View Full Version : Touring Models
- Upgraded from 2005 road king to 2013 ultra limited
- Rear Pulsing Breal Lights
- Harley 3 bag storage on ultra limited
- Tour Pack mounts
- Fuel pak
- 2013 Street Glide with 120R
- Brighter Tail/Brake lights for 2010 SG
- 2012 Flawless running Road Glide
- Arlen Ness parts dept stinks
- New part new issue???
- Street Glide fork oil, how much
- Compensator issues??
- question regarding ultra glide
- Cell Phones & Bikes
- 21" front wheel
- Checked My Cam Tensioners......
- LED Tour Pak light kit harness question.
- Good Ground spot for Amp on 2013 Street Glide?
- 1 LED strip left, where do I put it 2009 FLHTCU
- Air shocks leak question
- shifting louder
- jerzee custom oil pressure gauge leak
- intercom headsets "Free ride moto sports"
- Problems while at the Myrtle Beach Rally
- Shifter position moved
- indy
- Picked up my RG Custom! Questions inside.
- Picked up my new scoot!
- Site guage for belt
- 09 Ultra Battery ??
- Any ideas for a compass?
- Saddle bag straps
- Need Wedge - Front Brake Light Switch!!!
- FM Backing Plate w/ HD Cover
- Different Connectors !!
- Myrtle Beach impressions
- Fullsac True Dual Coversion, thoughts
- New Scooter
- Which Cable Kit?
- Chrome Cowbells / Street Glide?
- ordered some cfr pipes today
- Speed wobble in turns- Suspension?
- Stock Radio, Something I don't Understand
- Miffed at s&s
- No fuel on my 07 SG
- Who else works in the "friction zone"?
- Stage 1 - Dyno or Tuner?
- cam tensioner upgrade kit
- Best Way to Mount Bitubos on a Bagger (up/down, forward/back)?
- Monster Rounds too loud!
- Can I put a Stock Front Wheel and Tire from a 2012 on a 09 S/G
- How much buffeting reduction
- 3X quick start and stop routine
- Shock pump
- 2013 Big Blue
- Burst collection life
- Best Torque Wrench??
- antenna cable
- When going from a Dyna to a Touring Bike...do you now ride more often or less?
- Inner Primary Bearing Replacement How-To
- 96" with 222 cam advice
- Over Tioga Pass back on hwy 88
- Shot rear wheel bearing,
- Brake light issues!
- Noteworthy dealership experience you might find interesting..
- Installing Newer Gauges on 97 Ultra Classic
- Full size cross over pipe
- Inner Primary Bearing Vendor
- Tall Boy Seat Mod done by Mean City Cycles
- What passenger backrest docking hardware do i need for my 06 ultra
- Wheel weights adhesive not sticking. Pressure sensitive?
- Tour Pak Side Marker Lights - Options & Opinions???
- Voltage Regulator
- Wheel shipping cost???
- NO ideal....
- Streetglide windshield
- Busted case
- Trouble shooting electrical problem
- big crank...oh yea!
- Pcv downloads
- Running PCV without auto tune???
- JRI shocks
- YAHT (Yet Another Heat Thread)
- FLTRU: passenger backrest options?
- 07 Ultra rear brake switch
- Voltage Regulator Replacement
- Customising the SE tail pipe?
- Modifying Road King-Need Advice
- 130/70-18 vs 130/80-18 tire
- Detachable tour pack rack issues.
- Road glide AUX input volume very low
- Color of Spectro 6 speed trans oil after service
- What are symptoms of excessive primary oil
- Space available ---Tail of the Dragon
- Really like the SG
- Where can I fin a black cupholder???
- Best way passenger to hear radio
- heavy duty clutch for 120 horsepower
- Another Handlebar Question
- Cam chain tensioners
- Tallboy seat for Road King and how to get more room
- 2013 sg/fuel gauge
- Front dive under breaking ?
- Vibration after brake change
- Which wheels are a direct replacment for the 04 road glide?
- Blacked out Yellow and Black Limited
- SEH-203 cams ???'s
- Is there a difference between 04-2010 saddle bag lids?
- Is fuel cap hissing normal?
- front wheel install question
- FLHSRI or Road king Custom fairing
- planned amp upgrade good or bad?
- bub7 quiet install question
- Different, yet same speel on an oil thread !!!!
- Road king shut off while driving
- Need help troubleshooting voltage issue on a UC
- Drilling holes in saddlebags
- Had never seen one
- No more coffee spilled in saddlebag -- PIC HEAVY
- Hard Clutch/ Barrnet cable
- I Want to Learn to Wrench...
- 17" Todd's Cycle Apes
- First service?
- Security icon
- Help identifying these floorboard inserts
- Throttle issues with '08 SE Ultra.
- need some help / advice
- Bike struggles to crank and start
- V&H Pro Pipe
- made my first mod....
- Cfr pipes have been updated?
- passenger seat screw rubbing rear tire
- Fairing Adjustment
- Pitbull lift question
- Upper banjo
- Air filter question
- Fat Baggers tour pak mount
- 06 ultra coughing on cold start...
- Not as long as I thought!
- Rear brake sound on a new Road King
- T-Man 555 cams
- Noisy Tappets
- Snaps on Lowers
- Noisy tappets ? Best Oil to use to stop this
- Interesting issue at 5000 mile clutch adjustment
- '13 Street Glide
- How's this setup sound and what am I missing?
- One-Stop-Shopping for 2+2 Sweepers and cables?
- update:"like someone hit the kill switch"
- Locking Gas Cover
- finding neutral
- Bought a 13' Street Glide!!!!
- Pinging testing
- Windshield Advice
- Cat in Mufflers ?
- Pretty Good Day!
- Tested a 103 Stage on 2013 Road Glide
- Looking for Drag specialties ANTHEM fairing air deflectors
- Sissy Bar Luggage... Recommendations?
- help please Road king shut off
- HD Touring pullback bars
- Gerbings extension as jumper?
- CV help
- CFR Knock-off Re-Packing, Notes and Pix...
- Inner Primary Seal
- Discontinued part #'s ?
- Anybody running rcx-celerator
- Drago's True Duals?
- distance to empty guage disappeared
- time for a change ?
- SE 103 Stage IV........
- not charging
- How to Boost XM Volume(Portable Unit)
- No Right Rear Turn Signal
- Jackpot 4" Baffle Removal?
- J&S jack to use with my Street Glide
- Idle changes
- White Bikes - Post some images
- [bb]cooling down process
- Super Sucker Questions
- santee fred kodlin bars
- Road King cut off in traffic, any ideas?
- Changing clutch spring
- FYI,Flashlight that is worth a look-B Prepared for your Touring Trip!!
- seat cleaning
- What Timing Cover
- Using the Pitbull jack with my True-Track??
- How many wear Mesh jackets with Armor?
- taking her in fo 5000 mile check up.
- Recommendations: chrome hand controls
- Dynamat vs. Roofing Material for ratteling\vibration?
- Americade
- Down shifting clunk
- front sproket
- Headlight upgrade over stocker?
- Electrical Issues ????
- Rear pulley choices?
- gas in oil
- Whats causing worn final drive pulley and belt chirp
- Need help! rear running lights and main brake light are out
- Pics of Arnott compressor in front of battery
- What Do You Take On A Trip?? Besides the Ole Lady?????
- Bike won't start...
- shock air inlet tube
- Warped rotor on new street glide?
- Corbin Backrest Install Heads-Up
- Battery change out
- any opinions on a 2013 ultra?
- Cycleshell
- I hate to have another knocking question, but...
- New Andrews 48H Cams/Dyno Results...
- Upgrades Complete! 10" MBB's, painted inner, and more!
- Will she crank and run after cam change?
- speaker emblems
- Need ABS Help
- What is the best tour pak mount????????
- seat upholstery
- Exhaust question
- 2 part question Ape's and dyno
- 2007 Road King Cruise Control,,
- Exhaust Note Changed...
- Stage 1 air cleaner questions
- HDPDPLUS II vs. Boom Audio
- Lighting question
- seat inquiry
- Got rear-ended by a Triumph!
- Brake Pads: Sintered or Non-Sintered/Organic???
- Truck Lite Question
- Paul yaffe 14" oem black monkey apes bar ape-hanger handlebar package kit abs
- Easy to replace brake pads myself???
- $4 garage door opener
- Rear Shocks
- New bars popping fuses
- What year electra glide wheels are interchangable?
- ETMS Help
- Rotors For Chrome SG Wheels
- wiring nightmare
- derby cover gasket
- 14 days in Shop comes home
- Front Brake Switch Replacement Instructions
- No acceleration
- Torque wrench ranges
- Brake pad life
- Short Backrest Bracket
- Proper Footwear
- Waterproof Powervision
- NEw seat !!!!
- Check those exhaust flange nuts
- Vibration in 2012 103
- Not My Week...
