View Full Version : Touring Models
- 98331-15VM Electric Jacket
- whining sound
- '14 and up fairing on a pre '14..
- 2016 RK speedo reflection on windscreen.
- motor shut down
- 2009 Ultra Classic CB Radio Problems, HELP!!!
- FP3 auto tune support...
- Honking Brake, please HELP!
- Transformer- Because We Can
- 06 Electra Glide Ultra Classic vs an 02
- Hott!!
- Two sets of slip-ons and back to stock
- led sidelights on 2003 ultra classic, cannot get old rings on kights
- Show Your 2-1 Exhaust
- CVO backrest bracket install questions...
- Loss of clutch
- Passenger armrests
- New Road King (2018)
- Road Tech Zumo 665 vs. Marine Radio in aftermarket fairing
- Candy orange accessory solutions
- wierd diagnostic message on radio display
- Road King Question
- 2008 Anniversary Saddlebag Value?
- Ride-On Tire Sealant
- Primary Case Drain Plug
- 2018 Tri Glide paint codes
- Trans Shift Shaft Leaking "Again"!
- Baker Ultra Wind Blockers
- HOG Roadside Assistance Program
- Battery issue
- o2 sensor
- mini apes
- Would you install new cam that looks like this?
- Brake light modulators
- New Road King fender-no bags?
- Handlebar install: What did I break? Help please.
- 2017 SGS fairing rattle
- hazard lights
- Superbike forks....for a Harley dresser?
- 16 Road King
- Dead Boom system?
- RK ckassic saddle bag fillers
- Extra Wires ???
- Where are the deals?
- Just Bought My First Harley-2016 FLHTP "how do I lower the solo seat"
- Bike wont start after amp installed
- Harley fitted with car tyres
- Upgrade air filter
- alignment pin removel
- Disappointed in Ga.
- Riding with a pain in the neck
- paint
- Different lengths of shocks after modification
- ABS Modulator Service
- Bars for 2013 Ultra Classic Limited
- ULTIMA Handlebars
- C and C seats
- 944's or how I stopped worrying and loved my motorcycle
- Cartridge left fork question.
- Removing the cat.
- Where to hide the wires on Electra Glo install?
- Hogtunes speaker lids
- SKWOOSH Motorcycle Gel Seat Cushion? any reviews?
- Runs rough when it gets HOTT
- Bike start up issue.
- Eclip for Seat nut
- non factory tuners on the block head touring
- front lower forks info please
- FP3 and radio troubles
- Road King not moving when put in gear
- 2014 Ultra Limited Tranny Chunk
- Extended shifter lever installed
- What is the deal with running a thinner head gasket?
- My levers floppy :(
- UC seat compatability
- My First Touring Bike!
- Radio
- oils
- Christmas in April
- Opinions on Corbin Gentry solo seat.....
- Goodridge brake line install question
- Brake Compatibility for 07 Street Glide?
- Passing Light Power......
- Helloooo..I'm from Calgary...still cold here
- One last time. Commander II or American Elite
- Daymaker question
- Accessories bag question
- Tank Lift
- 180/65B-16-81H Michelin
- Question for you Howard Motorcycle Metal
- Cranks but doesn’t start!
- Road King 103 primary outer cover leak oil
- Menace Apes on Road King
- 06 Ultra Harley Profile wheels
- Rear Fender Install on 2016 Road Glide
- module for brake light that turns the rear turn signals to brake lights.
- Help with starting
- 02 FLHTCUI running like crap!
- 2016 Limited with 10” LA Twin Peaks
- Electra Glo
- Another seat question?
- tire wear/ alignment issues
- new 14" bars and cables
- Tire Losing Air
- Sup
- Big guy, big seat suggestions or ideas
- Service Schedule Question..?
- Laser exhaust heat shields
- Steering dampners
- SGS'18 and iPhone mount
- Stainless Steel fasteners
- Ready for spring, replaced tires and brakes today on 14 sgs
- 2012 Road king tank emblems
- Tuner
- Progressive 944 Standard or HD recommendations
- Should a 91 Electra hit speeds over 💯
- Relays and Circuit Breakers
- Power Vision
- Really impressed with the 2018 Road King!
- Adding a tour pak to Streetglide
- 107 kit with 574 reaper
- help with security system
- Dented tank
- won't start
- Tour Pak Bracket Broke.
- Security system
- Red Loctite confusion....which one? 262? 271? 277?
- Throttle?
- Wind Deflectors on 2001 ultra classic
- Air pressure
- setting up for several years
- Boom! bluetooth Audio for 16 Road King
- I pulled the trigger
- Primary and Transmission Bearings Replacement Already???
- Ignition switch plastic peeling off
- Harley Pro Tuner Program Deleted?
- 2018 RG Special 1000 Mile Service
- Will 103 heads for fuel moto 107 kit?
- Road Glide pulling Right during front braking
- 06-13 Tour Pak Latches on older model?
- Cams
- Stock size windshield 2013 CVO Road Glide?
- Winter Mods DONE! BRING ON THE RIDING WEATHER!
- Forward attach bracket for 2014 Saddle bags.
- 2014 flhtp hydraulic clutch drags
- Throttle cable advice. 12”Yaffe on 2007 Ultra
- I am trying to find out if my 2010 ultra classic has security!
- 2012 RGU Speaker Switch Came apart
- Stage 2 upgrade on 09 Ultra Classic (Parts needed)
- Metallic rattle when I accelerate
- Transmission whine
- CFR's or Rineharts????
- Drilling out cat
- new exhaust installed
- Reprogramming BCM for Police Switches
- New member from Queen City NC
- Lowering forks on a Road King standard
- hello all
- Bag Turn Lights
- Twin Scan II Question
- Vivid black lowers on a non black bike?
- Electra Glide 21" Rim?
- Comfortable passenger pillion for C&C?
- handle bar controls
- 10 or 12 inch bars
- FNG here
- 2018 rgs
- 103 stock header modified with x-pipe
- Battery Drain
- First Ride Of The Year Pics; Please Post!
- detach passenger backrest help please
- Passenger pegs vs. floorboards
- Best looking and most comfortable solo seat.
- 2014 Limited Upgrade
- Who uses quick release hardware on their lowers?
- lids/speakers
- 2012 roadking cutting out
- 05 ultra classic quick detach tour pack.
- Changing the Accessory fairing switch cap to read Heated Grips
- New to me Road Kinggg
- 2015 SGS Braided Oil Cooler Lines
- How to replace lifters
- Lowering Suspension
- 2013 Road king will not start
- 2013 RKC Fog Lamps Issue
- Only sexy gal's like to ride on a 103"
- Corbin Dual Touring Saddle
- 2018 street glide special pricing OTD price
- street glide fender on electra
- Massive BLX4 amplifier
- Klock Werks Review & Power Coating
- Master Cylinder Clearance on 1.5" Bars
- Fuel Moto Street Outlaw 2-1 on S&S T124
- 2008 Road King- Belt shreaded, Pulley Advice?
- cruise control
- Engine swap
- Any issue wiring Cruise Control to be always ON?
- 2018 road glide ultra
- escort 360 handlebar mount
- 23" front wheel on 16' SG FLHX
- Gear drive question
- Fender Filler and Extender that Cover Fender Tip Light?
- cup holder for tourpak
- Those Who Have Swapped Hand Controls on Police Road Kings
- Harley Daymaker Reflector Lamp help?
- Suggestions for Pullback risers on a 2011 Street Glide
- Dirt around rear trim bar light
- Handlebars for throttle by wire bike
- A question about seats
- Dome Covers Recomendations
- new pipes
- Big bore kit or cam upgrade?
- Finally got to ride today
- Electric short
- Head porting job--opinions please!
- Come mute size
- Your thoughts welcome
- New Tires
- Car tires
- USB port in Street Glide fairing switch housing?
- saddlebag lid help
- 08 Street Glide Docking Station
- Airflow derby cover too big
- Looking for some advice/points of view
- Roadking no spark
- Brake lever help
- Compensator Noise?
- Anyone know if Harley put a build stamp on the 2008 anniversary models? ie, #xx of xx
- Oil out breather
- 09 FLHX Harmon Cardon audio issue
- Made the switch from Street Cannons to Rineharts
- kuryakyn Crushers
- Need some help, PLEASE! Hand controls
- Rush slip on questions
- 2004 flhrci
- Getting A New Windshield, But .....
- Ohlin 2-2a shock and belt deflection setting
- 09-10 touring rear fender on a 07 softail custom
- 2010 up rear LED international wiring
- Electra Glo keystone auxiliary led lights
- 96 to 103 questions
- 1988 FLHTC wiring concern?
- Shocks
- CD ProBeam front turns
- Overlay fender with tour pack- ultra classic 2000
- Need advices from LED gurus for my 2018 Street Glide Special
- Street glide issues
- 2013 Road Glide, will not start.
- What's a fair price for a new set of tires including installation?
