View Full Version : Touring Models
- Started out as a leisurely trip
- Run/turn LEDs
- cvo 110ci is ill
- Size of L rear spacer - SOON W/B Great!!!!
- Rear tire recommendations for heavy bikes - Shinko 999?
- H/D Security system
- 01 Road King front motor mount
- Bolts/screws for touring models?
- Jiffy stand rub on primary case
- 09-13 Saddlebag guard rails on an02
- 08 Road King loose trim ring.
- Road King Lower Fairing Question
- Road Glide Question
- New Highway King Owner here-
- Boom GTS Rain Issue
- Front brake caliper rebuild, need torque ratings for all bolts and pad pin
- laid it down....
- Old Member new problems - RKS with fishtails and 21"
- Bad Battery
- Fairing cover
- Seat help
- Tappet Covers
- Need service on a road trip / Tulsa or OKC?
- True Track install
- Wrap Fenders
- 18" RK wheels on a Electra Glide?
- Accessory Fuse Blowing!!!
- Tank Console Stud Size???
- Low on oil
- Whim and intercom volume
- 02 Road King Transformation
- No power to anything
- 2007 electra glide charging issue
- 2020 Street glide Security System
- Fuel Moto+ S&S heads
- Having issues with external breather bolts breaking.
- Will not complete import into GTS navigation
- 04 road king help
- Side of the road
- fuel pump priming question...
- FLHP 2012 - Alarm/sirene when motor starts w/o TSSM
- Handlebars
- Bike shutting off in right leaning turns.
- Bars for road glide st
- Older Road kings
- 14K Mile Checks
- Frozen Wheel Bearings??
- You have got to be freaking kidding me
- 2002 Ultra Electrical problems
- Installed thermos holder a bit differently
- 2010-2013 Street Glide Tour Pak Lights
- Looking for a seat
- 2015 CVO Street Glide Heated Grips
- 08 RK, Baffling Tick Front Cylinder
- Not a very good M/C mechanic!
- Oh boy! Wiring the handlebar switches...
- Newbie here
- front wheel alignment
- Weird wiring issue. Front turn signals on.
- 2023 Icon series King of the Highway
- Engine cut off while slowing down (getting worse)
- CVO Style Fender Filler/Fascia for CVO Taillights on RKS??
- 2009 ultra classic 2 piece clutch cable adjustment
- How to get DC power to the bags without drilling?
- 19’ RG Special High Rev when starting
- Head pipe 2011 street glide
- Anyone run Pirelli tires on their bike?.,,,
- 2007 Road Glide Stalling / bogging
- Can you have too much fuel pressure?
- 07 Street Glide starting problems
- Vibration since putting 21in front tire
- HD M8 Recommended shift points = severe lugging? Need Advice PLS
- Branson Motor Officer competition this past week
- Rocker box gasket leak- How bad is this ?
- FLHTK Gas Tank Cover
- new seat. LePera Outcast
- Add on cooling fans
- centering a dash console emblem on 2010 Streetglide
- Repair manual search?
- Heated Grip Problem
- 2018 Ultra limited quick detach kit
- Good seats for Ultra Classic that aren’t $500+
- Bike Week in NH - Watch Out For... Kayaks????
- Question for twin cooled model
- Higher handle bars
- 06' Ultra Classic new audio/radio
- 01 Road King police
- 2007 Road King classic cruise control issue
- Center stand Worth It?
- Swingarm movement
- Vibration?
- How dificult is changing out tins for another color
- HogWorkz King Tourpack any good?
- Looking at a 2010 Road Glide
- Corbin Seat Backrest
- I got a problem :( just before trip
- 2014 ultra glide GPS problem (6.5" GTS)
- Road King Classic best years ?
- In-n-out Radio
- Good Cam for all around performance
- Cool flow fan
- Speedo on Police Road King flashing 12.00!
- Evo vs s&s
- Extended foot controls
- Sump after 43K miles????
- Does raised bars help with back and shoulder pain
- Heated grips
- Need help with this code
- Seat Question
- Rear Enforcer Pre-14
- Best touch screen protector for 2015 SG?
- Starter question
- EU street legal slip-on for SG ST FLHXST
- ‘01 RK air shocks
- Turn signal and Neutral indicators, 2014 Road King
- Passing lamps 2011 FLHTK
- 2007 road king. Best $1,000 performance?
- Wheel chock issue
- new member question for Road King
- New Platform Modification Ideas
- Wheel Swap
- Frame Mounted Highway Pegs
- New CVO Road Glide and Street Glide Launch Film
- Avoided what could have been an accident today
- Looking for a factory hydraulic clutch lever - ‘20 road glide
- Pain in the Shoulder
- Back Surgery is taking me out of the saddle AGAIN
- Drilling out stock mufflers
- 2021RG standard heel shift and speakers
- Batwing on 2003 Road King CVO
- Right angle metal valve stem???
- Production numbers: 2022 Road Glide Limited
- Upgrade
- Petcock
- Time for tires soon
- 03 Road King tour Pack docking hardware not square.
- 2009 Electric Glide 96ci - Odd Whine
- Road King 2002 FLHRCI electrical connectors circuit braker question
- Security light on while riding?
- CVO mufflers
- 2013 Ultra - Radio Issue
- Harley FLHTK VS BMW GS1200
- Question on years for compatable compensators.
- 07 Ultra Tail Light Fuse Blows with Passenger or Luggage
- Fairing mounts.
- Issues after cam upgrade
- Limp mode & cruise
- Engine misfiring when getting wet
- Oh Crap! What did I just do?
- Part Interchangeability
- Getting excited,my 2023 Road King came in yesterday
- ‘01 RK front Motor mount replacement
- 2017 Ultra Seat - 2" back 1" down?
- Bare Knuckle Axle Spacer Install/ Review
- Right signal doesn't work
- 1993 electraglide
- Engine guard
- Break Light Recall
- Active air ride? Anyone see this before
- Tire Balance.
- 2006 street glide rear docking hardware too flimsy
- Performance upgrade
- Well, it happened. My ABS light is on constant and the ABS is definitely not working
- Headlight
- Raising handlebars
- 2022 FLHTK stage 2 questions
- 2021 ultra- slow start crank
- HELP! EFI Throttle partially stuck open
- Rolling out to Skyline Drive from Philly
- Adding a Road Glide to the stable
- Zumo 660
- Valve noise and oil leak from valve cover
- burly brand MX style floorboards
- BCM Error code b2151h
- Need measurement for the Kraus Raptor Pullback Plate
- 2013 SG randomly shuts off
- Comfort seat
- Fuel injector help
- '08 Ultra Classic Radio Cable
- Engine missing out after warmed up
- Dresser Duals
- 2007 Road King
- Belt Tension Confusion - 2020 RG
- Cutting the air filter
- Road King gas tank storage pouch ideas?
- Rinehart True Duels..Is A Power Commander Required?
- Melted Battery Terminals
- Road Zeppelin Seat Repairs
- Left controls work but cruise+volume dont after a wash
- Packing the bike for a trip
- Oil change dilemma
- HD Longblock 110 for 09 Ultra 96
- Find an intake question.
- High Idle after awhile, Help!
- Sick of the same old dashboard?
- 3.5 or 5.5" Rear Wheel and Tire?
- Led lights on bike for extra lighting
- Primary Oil Level; small change, big difference
- Sticky Grips
- Sportster/dyna shocks on 18 SG
- Sportster shocks on 18 SG
- Rushmore shocks on a pre Rushmore
- 2015 CVO temp light, tried everything
- Wheel
- Changing mirror on about a 2015 street glide
- A Color for Any Occassion Advanblack Full Body Color Swap
- Best seat cushion to prevent numb ass
- Le Pera Daytona 2 Up Touring Seat
- Shocks
- Saddlemen Road Sofa LS seat
- 2000 FLHTC vs Late Model Touring
- From a Road King to ??
- Brake rotor suggestions - Street Glide?
- 2019 Electra Glide Standard fuel gauge behavior -- is this "normal"?
- Bike clicks then starts slow
- tips of my exhausts
- Switch, Neutral indicator
- Road King Death knell?
- Cool "Shark" Tank Badge
- Connector ID?
- If your seat doesn't feel comfortable
- 2002 FLHRC Check engine light goes on after startup
- Life of a Twin Cam 88 and 96
- Suggestions on adding Bluetooth to 2012 SG?
- 2017 Road Glide Ultra
- Runnability issues
- Can an Ultra Limited Low (FLHTKL) be “de-lowed”?
- 2021 RGL not tracking straight
- '12 Road King - 4 point seat mount bolt size
- F#@king harley davidson!
- Please help!? Can't find bars that fit my bike...
- Turn signal not working
- New Bars for the Glide
- New Member
- Custom Dynamics Customer Service
- Passengers backrest relocation
- 2013 ultra classic
- 2002 FLHRC-I Fuel filter replacement
- The amber trailing in the direction of turn is just bad ass!
- Set default startup page - boom box gts
- Fox suspension?
- 2014 streetglide not starting
- IF I were to upgrade from my '07 FLHTCU...
- Screen Protectors
- Header Question
- Push button start
- KhromeWerks Louvered vs Performance baffles
- Oil check
- Cam Chain Tensioners
- Problem with mode select/scan switch on '03 FLHTCU
