View Full Version : Touring Models
- Street Glide with 21" Front Wheel & Single Rotor
- How are you powering your Zumo?
- Warranty
- Soggy seat
- Pack your rubbers for Laconia..
- quadzilla fairings
- Police seat
- Chrome front end and parts with contrast cut wheels
- Street Glide front end
- Need Your Opinion
- Gravel, Rock, Sand Trucks Spilling Loads...
- Man am I pissed a Harley right now
- Installing oil temp guage on Eglide
- Buying Motolights: Get Standard LED's or Ultra Bright LED's?
- Cam chain Tensioners bad - input please
- Stupid is as Stupid does
- 08 and 12 RKC speedos the same part #
- Nacelle won't fit with Wild1 bars???
- Soggy Seat
- Any other whitewall tire options for the 09-up RK's?
- Pictures of Street Glide with Passenger Grab Rail
- needed a face lift, so heres my build
- vrod into street glide
- Stock air cleaning backing plate question
- 02 bungs
- Wider than Stock Rear Wheels
- Sale on pitbull jack
- Kuryakyn Panacea LED Tail lights
- Windvest or National Cycle windshield?
- 21 pirelli night dragon psi
- Can I use stock cables on 12" Yaffe Monkey Bars?
- Fuelmoto micro efi and pro billet AC
- its was hell never again... well i hope not
- 2013 Road Glide question on breaking in and oil
- stage 1 complete, review and opinion
- Advanced rider course?
- Switching to all LED lights
- Stock 2002 RK hardbags filler?
- Longest Trip Mileage wise
- Russell brake rotors
- 2013 flhx turn signal question
- Street Glide fender filler on Electra Glide?
- Tennessee Advice
- RPM level
- Custom paint shops, SoCal or mail parts out?
- 2001 RK Question
- Adjusting TFI for mountain riding?
- headlight bulb
- Best and Worst Air Intakes
- 2005 Road King Stage 2 kit?
- CFR slipons installed, but will they stay on?
- Maximum payload for stock suspension
- rotor warp
- Moderate decel popping
- 2000 RK exhaust
- Street Glide 2013 vrs 2014
- Non HD stero
- wild ones 575
- Any riders living near Lebanon Oregon???????
- O2 sensor cross talk question
- 1987 flhs
- V&H HO Duals vs Jackpot XXX & Pro Touring
- Drag Designs still around?
- oil filters???
- 09 vs. 07 Oil Change & Clutch Adjustment
- Bleeding Brakes on an ABS Bagger, Different Procedure Than Non-ABS Models?
- Kicking around doing cams myself, or local indy
- I have to say I'm Impressed.
- 2013 Street glide wheel on 93 electra
- Ultra limited cam install????
- Shop manuals 2013 RKClassic
- polyfill wrap for speakers
- Brake light issue
- 1000 mile service
- installed
- Police Bag Puck Problem
- 2001 or 2005 flhtc or 2000 flhtcui ?
- Roadking stock bars to Wild One Baby Apes
- Rear Fender Setup
- Question on Engine Idle Temperature Mgmt. System
- LED 3157 in the tail light
- Sundowner Heated Seat Problems
- Cam for 2013 103 CI Street Glide?
- HD Radio
- Help me pull the trigger...
- Engine noise
- Down shift or brake?
- Speed Bleeders 06 Ultra
- 1999 Road King ????'s
- 1996 FLHTCUI Ultra Headlamp with Eyelid
- Brake advice please!
- tires in michigan
- Street Glide Strap on Stock Seat
- Tire pricing, watcha gonna do..
- Just spent some money...
- Starter not catching
- 2013 Roadglide handle bar change
- Happy early Fathers Day to me!!!
- Powervision Autotune basic...how long do you run it?
- Looking for chrome exhaust bracket
- want to upgrade but not sure how far
- Injector cleaner needed?
- CFM flow of different intakes
- For Those Running Vieds
- 2012 street glide 2 into 1 pipes and chrome front forks?
- Is there a slip on I can get for this 2 into 1?
- question?????
- Too black out forks or not?
- Who's done a Stage 1 and then......
- Hammock seat and backrest
- First impression of Joe Rocket 5.0 mesh jacket.
- Newbie in need of Help
- Do I have baffles in my 3 inch Rhineharts
- Passing Lamps - HD LED or ?
- I need to know which 02 sensor is for which pipe
- Hard Bag Luggage Inserts
- New to Baggin found and realized something
- Uh oh.... No fuel stabilizer (need to drain tank)
- push rods
- what is the difference between the Dunlop 402/407 and the American Elite
- Weird noise when I 'blip' the throttle
- Converting SG to RG-will 09 lowers fit from ElectraGlide?
- Tour Pak with speakers on Road King
- MAP sensor with carb.
- Shipping a Tour Pak!Thought id check with my Touring Group to get some pointers!! :-)
- Width on Apes, make any difference
- Need Seat Repair in Charlotte, NC
- '09 SG cruise is disengages!
- Carburator Harley models?
- C1034 Rear wheel speed sensor circuit open or shorted
- SE Heavy Breather
- Dead Road King
- Using 3M 94 primer to attach LED strips
- License Plate Vibration Buzz Kill
- Removing/Refitting 6 Gallon Tank Locking Ring
- Decided to go for looks and not performance
- Converted RK to RG
- Are the phase 7's worth the money
- brake rotor question
- CEL And Code P1351. Runs awful under 2,800 RPM's!!!
- Info on removing read speaker pods?
- screaming eagle heads
- Crotch coolers - Captain Itch or Plastic
- Help in re-locating horn
- Spark plug gap smaller than spec
- Cover for my bike questions
- H-K radio
- Road Tech Zumo 665 install question
- 04 road king handle bar options
- Tires from stock to lace wheels
- Anyone wrap their baffles with header wrap?
- Planning to buy a road zeppelin seat tomorrow
- Cd unit head cleaner
- eBay bags
- My trip to the smoky's (w/ pics)
- New Street Glide or 2011 with 120r?
- New pics of my Glide
- 160/80 B16 Elite 3 Rear tire on 2007 Ultra
- Aux Port on stereo not working right
- Re-map?
- Rinehart 4 inch slip-ons
- Rivera-Primo 6-Speed for 2000-2006 Touring
- Sparkplug Thread Repairs
- Rear wheel - hard to change
- Fork baffle chrome half moon looking thingy
- engine code for overvoltage
- What Company to Go Through for 107 Kit
- 07 Road King brake light not working
- Fuel Injection Tank Fittings
- Gps no-no
- Single Left Side Brake Lines?
- Oil blow-by after AutoTune, Is this normal?
- 57h cam tuned
- Bear Cub
- Trickle charge
- Question about Wild One WO509
- good Indy shops? Billings Mt area?
- Pac Switch Question?
- Swingarm retrofit on an 01 FLHR
- Lockiing Glove Box Doors
- Smokey Chrome ??
- 600+ mile ride on Saturday to NC mountains
- Too much black?
- 2006 Road Glide Tach issues. HELP...
- Stock dyno #'s
- Antenna tip
- JES or HD Fork Deflectors?
- Headlight
- That's different.................
- Another PCV thread!
- Second hand tourpak blues
- Carlini's and a few more mods
- Suspension options for rough roads...
- Tw222 or se255
- Downsizing to a Fat Boy?
- clutch cable replacement
- Removing CB/intercom advice please
- '09 SG: Progressive Drop-in Fork Springs Quetions
- Vrod wheel and pulley?
- Back fire when letting off
- Shorty seat advice
- Hello, from your newest convert....
- Glide
- Anyone with an Aftermarket Chopped Tour Pak
- strip threads in the head
- Can I put a batwing on my RKC with apes?
- Who do you complane to
- Fork Wind Deflectors...long
- Solutions for valvetrain noise!!!
- Road King options for sound system
- Another Motor Officer Gone!
- CVO Crotch cooler install..
- Air shock leaking oil
- Air foil backrest w/LED light
- CVO Road Glide v. CVO Road King v. CVO Road Glide Ultra
- 67349-08 Speedo Qs: Chrome trim ring PN and RK compatibility...
- Turn signal issues 1989 FLHS
- Inner Fairing Premature Failure
- SE compensator
- will this starter work for me?
- Oil Coming from Right Shock
- Snap Repair with ball end hex key
- 2013 Road Glide Ultra
- 2013 road king seat help
- SG CVO fender fascia
- Map for 2009 StreetGlide w/Carey Faas Slip Ons
- V&H pro pipe
- Need some info help
- replacing stock tires - best place / price ?
- Decatedheader and Ness AC
- Exhaust question 2010 RKC
- Rear shock difference pre 06 to post 06
- Odor of Fuel upon stopping
- New 2013 FLHX
- Seeing in the Rain??
- Need advice -- Tour-pak brake light accent cover
- Harley communications headset
- Street Glide..Biggest Seller?
- RGU Engine work done, finally
- Oil drain plug o-ring
- Passenger arm rests for Road King Classic tourpack??
- Weird exhaust
- 1996 Road King stuttering and backfiring at midrange
- Winter mods FINALLY done!
- ACR's not working?
- Anyone running just a stock de catted header?
- Saddlebag organizer, side not top.
- Confused? H-D Download or V&N Fuelpak
- Metzeler 888
- 2013 Street Glide purchased.....
