View Full Version : Touring Models
- 2001 Electra Glide front brake lever question
- auxiliary light and fangs question
- Good Seat For Both That Doesn't Move Me Forward?
- Finally!
- H.O.G membership
- Idle..
- 103A HD in 1994 Road King
- Fitment of Saddlebag Guard Rail Dress Kit
- 1990 flhtc no headlights radio
- Indicator delay
- Cam bearings... order or buy locally
- Cold weather riding
- Adjustable backrest mount differences
- Quick ? on apes.....
- high output charging system (2011 CVO 110)
- 2008 Wheels on a 2000?
- PV2 Autotune
- Arlen Ness Saddlebag Latch Kit
- Electrical Gremlin HELP..
- 2007 Ultra Compensater
- compensator question
- Convert Ultra Classic to a Road King
- Extreme Engine Heat!
- debating on wheels
- Heat
- Front end 'wobble'...
- 2014 103 cam.....similar to what cam?
- Stolen Fob...limit 2 fobs per ECM?
- Frame Tube Oil Cooler - FLHTCU
- JRI A shocks question
- Bike Temp
- Warranty Fullfillment Question
- crashed bike and got the estimate back, couple questions
- Installed True Duals, Now Engine Light Is On
- How can I tell if I have Rinehart true duals or slip ons
- Anyone have any idea what this is???? Aprox. 2'w x 30"h???
- Wire a king tour pak lights on a FLHR
- My Radio
- Got Hit and the crash bars saved me!
- SG Rear Fender On AN EGLTD?
- S&s 124 engine crankseal leak
- pic of new bike
- Air compressor
- gas mileage issues
- RB Racing Exhaust
- heritage bars on a streetglide
- Speedometer calibration???
- O2 sensors, no O2 sensors
- WATERPROOF cover
- '05 and '06 difference
- Questions about installing Big City Thunder Monster Buffles
- Fuel Moto 117
- A little extra sound...
- Is it only me or...
- Mystery rubbing
- Looking to buy progressive shocks
- Discount code for RJ's Origionals?
- Need some help with 30 tooth conversion
- Which Rack for 2012 Road King Classic
- Roadking Rear Clean Up
- Aftermarket seat with factory backrest?
- Ordered handlebars....now the wait
- 1984 FLTC with EVO engine value?
- What are you paying for when you purchase a Harley Davidson
- Sony head unit crapping out....ideas for a new one?
- New to here and have a qurestion
- I can't stand a thief!!!
- mufflers
- How much brake fluid is needed for brake flush?
- Flhri intake
- Primary oil
- Put SE air cleaner on 2014 street glide special...ECM calibration question
- Looking for luggage rack options for 4-point dock when T/P is off.
- Tour-Pak relocation "on the cheap." Two inches back for about $15.00!
- Update on refinishing inner fairing ...
- Audio control switch on 2009 Street Glide
- What have I done? our wether trip
- My new Limited
- Front cylinder noise -
- Ohlins HD 159 & FKC 101 Review
- Indy in Memphis
- Road King tail light
- 06 ULTRA vibration
- hd-41609
- Aftermarket clamp and bushings ??
- Have cam chest apart, what should i replace?
- failed inspection :(
- Jensen HD1BT Radio Impressions
- Need new tires, what am I doing wrong.
- Awesome Tour Pack Rack Bag
- 2014 flhtk handlebars
- HELP on the road
- 14 sgs head light fit 13 sg?
- 09 flhx headers
- Detachable acc. wall mount measurments
- 48 States, 10 Days, 1 Road King
- Passenger seat for 1985 Electra glide classic
- check eng. light
- Handlebar damper problems
- S&S super stock heads
- I drank the Harley Kool aid again
- Dealer doing the right thing!!!!
- Fork bolt + clutch cable = damage
- Long term storage
- Ya I know buy the manual!
- couple pics, lowers/crash bar removed
- Exhaust
- Which SE cam compares to Andrews 57H
- 2004 road king custom w/95in motor from the factory??
- dirty bird "up yours" exhaust opinions?
- 2014 warranty or not?
- Need just a tad more power
- Sitting without gas...cracked fuel lines?
- BOOM antenna or reposition stock antenna for street Glide?
- detachable tourpack relocator
- Smoky Mountain HD...Thumbs up!!
- Hammock Seat Question
- Garmin 665 install causing feedback
- Solo Seat For Long Legs? Road King
- Streetglide back pain. Help
- Checking 2012 FLHX Rear Tire Air Pressure
- air cleaner
- eBay rear fender extension install help
- Spoke to Aluminum wheel question
- Do I need a Non-Fairing bike to do precision riding competitions?
- Leathers in hot weather...
- Need Help Front wheel/brake issue
- 2008 drive belt
- When to do a big bore?
- 2005 tc88
- 2007 Street Glide
- Another decatted header pipe question.
- Security or Not?
- How hard of a job is it to straighten the shifter fork on my '97 RKC?
- SG Light Bar on EGC questions
- 2012 street glide battery replacement
- Paul Yaffe Originals 10" Ape Hangers
- Tour Pak--older fiber glass vs new plastic?
- CD rear only turn signals
- What fluids in primary and tranny?
- 7 codes, check engine light and low battery voltage
- Anyone run the Kuryakyn Mach 2 A/C??
- 13 Roadking update
- Not Best oil Thread
- Can't keep my cap on
- friday the 13th
- Smallest Rotors possible for 2013 Street Glide?
- One Piece Full Riser Clamp For RK Ape Hanger??
- Would you carry your bike like this?
- Trading in my fatboy
- 2001 Paint question
- should i wait for a 2015
- New set of bags, latch won't lock into place
- powertrain factory tours
- Novelty Helmets
- Got cut off, bike and I down
- Street Glide Mod: Fairing removal.
- SEPST Update Question
- Big City Thunder Baffles in Rinehart 4"True duals....
- Adjustable passenger pegs
- Tuner Issue with 2014 SG
- New home for my street glide
- Which one, TTS or Power Vision?
- Rinehart 4" slip-ons with performance baffles
- Losing the "recliner" look - Rear seat back cushion.
- Looking for new seat '14 Limited
- OEM 2001 Road King Shocks
- New Owner Help
- can I
- Amsoil Severe Gear users......
- member with bottoming out issue
- oil leak
- Slightly off topic Derby Cover Torx
- Another engine light question
- rubber bumber insert (rear)
- wether
- engine pinging
- passing lights into turn signals
- 1985 Electra glide service questions
- Help Please on Highway peg set up
- best street glide headlight?
- blue-ish H4 bulb that'll match LEDs?
- Whining at lower speeds
- Found a excellent alternative to the "Fugly Fangs"! And they work!!!
- Oil filter shelf life ?
- Front brake makes bike vibrate more when idling
- SoCal HID and Hidden Antenna Interference
- Heat Shield & Extended Service Plan
- How Wires System
- Air cleaners and getting caught in the rain
- 2007 road king 5th gear sound!!
- My new ride
- 2009 Ultra red hot sunglo/smokey gold front fender
- More Pictures...
- Help with Throttle Cables
- Tour-Pak removal, better handling??
- clutch slipping
- 2015 RGC Looks Sweet
- Harmon Cardon in 2012 Problem
- rattle when decelerating with rear brake?
- Akoury 88 1/2 helmet
- Muffler Rubber Mounts
- S&S cams MR
- Reputable Indy in Minn/St Paul
- Installed a Power Vision on my 09 Geezer Glide
- Street Glide Saddle bag speaker problem
- 2014 Saddlebag Hardware...What would the cost be? Anyone done this yet??????
- Officially changed clubs, not on purpose!
- 19" agitator wheel....rides rough
- 103 c. i. engine
- Need help...'14 Limited won't start
- First long ride on my new glide
- Sears bike jack won't fit under my street glide?
- Pipes too loud now
- Oil on cam cover dont make sense!
- screamin eagle air cleaner breather bolts
- MGS Performance Package Results
- What footpegs you guys use?
- Top end clattering noise- Help!
- Difficulty level of installing progressive shocks?
- bluetooth head set not com with music
- 1st time dropped.... ouch
- 100 ft lbs at 2200 RPM
- Superchips 5841 Vigilante EZ Hand Held Tuner
- Run/Brake/Turn module
- Dang cough
- 2-1-2 problem
- Cobra
- Gears not engaging.
- looking for 1 1/4 coversion handlebars for 2006 RK
- looking for speedo tach in kilometers
- Stator-what would you do?
- Big Radius fitment question?
- Trans seal leaking
- Fuel Range Function (r###/Lo) inaccurate after speedo change
- will over filling crankcase push dip stick out ?
- what vent system with se intake
- Electrical Guru's I need help!
- where is the crankcase vent '98 flhtci
- Need help with Adjustable Backrest mount
- Mounting j&p grab rail to late model HD police solo
- Cvo bags on a pre 08
- Tank Lift
- Chrome Front Lowers
- 2000 Road King Mini Apes ?
- Ultra License plate
- 2011 roadking cop bike oil filter number
- GPS Tracker APP - If you don't like tecky stuff on a bike don't read this thread.
- Lunging at steady throttle. HELP!
- Need help again
