View Full Version : Touring Models
- long ride shields review
- Cheaper windshields
- street tuner open loop
- Noise from LED headlight bulb fan
- Idle, neutral, clutch engage-dis, drag on motor?
- Wheels, year, fit?
- Need a lower fairing cup holder for '15 Ultra Limited Low
- Best radio kit for batwing
- New Road King owner
- 17' Road King Special, Extended Brake Pedal
- Clutch Lever Won't Move After Clutch Adjustment
- SG wind buffeting?????
- Police Seat Adjustment????
- 2003 rim on a 1998
- Tire pressure
- Tire sizes
- CDN Riders- Ottawa to Quebec City routes?
- 03 wheels on a 98
- Simple ipod question
- Feel like I'm dodging bullets...
- Eagle Lights Daymaker Gen II anyone?
- You can have Biketronics and a CB also
- Clutch Cable Tension Release?
- $500 for first service?
- My breather mod
- Wild 1s 518 and brake cable
- 2015 Roadglide Windscreen
- Dunlop vs Metzlers
- Best tires?
- 2001 Road King Shock upgrade For 2 up Comfort to replace stock Air shocks
- Adding Cruise Control to a 2012 Electra Glide Classic
- No start.
- Rate my external breather
- Elite III
- noise from engine
- saddlebag crash bar on a Street Glide Special
- Road King Clutch Won't Adjust
- I purchased a 12" Windsplitter windshield for me 12 RoadGlide and I cant seem to keep the rubber seal "stuck" to the bottom center of the shield. It keeps coming off.
- 2000 flhr
- Should I change my cams?
- Bought tour pack. Now detachable mount
- Passenger sissy bar options?
- O2 sensor
- Vibration in front end
- fork and shock oil update.
- Service and warranty concern
- To headlight lens
- Cam upgrade
- Adding reverse to a new RK
- 2010 dyna motor assembly to 2006 street glide
- Stereo speaker systems for Road Kings - Options?
- Shift Shaft Seal?
- A real HOT bike, but not in a good way.
- Bike dies/shuts off while riding
- Fork Oil - Question
- Tour Pack
- Kuryakyn deep dish turn signal bezel
- Extended warranty worth it?
- '99 Road King stripped oil drain plug- Help!!!
- seat recommendations
- I bought a Chopped Tour Pak for a Road Glide Special
- Harley Garage opener versus Custom Dynamics LED TruBeam headlight
- 2001 Touring fuel filter
- Pics of pistons
- SE 110 Tire Shredder Kit
- Glide pro bushings
- Dyna wheels on bagger
- LED Headlights for My Road Glide
- Will 09' 96ci cams fit an 05' 88 Road King engine?
- Keeping Windhshield in place
- Bent Rim
- Road king issues when hot.
- FLHP passenger backrest - my way
- why doesn't harley fix their problems ?
- Anyone knows how good twin power rotors are.
- Rear break squeaking
- Changing wheels
- Uhm, No.... just NO
- Hogworkz
- Rear fender protection
- Muffler and Baffles 2009 Electra Glide Ultra Clasic
- SE Pro Street Tuner vs. FP3
- I'm tubeless!
- fuelpak issues
- Aux Power
- heat and baffle
- Sportster owner looking for advice on tour bikes
- What did I do!?!?!?
- more low end
- Mystery bracket while replacing the battery
- Going to get a 16' LRS clear or smoked for my bike?
- Death Wobble
- Cylinder seals bad, low compression, etc.
- Stock Road King handlebars
- wire size help ....
- Ultra Doesn't Recognize CB after Re-Install
- Power
- Bit the bullett shocks
- 2016 Road King with Magnum clutch cable - VERY STIFF
- 2016 Roadking with Rinehart slimline duals - bike is bucking not lugging, need advice
- 2012 road king
- Front Brake Drag w/ ABS 2016 FLHXS
- Does Long Ride Shields still offer a discount code for forum members?
- Suggestions for saddle bag luggage liners for cross country trip
- Moving Speedometer to Right Side of Fairing
- Backrest for Road Zeppelin seat
- Trying to add chrome transmission shroud
- Seating
- Tour pak hardware question .
- Speaking of gauges...
- Seating
- Help with amplifier
- High idle
- Non working cigarette lighter
- Looking for some advice
- Detach Kit
- Miles on a full Tank of Gas
- Need expert pipe suggestions for Ultra Classic Low
- front highway pegs
- Love Jugs
- Which models does Harley Davidson
- Street Glide 2006 annoying and weird vibration
- Compensator repair question
- Saddlebag guard set
- Who else has been blackballed by the "shock Nazi?"
- Viking windshield bags
- New handle bars for my Road King?
- Need some windshield help
- 2013 Ultra Limited added FuelPak 3
- Turn signal problem
- Police tires
- idle surging
- HD help
- 08 Ultra Classic Stage IV Tick
- Hello I'm Dean from Winnipeg. ..I ride a 2014 Breakout. ..
- Street cannons and no converter
- Aftermarket brake lever install help please
- What is the torque for the rocker cover bolts?
- Charging Pigtail Connector
- Rinehart Exhaust question 2003 Ultra
- LRS winshields question
- Will the 2016 Road Glide seat fit
- Forward floorboards RK
- iring Diagram request
- What do you do with your old helmets?
- Americade tire installation?
- Looking for the best iPhone 7 handlebar mount
- Street Glide vs Electra/Road Glide seats
- Throw out bearing issue
- Ever seen SEALED Wheel Bearing Shims/Spacers (internal) and Where They Go?
- New paint on RGC
- tires for an 08 ultra
- Grease Fitting for Shifter Shaft
- Oil leak
- 07 street glide jiffy stand problems
- Merlot Sunglo question
- E 15?
- stranded without service options
- Tail light lenses on SG, RG and others
- Strong Exhaust Order On Start-UP
- 2011 FLHTCU ignition/electrical issue
- Best way to wire for an iphone?
- Installed fast up dirty air need ideas for air horn
- Rear pads on a 03 Ultra
- Handlebar Riser Bolts
- Please help identify this luggage/tour pak
- Middle Tennessee
- CV Carb
- 2009 FLHTCU TBW Issues & Oil Pump
- Engine compatibility
- 99 heritage 8k miles or 02 rd king 60k miles first bike
- 97 Electra Glide Classic tire replacement
- Loud knocking
- Loud knocking
- What mirrors are you using with apes?
- Dragos or FuelMoto 117?
- Best way to lower a 2014 road king
- Oil pressure
- Show Off Your Bagger Sissy Bars
- Motor swap - 103ci to 110ci Screaming Eagle
- Ohlins vs Pro Action
- After Market Tour Pack
- Tranny fluid
- Hi all
- air bleed ABS
- 3 Hole Oils
- Horn mount breaking from vibration. 2014 Street Glide
- P0572 code rear brake light switch 2008 FLHR Road King
- Engine light
- Ultra Antennas
- installing diamond microv2 600 watt amp
- SMART Triple Play
- Rinehardt true duals
- '03 FLHT tire size
- Different cover for Arlen Ness Big Sucker II
- Anyone done this or something similar
- 08 street glide cutting out
- 01 Ultra Classic no speedo, turn signals, etc.?
- And now I have a drip
- Garmin Zumo 595LM
- Visor Style Trim Rings 2013 FLHRC
- Road King ABS
- torque spes 12 FLHTC-
- Brighter brake light
- Help identifying non-stock parts
- Any Good Chromers Out There?
- HardDrive handlebars
- Warm weather gloves
- Exhaust backfire on warm start up
- Extended reach seat
- 2017 Road King Beach Bars
- 2014 street glide special running lights problem
- pcv auto tune help
- Chopped tour pak
- garage door opener
- Anyone using Denali Soundbomb air horn..
- 2001 Road King fuel mileage issue
- Derby Cover Gasket
- FM micro tuner and oxygen sensors
- Dynotune-$850.00 just to start -03 RKC
- 2012 Electra Glide Adjustable Backrest Install
- Amsoil change
- no key fob and pin
- Internal Ape Hanger Wiring
- 2008 street glide instrument gauge fitment
- shovelhead oil drain plug gasket
- evo 1340 stater
- 2011 Street Glide fairing
- paint code
- Switch 71549-82 1989 electric glide
- My 2003 Road King Anniversary Bagger build
- Electra Glide Tour Pak Wiring
- Take a good look at the m8
- 2013 Street Glide Rear Fender Replacement
- Tuner
- detachable tour pak parts ....
- Fuel door
- Toby
- Anyone own a 2008 Firefighter Edition?
- Not your typical oil question....
- Double Mods & Beyond
- 2013 road glide ultra
- 08 street glide clutch adjustment problems.
- Pressure relief bolt
- '96 fuel injected rk exhaust help
- 2014+ Lower Fairing part number; what's the difference?
- '06 Screamin Eagle Ultra Classic - Inner Cam Bearing Blown
- Where can i get a good deal on Brake Pads?
