View Full Version : Touring Models
- RG conversion ?
- Anybody running arlens stretched angle bags with stock fender
- Just bought a 2008 Street Glide, When Braking It's Not Smooth...Warped Rotors?
- Annoying tap from dash area
- Brake noise
- Premium latchs install question
- Help how much fork oil??
- C&c sport tour
- TTS mastertune need download for 124ci build
- Decided to buy a 103HO motor for my 2007
- LePera Seat and Detachable Tour Pack help
- Hot rod flatz!!
- Anyone Run a Solid Rear Wheel?
- Basanni DnT slip ons
- Better Bushings for Monroe MA785's?
- Straight pipe fishtails
- What should battery volts be?
- Trouble starting
- Finally
- '07 on up clutch replacement
- Finally my first ride
- Rear tailight issue?
- Voltage Reg. Spikes w/ pics
- yep.......another 23" wheel post!
- brake guru's, need help.
- Police saddlebag latch to standard hinge/latch?
- Painting Inner Fairing
- Bassani True Duals?
- short legged riders
- 18" front wheel on rear? (2008 Touring)
- Right side air intake , what does it do and options?
- S&S power tune duals with Jackpot mufflers
- 15 Sg shocks compared to 13 and down air shocks.
- Broken Wire Connector
- 2011 Ultra Classic Tourpack
- hips seizing up
- HELP. Fork lock won't disengage
- maps
- Sell my Harley to my neighbor or not.
- 2005 Road King stage 2
- Seat for tall riders?
- Solid Color Fender on Two Tone Bike
- Selling my Harley to my neighbor???
- O2 sensors codes on straight pipes with Fuel pack
- Template for drilling front cyl head?
- Whitewalls on Rushmore Touring?
- wheel bearings
- Cleaning K&N Filter
- Old trike rider
- 110 for 2017
- Exhaust upgrade advice
- Cruise kit doesnt work....
- Help identify plug on 2012 Ultra
- Used Road King question
- Flat battery yet again.... 2014 Road King
- Ness Undermount Mirrors on 16" WO Apes ?
- 2016 street glide special.
- Seats
- learned a lot about baffles and packing today
- Aftermarket Brake Pads
- Question About Changing To Lower Handlebars
- 117 Tire Shredder Kit.
- Am I following Howard's Ohlin install instructions?
- rear shocks
- Setting Sag - measurement question
- To Stage 1 or Not to Stage 1?
- Cams
- Knock off 14+ Tour pak
- REAR SHOCKS for FLHTCU
- Yuasa's best high perf 500cca agm battery @ great sale price!
- RC Components 4.5in slip ons???
- How high?
- baffles
- Ram Mount cup holder
- Fuel Moto and Pure Powersports
- 14 Ultra Engine Issues
- HD Garage Door Opener
- Safe, effective degreaser for engine?
- Road King Bar Fitment?
- Apparent oil leak under clutch release cover
- Need a battery
- Bike dies when put in gear
- 2001 Electragide won't stay running
- LEDs fitted but flash rate wrong
- Help! Really Confused About APES.
- Dyno guesses
- Back from Paint
- 2014-2016 Street Glide Fender on 2009
- Hayden M6
- What Headlight bulb is in an 06 Road King?
- A Question About New Rotors
- Annual service
- 2013 FLHX Street Glide-Rear Light Issues??
- 2012 flhx rear fender on 2012 flstc
- Replacing Linkage Bar
- Drop-in springs
- Saddlemen Dominator Seat
- Premium Tour-Pak Latches Alternatives?
- Rider Backrest Repair
- Andrews 21 HP/TQ number question
- drivers back rest for 16 cvo?
- Rain pants for short women
- Washer for Harley's 7" Daymaker LED Headlamp
- New to Harley's, looking at Road Glide, advice?
- Help! Snapped rocker assembly bolt off in cylinder head!
- Air ride
- Rear rocker assembly won't fit in frame. (2008 RK)
- 2005 FLHPI ABS Mods
- Any one using a Manual switch / Valve for their air ride?
- Changing Odometer
- rc components 4inch or 4.5?
- Hard start / grinding SOLVED
- Finally some pictures of my bike
- Too much lean with 21"
- Arai, Shoei, LS2 or HJC?
- Installing 2016 ABS enforcer wheels on a 2013 ABS roadking
- Really loud knock after removal of covers.
- New (to me) RG, What Did You Do To It First? Besides Stage 1
- New Road Glide Special - pick up Monday
- 3M protectant from the dealer
- Streetbb apes on RKC
- Relacing SG lower brake line
- Locking Detachable TourPak
- 2007 FLHRC Road King Classic Saddlebag Replacement
- Ok, this stinks
- Chrome disintegrating.
- Fuelmoto led headlight
- Signature Series Rider Solo Seat 51700-09
- Windshield fitment Question
- Reduced Reach Seat Advice
- Street Glide price advice - go, no go?
- new rotor issues
- Voltage Issue
- headlight demon 2000 ultra classic
- clutch cable question....im sorry
- 07 Electra Glide Standard MPG
- Bought a new Bra for my girl
- front wheel bearings
- Will this Tour pack bracket fit my bike?
- Worn shifter bushings causing rattle
- Air Ride Lowering Kit for Road King
- Locking soft Bags for Road King
- 2006 Road King Front Wheels
- Rinehart True Duals
- Extended Bags
- A little Help please..
- Clutch adjusting the easy method
- Engine guard size
- Clearwater Auxiliary Lighting
- Softail exhaust
- High Mileage???
- Schuberth Helmets
- Replacing the plug on a Heated Hammock Seat.
- Floating Front Rotors
- Alarm system
- Mid-frame air deflectors
- Oil Temp in place of Air Temp guage installation?
- solid riser bushings and top clamps???
- Black bolts - paint em ?
- 2012 Street Glide exhaust issue
- Installed 21" wheel. Now ABS problem?
- Fuel Range Function
- Help me with a charging issue
- S100 Engine brighter
- Floorboard insert repair
- Footboard inserts
- want to remove tour pack on my 2009UC
- Extended Warranty
- Mobile 1 V-Twin
- Custom Dynamics Truwrapz
- 2014 and later Rushmore Saddle Bags on 2013 and earlier bikes
- Replacement License Bulb on Street Glide
- O2 sensors on a 2003 RK
- Flush front axle? Which brand
- Brake light malfunction
- I want to add a cool lookin fuel console cover
- Driver backrest questions
- Lifter or ???
- 2011 RK ULTRA pricing?
- Help! Hard-to-start '97 Road King
- Ape Install Thoughts on 2011 RKC
- Fuel Pak a necessity?
- Broken fairing bracket and fix
- clutch woes
- 2 up seat that won't raise the passenger too high?
- Front Brake master cylinder on 2010 Limited
- Does the JW Speaker Evo 2 headlight require a mounting ring?
- street glide 105 anniversay
- '02 FLHR Fork Oil Replacement
- Seats...2 cents welcome
- 2014 vs 2014 Ultra Classic
- Glide Fork Oil Advice please
- Need help finding new Air ride Switch / Valve. Pic included.
- 2016 H.O.T Louisville, KY
- Detachable fairing on a roadking
- Is this normal for ohlins shocks, pics
- Street Glide FP3 and Evo 49 tooth
- Turn signal Indicators stay on on the dash
- Opinions on 08 ultra with HIGH miles
- Help me with exhaust options.
- Road King face lift
- 60 wt in ontario Canada
- Anyone use liners from Customsaddlebagliners?
- New battery, new challenge.
- Looking for rotors...
- kury crushers
- Removing saddlebag guards
- Brake Light Flasher
- 2012 wheels
- Have any of you taken the "Ride like a Pro" class?
- Engine detonation and just runs like crap
- Oem mufflers
- Upgrading clutch in 2003 Electra Glide Classic
- Feuling OE+ oil pump- 2003 Electra Glide Classic
- Handle bar installation
- New 14" Handle bars
- LED headlights
- CFR’s with Dresser Duals should not have taken me 2 years to consider
- 1997 Electra glide with 18 inch touring tire problems
- Stripped Clutch Release Plate
- 2014 Street Glide -- Private Party Value?
- Rattle in Neutral
- Tour Pack Help
- Sound system help?? 2015 SGS Amp & Speakers
- Baker High torque bearing
- Sliding Sissy bar mount?
- Limited badge on fender coming off
- Trashed 88ci Motor. Must replace. Options?
- Security...dash flashing?
- Alloy Art Strong Arm install issues
- Cloce call, almost dropped - Warning!
- Got my EGC
- recluse and efm auto clutchs
- Immobiliser Security System
- Possible o2 sensor issue
- Oil level
- Installed heim type joints....problem
- Fitment Issue
- Passenger Floorboard Mounting Points Question
- Correct way to pass?
- Yaffee 12" Classic Apes
- Target Tune for PowerVision
- Dims on stock handle bars ?
- Adj. backrest
- Customization and fabrication?
- Holy Smoke cloud Batman !!!
- 96 ultra classis
- stock pushrods with SE 204's
- seat question
- 2015 SG security left me stranded!!
