View Full Version : Touring Models
- Ricor Intiminators vs Monotubes
- 08 Road king fork oil change,with vacuum!
- Another question concerning EITMS
- Check the chrome on the rear wheel of your Ultra Limited.
- Adding abs
- A 1/2 inch makes a heck of a difference
- Educate me on half helmet headsets
- Friday 13th Port Dover, Canada, PD13.com
- Anyone with SE 203's cams in TC88, MPG question
- Ignition Switch Pulled Off???
- odometer problems
- what can i expect to pay...
- Dropping a Road King
- Harley Davidson Smart Security System
- Ultra windshield
- This has to be the worst part of owning a Harley
- valve chatter - push rods are bent after 11K miles
- Concerned with overheat
- Klock Werks 180mm Wide Tire Kit for Road King - Anyone done it?
- Long Ride Shield (LRS) Install – Review
- Clutch Cable routing on 09 SG
- Tires
- Defective Battery
- Don't laugh
- Bell 500 Helmet
- Looking for dyno guy
- new rider on a Road King, Day 1
- Stage 1 Decision made
- fueling 525 cam in 2005 RK
- Arkansas Road Trip
- High Idle Randomly on Highway
- No helmets needed
- Install CC on 06 SG
- Battery Dimension??
- Electrical help please....?
- Another transmission bearing failure
- Apes on a Road King
- 2011 FLHTK engine concerns-Need advise/help
- Anyone know off-hand the size of the clutch lock nut?
- Installed a couple of things...
- My New 2012! Scooter
- Trinity MT3 Motorcyce Trailer, anyone have one
- New 2012 FLHRC
- Anybody with Alloy Art turns on a FLHX please chime in
- FLHTK New Clutch
- HELP front drop in lowering kit 'rides to hard'
- Loud Exhaust/performance advice?
- Crashed on 3/29/12, last Sat. 4/07/12 got my new bike 775 miles out, rode it home!
- Just saved $4500.00...
- Red Key Light ON ???
- Bad buffetting
- Rinehart Exhaust
- Road King Fork oil
- value accessories
- FLH saddle bag rail license plate mount?
- Replaced clutch cable-- what did I do? Or what am I supposed to do?
- 2012 SG - should idle be steady?
- Powdercoating in the Seattle area?
- Landers Toad Suck Harley Davidson customer service !!!
- Don't EVER think your done- especially if you read this forum
- Do you change oil on long road trips?
- 2007 Road King valet mode (alarm)
- Street Glide Passenger Footpeg placement issue
- Shiney Stuff
- 4'Ohm 6.5" Speaker in the CVO Lower fairing
- New Paint
- EZ UP Center Stand
- Ohlins 3-3's installed today.
- 96 ci in the 2009 models
- 2010 SG Radio
- How to troubleshoot starter??
- Forums can be a scary place.
- 08 FLXH RC Components Pulley HELP!
- Tying a bike down on trailer?
- forum vendors who sell engine parts - do you have this in stock?
- drivers backrest
- My ass is in heaven
- Best place to get a J&M set up?
- H-D Adjustable Air Deflectors
- Shock Upgrade on an SG
- Thundermax TBW tuning advice
- Communication is the Key
- reliable on line parts ordering - who do you use
- Changing Dot 4 to 5?
- Grills for Polk MM651's???
- Ultra Handlebars
- headset problem
- Any reason a 2012 RKC same size rear shock wouldn't fit my 2000 RKC???
- HD Visor Style Trim Ring & PHASE 7 (pics)
- 911 Tribute (343)
- 1999 Factory Mods/Improvements
- A Fork Question
- Mustang Low Down Seat 79704
- Progressive Monotube Cartridge Installation
- Couple pics of white lightning
- Pics of SG or RG with a FAT front tire?
- SE Super Tuner AND TTS
- 2005 Road King help....(oil)
- 18x4.25 vs 18x3.5 Rear Wheel
- Question About HD Premium Adjustable Shocks
- When to do a stage 1?
- ultra classic seat for tall guy 6'2?
- Safe to ride to tuner?
- How long can you run the stereo without starting bike?
- UClear Communication Systems
- First time buying shocks....any reason to avoid these....
- Crash bar options
- 12" Torch Industries Apes on 2012 Street Glide (pics)
- Jim's introduces new Forceflow Cyl Head Cooler
- Rat Road King
- Knee Arthroscopy ?
- Monkey bagger bar install questions
- Rear shock leaking oil...now what?
- Saddlebag crashbars interchange between '11 & '03?
- Roadking raise
- Badlander ?
- Iron Glass Design
- Broken saddlebag lid post
- Clamping brake line
- Painted inner fairing
- Hidden antenna
- what is the most waterproof windshield bag?
- Is there a TRICK to Cam Tensioner Replacement??
- Drilling for inner fairing mirrors
- Need Help With C&C Seat
- H.O.G. or AAA
- se pro super tuner problems
- will 17" laptop fit in tour pac?
- gotta ask this exhaust question
- Good bye Sporty - Hello Road King
- Arlen Ness "Modular" bagger apes
- Engine Noise coming through Radio Speakers
- Whoops!
- Power Vision on stock bike
- Rocker Breather
- connector 107B air temp
- Anyone know what brand receiver hitch this is?
- 53803-06 Hardware kit 07 roadking
- Pulled the trigger on cam plate and hi flow pump
- Qucik A/C Question - Upgrade While Keeping Stock Look?
- Stopped for gas, then won't start
- Harley Radio
- Speaker and amp install how to
- UCEG vs RK vibration
- 2011 SG Solid rear wheel fitment ???
- Passenger grab rails + Adj rider backrest
- tender killed batterys?
- tour pak lights
- LED conversion done!
- Best Way to Attach Multiple Accessories (Stereo, Tender, 12V Port, etc.) to Battery?
- 2007 ultra
- cam Tensioner Dilemma, Please Advise my Spending...
- Primary Whining and now so am I
- 07 Ultra Compensator sprocket Noise
- New look for the Road King
- Passenger floorboards- how to hide the holes when you remove them?
- Should you replace a working Stator before it goes out??
- HD Smart Security System
- 11" Progressive 412's on Road King
- Bought a 2004 FLHTCUI yesterday!
- Fitted saddlebag liner
- Long Day
- Front brake line fittings for single rotor set up
- Fulmer
- Need some opinions
- SG pricing
- handles on Road Glide dash compartments
- Empire covers Titan Rain Cover
- Break Time
- dog on the hog
- AVC adjustment on '01 RadioSound radio
- Enjoying a full face helmet w/ bluetooth
- 06 FLHRI air filter question
- Braided Brake Lines on StreetGlide
- tour pak removal
- Interpreting Dyno Numbers
- 09 RG Upgrades complete!
- Arnott air ride
- lost my fob and key
- HD LED Headlight or Aux Lights
- Install cruise on 08 flhx
- advise/options - adding forward top engine stabilizer link
- better double-side velcro/tape
- 2007 street glide alarm help
- Most comfortable seat and convienient thing i have ever seen!!
- Vance & Hines Fuel pak mods
- Seat that helps tail bone pain?
- Wow are these wheels fun to clean!
- New Ride
- Best headlight upgrade for '10 SG?
- Cleaning your WWW Tires....easily
- Brake job screwed up
- Got my bars on!! Pics
- Got my new custom C&C Seat....awesome!
- what kind of dyno number should i expect?
- Need some opinions on matching highway pegs
- Michelin Commander II Tires
- Setting up my 2000 FXDX #2
- Speaker Problem 2000 UC
- 07 road king a little sick.
- Road King Face and butt lift!
- RoadGlide Windshield Trim
- HF wheel chock
- Int/CB question - Stock radio
- Help with 18" tires
- Road king handlebar cover
- Thinking about getting a 2012 Street Glide...
- Polk MM651 for 140 @ Crutchfield...
- 2102 EGUL Detach Kit - Relocate License Plate
- Fairing Mirror Location
- The most wonderful wife in the world
- Doc gave me the all clear to ride!!!
- How do I know if I have an exhaust leak on my FLHTK
- Sardine oil
- Center Jack
- Your input on exhaust, please
- compensator ?
- Helmet Issue
- Bleeding antilock brakes
- Street Glide with black and chrome wheels!!
- 2011 UG Navigation Help
- oil cooler for electra glide
- Scratched Paint - HELP!
- Pillow seat 51102-01A -- Road King
- New scoot
- 3pouch windshield bag for the RG?
- Grip Adhesive
- Another Lighting Question
- Thanks to Iron Cross Audio
- Audio compatiblity w/hand controls
- anybody with fuel moto by dyno jet, rinehart slip ons, and stage 1 a/c??
- Adding to the Batwing air deflector debate......
- 2010 and up with non wideband 02's
- 2009 on 2011 Ultra Pipes Question
- Kuryakyn Tour-pak relocator?
- Wild Pig slipon sound improvements
- Rant on Harley (pissed)
- Temporarily off the bike
- Can someone show me a black SG w/...
- finshed the front end
- Dennis Kirk for tires???
- headlight assembly question
- 10" Windsplitter
- Road King Conversion
- Tour Pak Light - Just Had An Idea
- Are 09 exhaust shields same as later models?
- Custom Dynamics "Dynamic Ringz"
- Spark Plug Wires
- Free mod - removed plastic oil cooler cover, '12 RKC
- Clutch VPC
