View Full Version : Touring Models
- Re Mapping
- What's the difference between 1994-2003 and 2004-2008 bagger wheels?
- Heated Seats
- Is this what an E3 looks like after 6k miles?
- Bolt orientation Billet Heel Toe Shifter
- Charging problem
- First ride after Andrews 21 install
- Sena SMH10 - Best Bluetooth/Headphone/Intercom!
- Sturgis in July ????
- Rear brake lights
- Roadking owners with the Heritage bars question...
- Ok guy's godda pick yur brains on this crazy issue i'm having..
- Painted Inner Fairing on SG
- Finally got my Arc Mini installed
- 2011 Paint issues???
- Yaffe Classic Bagger Apes
- USB power adapter
- anyone with any pics of an installed inline hitch????
- Heat shield clanking on floorboard.....
- Auxiliary Lamps
- HD Synthetic blend
- Went with kerker stout 4"
- 2012 road glide custom
- leaking cases
- Put a New Deka Battery in My 2005 EGC
- Communication advise please?
- redline oil
- Stage 1 download questions
- Rinehart 4" Slip-Ons Installed Today
- driver backrest problem
- This may be imposable cheap 12" shocks that ride decent
- BADLANDER OR LaPera Bare Bones 96-07 FLHT's
- Grinding sound in Primary
- Anyone have, or ride a 2011 CVO Convertable?
- 03 Radio trouble
- Passenger backrest option? RK
- Noise in the tank?
- Wanted - 07 and up Touring Bike for new product testing
- tbw replaced, bike wont startbut at full throttle.
- Radio & Starting issue
- which one would you buy and why?
- Potential issues adding rear LED lights
- 2010 Screaming Eagle exhaust onto 2011 RKC?
- 10" PYO monkey bars and fairing mirrors??
- 2011 Root Beer Road King
- pics of my 2011 streetglide finished
- To de-cat or not to de-cat that is the question
- Headlight Fuse
- FLTRX Air Deflectors :)
- Help with 2003 Road King DTC codes.
- Cheaper way to brighter passing and headlights
- 103 Exhaust question
- Why no factory installed tachometers on newer Touring bikes?
- Pulling a trailer
- completed Sportech Batwing install on RKC
- Race Tech G3-S shocks
- 2012 RG Frustration
- question for 103 guys
- Monkey Bagger Bars & Heat Demons
- Hard start after K&N install
- 2011 Touring Service Manual is...
- Question
- Wiring issue
- RC Components?
- Clutch Problem or Operator Error?
- OEM Part # Rear rotor
- Writeup/ pictoral of primary & trans, seal replacements
- 9,000 Miles in August
- Help Pager II power supply!!!
- ABS Rear Brake seems off
- Fullsac
- 21 inch wheel on FLHXI... Right wheel?
- '05 Road King Makeover
- ABS bearings or not?
- Hard starting when cold
- fuel leak
- '02 Screamin Eagle stage II?
- RK brake pedal pad
- D&d fatcat exhaust gaskets??
- cdn law requirements
- Off-Road Lights???
- Rinehart slipons or true duels?
- How do your mini ape hanger handle?
- PCV cylinder reference which is No. 1
- 5,000 mile service is $300, what the heck
- My Street Glide with Jackpot Pro Touring slip-ons
- 2006 Ultra Sputter out air cleaner
- Progressive Drop-In Kit
- 2 Plugs
- How's your winter project shopping list going?
- Road Glide...biggest fairing speakers possable?
- 2011 Limited Gas Smell in Oil
- Extend your exhaust
- Would not idle after an hour of hard riding
- wheel alignment
- Air cleaner Covers
- Drive belt to lose.
- Did I screw the pooch?
- Fuel pump and security light come on twice
- 2010 Ultra classic pulls to left when I let go of handle bars
- Help....
- trans shifting issue
- How to clean up rear fender 11 FLHTK??
- Air ride or not?
- 1985 Electra Glide Classic...Would you?
- Finally got my Street Glide!!
- Extended Warranty
- help with front brakes
- No more kuryakyn for me!!!
- Thump going into 1st gear??
- Part name / number? Quick detach windshield grommets?
- Notching Heritage bars for electric throttle assembly?
- 103 put off more heat?
- Legends Seat on touring
- Compensator sprocket/Hard starting/b1006 b1007
- Buffeting Returns
- Need Advice on Shocks for 2010 Road Glide Custom
- Did not get ripped off after all...
- Who Makes It.
- Heat Issues
- Accel SLM Auto-tune user report
- Street Glide buffeting fixed by accident
- Antenna Cable
- Who Manufactures The Screamin Eagle Slip Ons For Harley?
- SG rear fascia entension ?
- What is cost for service manual?
- P0572 Code: Brake Switch Low
- Headset Arm Repair
- Cool backrest plate
- any good wrenchs in VA
- fairing factory? Lower fairings
- Rinehart 4" slip-ons
- Seat advice needed
- Cornering over painted cross walks, lines, etc.
- sad day
- ecm ?
- New to HDFourms
- Considering a new Road Glide Ultra
- Windscreen Storage
- Engine Clatter RKC 2011
- Forge Tech Legacy wheels
- some advice
- Got to ride home in limp mode.
- Stylin Products switches
- Road glide xm radio wiring
- Should I have dealer do the 5,000 mile service?
- Was there a full Harley moon this weekend?
- Clutch Help
- Best looking/performing heated grips??
- Running lights
- How do you wash/clean your bagger?
- Remove brake calipers to remove front wheel?
- Map values- Vance&Hines+P.M Heavy breather+P.C.V
- Rev limiter?
- Heritage bars on new Road King
- will a 2008 flhx rear fender fit directly on to a 2005 flhtc
- intercom
- Replaced Front Brake Light Switch
- 2011 FLHTK decel popping w stock head pipe
- Security key light coming on and I don't have a security system?
- Just Ordered a Thunder Max TBW System.
- Oil Leak
- Hit a skunk!!
- Streetglide tail lights burning out
- Is great to feel like a kid again!!
- Army paint scheme on bagger
- Installing fat cat
- iPod Install Question on FLHTCUSE2
- SE compensator 40274-08A - what's changed from -08?
- Transmission Sprocket 30T Replacement - Homemade Tools
- Help, Got some drips on the concrete under my Primary?
- Panic Stop with ABS
- How to bleed ABS?
- Could this pipe be new? Cheap bike price
- Black Box for Your Bike
- Turn Signals Don't Work Consistently
- Ultra Classic brake problem
- Head pipes question
- Cam Options for SE 103 Stage III?
- Picked up my first touring bike yesterday
- Ultra swing arm bushings
- 98 Road King Engine Upgrades?
- Question about Road Zeppelin Air Adjustable Seat
- TBW Plugs
- Harley Heated Hammock Seat Question
- My bags blow in the wind. Any fix?
- sticky grips
- Availability of Custom Colors.
- Power Commander 3 or 5
- Spark plugs
- Street Glide Wheels on my Ultra?
- Line-ex or Rino-liner on saddlebags
- Thinking about buying a RK Classic...
- Lost My Lights
- Rally Q - BBB Fayetteville AR vs. SPI Bike Week
- Want to change headers
- Can anyone identify these wheels + size?
- My new Street Glide is home!!!
- Squeal/Chirp on Decel
- Ultra Tour Pack
- Hard to find neutral after SE Comp install
- XM Radio module installation
- Wife's got me pegged ....
- Installing new cam earlier than planed..
- Suspension dilemma
- Muffler touching axle
- Brake Light Switch Removal
- Anyone else actually like the stock SG windshield???/
- adjustable push rods - will these work on a 96"/103" engine?
- Just recieved my Heritage bars. Any suggestions on the install?
- Progressive Front lowered SG Opinion
- 2008 Road King .what time of exhaust should i go with
- Anyone seen this
- 2012 Street Glide - Stage 1 Installed - Lessons Learned
- Rineharts
- Size of trailer needed to transport bikes
- Stereo Issues with '04 Ultra Classic
- finally decided on a seat
- I have an awesome Indy
- Baffles, stock replacement
- Freedom Performance Poor Quality/Customer Service
- Adding ABS to 09 FLHTP
- SE Comp
- 2005 Road King w/ FI -- any known issues
- Review of the Harley Davidson Combination Speedometer/Tachometer
- Wheel balancing question.
- Need help: apes pushed up so windshield cannot go on, any solutions would be apprecia
- New Extended Bags - Bagger Werx
- 2011 RG Stage 1 download required?
- Rear Bumper
- Any cure for "the shakes?"
- Solo seat air fittings - how?
- Detonation
- 09 Ultra ignition switch
- Anyone have a quadzilla road king fairing?
- 120 mm tire on front of touring?
- 2020 Road King windshield with LRS 17" Med. Tint shield
- Heritage Bars?
- Exhaust sound (high pitch)
- Will an 09+ front wheel fit an 07?
- How can I make my blinker lights stay on as running lights?
- FLHTCUI Ignition
- pinched O ring - reuse fluid?
- Soon to be harley owner :)
- Best way to quiet valve train noise on stock FLH
- Just joined the Touring Family
- 2010 Ultra Classic Vibration at 1800-22-- RPM
- Had a coyote in my lane
- Rear stabilizers....benefit gains only for the aggressive?
- Man crow sure does taste good...
