View Full Version : Touring Models
- 2014 to 2009-2013 OEM Rigid Tour Pak Rack Fitment question.
- 2014 saddlebag latch on older bikes?
- Wiring Question
- Bike Tronics
- Transmission noise
- Clutch cable ajustment
- Road Glide oil coming out intake
- Should I buy this roadglide ?
- Arlen ness big sucker vs Zippers hi flow (2014 Touring)
- in gear, idle coast or off??
- 7" rear fender extension
- new, need help
- Can't find a air horn install mod on forum
- Rear Break Rotor bolts grinding againts caliper bracket
- Apes on the way!
- Infotainment question - deleting saved contacts
- Mustang Tripper Solo seat
- air temp sensor in 2012 RG
- tour pack rack?
- Well, I guess they saved a couple of bucks.
- Soft Lowers
- Took 2nd Place
- Gauge compatibility for 2001 FLHTC
- 2001 electra glide
- Tuning question
- Question, Magnum BYO brake tee on FLHX
- ? Are the "passing lights" adjustable?
- Dumbest Thing I've Done in 20 Years of Riding
- Headlight will not aim
- Taller backrest?
- pipes+header & air cleaner now or?
- 2005 road king advice-going to look at it tomorrow!
- Problem changing rear brake pads on a 2012 FLHX
- Ideas to hide fender damage
- Highway peg advise
- New to me: 2010 Road King Police
- Should I retune?
- Brake Pads
- 21" Wheel Front fender adapter kit?
- Any DIY forward controls
- parking scott outside
- Tire PSI & heat fluctuation
- Rocker Upper/Lower install tips?
- Thoughts on Metzler ME888s for a 2007 Street Glide?
- 99 road king no spark
- Will a tuner improve completely stock engine?
- Replacing spoke wheels
- Fat Spokes for Touring
- Does anyone make replacement silicone bushing for detachable wndshields??
- e3 vs American elite tires
- what is this seat off of and what does it fit?
- How Hot is Too Hot?
- Wheel for electra glide
- Help With Upgrading Speakers
- Trying to figure length for cables
- Independently Owned Shops
- More sound
- Big Crank arrives ahead of schedule....
- Oil leak after SEAC infall, need help.
- Finally got it all picked...
- Road King Fairing Fitment Question
- Michelin Commander II's who's ran them?
- What should I expect to pay for a front/rear brake fluid flush on an ABS bike?
- SG Rear light bar on Limited wiring help
- What size after market rear wheel for 09 SG?
- 3.5 wide wheels on my 04 fltr, am I ok?
- Anyone here compare the Dragula 2:1 to the S&S Sidewinder?
- Willie skull grips
- VHT Nite Shades tail lite paint
- Cam....Question
- Turn signal problem
- 30k
- Repeated primary seal leak
- Black front end vs. chrome
- headset & infotainment system
- Fresh Oil
- Airfilter Woes
- Blinkers
- Extended bags yes/no?
- road graders...
- Need help with valuing my totaled 2014 FLHTK
- Cam question..... yea I know....
- Night rides and guages- white faced- too bright?
- Catalectomy
- Gotta love eBay sometimes
- Starting Issue 2012 limited
- Stock exhaust resale?
- Roadking cvo FLHRSE4 -08 110cui
- hill country ape hanger kits
- Looking to buy a new ULTRA LIMITED. What did you pay????
- Roadking vs heritage
- Cheap Quick Detach Kit Okay?
- What is a good choice for replacing the Horn using stock cover>
- lesson learned rookie mistake
- Wanting better than a 120
- Detacable backrest mount luggage rack - "V"s come off?
- Headers = less MPG?
- stage 1
- No Fuel 03 Road Glide EFI
- Charging Problem?
- Street Cannons on Order
- Tinging noise?
- Not Happy with New Cams
- hd radio
- pros vs cons of running full exhaust on 2014 FLHX
- Air baffle question on Road King
- If you wanted....
- ...so I pulled the trigger, it's Classic
- Maybe You NYers Know This About EZPass Already
- parade fans
- Dunlop or Metzeler
- Heated Grips retro fit an 2013 Ultra
- DIY SE compensator change?
- Yet another reason to hate Ethanol
- Centerline Footboard Inserts
- Too good to be true?
- Ride Quality Wheels/Tyres Ultra vs Street Glide
- Custom Dynamics lens cover preferences
- Which seats will fit?
- Vrod Fugly ?
- Another Boot Search
- Where is Aux light plug?
- Clutch advice
- New brake lever
- Throttle by wire ?
- warranty? ?
- Torquing Rear Axle Nut
- Road King
- New exhaust for my 2011 FLHR
- Winter Mods FINALLY Complete
- '14 Street Glide pannier lid covers
- Eliminating a 2009 tail light- Street glide
- Fuelpak
- New Harley Owner/FLHTK
- tradeing/selling your bike
- Dresser Duals Headers VS Stock Headers without Catalytic Converter
- Voltage regulator test question...
- Need help with error code
- Oil Level Question...
- Problems with 107 build kit
- Daymaker: Both the Hi and Low Beam on?
- '07 Wheels on an '02??
- Anyone have these?
- Chinese, but very interesting
- Packing advice for a month long trip..
- got my new flhxs/first time poster
- I've been had on eBay for the first time.
- Bad Stator on the Road Glide
- S&S stealth intake cover
- Turn signals/lamps on 09 Road Kingq
- 2014 chrome enforcer rims
- V&H O2 Bungs... placed properly?
- Inner Faring Idea - Seeking Feedback
- Suggestion for Fuel Moto
- Engine Guys Chime in...
- Slight Decel Pop after gutting Converter!!
- How much should I pay?
- LED bulbs....
- What do you think?
- 1978 factory paint
- bike occasionally sputters when starting up?
- Bought used. Looking for past history.
- still new to harley 88 quesion
- Front Brakes Locked Up - at 70mph!
- After Market Hard Bags For A RC?? Any Good??
- Excessive vibration at stop using front brake
- Buky Bar..12 inch ape
- What do you think, 103 or 96 with these numbers?
- Freedom Performance Amendment pipes... For touring models?
- ABS vibration
- Road King Wider Windshield - seeking input/experience
- 1.5 thick bars on street glide?
- anyone prefer clear shields over tints and dark?
- Figured I'd Share
- Decisions, decisions
- Apes vs OEM handlebars?
- 03 electra glide classic
- Cool shot of MY bike
- 09 Ultra CVO ??
- Completed the finge additions
- 2014 SG Dual bulb headlight on 2012?
- Fuelpak setting: Anyone running stock exhaust baffles removed with Fuelpak?
- 06 SG replacing the primary shoe tensioner
- ABS help
- Torx size
- Tourpac questions
- Starting issue
- Wanting 14 in apes on 2012 SG
- 2011 SG with 120r motor
- Will SG headers fit an UC?
- Mounting holes - new to old touring frame rear signal bar
- 06' FLHX-I Aftermarket Wheel Questions
- HD Auxiliary power port
- Warranty ESP questions with handlbars
- 1986 Tour Glide Classic
- Putting bike on a table lift backwards on my own.
- Full sac -outstanding service
- Source for a RH Saddlebag lid for a '92 FLHT ?
- Turn signal switch extensions
- Is my fuel gage broke
- Quick tire wear question.
- mag wheel cleaner ?
- throttle cable return issues
- Ebay One-Off Highway Pegs/Mounts?
- to those of you who have CFR's and true duals...
- Khrome werks Sweepers for a Road King +2 or 2+2?
- Fairing comparision, size difference shovelhead vs 2000's
- Paint Work Teaser
- Exactly what is ion sensing, and how does it work?
- good choice for aftermarket brake pads to beat harleys nuts price?
- Buky's Odyssey 12"
- Side reflector demo
- Put 585 s&s cams on 103 2008 road king looking for tuner
- Progressive 11" shocks on a street glide
- Short guy trying to decide which Apes.
- Cool shot of the bike...
- Roadglide Restore
- Bar Swap..
- Heat demons suck
- Over from the Dyna Forum
- want a street glide bad
- what tires do you guys prefer...
- Yes, poly bushings are available for 2014 touring
- Headlight/custom dynamics question
- cold start issues
- What TourPak Did I Buy?
- '14 tour pak backrest question
- Sorry...SE204 cam vs 57H andrews
- Toggle switches
- Anyone ever changed bars and had trouble with throttle by wire after?
- FLTCU instrument panel swap?
- Tuning Question for 2013 Road King
- Meguiar's honks inside... Gonna ditch the Zaino and have questions.
- 10 " Yaffe Monkey Bars mirrors 12SG
- Anyone know The Dyno Difference in Plano?
- Cool Cruisin Formula
- gps route
- radio
- Add ons and battery posts
- Make a 1/4" drive tool for tranny end cover or bar clamps.
- Cleaning up fuse connections-
- 99 Road King - No throttle
- V&H monster round issue
- Need paint advice and sources
- Tunes w/o a Base Radio
- Tour Pak Wiring Help
- Shout out to 13SGERS
- Night Rider FL-ViED-10
- First service
