View Full Version : Touring Models
- What kind of Suspension for a 2010 SG
- 2010 "103" backfiring
- PIAA Light on Limited
- Unique Derby Cover Ideas?
- 21" black spoke on my old school Road King Classic
- part # please
- Putting Pucks back on my Police bike
- 13''ape cable length on 2009 FLHX
- 2009 Road King points right when going straight
- Road King Riders - What year???
- Schluuurping Noise 02 Road King
- Harley's compensator mod - no more need to grind grooves in sprocket
- Mini-Beast 5 (close ups)
- Grinding noise in front wheel
- compensator ver 2008-09-01 vs 2011-06-01
- More Exhaust Help :)
- thanks fuelmoto
- Baffle re-pack; what to use?
- 18" Wheels??
- want to change front fender
- Left side passenger peg problem
- Anybody make their own aftermarket Radio Bracket?
- Thunder Max Ecm ___ Dyno tune
- Twin Cam 88, no oil pressure, HELP!
- Wish Me Luck
- Custom Dynamics Did What ??
- Sending my HK to IronCross
- Reusable oil filters
- I dont like RoadGlides
- car tire choices
- roadglide wellnut replacment
- tuner near zanesville oh
- HK radio toast.
- Tuner + Cat = Increased heat?
- Compression release drill jig in NYC area
- progressive mono tubes backordered
- Accent LED'S for that WOW Factor
- New Helmet, New Sounds
- trading
- 1st clutch adjustment, WOW!!!!!
- Need Handlebar advice from those of you that have had shoulder pain.
- What speakers to put in lowers?
- Rear Shock ?
- Need Help finding Luggage Bag???
- Burly 14" apes and Heat Demons
- Which Bars for Road King
- Supertrapp Slip-Ons
- Can Someone Please Help W/ SCII Exhaust Question
- CVO SG owners, post pics of your passenger backrest
- Radio Options
- Rode a RG custom last night
- Pleiku 69
- Speakers cutting out
- Stock Muffler Mods?
- Opps. Bike runs like crap Help
- 21" PM Gasser installed
- Voiding the warranty question
- Can somebody help me with a part number?
- Mixing fork oil-My Experience
- 2011 SG Clutch Adjustment ?
- Clutch Slipping?
- 2011 Street Glide: Fuel Pump Constantly Whines. Normal or Not?
- Sinister Industries Pissed off headlight bezel installed
- Right turn signal won't work
- What Is this? (pic of fuel inlet)
- Did My Boy Scout Good Deed Today
- Looking for some pics of the kuryakyn 2262 passing lamp
- Fairing question
- Help for a newbie!
- code running front led turn signals
- What's the most cost effective way to cool down a 2011 Ultra limited
- Engine front rubber mount
- Anyone bought a cover from carcovers.com?
- Reinhardt TD replacement question
- HELP with fine scratchs on 2011 rg
- Stock air filter cleanable?
- 2011 street glide
- Passenger backrest relocation
- Opinions on slip on exhaust
- Speaker and Amp install on Road King?
- Clutch Adjustment Question
- Has anyone tried BDL compensator??
- HK Radio Losing Time
- Stage 1, download vs super tuner?
- Rush Mufflers on 2010-11 Touring Models with Stock Headpipes and Cats
- Cost of Harley ECM Download
- Mobil 1 Coupon
- Normal or not gear whine RK
- Cover for FLHR?
- Vibration at high speeds
- starter 10T/84T gear sets of 07 and later?
- Screaming Eagle Fatshotz
- Short Passenger
- Shifting Arm
- How to change the trottle grip
- FLHX gauge lights
- hog tunes speakers review
- air pressure gauge dash
- Having problem getting cord from Headlight
- Pics of New Mustang Super Touring Seat on Street Glide
- bad lifter????
- 200 Tire on 2011 FLHX
- rear shocks on ultra
- Oil Cooler Thermostat
- Bag Guard
- Can you mix ethanol & non ethanol
- Worth the change from Rinehart 3.5 to 4?
- 94 FLHTC Starter relay
- Advice/input on Yaffe Monkey bars?
- Windshields: Polycarbonate vs. Acrylic
- Did they do me wrong...?
- HD Garage Opener Question
- Exhaust upgrade options for a 2008 FLHRC California model
- headlight fuse
- Blown Discs
- fuel choices
- Rear fender for my road king
- Tuners?
- Major problem
- increase height
- Need Advice on selling price !
- 700 dollars for a dealer to dyno tune?
- Snoopy shield helps buffeting
- 08 street glide engine upgrade
- 2011, 103 FLHTK Head pipe change
- V&H FuelPak and Arlen Ness Big Sucker?
- 2003 Road King Vs NEW 2012?
- New HD "Premium" touring shocks & fork kit.
- 2011 fltrx 96" What to expect?
- who's going to mountainfest
- Who's Going to Sturgis???
- J&S Bike Lift
- Detachable accessories and docking kits
- DIY XIED fuel ratio enrichment - thumbs up or down
- Red Security Indicator on solid no backlight
- Got greased by the dealer!
- SG vs RG handling test-
- what's the best stuff for winshieled detailing, removing fine swirls/scratches?
- Bubs ???
- GPS Power
- Sturgis Newbie
- Ordered Clutch Spring 37871-98A
- Tour Pak Luggage
- need a little help - bag on back seat
- vacum port
- got a problem....any tips
- PowerVision...
- wheel bearing removal/install
- What's the Difference?
- Late pipes on early Ultra?
- got my FM stage1 but 4"jackpots seem alot ..
- I got published (sort of....)
- got the bike all cleaned up for sturgis
- 03 Ultra Classic Armrest
- FatShotz Mufflers: Ahhh...
- Another Fix for Intermittent Speedometer
- Screamin Eagle Hay Wagon
- Help me fix my SE baffle
- 09 Ultra starting when hot
- StreetGlide CVO Seat anyone know the part #?
- HD of Ocala,Florida
- Rinehart Chrome Sucks
- SE Stage IV crapped out @ 18,000 miles
- 2006 flhx smoking oil past 60 mph
- noise behind primary cover 2007 Roadglide
- Fishtails for baggers
- 90 degree valve stem?
- Electrical gremlins
- ABS, worth it?
- Anybody Ever Had/Heard BOTH These Pipes?
- Kickstand issue solved!
- 16" Fat Apes from HD: Why the Risers?
- yet another handlebar question
- Tires
- Has anyone installed Center-Mount Auxiliary Running & Brake Light P/N 68000029 kit?
- Help with noise please
- 21's for someone that is NOT height challenged
- roadking radio
- Hd circulater pad and road zepplin
- Ignition Switch Nob Malfunction
- single up seat options low profile for the short
- Pics of the new scoot.
- Why does the Sundowner Solo require the tank adapter?
- 18" abs streetglide wheel on non abs bike
- PC lll and dyno tuned mufflers
- New to me wheels
- front brakes squiking but only when riding not stoping
- Need bagger input from the Forum
- CVO Factory Rear Amp Wiring Cover
- New to baggers, and loving it!
- Installed Saddle Bag Guards
- Prayer request
- Why you didn't like your Sundowner seat?
- opinions on this ultra classic wisconsin craigs list
- starter jackshaft gear - problem or not?
- Transmission issue
- Never say Never!
- Slow crank then only 11 volts on gauge!
- Razor Pac
- service manual
- Cruise Control Failed Again
- squeaky brakes?
- Gerbing’s Heated Gloves T5 or G3?
- '11 FLHR Rear Smoke Tailight choices
- Price check and tell me about 02' RK
- Rain
- Air Cleaner
- Cage free roads
- low fuel light in-op
- Trip Reset Button
- Thank You ABS!!
- Extended bags and rear fender
- 09 SG swing arm/belt/pulley measurements
- Tip indicator
- Shipping Ultra...?s
- 2011 Street Glide help(just bought it)
- new clutch
- Looking for a part.....Chrome clutch lever perch bracket
- Dakota Digital MCL-4013 Speedometer
- Help Rear tire Question
- Downloading HD Manuals
- 2012 RK vs RKC? Differences...
- Kudos to Long Ride Shields
- Which LED Headlights?
- new rims and fender pics
- props to C&C
- I am broke
- Ricor/KC Int/Rev Performance review
- CB radio
- Front Tire Noise?
- Mini Beast 5 Air Horn
- Bat Wing Mini-Ape Handlebar - New for '12
- Suspension Technologies Shocks - Anyone Have Any Experience?
- gear drive cam tensioner/oil pump?
- Heated Grips with 12.5 Wild1 Bars
- I did not realize I was upgraded.. ?
- rear tire alignment, belt tensionser alignment
- cam swap
- '05 RK (almost) done...
- exhaust question again
- CD player quit already
- Fuel Moto 107" Hellraiser Test & Dyno Info
- Best Brake Pads ?
- Radio Controls
- A+ to Brukus (but bag there tool)
- Any California Motor Officers??
- Dropped my baby.....STUPID
- Another "I need a seat" thread
- Hornet Deer Whistle......experience
- Sundowner with pics
