View Full Version : Touring Models
- Front Master cylinder rebuild
- Cam bearings puller/installer question
- 2011 Street Glide- 1st Ride
- new frame on 2009 models
- Backrest question
- My 120R install results
- Need Ultra half cover
- Front SG wheel is on
- Installed a few things
- cut down windshield...
- Michelin Commander 2 Can't Believe It?
- Adjusting handlebars on 2005 RKC
- Kuryakyn Airmaster Deluxe review
- ACC Switch
- Cigrette lighter
- iPod Interface Issues
- So that's what buffeting feels like.
- Andrews 26H +4, or not?
- Alarm Problem
- Pro Pipe Quiet Baffle
- Air Cleaner question
- Help, Bike won't start after bar install
- Foot clutch - hand shift ???
- questions on SE 103 kits and FM 107
- Finally made myself bust open the camchest
- Indexing spark plug washer sizing....
- Spitting and cutting out
- cylinder stud questions
- abs pros/cons
- What lifters should I use?
- Intercom / CB questions
- Paint code number???
- WHAT THE PUCK! The puck has gone by the wayside.....
- Are your air shocks going bad?
- Source for Shop Manual
- Where to Mount Gerbing Permanent Dual Controller on Fairing?
- Flhx vs. Fatboy
- Best Fix for Scratch in Saddlebag?
- Towing w/ 21/18 or 18/18
- Lady Rider needing assistance with fitting new street glide to myself
- Harley headlamp modulation kit, anyone?
- Radio Cover??
- True Duals, Power Duals, Cat-Less Stock pipe...????
- touring handlebar wiring extensions
- Helmet lock
- Road King Classic Saddlebag trim
- Jiffy Stand Mounting Kit
- Speker grills, do you have em?
- Extended rear shift arm review
- This week's Ultra Classic Mods
- right side signals not signaling...
- saddlebag trim spears template needed
- Just Finished My Latest Project - WOW!
- Revolution Performance
- New Pinstriping (Pic's)
- 2005 Road King front shifter shaft
- FLHTK Detach Tour Pak - Lower Seat Options
- HD trip planer usage
- 07 Ultra Misfiring
- Front fender for street glide?
- mini tach install
- Someone has to know this answer to this SEPST question
- common for back wheel to turn when on stand in Neutral
- Seeking Advise of hot weather traffic Jams?
- Exaust Gaskets
- DriSlide?
- Best tires for a 21/18 setup
- 07 FLHT battery replacement
- Fairing Cap Rocker Switches
- Terrible XM Reception -> New Antenna -> Reception Still Poor. Suggestions?
- 2011 FLHX Reduced Reach Handlebar Options
- Wheeldock EZ-Up Centerstand Question
- PCV vs SE tuner
- Thinking bout cams, mmmm maybe not
- 6th gear indicator and cruise control link ?
- picking up a new bike
- Trailer Questions, Not a debate, no need for hate
- New Memphis Shades Fairing Installed on Road King Classic-- pics
- My questions for my amp/speakers install in my Ultra
- Anyone tried one of these? Rockford Fosgate PBR300X2 300W RMS,
- Chrome front caliper
- Fuel Pump ?
- renovations to rkc
- 2002 FLHTC carbed - SE part # ?
- Police Rodeo in Grand Prairie, Texas
- Kuryakyn Chome Caliper Covers?
- 10" Paul Yaffe Bagger Bars w/ stock cables
- Black washers and screws
- General RPM
- Thank you everyone who offered help while I was stuck on the side of the road
- cycle smiths bag extensions installed. PICS
- Fuel Moto / Jackpot is great!
- Will a 4.25" rear rim fit an 07 Electra glide
- Seats
- RPM's
- Can you REALLY like more than 1 model????
- V&H True Duals hit floorboards 2011 glide
- Wiring for trailer
- Help with tube size please...
- lubing cables.
- Tail Light problem
- Anyone running Kuryakyn Street Sleeper II ?
- No Front Fender
- 2003 rebuild 88ci to 103 ci not running right
- Saddlebag Spoiler Instructions
- Wiring Tour Pak to 2012 FLHX
- shift linkage
- Looking for Extra Large Floorboards...
- More experimenting to come
- Brake light stays on
- How much Weight can you carry
- saddlebag speakers powered by tourpak ?
- 08 FLHX and Power Commander III
- Ceramic pipes, worth it?
- New Paint
- Winsdhield that is wider then normal stock width
- So who wants to buy my C&C Solo seat?...
- Fuel Moto and Power Vision tuner
- Anyone ever get a sort of puckering sound from their suspension?
- Redline 20w50 oil package
- tire age... please help
- 2011 Ultra Header Removal
- Bogging Down When Starting Out
- Gerbings Discount!!!
- lowering street glide
- Anyone running Matrix lightweight rot0rs/discs
- LRS Ultra
- Forks leaking...help!
- RKC bag hinge spring things keep breaking
- Big Blue Pearl FLTRX w/tourpak and lowers pics
- Screaming Eagle Auto Tuner
- new front bake lines - time to fill & bleed
- HQ 107 Kit in Ultra 2010
- thinking of buying a 1997 rk evo
- Any pull a Bunkhouse Tent Trailer with an Ultra?
- Need some ABS advice
- Anybody do a Stage 1 on 2007 touring and no how it reduced engine or oil temp?
- First 100 MPH hug.
- Why Ultra First?
- Has anyone used these instead of xieds?
- Quick primary service question
- Installed my Florida Joe LED kit and blew a fuse
- 2003 ultra classic speaker switch
- interesting ride today
- Help! Stranded by side of road. Bike won't run
- Favorite Street Glide Windshield?
- Harmon Kardon Radio - Sound Field Processing?
- What year 6 gal. tanks will bolt on my 2006 street glide?
- Tourning bike questions?
- I added just a little engraving
- Roadking stock cast wheel cleaner(s)
- Black LED headlamp/Custom Dynamics
- Bike will not start! No spark
- detachable touring pack for ultra
- The Visor Style Trim Ring is a POS!
- help with gauges
- If you pull a trailer....
- Ortho Deluxe seat cushion
- SE adjustable push rods nut problem
- Is it the cat, or the pipe?
- Lace wheels on Street Glide?
- RK to SG fairing-audio wiring help
- Need help finding a Roadking Low Recipe
- To much oil pressure
- Something really weird happening with my REAR LED turn signals
- Sheepskin or Gel Pad
- Road King solo seat? C&C wins for my money!
- Neutral rattle
- o2 sensor question
- Fairind mount mirrors
- Kuryakyn tie-downs installed
- HD Premium Ride Shocks
- Installing Grips on TBW
- 2011 rk mods done! Convert to roadglide next!
- V&H vers Fulsac
- I am hooked on the winshield!
- KY PGR Riders
- Progressive Fork Kit Question
- Passenger Floorboard Covers
- Stage 1 question
- 2003 Ultra stereo specs
- Progressive 940 Ultra Touring Shocks
- Fairing Mount Mirrors-Relocate?
- Road King
- 2012 FLHX Brake Light Wires??
- 2012 SG, Tuner question
- HELP! - Please - bike is dead...
- Just bought an 05 Ultra Classic.
- High speed wobble with Brace
- Made the move...
- Carbon fiber inner fairing from Nostalgia Works
- Finally! Wheels ordered. Great price.
- Reset cover and nut fell off
- Pics of my 23" just installed
- Xied's Question
- Replacing rear pads on Electra Glide Ultra with ABS
- fairing for road king
- bought a bike today
- Gas Mileage on 2012 Ultra Limited
- Anybody got any pics......
- Road King OTD Price
- Stage 1 info for 2012 RKC
- roadglide vs ultra limited
- Dunlop Elite 3 front/American Elite rear?
- Need input on this...Please
- Cruise won't engage!
- sudden vibration?
- I need to be flat footed on my street glide?
- Baby Bagger
- Changing a Drive Belt
- Power from battery to batwing fairing
- trans shift shaft arm loose??
- Floor board opinion
- Throttle roll-on
- From dual calipers to single ?
- 2008 street glide tank on a 2006?
- What's best for removing boot mark from heatshields
- PC-V tune...something ain't right? Opinions?
- Fork Wind Deflectors
- Photos FLHTC with Road King bags?
- A weird one...
- How much to replace all this?
- 4 inch vs 3 1/2 inch rinehart slip ons
- Not a road glide fan but...
- Spending Spree
- Electrical Issue
- Tall guy needing seat help!
- indy's in se wisconsin
- 97 FLHTCI No power/backfire
- 103 HD download on a 96?
- Is there such a thing as overcamming?
- K&N Air Filters
- Front breaks scream! ( just replaced pads too)
- simple EFI tuning help
- 5 hour True Track install.....
- noise and gap
- New FLHTK
- Pulled Trigger :-)
- Belt Tension On Newer Models (Tight)
- 2009 Sg fender and fascia on 2009 flhrc?
- Power vision install
- Install engine before transmission?
- NO Helmet on Ultra
- SE RACE TUNER... how can I know if the module is running properly?
- Front Wheel ABS Sensor Replacement
- 2011 flhtk compensator
- New product LRS Ultra Flip Up maximum flip?
- Extended service plan
