View Full Version : Touring Models
- How many miles before dealership considers bike not to be new?
- Ticky Clicky Knocky Sounds and Carbon Buildup
- S&S quickee pushrod. What tubes
- paint roller fit in saddlebag?
- LED bulbs for HAD fog lamps?
- Service manual questions
- fairing ratttle
- Left blinker indicator not working
- Street Glide rear fender
- Hard start when hot in Sturgis.
- security code for the alarm
- Vented OEM lowers from 2016 touring, would they fit 2017 2018 touring models?
- KST Mayhem and Yaffe MB turning at low speeds
- First oil change on my 2010 Street Glide and oil plug is leaking....
- 09 Road King engine swap
- How many of you guys are financing your new bikes?
- Dealer purchase or individual
- Is There A Way ... ?
- Fish Tails
- engine LED's?
- Bike cover
- 1st time Harley Owner
- 2018 road glide won't start at all
- bobby9621 Street Glide Special Build "Blue"
- 2018 sgs lowering/shock help
- What do you do when......
- Upgrade already????
- shake, rattle and rolll
- Is my bike "Normal"?
- hammock seat
- Harley premium rear shocks
- Harley Touring Owners' Favorite Mods and Upgrades
- Drive sprocket wear?
- Noise Mystery. Rapid Tink Tink Tink Tink
- Brake Pedal Relocation
- Horn dilemna
- 2003 FLHTCUI radio issue
- best easy pull clutch kit? 2012 Ultra Classic
- Bad clacking Stock Compensator fix 07-10
- Ram Mount Customer Service.
- Samson Cholos
- Burly Kit
- Finally made a seat decision
- Bone conductive headphones with mike?
- Crash bar lighting
- GPS Issue - Looking for help / input
- Should I.... 2011 Electra Glide Ultra Limited 46k miles $9,999
- Why Are 99-01 Twim Cam Parts Hard To Find?
- Non Air Suspension Recommendations for 26" Wheel
- Tour pack connector protectors
- Bar help
- 50,000 miles and I have questions
- Shock Help
- Does anybody actually wash their stock air filter element?
- Need crankcase vent kit
- best replacement clutch cable? 2012 Ultra, do not want to lube if possible
- thinking of moving to a touring bike.
- I am looking for the torque specs for the rear wheel and rotor and hub for a 2016 street glide. Also, should I use loctite or not?
- Question on Ohlins #3-#3
- P2127, 2138, 1510 Codes. Stumped
- What part is this?
- Temp guage
- Road King special front wheel question.
- 30T front pulley how to do it properly
- passing light help on flhx
- Left hand grip removal and re-Install
- Long Ride Shield
- Saddlebag hinge bolts came out - lid almost blew off
- Newb with a Street Glide S 5000 mile service cost?
- Which are Quieter?
- CFR + Rinehart dual's TO LOUD need advice
- Odd Exhaust chug at idle - Road King
- 'Wanting to change handlebars' question
- 2014 Road King FatCat
- How much did you pay for True-Track
- POTUS today
- We just purchased the Sena 20s evo with a WIM. Quality is not good.
- Handlebars
- he same setup as me?Bassani Greg lutzka 2 into one and a Arlen ness monster sucker.
- Rear Shocks 2016 CVO
- Boom audio FM channels are not going to be tuned
- Electrical issue
- 2piece solo seat shopping. Please offer your input.....
- Bike took a dump today. 3 codes.
- Air ride
- 2001 Road King Won't Start / Troubling Idling
- New mutazu mufflers
- Engineered a phone mount for a Road Glide
- 2002 Road King Stock Handlebar Position
- For those who were following the build
- 2011 flhtk sputtering after cam, pushrod, header installed
- 2011 Flhtk sputtering after new cams, headers, pipes, air cleaner
- pouch windshield bag Ultra Limited Low
- New to the forum, NEED HELP
- move electra glide handle bars
- 2017 Road glide ultra
- New member
- New Street Glide limped at the entrance to Devil's Tower during Sturgis rally
- Do Black Bikes Matter?
- Electrical Gremlin on 07 SG
- Regaring EITMS
- best inner primary bearing replacement? & oil seal inner shifter shaft (behind primary)
- Driving light for road glide
- This Ultra just followed me home.
- tires for HD agitator rims
- Auxiliary Fairing Switches
- Throttle By Wire After Market
- Chopped Tour Pack Organizer.
- Air Temperature Gauge Size? Want to replace with AFR gauge
- Fork oil amount 2014 Street Glide
- Opinions and reviews on the FLH oil coolers.
- Boom Box screen cover? Anyone had this happen?
- Bigger
- Rineharts Bit too loud
- Moved out of a dyna and into this peach...
- louder pipes
- Anybody Using Foglights?
- DIY Tire Mounting
- Loose shift lever
- side stand ..aka jiffy stand
- Rear brake torque specs
- amperage
- Seat with drivers back rest
- Experiences Ordering a Bike from HD Dealer with Wheel Upgrades?
- Cooling Fan Kit Worth it for someone in Seattle?
- When to walk away from a bike
- High temp and Eng light ov 2016 FLHTK
- RKC Cover
- Should I Road King classic 54k miles...
- leaking gas when i shut it off
- Where to get info on my bike
- Differences in Ultra Limited Models
- Question Re: Polyurethane Handlebar Bushing for my 2000 Road Kings
- Air filter question
- How can I diagnose frame and forks after a crash?
- Mustang v Corbin v Harley seats
- Intake cough
- How many of you'se guy's.....
- oem or ???
- Dash light go on after riding in the rain
- Back in the saddle again ( or, getting old sucks)
- Fuel spraying inside gas tank
- Trying to locate 5v sensor ground and power at ecm plug
- Skips a beat
- Bluetooth add on
- M8 Stage IV "w /Warranty" Cam options?
- Voltage Regulator...Again?
- which Vance & Hines slip-ons?
- After market seats for Electra Glide
- 04 Road King Custom, front turn signal flashes but won't stay on as running light
- Will Aquatic to replace HK support the headset plugged into console
- polished rotors from auction site any good?
- rotors n pads
- 2018 Road Glide Special is Coming Home!
- Intermittenly cuts off 2006 ROAD KING
- Front brake light switch
- Weird humming when turning?
- Fp3
- Batwing ; paint it or not?
- Engine noise issue
- Thoughts on Longblock program
- ignition switch key
- Extended Saddlebags with 4.5" pipes?
- No longer available?
- Buzzing front brakes
- What are the real Advantages of a removable touring trunk pack
- Anyone try a Fuel Moto E series on a D&D Fatcat?
- Harley multi-tool question (little tool came w/ the bike)
- Stumped
- Newer Calipers on an 03 Road King
- 05’ 88 engine blown. 103 longblock with 5 speed?
- 2010 Road Glide no fire
- 2016 road glide rough idle
- New member, looking for help
- Lid organizers
- Looking for Clarks Custom Windshields
- Windshield Choice For ‘18 Road Glide Ultra
- Wax on, oh shit what a mess it made
- SE Compensator
- I ripped off the a baggage strap on my leather bag on my 2002 RK and need help finding a replacement
- ebay tour packs
- Wheel bearing question
- Anti-lock brakes
- 2002 Electra glide handlebars
- Tall boy seat reviews?
- Hi from New York
- M8 oil migration...
- AIr Shocks only one sidetaking air
- timing at -5
- From rider to Solo
- Which brand of headers
- rear brake pad pin
- Backrest for Brawler solo seat?
- 2012 Ultra - 50k maintenance- what to check/replace that ISN'T in the manual
- Buying first Harley ,can anyone help?
- Powder Coating Monster Squared tips?
- 2002 Road King Police Edition
- My new wheels and tires, just wanted to share.
- Has anyone done any engine mods to the new 117ci CVO motor.
- 09 Electra Glide Fuel Pump issues
- HD Fan assisted oil cooler kit for M8 engines
- wheel bearing failure and pressure washing link?
- Twin cool fans and pump not operating
- add security to 08 electra?
- 06 Electra Glide Codes
- TPMS for HD touring bikes? Anyone ave one?
- New Engine Running Hot
- If you unhook your ECM for a couple minutes, do you lose the tune?
- Wheel bearing paranoia
- Bluetooth headsets? Im confused
- Dyno tuning question
- Front Fender Tip Light
- Adams wax products
- Clutch housing
- 2011 HD limited .... .
- Police Seat; questions about fitment
- Windshield Lock
- 2017-18 Road Glide Special bars on Road King Special
- FP3 can't register new ECM.
- Heat shields
- dyno tune 2005 road king
- No power
- Trailering-strapping down a Road king
- 2013 Electra Glide vibration
- Headlight help
- electrical schematic 2011 road king
- Options for front fender replacement
- What model of V&H muff do I have?
- Tour pack relocation
- 2013 streetglide wiring run/turn/brake
- Which backrest?
- Clutch adjustment question
- Detachable tour pack vibration
- New member
- Can’t get smart siren to reactivate
- JW Speaker headlamp?
- Heat shields
- Anyone know about crosstalk on o2 sensor's?
- Tour pack squeak...
- Road king Sundowner seat...any good?
- Right leg heat
- Clutch adjustment/takeup issue
- Toque settings
- Rinehart hi flow baffles vs. stock baffles
- 2010 FLHTK fuel moto 107 clutch slip
- 8" and 10" Monkey Bars on Street Glide
- Brake pads rubbing
- Need recommendation for cellphone mount
