View Full Version : Touring Models
- Can I put a 6 gallon tank on a 5 gallon touring bike?
- no odometer but trip works?
- 08 ABS vs 09 and later ABS
- Dunlop mt90b16 the right tire?
- Pro-Pipe HS baffle's impact on HP/TQ ?'s
- Good deal On A Road King?
- 14k on her and ....
- Road king rattle
- V&H Slips Ons with Reinhart True Duals - Can you do that?
- sert vs pc5
- RK Classic fenders on an EG Classic
- Fat Baggers Backrest Relocation Kit
- sometimes i have a miss
- how hard is it to remove tank?
- Hogtunes inside the fairing antenna
- Vance & Hines true duals ?
- Windshield Fit.
- 09 FLHX Front Wheel on 02 FLHR
- help..cant find my owners manual 06 RK
- I need an aftermarket Roadglide windshield. Anyone have one for sale?
- Will 2009 Street Glide rear shocks fit a 2002 Electra
- Pay Attention
- Charging Problem
- ABS Good or Better
- Warning to all
- Killed 2 Birds with 1 Motorcycle
- Winter mods almost done.....
- Check Engin light
- GPS- how bright is the 660 screen (can not read my 765T)
- i am a little nervous about riding anymore
- HD Fog Light Video
- 2009 flhtc starter f-#ck#d or what
- 2010 RG exhaust question
- Great big fat A$$
- lowering electra glide
- Jackpot PowerTube Install on 2010 FLHX
- Need help!
- How can I know if ECM is stage 1?
- Riding in the rain
- Vibration-bent crank-?
- Prayers Needed
- Bike won't start..no power.
- 2010 sg
- Posted in WTB Maybe more will see here
- 21" Wheel with stock fender??? Streetglide
- hd rmanufactured motor
- Chirp noise
- Thank you HDForums and Easy Off HD
- Help with front fender for 21 wheel on 09 road king
- Dyna-bead balancing...anyone using it???
- tire manufacture wives tail true or false?
- 2010 Ultra Classic seat advice needed
- Elite 3s in the rain
- Best three pocket fairing pouch.
- Heat shields for Crotch / Inner Thigh?
- Windshied- Look over or through? Brand Suggestions
- Another Cruise Problem
- Gps mounts
- SCORE, 2010/11 winter project
- Saddlebag filler strips
- tachometer resetting
- How did I end up 50 miles from home?
- HD Split Vision Mirrors review
- Tour Pak Rear Speaker Pods
- Question on Aftermarket Rims
- Rev limiter
- Finished my pull behind trailer
- Cam bearing change question
- Sepst to tts mastertune
- 2004 H-D Road Glide FLTRI
- 88" Silver Jugs
- Has anyone tried the HOGTUNES RG tweeter pod?
- Hog
- 2010 Street Glide Exhaust Advice
- Bike acting funny...
- Free stuff, from a 96"!
- How many are keeping your ACC helmets?
- Wheel Chock
- Pannier lids coming loose....
- Wanting to replace stock rims on my '09 Streetglide
- PCV for my '07 KING Dual Maps!
- Oil leak on a '06 Roadking
- FLHR nacelle question
- won’t start after a winter outside
- Got the bike back today...ahhh...almost perfect for me
- 1999 FLHTCUI Cam Upgrade and Mapping
- 03 Road King
- Typical HD -- headset parts issue...
- Pic of Red Hot Sunglo RG with Black Reinharts??
- Good sound sys. For rkc
- 1982 harley amf flt-80 tour glide classic
- DOT 5 instead of DOT 4 ?
- 2 ohm or 4 ohm speakers ?
- Extremely Disapointed in ARC Audio / FireCaps Speakers
- ADVANCED CARBON COMPOSITES EXT MOTORCYCLE HELMETS - Recall
- Squeeling Brakes
- Lyndall Gold or Z pads?
- Just got a 2008 Ultra Glide..Need Help
- HD Hybrid Ultra-Light Half Helmet & Street Glide??
- 124" StreetGlide back together
- Anyone tried a tanklift on a RG?
- J&M 7.25's 2ohm or 4ohm
- Could my frame be tweaked???
- 110
- Cracked Light Bracket 09 Ultra
- CVO Street Glide Seat
- Pickard USA
- Standard Ultra Headsets
- Mean City Cycles seat mod
- Planning 7 day trip on our Ultra
- Cant Reach the Kickstand on FLHX
- Want detachable tour pack on new Ultra Limited!
- clutch slipping
- RK Sprung Passenger Saddle
- Backrest suggestions: 2008 Road Glide
- Help with harmon kardon radio
- WIndshields for batwing - Clearview?
- 95'' budget build
- FLHTK 2010 rear wheel chrome coating peeling
- Please help me with some toips, advice and opinions
- Oem seat problem
- Need powdercoating & paint prep help....
- looking for
- Working with ABS?
- New Radio Issue
- Bell helmet
- streamliner footboards
- Question about CFR slip on's
- more pix
- Help with RG rear
- Anyone Try these??
- Ordered C&C seat, was a mistake to not go Mustang?
- music? tunes? cd's
- Vibration noise
- Need to get my '01 RK tuned - how much $$$
- what size tires on 21/18 combo
- front motor mount help
- HQ113 ST kit, hillside 117 kit, or what.
- 6th Gear, windshields and MPG on the Ultra Limited
- 5th gear
- lowering bike
- Fuel Pak or PC111?
- 1984 FLH Shovel/Evolution
- 05 electra glide w/carb
- Through the Looking Glass
- Interesting day at the eatery
- ruff runnin flhx 09
- Terry Components TV-3
- 160 Rear Tire on a 2006 Ultra Classic
- How to use a tach when riding...
- Kudos to Dr. V-Twin and D&D
- Warped Rear Rotor???
- Difference between 103' and 110'
- Adding XM
- who knows about the shoei cruz helmet
- Should i trust the dealer to perform motor build ??
- question on 21 front fender and wheel swap
- Slip-on muffler question?
- Modified stock
- 2004 Roadking custom-viberation
- Camping vs Motel
- Before and After Police Electraglide makeover!
- Shopping for Dunlop Elite 3 Tires
- Need A 08 FLHTCU Rear Bumber!!!!!!!!!!
- Seat 2010 Road King
- SE pushrods, which set?
- Smoke out of air cleaner
- What is everyone using for speakers to replace the stock ones?
- painting lowers and glove box?
- New painted lower fairings installed on Street Glide
- Yaffe bagger bar in 10", where to get it
- FLHR - Mustang solo - TourPak
- hawg wired harness, important question
- Shock question (Progressive part #s)
- Best 2 into 1 Exhause
- Solo tour pak install with Corbin solo with backrest
- Klock Werks SS exhaust review
- rotor experts, slot and bulb orientation help
- I want your opinions
- Gas Tank Sealers
- Help with tank console ................
- Exhaust Help please !!
- older riders
- 124" build: ignition switch problem
- solo seat with hd backrest
- HD Leather Low Profile Bucket Seat?
- 8.5" Klock Werks Fleer windshield and VPC clutch
- 07 Electra Glide starter Update
- Seat question
- Road King Custom Upgrades...
- not able to post in parts for sale forum why?
- Fuel Moto Performance Package
- Long Ride Shields X-treme 8 "
- Strange Cruise Control Problem
- Question about pipes
- Loud clunk during startup 09 EG it's a new noise
- Abus Detecto 8000 X-Plus Review
- 2010 Mods Done
- 2009 ultra detachable tour pac ?
- Happy Easter
- 4 point docking on a 09 RG
- Oil Temp Gauge
- wiring question
- Handeling woes!
- Fork Stem nut size
- Smoke from the rear!
- Another cam noise question!
- Decision Making Time Need Help!!
- ZUMO 550 Died - Garmin's serve is great !
- XM Radio
- clutch cable issue
- Just purchased 2010 Limited
- what is the best LEATHER touring seat?
- Acc helmet recall ?????????????????
- ATF Type?
- Cycle Shelter experience?
- I ordered new seat....question!
- velva-ride frt mount
- Jackpots... Next step
- Throttle/Idler cable Street glide
- couple more
- squeaky back brakes
- Gear drive or chain drive
- Can't find
- Nacelle toggle switches
- The Perfect Harley
- Jacking up Ultra--any tips?
- Night Lights
- What a difference 1" makes!!!
- Fuel Line Part # 2007 Road Glide
- 09 Street Glide winter mods DONE (2nd Bike)
- I need a Jackpot 2-1-2 head pipe!!!!
- Here it is with 99% of the winter mods
- A Perfect Dealership
- Security key icon on while rideing
- windshield
- WANT/NEED quieter exhaust.
- Spring has finally sprung
- Lanzar MNX-250 Amp, anyone know or using?
- Remote garage door opener ?
- Securing Bag to Passenger Seat?
- Fuel leak..Help
- Road Trip advice from Los Angeles to Galveston, TX
- Raise rider footboards or pegs?
- Which 2up comfortable seat to buy?
- Iron Butt ride, Michigan to New Orleans
- Help me price my RG
- 02 Ultra Classic - Electrical - bike runs - no headlights, instruments, light bar
- How is ride quality on a Roadking?
- Heritage style bars for my RKC
