View Full Version : Touring Models
- Seat For Street Glide
- Fatcat Q or Rinehart's Tru Duels which ones?
- Led blinker makes noise n no light!?!?
- KW Front Fender Installed
- Questions about fuelpak 2012 FLHX
- Cat Converter
- I have invested many hours in my Ultra
- Motorcycle Shipping Question
- On the road again
- Tires
- Bike shut down
- Need seat suggestion
- H-D 10'' Windsplitter Windshield
- neutral to first clunk 'why'
- My homemade backrest mounting bracket
- My homemade backrest mount..
- 2009 & Later Exhaust on 2008 & Earlier Bikes
- ok another exhaust question
- 2005 Road King Passing Lamps
- fender saddlebag gap
- V & H twin slash rounds
- Pyle marine amp
- - Need Help with Bike Appraisal.. May Be Selling! -
- Handlebar makers?
- A few color matched pieces
- 2012 Street Glide.. Small profile passenger back rest options?
- Fender Ornament
- Passing/spot lamp connector terminal removal?
- Let me see you Wild 1 Chubbys (575)
- Extended bags. Any thoughts?
- Anybody Have Pics of Ultra Classic w/WO578 bars?
- Has anyone tried this Eiko12V/100-55W Blue Tinted Halogen Bulb
- How many miles on front tire????
- trouble codes
- Starter??
- How do you protect speakers?
- Chrome Plater Help
- Switching to focal
- Heritage bars on a Road King Last night
- Monkey bar installed pics
- Need P/N help 09 EG
- '77 Electra rebuild
- Zipper 575 redshift cams failed
- New Road Glide Ultra
- Ultra Classic 2009 and newer vs. Old frame?
- 96"SE255 beat by 103 stock engine
- Kromewerks 2+2 sweepers availability?
- Stage 1 or Stage None... Input please?
- Ohlins HD039 and Ohlins 2-2s or 3-3s
- 120R race engine mods
- Indy delivering on time - unreasonable?
- Finally!!! CFRs, Cobra Head Pipe, Big Sucker AND PV!
- Friend,s Road Glide
- Finishing Touch
- Front bearing install question
- ABS vs. non-ABS gauges and warning light
- Dead Battery
- How Smart Is This?
- Drillling out the cataletic Converter
- Questions for the Stage 1 Gurus out there!
- Doing the Stage 1
- Fork Wind deflectors
- Anyone have cell buckle?
- Opinions Please
- Got some saddle shields.
- 2012 103" Running Hot and Poor Mileage
- Heritage Style Bars on my RKC "Pics Inside"
- Swing arm / pivot shaft bolt cover removal
- Pro-pipe 2/1 Baffle (2009-12) Modification ??
- Considering Replacing My Stock Shield With A 12 Recurve. Is it worth it????
- I know....another Windshield thread.
- How much prep is required prior to chroming?
- Hydraulic Suspension Video
- Just joined the 95% club - Or "Of all the bonehead effin' things to do" Pt II
- Finally gonna Ride like a $20K bike! Ohlins & monotubes!
- HD Touring Pull Back Handlebar
- My little Klockwerks 3.5'' review.
- 4 point docking for stretched fender..
- How fast is toooo fast
- starting roadking 2001
- Tweeter Installation Question FLHX
- Wild West Thunder touring ralley?
- I Have A Harley That Runs Great
- what fork oil you guys runnin?
- Why should I use Redline vs other synthetics?
- Iron Cross Audio coupon code
- Replacing upper brake line question?
- 6.5 or 8.5 Klock Werks Windshield?
- 2012 FLHTK Limited, Problems and Perceptions
- Oh no... it finally happened
- how to connect an ipod to and ultra
- Saddlemen Explorer seat pushed me forward_floorboard extensions needed
- S&S easy start cams for Harleys
- Xied + Stage 1 download?
- Riding from Florida to Myrtle Beach... Best Route
- Ape parts and install info
- Splooge Oil in the Air Cleaner - Round 2
- Satelite radio/speaker question
- Another clutch adjustment question....
- PC-V Question
- FM reception with hidden antennas
- Purple Rain or Speed Shine?
- Cats: yes or no?
- Electraglide question
- no more pussy
- Independent Control Auxiliary Lamp Wire Harness Kit
- 2013 color chart
- Denim Black SG with Black or Chrome Exhaust
- Batwing vs Shark Fairing / Streetglide vs Roadglide
- Exhaust popping continued...
- steering stem grease?
- Drago's bike question.
- Stupid question, about a 21 inch front wheel
- Advice on Starting issue
- lifter question
- Opinions on 2003 electra glide
- A little spooked
- Re-core Stock mufflers
- How many are really happy w/ Ohlins shocks for the money spent?
- Bad dad king Midas bars?!?!?!
- Does the Street glide have a center stand
- Carlini 16" Apehangers
- 09 street glide factory cruise resume blows fuse
- Question ref replacing clutch in starter
- Glide pro on 09 and later Flh frames
- 09 SG rattle?
- Electrical problem
- Site connectivity problems?
- another dumb pipes question...
- Tank Bag
- Painting slip on and heat shield
- Checking crankshaft runout
- Cut off by another Harley
- Harleygoodies footboard extenders
- Just rode my CVO Road Glide home and cant hear a thing
- adding accesseries to circuit breaker panel
- Brake Caliper Pistons
- Back on a motorcycle tire.....
- 88 ci Spanked 103 ci
- can anyone explain the difference between
- Is the RKC factor wired for the fender lights??
- Opinions on new Grips
- Threads anyone?
- Some updated Pictures
- eBay shocks?
- SG exhaust baffle removal
- Aux input broken ??
- Getting ready to do an Iron Butt...
- Horn vs Rain
- Need a little advice on brake rotor & pads
- Front brake master cylinder seeping fluid
- Jam nut on clutch
- 2012 FLHX gps battery drain.
- Santee Ape Hangers
- 96" engine noise
- Hot weather riding gear help (pants, jacket?)
- Wasnt as impressed as I had hoped
- 2013 Street Glide
- 09 Ultra seat question
- 07 Ultra tranny "tick"
- what does a "flash" actually do ?
- Classic tour PAC wires
- thunder stick
- RK running issue
- How do you justify...... your spend
- 2013 colors?
- bike rental
- Fishtail tips for Rinehart 4" ???
- Mounting the bike
- Check out this 30" Road Glide Vid
- Wheel Bearings
- Streached bags and rear fender
- Punching out the baffles on my 04 Rg, info please...
- whats the best tuner for a 2012 streetglide Help!!!!!!!!
- Can factory cruise control be added?
- Passangers legs hit guard
- remove muffler packing, how does it affect sound
- Utopia backrest
- BAL-1 tail light w/HD led turn signals
- street vibs
- PBR300x2 Cutting Off -- Please Help
- Clutch Cable change question....
- Black Passenger Peg Brackets: Who Makes Them?
- Question regarding cams and PCV
- PBR300x2 with 2 or 4 ohm?
- Street Glide with C&C Solo & Backrest
- Metzler Tires... Back Ordered for months
- 89 Electra Glide Classsic wiring problem.
- original bike spirits
- 2000 UC JERKY @ slow speeds, Please Help!!!
- May need therapy
- Pitbull Lift Oops
- LED Turnsignal Conversion Question
- 07 ultra will not start
- One time tuning ?
- Rear turn signals supposed to be on or off?
- Belt Troubles
- Belray motor oil
- front caliper removal??
- Anyone done similar?
- Anyone done done similar?
- Crossover Pipe Clamp Wont Get Tight?
- 2012 exhaust on 2010 Street Glide?
- New 2012 Road Glide Ultra "Smiles"
- Looking for an innovation on TBW Grips
- Head Bearing - Swing Test... HELP NEEDED
- What kind of bars are these
- Bike is in the shop
- 2006 Ultra Classic Engine Cough
- will 2011 fatboy heads fit 09 RK
- Help! What goes here??
- Fi2000...Worth it?
- 02 EG Classic Vibration!
- Can a Bad Tune Cause Engine to Miss?
- HD Rear LED signal lights with run/brake fender tip light
- Cam Change
- Where to buy
- 02 FLHR Knock/Clatter
- New Ohlins installed!
- 2012 Ultra, FM/AC Xied... love it
- Loving the Hell out of my new bars!
- Rear Wheel alignment and belt adjustment
- Fairing mounted Mirrors.
- Oil Temp Gage/ Oil Pan
- Rear tire
- Gear shifter
- power duals, AC,Tuner
- Jackpot 2/1/2 Head pipe and Touring Pro mufflers
- Anyone tried the Lepara Aviator Seat and Pillion
- scratches
- Idle / Low RPM Knock in Rear Jug - 2012 FLTRU
- Street Glide with vibrating license plate
- 09 Heritage bars on an 09 Road King
- Longer floorboards
- Starting issue for the RK - need some help
- Remove TourPak
- o2 Placement
- Air Shocks
- 84 Electra Glide restore
- Aftermarket tour pak backrest suggestions
- 05 road king custom
- Couple of questions
- HOGPRO Contrast Wheels
- Mustang Super Touring Seat....Help
- My Rockfords went boom alright!
- Heat Help
- klock werks or hd wind splitter
- 10" PYMB on my 2011 RGC
- Thinking of selling my 21/18 combo. How much $ can I get?
- Danny Gray Big Seat w/ Gel??
