View Full Version : Touring Models
- Can 2014 & Newer Bags Be Made to Fit 2013 & Older?
- What seat to use on stretched fender?
- Water loss on ultra limit
- Will windshields from the 96-13 fairings work on the 14's and up?
- Electra Glo Stealth LEDs fitted
- Expected Discount on 2018
- charging problems
- New chopped engine guard
- Has there been any changes to the touring frame since 2009?
- New 17 RGs
- End Cap on 2010 FLHTK handlebar grips
- Crash
- Cam chain tensioners
- Temperature sensor
- Tie downs on a lift
- 2008 Ultra Classic Electraglide Fairing removal
- Clutch lever effort with heavier spring
- How to eliminate tri bar light on SG
- Tour-Pak Accent rail kit - how to remove hole plug from upper right accent rail mounting location on Tour-Pak for a model without CB?
- 3rd Low Beam In 77,000. Is this normal?
- Torn between a 2013 RG CVO or 2017 SG
- Boom Audio Speakers
- Fluid Transfer on older.....
- RG vs EG
- Saddlemen Solo Differences
- Primary case oil change
- 2006 flhtcui
- Bike seems a little "off"
- Re installing forks?
- Road King won’t start...help please
- Earplugs?
- How To Raise Comp Ratio of 117 Kit Motor
- Harder Paint / Clear Coat ???
- New Tach for 2003 RKC
- Dyna to Road King
- Engine Upgrade
- A very interesting problem with Radio volume
- Fat spoke rims ?
- 2013 flhr does it have aq horn relay
- Progressive Drop In front shocks on Street Glide
- Finally a Harley Owner. Paid off.
- No stupid questions you say? Well try this.
- 99 road king cam sensor issue.
- Road king vs Ultra
- Mismatched tire tread.
- Road King Classic vs Deluxe
- Bad year for tires
- Newbie w/questions
- oil filter
- Clutch Cable Adjustment Problem
- BAL (1 or 2) on a 2010 Ultra
- Two new Ultra Limiteds this Saturday
- 1995 Road King Help!!
- Repainting Lower Fairings
- Poor front brake performance when wet...non-OEM pads/rotors
- spark plugs
- thread size and pitch for 06 road king 88
- Rear shocks
- Stupid Question?
- Gear ratio 2017 streetglide
- US Flag on Tour Pack rack
- 08 FLHTCU wheel speed sensors
- Razor tour pack retro fit
- Best $160 I ever spent on my bikes
- Is it really worth it?
- deutsch wire crimpers
- Best Passenger Seat for 04 Road Glide
- Power only - radio dongle
- Rear turn signal bar loose
- Coolant issue - advice sought
- Interchangeable parts flhtk
- 10,000 mile PM
- slip on exhuast
- This is why I retired in the desert.
- 2017 Road King - next upgrades.
- Lower shocks 2017 RK - what a difference!!
- 07 glide 100k overhaul
- Best sounding cams
- Electra glide sport screamin' eagle keihin non cv carb throttle cables fitment
- 6,500 Km and still going strong - bulletproof 2014 FLHTK
- Strange noise in primary...
- Bearing noise when riding
- Neutral Switch Test
- Gas light staying on and stuttering engine.
- drive belt question
- tour pack quick connect
- TP Sensor replacement
- Mixing Tire Brands
- Billet aluminum Wheel spacers
- 07 road king 525 cams
- Options question
- Well I Get To Do It Again, Dangit
- Problems with the ABS, Radio, and the Stage II
- Road King Classic rear fender upgrade
- Wife rode a FLHXXX, and now....
- Heated grips not staying on
- 2017 Road King Special
- 2015 FLHTCU exhaust
- Would you consider a 2017 Demo
- Tiny Spring - What is it?
- Stage III class
- 2015 Road King lower forks change out
- my idle on my 1998 sup
- stripped Oil Pan
- 1999 fatboy inner primary
- Bought a new Road King.
- Front wheel Bearings
- Road King Lamp Visors
- License plate holder
- Oil leaking around filter .
- firebrand mufflers
- 2015 road glide
- Fuses blowing
- Help Identifying Exhaust
- Slipons
- Excessive cranking no start
- Touring models and traffic
- Installed Illuminated Passenger Floorboard Covers and can't find the $%£@ing accessory wire
- Harley in trouble?
- 2010 Road King Police Service Manual
- What size socket do i use on my axle nut?
- Help with fuel consumption
- 2018 Gold Wing
- Adjusting Progressive 444 SD
- Loud Noise from Primary When Starting
- Barnett vs se clutch
- Windshield - One shield recurve shape over another?
- 12v Heated Riding Gear
- bike acting up, voltage regulator?
- 2012 Ultra intercom cap broke
- Gas Tank Compatability/Conversion
- rocker arm support
- 2017 roadking
- Bitchin bagger shocks??????
- 2018 Street Glide Special / Road Glide Murdered out mods
- 2010 Ultra Classic
- Sundowner seat shell has changed
- What make do you think these are?
- Odometer stays on
- Will these Foglamps (68913-98B) work on my 2017?
- Radio Amp Fitment
- Heated grips fitment for 17’ RGU
- instability in front end
- Harley vs. Indian... my experience (long post)
- Best tuner for M8?
- Backrest bracket question
- Bike Won't Go Into Neutral
- Someone educate me about Harley's
- 2002 Road King Classic Rear Lowering
- Bigger wheel / tire for 2012 wide glide.
- STREETGLIDE Passenger Foot Boards
- Harley OEM Fairing Lowers-"Glove box doors are sold separately!"
- 2017 Street Glide - Handle bars/seat suggestions
- Rear tour pack CB post
- front light bar/windshield nut size
- Progressive 944 Advice Please?
- Turbo or supercharger
- Retrofitting the dual bulb headlight
- RK Police Tour Pak options??
- Need Suggestions for Slip Ons
- Noise from front cylinder
- part numbers in on board diagnostics
- seat difference for a 89 flhtc to a 94 flh
- Hi output torque question
- seat showdown
- Front end feels "rough" in turns
- 2005 FLHRSI question
- Limited
- Pulling/bogging with clutch in
- Cylinder head temps
- 2016 SG fender on a 2012 ultra
- denim paint question
- 2008 Streetglide want idle without applying acceleration
- New ride
- Reinhart Baffle Change
- 2016 Audio Wiring Schematic
- Black spoke wheels
- Best Indy Near Spring Hill Florida
- Ignition switch on 2012 roadking on hand controls
- Chopped tour pack
- Speedometer Issue
- Road king engine guard
- Tour pack quick disconnect with led bag lights
- Replacing heated grips
- ignition switch
- Cant get over how much dealer OTD prices vary
- Aftermarket tourpak lights
- Gaskets, etc. to Replace When Removing and Replacing Engine
- Auto tune finished
- S&S 551 Easy Starts + Power Vision Tip
- Sg to rg conversion
- sticky tape
- Pin hole in rear brake line
- 2014 street glide speedometer issues
- Security for garage
- Corbin Seats (dealers)
- Looking for help trouble shooting black streaks on white walls
- Street Glide owners - Need your input
- 1.725:1 rockers
- fuel pump fuse blows
- Weird water mark issue
- Do I really need to tune my bike?
- First HD!!!
- Any high mileage compensators on 09 or 10 models?
- Squeak in front shock
- Outer to inner fairing bolt size
- Lowering front end
- Bike Alarm ?
- ISO 6.5” Harley boom
- Gloop in Brake Calipers
- New rider
- Cool flow fan
- Infotainment/Boom PDF
- 107" twin cam map
- Andrews 48h in a 96" (Stock clutch ok?)
- Tire concerns.
- Oil Leak from Bolt
- redline
- 2017 flhx gauge
- 05 Glide CKP trouble code
- LePera Daddy Long Legs owners
- Finally back to an RK
- seat for my 09 flhtcu
- That's Me!
- Chubby Road King Bars
- Dyno numbers
- Advan Black speaker pods n factory lowers.
- 8" Speaker Lid options
- Best AFR for Roadking
- 2003 Road King Capatible Tanks
- Corbin Dual Touring Seat, Comments?
- Couple of FLHX questions
- limp mode/check engine
- 1991 FLHT Stabalizer?
- Back in the touring line
- audio question
- Road King Dress Up After Removing Bags
- Commander 2 vs. Scorcher
- Chewed wires
- 2000 ultra classic starter clutch, again!
- starting question
- Exhaust fitment
- saddle bag speakers
- driving lights went out
- New Paint Set for 17' Street Glide
- Homelink for touring bikes -- Opportunity for someone
- Wide front tire Ulta Limited
- Help Please - Bike Slows Down Abruptly When Closing Throttle
