View Full Version : Touring Models
- Dunlop 408
- Cleaning black cases???
- Speaker baffles or Dynamat whats the best ?
- Only 9500 miles on rear tire
- Stereo Gurus...
- Trailer Hitches
- 87 Octane
- Retune after high flo baffles???????
- Bittersweet change to Touring.....
- Black windshield trim
- Anyone put shock absorbers on single axle trailer?
- Who knows abouit the Ocala Loop at Daytona?
- Saddlebag guards missing part
- Clackity clack valve noise between shifts?
- Do I need a load equalizer?
- changing tires
- Painting clutch bracket & master cylinder
- 1999 Electra Glide Classic - buying question
- Solid numbers ?
- 125 Chubbys Installed
- cheapest riders backrest ever
- Unfrickinbelievable
- My new C&C Seat
- Where does this black dust come from?
- High performance air cleaner question
- Riders Backrest on eBay , request for buyers experience
- Handlebar help please!!
- Driver floorboard question
- led lights
- security problem on flhx?
- I'm stumped!
- Sinister Industries RK Drag Bars
- Leather saddlebag hinge spring clips
- Best Oil Filter
- Joined the "club" that none of us want to this morning.
- Fitted Liners For CVO Hardbag Question
- Winter Project finally done
- does the rick doss saddle bag guard elminator come in a pair or seperate?
- Shout out to High Octane Harley
- FINISH "For Now" RKC 07
- ACR Harness 0n 2007 Ultra
- Jamie warned me....I didnt listen, need a dyno!!!
- MGS true duals install and evaluation
- Bike week add ons
- Shoveled the driveway and went for a ride!
- Baddest Bagger In Daytona
- D&D Fat Cat on '13 RG
- Need advice on service
- Help!
- Looking for a comfortable 2up seat for my 1996 Road King
- Shocks PSI 12 SG
- fl-vieds, sound change?
- Shock performance with lightweight rider
- Mini Beast 5 air horn installation
- Heated grips don't fit
- Sta-Bo ED 16 Swingarm Bearings
- looking for harley part
- average MPG
- switching bars on the king
- Rinehart 2 into 1
- Heading into the inner primary
- Want some advise on what to look for... looking at an '01 SE Road Glide
- 2 up (standard seat) on RKP?
- brake switch in from brake
- Installed PYO 10" bars on my 09 FLHT
- What kinda damage?please help?
- Video of my Hid headlight and my led turn signals.
- Radio Doesn't Tune
- ABS vs NON-ABS... WHY??
- Need K&N oil filters
- C&C solo width??? To Narrow???
- new to the bagger family
- AMP question
- Cruise control problem
- Warning for V&H Fuel pak users
- Radio pre-sets not working
- Back in the saddle
- First Ride of The Season!
- HD Tall Boy vs LePera Maverick Daddy Long Legs
- LePera Maverick Daddy Long Legs Seat
- HD Tall Boy Seat
- hf lift coupon
- Truck-Lite PH6 vs. PH7 4 ½ Spot lamps – Which one to buy?
- lets see those yaffe monkey bar pics
- Checked for codes
- What model V&H pipes are these?
- Loose Transmission Case Bolts
- Long Ride Shields-The Ultra 6"//Perfect for me
- Is This A Normal Amount of Metal Shavings?
- THANKS Captian Itch / Isabel for custom fender bib.
- ditch my front fairing? RK setup, pics inside
- How much preload on Fuelmoto ADJ Push Rods???
- need help with swing test for steering bearing
- Can someone tell me where to find this part
- Just back from Bike Week Daytona
- 1.25" Chrome Clamp for new bars?
- Smping on newer bikes, oil pump?
- Removable tour pack 2012 ultra limited
- Who Has Sumax Extended Bags?
- Grab Rail Handle - yes or no?
- Dakota Digital oil temp install
- Transmission/Swingarm mount
- MGS Strikes again!! A+++
- Installed an Iron Cross Ipod interface, and oil temp gauge
- Extended bags with stock fender. Solutions?
- Do I Need a Billet cam plate?
- SG new windshield time
- Nut-less. Need help!!
- Road King Police Tachometer
- BUS ER Code 2012 Street Glide FLHX
- Any tips stock brake line routing bat wing apes ABS?
- A little added flame work
- Hopefully a simple stupid question
- New rims and tires.
- 2012 Ultraglide runs rich
- Speaker Baffles ??? Yes or No >>
- oil temp gauge question
- tour pak detach kit
- A good brand tire changer for the DIY person
- Time for new tires. But...
- Should have listened to everyone on the forum
- O2 Sensor Question
- need help
- PoweR commander maps
- Not identical twins...new bike
- 2012 Wheel on 2006
- H-D iPod adapter interference
- 2013 stock rims, are tires same for agitator rims?
- My First Harley!
- Molex connector pin
- D&D Boss 2-1
- need some help with parts
- Soft Lowers on ebay?
- 2010 Street Glide Swing Arm Removal
- GPS mounting options - anyone try these?
- Stage 4
- rear turn signal bar width difference?
- lowers???
- Bar Swap - What Am I Forgetting
- What to name her
- another fluids question
- Engine miss FLHRCI
- Cigarette Lighter
- MU (140) wide on rear of 99 Touring
- Doing CB install in phases on a 2012 SG.
- Model year differences
- Won't start aftering cam change
- Slipping in 5th after Burly Lite easy clutch install
- Which Wax
- Michelin Commander II 130/70B18 Front - When!!?!!
- New Ultra Delivered but ???
- 2012/13 FLHTK check transmission oil ??
- Slip ons-- easy to install ?
- Guess what showed up in the mail?
- 103 mtr noise
- Com problems
- All set to get my baby out of storage.
- Torque wrench question
- Mouse Pads Behind Speakers In Fairing -- It Really Works
- Cam Change With Screamin Eagle Hybrid Cam Plate
- Momentary on rocker switch
- Has anyone built a passenger pillion?
- Older style wheel bearings
- 2012 ultra true duals
- Need help from anyone with an 84 FLHT or FLHTC
- Too rich
- Buying question
- Legends or Arnott Air Suspension 12 or 13 inch ???
- difference in tire pressure cold/hot
- Handlebar Help Please
- Mounting iPod connector under the radio
- Help: Put bike back together, started fine, but no throttle and 17 different codes..?
- matching paint on custom paint set
- Loose Fuse Connection
- Bub boom can slip ons
- Screamin Eagle Street Tuner
- Diagnostic port
- 96 Road King Rear Axle Block adjuster
- luggage rack
- anyone have a clearview they look through?
- Mustang Seat question
- Progressive Monotube on FLHTCU
- seat suggestion
- crashbar running lamps?
- Airlite Chaps
- Fuel moto micro tuner help?
- Zippers cam chain tensioners
- Handlebar swap DIY?
- Batwing apes aluminum bushings in box with bars or use urethane?
- ABS, Light illuminated, DTC No Codes, ABS Working
- 2007 - 2012 PPG Paint cCodes
- 110th Anniversary Road King
- Calling all 110th Anniversary Road King's
- Tyre trouble
- Will this ck fit with my sundowner 2 up seat?
- Stock Headers?
- Anticipation
- Hawg Wired excellent customer service
- Boom Street Glide Kit - Install
- 21 x18 raise bike?
- This is my winter mod .....
- Trade in values for my king!!
- 2012 Street Glide Tire Recommendations
- sert tuner cables
- 12 FLHP Rear Tire Change Recommendation
- Progressive Monotubes -1" or Stock Height?
- Indy Between Jax and Orlando
- Hard Bag demensions question
- Street Glide - LED Headlight - Custom Dynamics LED's
- 2012 FLHX Fluids
- freedom performance union
- Aftermarket Wheels '06 Street Glide FLHX
- What windshield do you use with your Apes?
- Replacing A RevPerformance EMS tuner with a Powervison
- Bought a 2013
- ABS Lower Brake Line
- Custom Heat Shields
- WardsPartWerks FCS cooling fan install with Howards Hog Horns
- 2008 Brake lever on 2006 Street Glide
- What to do...
- Soundstream amp install
- Trueing the Harley crankshaft 07 and up
- V&H Power Duals ?
- New from NC
- Anyone using the Kuryakin Rider's Backrest?
- What Would You Do
- Cobra Slip on's?
- Discounts, free shipping
- Primary Chain Tensioner - what is too tight?
- Just got new exhaust today from American Custom
- Minor but annoying PIA - shock air pump
- Is this something I should be worried about?
- 2008 stock headers & mufflers
- Thinking about getting a Road King
- Exhuast
- Hales is ending on line ordering
- 2007 StreetGlide with Rinehart 2 into 1
- tour pak tbaggs bra
- Replacing my 2009 RK rear fender with a 2009 SG rear fender
- Streetglide TGS 32310-08 Wiring
- Silicone before sliding slip-ons on???
- American Custom???
- Yaffe MBB & Mirrors?
- buying an engine on ebay - remember this
- What Now? advice needed
- Black Floating Rotors
- Mounting flags on a Road King Classic with tourpack
- Khrome Werks 12" 1¼” Fat Ape Bagger Handlebars, Anybody Use Them?
