View Full Version : Touring Models
- Instructions needed. PLEASE help.
- Adding Cruise to an 02 Electra Glide?
- Mix and match tires?
- american custom
- Transmission
- vance and hines power duals
- 21/16 Wheel Width & Tire Size
- How are Your Roads?
- Power Commander V and Factory/Extended H-D Warranty
- V&H Dresser Dual question
- 2008 FLHX Turn Signal Problems
- anyone experience this?
- Ultra with Springer Seat?
- Wiring GPS power on Road King Classic
- head pipe with cat ?
- Tweeter Pod or new Speakers
- American Elite now on the rear
- * Progressive Monotube install questions
- Technical question on O2 sensors
- Why all the damn allen head and torx bolts on HD
- A good place to get tires in Lawrenceville, Ga.
- Handle Bar Wobble
- engine noise
- Did i screw something up ?
- Steering head grease
- Need a bike cover? Try this one
- SG 16" to 17" or 18" Rear Tire
- Why do all bars seem to be taller?
- Arc mini two channel amp issue...gain control problem!
- Oldy's custom composites
- FBI 3" drop seat kit seats?
- pipes for 2011 ultra
- Motorcycle Show Del Mar, CA
- Sony or Alpine?
- Looking to order painted inner fairing
- what hits first leaning over
- Road Boy? Fat Glide?...anyway, it's interesting
- Agitator wheels
- Crank work. whos the best??
- 18" front 16" rear a good combo?
- Heat Comparision - 03 to 12
- abs , shudder, or chatter
- $$$ engine mods $$$
- Engine builders, Dyno guru's
- Smooth Chrome Lowers/Hidden axle
- Hog tunes 7" Woofer ?
- plug wire install on a '01 FLHRPI
- monster rounds
- question for those if you who have removed the cat converter from the head pipe
- gps
- Lower hd shocks on 2011 Electra glide?
- 97 EFI and Power Commander help
- What I Learned On My Summer Vacation
- Shout out for BRUKUS.
- Engine light at high rpm
- changing handlebars on a FLHTK
- Question about tire change and valve stem replacement
- Flat spots on tires?
- Getting Ready To Powder Coat need opinions
- lucas oil stabilizer
- 10 Days with no Sun and no Riding.......
- 03 RK engine swap questions
- 2009 FLHTP supplement?
- Oil leaking out of the air filter area
- Anyone had problem with the plug in their aux jack.
- '05 Road King Makeover **UPDATED**
- Touring section intro and hello
- Need Amp Suggestions
- Smartphone handlebar mount - Extremepda
- My NEW 2011 Street Glide 103
- Best GPS
- Touring Slip On Question
- Cheapest place to buy D&D fatcats?
- voltage regulator
- Is a 2011 headpipe without the cat the same as a 2009 headpipe?
- Need help
- Roadglide custom, RG Ultra or Ultra classic
- pipes
- Winter project underway
- V&H Twin Slash Slip-On Muffler Quiet Baffles?
- Stripped allen head Help.....
- Stage iv, 27517-08B or 27517-08D
- Locking down SE tapered adjustable pushrods
- Another primary problem
- Stage 1 upgrade and exhaust question
- Lower fork deflectors on a UC
- Replaced My Lids w/ Cycle Sound Lids
- Police Auction/Road Kings?
- Any downside with going with this exhaust setup?
- ? about Wiring garage door opener
- Bad last 2 weekends rides
- seat mod.
- dual exhaust
- Screwed up again
- New street Glide owner
- Most low.Least Dough?
- Do not buy from phat performance!!!
- SG LED Accent Lighting Suggestions
- Need advice with Speaker options for 2012 Road Glide Custom
- Checking tire pressure, is there an easier way? or gauge?
- brake rotors
- 21" wheel-lowering front and rear, or just front?
- I guess tire cupping is a "feature"...
- Harley Phone Numbers
- Does anybody know...
- Mufflers designed for bikes with the CAT still in the header
- Anyone powering their GPS from the cig lighter?
- Progressive 940's not for Road Kings!!!
- Tell me again about the "V" on a Roadking
- Loose muffler clamp
- LCD oil temp dipsticks - worth it?
- HD saddlebag extensions #90999-09 ?
- OK; it's time to destroy the myth........
- $$ instead of $$$$ engine upgrade
- exhaust
- Fat Katz Fenders?
- Axles???
- Help: low idle / stalling
- HD center stand desynchronize the legs
- Heated grips on 09 RK
- Loss of power today
- Tour pack quick disconnect locks
- Oil Leaking from Air Cleaner 03 RKC
- cvo mufflers
- 14 months and still put a smile on my face
- Rev tech wheel question
- Inner Cam Bearing
- Rear cylinder is not firing
- Hill Country Custom Apes
- Will '06 header pipes fit on a '05 RK?
- How much to ask for *new* Road King leather bags.
- Funny story for black Street Glide owners
- Ultra head set issue
- Screaming Eagle stage 2 kits
- Lovin' my SG!
- figured i'd say hello
- vertical alignment turnbuckle bracket?
- lowering kits - same ??
- Tank bags on a Ultra??
- Rented a Road Glide Ultra Friday...
- Will someone explain the AFR numbers
- Youtube vids of wheelies....who's doing it and HP/TQ requirements? Too cool!!
- 2004 FLHTP Major Face Lift
- 18" rear on streetglide, questions, and imprssions, please
- Updated pics
- 2009 to 2011 rear fender
- windshield and rain
- Gearing on the stock 103's (2012) vs 96
- Crank Case needed for a 90 FLHTC
- front brake question
- FBI drop seat installed and now it wont start Help
- My bike wont start Help
- V&H High Output Slip ons sound?
- calculated compression ratio changes due to adding MCR
- Which seat for my new 2011 Road King Classic?
- Opinions on Bassani slip-ons
- Iron glass pic
- stage 1 tomorrow!
- 12 inch "apes" on ultra
- Chrome head bolt bridges for twin cams
- stock seat vs hd sundowner seat
- Danny Gray seats
- Another tuner and brather question
- 11" 412 hd dyna shocks on street glide
- Need help/advice with services
- Elf audio e2125x amplifier mini amp
- Finally a 'proper' member
- Sold Rocker C Bought a Street Glide!
- Lost the damn O2 sensors!!! :-/
- Is a 2012 RK a bit cheaper then the RKC after adding cruise and ABS?
- Cam shim
- F-In Skippin' Harmon Kardon POS
- Please post rkc with custom wheels
- Do you remove the radio or the inner fairing
- Installed progressive 940
- underseat Acc plug on police roadking
- Clutch Cable Replacement
- I guess I own a DUD!
- 6th gear light & Cruise
- Rank Your Favorite 2 up Touring Machine
- MAP sensor carbureted Eglide?
- break in abs wire...
- Rear drive belt pully broke !!!
- !st Service New FLHTK
- long ride shield
- front rotor question
- Street Glide Clutch
- Compensator Bad Question
- What it worth?
- Ballistic cycles fairing for a 30
- TSI columbia Consolidating
- Old school king
- Q2 throttle tube?
- Trailering do's and dont's
- Question About Starting My Bike
- looking for comfort
- No more throttle lock
- Ordering a pitbull for streetglide should I get the standard or dyna lift?
- Throttle Servo Motor Cover?
- socal cholo road king
- No Better Place To Be!
- Tell me how you like the Rockford 4 ch. amp
- Need help on 07 Flhx brake line on
- I have a dumb question on buying a new bike?
- Mustang Day Tripper Solo Seat
- Like the look of dual exhuast on my RKC, but...
- Please help ID this tank emblem PN
- FOB Batteries
- 21" front, 16" rear?
- 2012 catless limited with 09 stage 1 download?
- Traded in the Deuce on a Street Glide
- Why 16" rear on SG for 2010 only?
- 15% off Coupon Code for LA Choppers
- Street Glide Make Over Times 2.. Pics!
- C&C solo seat passenger options
- What battery?
- Dynojet Question
- Wtf?
- jiffy stand bent to hell
- Pictures of my nearly finished 2008 Street Glide
- 2010 Street Glide Headlight
- Sold the "LUXE", getting a Road Glide
- THIS is freakin awesome!!
- Added Fork wind deflectors to Road King Wow !
- Will 09 front brake calipers fit an 05
- Help, Garmin 665& Nav NIM (A)
- Where to buy Ea Amsoil filter?
- 4.93 gallons in an '06 tank? Who's lying?
- reinehart 4" slip ons
- keep compression at 10.5:1 or change it?
- 09 Streetglide with streached rear fender and bags!
- Baffle options, baffling
- Air Cleaner
- best price on a 2011 RK Blackwall tire?
- Buying a new bike
- Rode the Dragon
- Would you do it again?
- PV stored DTC's
- Rake kit
- Need to Clear up the confusion
- Picked up my 1998 UGC - thanks for the tips!
- HippoHands
- 19" Harley SE agitator wheel
- slip ons
- Clearview shield for Road King Classic ?
- Rev Perf EMS Install Tip
- Connector help aux. lights
- Mounting Heated Gear Controller
- 21 inch vs 18 inch front wheel on CVO RG or SG
