual Batteries ...............
- Almost lost a saddlebag today
- Another approach to Heel-Toe shifter
- back rest removal
- CAM HELP Please Fueling or Redshift
- broken spring on starter button
- Verified first pics of '15 water cooled touring line
- Speaker advive/opinions
- FLHTCU saddlebag lock issue
- Thoughts on this Road Glide?
- Changes for 2014
- Kudos to Classic HD in Reading PA
- Looking for black flush mount Fuel Cap and Gauge
- Oil Temperature
- Sticker residue
- Hwy 18 in Iowa and South Dakota
- electra starter
- bagger ape cable length
- Thunder Max 02 Sensor
- Memorial Day 2013 - Sales?
- emission testing....
- Question for those of you wearing Mesh Jackets?
- Dayton Ohio Blessing pics
- Daymaker led light
- My Not-So Standard EGS
- Buy new or keep old?
- Agitator wheels on a pre-08. Can it be done?
- 2013 RG 103 Dyno with MGS Exhaust
- V&H Pro Pipe/ Dragos Dragula
- My 89 FLHTC sounds awful...help please!
- Replacement rubber pads for motorcycle lift
- Tickled to death with my Road King now
- Passenger minimum age Limit
- 07 Street Glide Brake light issue
- Batwing issue
- Seat Recoverd
- 2011 RK Police package..
- Tickingater se tappered adjustable pushrods
- Possible Blown Fuse Question
- What do I have? Need Help
- Personal review of the mods I've done. '13 SG
- '09 SG Code: P1351 (Front Ignition Open/Low EFI)
- Trailering a Street Glide
- New Member: 08 Road King w Danny Gray Seat & Boss Bags
- Need a low pressure differential switch, help...
- Covering the "Classic" - More uses of 91716-02
- help with picture uploading to threads
- performance machine prices.
- Hogtunes Big Ultra Help
- Any way to brighten up my dash lights?
- fork oil weight for road king
- Fairing Lowers Ebay or HoggChops?
- Denim Tour pak on
- Road King Console insert 3 piece kit question
- Carlini Bagger Bars - any feedback
- Trailer Hitch GVWR & Tongue Loading
- Rinehart 4" Muffler balance question....
- 150 rear tire project
- Leaving battery on charge for about 2 months
- Big Sky oil cooler fan on a 2012?
- New bars 2009 street glide?'s
- Powdercoated parts install on my SG
- Swapping 21" wheel to a newer bike
- Cop bike owners
- Picked up a new Trailer today
- quick question????
- Brake lines for Arlen Ness single sided front forks
- New 12.5" Apes Installed on Ultra Limited
- Decisions decisions
- '09 SG rear brake housing delete options
- 103 to 110 swap
- Is ttt a thundermax?
- Traded the Dyna
- SE 254 or Stock cams
- Hartco Seats
- Pressure settings
- Road Glide LED
- Back from Dyno
- exotic body parts fairing for road king
- Accessories mode w/ Ignition off
- Cleaning of the bike
- Moo-oovin on up, questions-thoughts
- J&S Jack with my 2012 Street Glide
- Progressive Drop In Lowering Springs: Too Stiff?
- headlight upgrade for 2001 EG
- Looking for small pouch for Mustang backrest.
- 07 FLHX Stalling Problem Solved
- Can u soften brakes ?
- HD Agitator Wheels in contrast
- Saddlebag theft...where?
- How long before retune with PV
- Road King Stealth Luggage Rack
- Throttle and idle cables
- Cockpit redo is finally done
- Engine guys help please
- New tires and rear brake pads
- Best Saddle Options??
- Flag using antenna studs
- Excessive vibrations?
- Logdging Info Help from my Cincinnati Area Members...
- nail in tire but no leak
- rear headset + speakers??
- stripped drain plug
- Wheel Fitment Advice
- 2012 FLHTK lower Fairing storage compartments
- Vibration after new tire
- Does anyone use these while touring?
- Intro and Dilemma
- Need some "Help"
- Is 2014 the Year of the Water Cooled Touring Bike?
- Hogrock anyone?
- Just did the home brew hardbags locks
- Primary Fluid Capacity: HD Service Manual Calls for 45oz. Is this Correct?
- Purge tube cap?
- New rear tire soon
- Inner Fairing Wiring HELP
- Starter Issues.
- Sounds like im revving too high...
- Clutch Cable
- Any info on Forbidden motorcycles?
- How to remove backrest??
- PYO MB Ape owners
- what is a fair price
- Good Vibrations?
- Genie wants to know what you wish for?
- Thinking of Tall Rider Seat Sit-Off
- Joining the Bagger Clan
- Not so newbi looking for advice.
- Need a new Battery?
- rear tire ??
- SG passing/aux light install ?
- saddlebag locks
- Street Glide stereo amp speaker upgrades that work
- EZ Pass Mounting Strips on Windshield?
- Width of rear fender on 2008 Street Glide
- next up grade?
- 2013 Street Glide seat issue
- Need help/advice 103 rear piston shattered
- Voltage Guage acting funny...
- Stage 1 Completed!
- Maybe I am imagining this but....
- Air Intake / Cleaner question
- What would you suggest?
- 2013 ultra limited seat??
- Bagger Wheelies
- do road glides have buffeting probs like a street glide
- Ventilated Derby Cover = Cooler Primary
- Installed new 103 in 2008 street glide
- Backrest help needed!!!!
- Tank "dash" 02 Ultra
- Damn clutch
