View Full Version : Touring Models
- 103 heat issues
- 88 TC low oil psi?
- Aquatic AV users, does it recognize folders
- 2012 Ultra Classic
- Passing lamps?
- Delete heated grips
- Windshield question
- Torquer 450’s to tab bam sticks…can’t decide on size and baffle
- Are they building touring models yet ?
- Harley Boom Box Update
- This is NOT another "Bagger Wobble" thread ...
- Dead Stick
- Raising Handlebar height on '07 Electra ?
- Shot tranny 3, the end
- Mild clutch upgrade....
- Low Voltage on 2011 Street Glide
- Ohlin front suspension experiences
- air temp gauge, What's it's purpose ?
- Speaker upgrade
- left turn signal on all the time
- Advanblack hard lowers review
- New tour pak on older bike
- 20,000 mile service
- 21” wheel with standard length Legend Axeos?
- Progressive Suspension - good or bad ?
- Harley Ride Planner
- Rear brake noise
- Lets Talk Oil Coolers
- 97 Road King 80in Evo
- Got some new parts on!
- Compufire 3 install help
- Passing light bracket
- Legend revo a 13” and 1” lowered front forks
- How is a modern bagger stolen?
- Ceramic coating spray
- Carb Jetting
- 5spd Ramp and ball help
- Speedometer Issues
- Shinko 200/50R18 is 200% better than Dunlop D407 180/55B18 on Touring bike!
- Gotta leak
- Two brother racing mufflers
- Street Glide to Road Glide my thoughts week one
- Front upper engine mount link torque spec
- Best way to run (temporary) power for fogs
- King tour pack with no backrest holes predrilled?
- 2010 FLHX starting problems
- Chopped Tour Pack Lock Assembly
- Anyone have Arlen Ness adjustable bars on their SG?
- Inconsistent Volume from external speakers
- Replacement Bulb
- Can someone tell me, what muffler these are??
- 2006 Street glide
- MM F/I conversion
- Road King Handlebars
- 70 000 miles, now this.
- Seat for Ultra Limited without Tour Pak
- 16" Burleigh Bagger bars are the BOMB!
- Cobra neighbor haters
- Handlebar slip
- Quick-Disconnect Wiring Harness for a 2010
- 2011 Ultra - P0118, P0134, P0154
- 2019 Road Glide ultra 114 m8 exhaust issue
- Fun in the Garage
- Harley M8 Oil cooler fitting O ring size?
- Tach and speedometer
- Tour-Pak ID
- Valve extender DON'T USE IT
- The electric run around
- Riding tours
- No Front Brakes After a Tire Change on 2002 Road King
- Jiffy Stand Foot
- 2013 flhx sert system
- O2 sensor codes
- FXRT Fairing
- I can't drive 55
- 2005 FLHTCI Power Loss after 75-85mph
- Help! Codes!
- Turn signal not canceling. Blown ignition fuse
- bypass cruise limiter
- Adjusting bars
- DCL Plug
- kuryakyn tour tech highway pegs
- Road Glide Ultra Speakers
- What Are These Electrical Connections ?
- Installed Harley Peg Conversion on Road Glide
- Difference in seats
- Need clutch help!!
- Road Glide and tour pack alternatives
- 2021 Ultra Limited, best yet
- Where to buy Ohlins Shocks
- 2015 Road King primary noise
- Rear Brake Failure
- Electra glide spot light conversion
- Side case parts
- 07 RK primary leak.....again
- 2004 RoadKing won’t Start
- Looking For Air Gauge For Fast Up Air Shocks
- Twin Cam air breather bypass question
- How to sell Dynojet Power Commander these days?
- 10 disc Barnette clutch and heavy duty spring
- Do I have to pull my inner primary...
- Noise Coming from Air Cleaner or Lifters
- Custom Dynamics upgrade: headlamp vs. fog lamps
- Saddle bags or lower fairing speakers
- Charging system replacement questions
- Slow Speed Techniques - Low Price Drop Protection Tested...
- 16 inch apes and No cables
- 2012 flhr hand controls wiring diagram
- CVO gloss black exhaust on a non-CVO
- Replacing the Radio
- Speedo slow display?
- Ride planner issues
- Solo tour-pak mount installed!
- Adjusting Auxiliary Lamps
- Saddle bag lid hard to close
- 2013 flhx cam selection
- Hard bag model year differences
- Need fangs, but have tie downs
- Tuning Questions
- 22 Road Glide Limited - Nav Issue
- So, I did a thing yesterday...
- Do You or Do you Not (A Baffeling Qustion)
- 2008 Electra rim/wheel question
- True Dual dilemma!
- What are the left side panel wire connectors for
- best 6.5 fairing speakers
- Tire pressure warning light on
- Which headers are they?
- Your Thoughts On This Bike
- Might be a stupid question. (be gentle)
- Rockford Fosgate TMS6SG speakers
- Poisitive Wire Connection Under Seat ?
- '07 Ultra Classic gets P1353
- 06 Street Gkide Headlight
- Light
- Fuel pump
- Trouble with Spectre Glo light kit
- Information Icon on Boom Box 6.5
- Rear swingarm rubber mounts
- Magic strobe
- 2017 FLHTK ABS and flushing Brake fluid?
- Models
- Road glide fairing question
- M8 vibration (need advice)
- Quick detach tour pack mounts somewhat loose
- RG ST owners
- 2014 Road King Classic seat
- 1999 Road King FI - no electric after battery change
- Stage one upgrade?
- Want new rear shocks
- Footboard Extensions with Ciro Frame Mounted Hiway Pegs?
- Le Pera Seat - Maverick Daddy Long Legs
- Harley reopened plants ?
- 2013 Ultra
- Arlen Ness "Big Sucker"
- Oberon Levers for touring 2021+
- Rear brake line on '08 Ultra w/ ABS
- 2 into 1 exhaust
- Celtic lay over fender cover
- Stator recommdations
- 2015 Ultra Limited issues/ concerns
- Drag Specialties or Yuasa Battery
- New Street Glide - Handlebar Suggestions
- Repair Tubeless Tire with a Tube - Ok ?
- Radio Problem
- a little audio help please
- 2012 FLHTK: Bad compensator?
- 2005 Electra glide classic
- 2011 flhp front wobble
- 02 Electra Glide
- Clutch adjustment
- 03 Ultra Classic Tail Light question
- Light bar make?
- Connector?
- Fairing trim solution
- Bike height (dumb question)
- Transmission Dipstick Replacement
- 07 Street Glide Rear Fascia/ Fender Extension
- Shot tranny part 2...
- Fuel pump noise
- 2020 streetglide P0132 and 152 codes
- 2003 Ultra Classic gear indicator options
- Carbureted fuel system cleaner
- Rear End Whistle
- Clutch binding
- 2013 flhx efi issues
- khrome werks 4.5 do I need to remap my bike
- Throttle grip play
- York factory tours 2022 ?
- Codes 1510 & 2138
- Is this reversion
- Backrest for solo seat
- 99 road king MM fuel injection leaking at top of injector
- security key fob receiver issue
- Whining or clinging while moving
- New to touring and have some questions
- Reduced reach handlebars on street glide
- Electra Glide Standard shocks
- Recommendations for upgrading 2020SGS radio stereo
- Red Fox Bagger Install Help
- Road King Questions for a Harley-newbie
- Headlight Option
- Rider Foot Boards
- Are OEM heated grips externally wired?
- 2021 Road Glide Special stock exhaust
- 2021 road king front wheel
- Is my transmission shot?
- Wheel bearings and other tire change questions
- Headlight Option
- 15 RGS red security light
- Fuel sending unit
- Primary chain issue
- Cable actuated clutch lever question...
- High speed Ferry across L. Michigan question
- speedometer color
- CVO Road King - strange plug ??
- Brake lights
- High speed wobble
- One head pipe discolored
- Rear Brake Light
- Rear Wiring Harness
- Good deal
- Help needed, Ideas for ignition switch delete road king special.
- 2015 Road King Sudden Failure To Start
- Philly to Tampa Fl
- 2021 FLTRX no response from starter button
- Heat Deflectors for 09+ with True Duals?
- Electric Baggers ............
- 02 Electra Glide
- Road king CVO 2013 max.height ape hangers without cable change
- Long Trip Luggage
- Road King Classic Rear Speakers
- 2021 CVO Road Glide (FLTRXSE) Handlebars
- Speed sensor question
- Front motor mount question
- 1998 Road King Speedometer
- brake pad question
- Kuryakyn to Boom audio
- Voltage Regulator
- 2002 RK Police Odometer
- lighting
- HD Site New OEM Service/Parts Finder, Microfiche/Assembly Images
- 1999 flh performance issues
- Interchangeable parts for 2022 Electra Glide
- Rear signals lenses
- Juke Box vs. Phone
- Poor man's 2 into 1
- Weight Limits
- Water or oil streaks behind speedo and tach still an issue with bikes
- Mini Ape install on '10 FLHR
