View Full Version : Softail Models
- Broken snap on saddlebag
- Is it common for control switch pack to go out?
- Progressive 422 issues
- Red key security issue on my 06 heritage
- 2017 flstfbs issues
- 21-inch spokes
- Springer brake caliper question
- Heat Shield
- 10inch or 12 inch mini apes
- 2017 Breakout - shifter change?
- Rear brake switch
- 2010 Fatboy with Street slammer handle bars
- Softail brake calibers
- No Start. Suspect Run/Off Switch
- 2005 softail won't start
- Sharknado
- 2003 Heritage classic fob disabled
- Foot clutch with floorboards
- Speedometer problem
- 2011 Softail Deluxe Speedo issue
- Shut off at light
- Wheel size
- Twin 88 Temps
- Will a 1999 Fat Boy exhaust fit a 1993 Fat Boy?
- 2008 FXCWC Ignition Switch
- Mean city cycles sundowner
- 08 heritage classic accessory connection
- Heritage Front Fender Running Light Question
- replacement petcock
- Help with Trouble Code on 2009 Heritage Classic
- how to check vacuum on petcock?
- My bike stops running after a while
- Let the teardiwn begin!
- Going to spoke wheels but what size, 2014 Fatboy
- Rear tire
- Changing wheels and need help with matching for correct size rear tire
- Splicing softail and street gliding fender help?
- can an old battery cause.....?
- 02 with oil seeping to primary area.
- 2008 Rocker C losing power
- Exhaust flanges fittment question
- Does 1990 Fatboy have the Turn Signal Module
- 93 fatboy blinkers
- 2016 Softail Slim
- Right handlebar controls not working
- Brake Rotor Dilema
- Wild 1 Outlawz or Nice Curves
- Stretched Tank covers and lifts?
- Think I have a serious problem
- ST2 brake module
- 2002 Fatboy Turning Signals
- V&H Big Radius Exhaust…
- Gear change
- D&d what would you do?
- 2001 FLSTC Tachometer
- Gas Tank capacity for 2004 HD Fatboy
- Mystery Crash Bars
- 2013 Heritage Softtail Classic
- Heritage softail 2012
- Looking for a seat
- Need help bought used bike , tune
- Opinions on value from the experts
- Night train Rivera primo dry clutch
- Wobble
- I picked up a SPRINGER today!!!!!
- cam chain tensioners
- Air cleaner/breather cover pic thread. Do we have one?
- Question about 05 Springer front end
- Looking at a 2012 FatBoy, what to look out for?
- Flag Mount for 2013 slim
- Heritage Springer voltage regulator change?
- 2013 Breakout
- Fatbob (2018) oil leaking
- Performance Machine forward controls
- Fork ideas
- Bus Er on 2011 Deluxe CVO
- Safe to drive with unresolved codes
- Please name the Handlebar brand
- Custom Chrome special construction
- 2001 Heritage Springer Steering adjustment
- Before i put my Arlen ness cover on.....
- 2016 Fatboy Lo Front Fender Issue
- "06" Heritage Classic EFI, won't start!
- Tank leaking from plate
- Night train Foot pegs to boards
- 2019 FLHCS Lower Fairing
- Is this an O2 connector?
- Adding USB outlet to 2012 Heritage Classic
- 2005 fat boy parts cvo
- So I bought a Sport Glide
- 2015 Softail Slim Hard Bag Conversion
- 97 FLSTC Headlight Assembly Removal?
- converting a Fat Boy Lo to regular Fat Boy?
- Identifying screw size please?
- Carlini Lo-Pro Risers
- 5 speed trans cover bolt count mystery
- 2000 softail cam sensor…do I need it?
- Heritage bag upgrade
- New exhaust question
- First time ape hanger
- Deuce gas tank
- What is this called?
- Fatboy wheels,
- Information about my 1989 FXSTL Heritage
- Buying OEM exhaus for 2005 FB?
- Normal compression
- Harley problems 2002 FXST softail SD
- New Suspension
- Custom Fat Boy project almost complete
- 01 Deuce Security System
- 02 Fatboy Fork Finish
- Key sign on speed stays lit
- Oil, or lack thereof
- 1991 evo back fires .
- Seat opinions
- Will a 60506-99 outer primary fit the same as a 60543-99?
- Need 06 Deluxe floorboards and mounts!
- Softail rear fender swap
- Sportster 1200 to 2004 Fatboy
- 2010 fatboy lo shocks
- Can't Find 5/16x24 mirrors for my 1991 Springer
- LED Fuel Gauge Not Working Properly
- Dash cam install
- 883r sportster exhaust on softail frame
- 2017 flstfbs vss
- Had This bad boy 22 yrs now
- 94 Fatboy belt rubbing
- Toe shifter extension recommendations
- Just put hard bags on my low rider now it has a front end wobble
- 08 heritage dash options
- Newbie rocker c engine management light and error code :-(
- brake pad bolt
- Fatboy Tank Emblems
- TPS electrical question…2006+ SE TB on 2005- softail.
- 2015 Slim wheels
- 09 Heritage Detachable sissy bar with luggage rack
- Want to install a decent tach on 05 FatBoy
- Seeking Exhause Advice - 2009 Heritage
- 10" mini apes on 05 FatBoy?
- Indicator Issue
- 07 deuce, no front brake
- 2003 Fatboy front/inner shift lever question
- Cleaning glass on inside of speedometer?
- Front wheel replace... tips, sources, specs confirmation?
- Wobble
- 2005 heritage footboard to pegs details wanted
- Need Hand Control Switch Packs 2016 FLS
- 1990 softail starter fitment issues
- '06 Heritage Soft tail Classic grinding badly
- 03 Anniversary Heritage
- Best service manual?
- Newbie to riding and Harley - Issues
- Apes and windshield combo
- what is the size for nut on top of the triple tree
- Advice Needed
- Engine light comes on and bike shuts off
- New Brakes ...
- What is the maximum front fork travel for 2003 FXSTB
- Harley 120R in softail
- hen to change belt on belt drive
- 2015 ABS wheels on a 2007 FXST
- New Bars for 05 FatBoy?
- Turn signal problems got me stumped.
- 2011 fat boy lo
- 2002 Heritage Softail quick detach stock saddle bag and sissy bar
- New Harley Advice Request
- What Harley do I have?
- custom dynamic turn/run/brake module install location?
- New Tires for my 2020 Fat Bob
- My 2014 Fatboy/Heritage/Deluxe!
- Be aware of J&P discount exclusions!
- Heritage Softail Accessories
- Does a Fatboy Swingarm Interchange with Heritage?
- Air ride shotgun service
- My bike steers hard at slow speeds
- Bought my 1st Fat Boy
- Looking for Custom Fuel Tank for EFI models
- New Brakes ...
- 2016 FXSB Front Brake Pads??
- Fuel Squirting in Tank
- Primary pad question
- Fat Boy lo and Fat Boy, what is the diff?
- 2008 seat upgrade
- passenger seat height on 2012 softail deluxe
- 2012 heritage eitms
- 2007 Heritage Softail Classic
- Looking at this Heritage
- Heritage idling issues
- 1999 Fatboy Carb
- Straightening my Handle bars
- Looking for recommendations for shift lever bushing - FXSB
- Hard Starting When Hot
- Has anyone had their factory breakout wheels chromed?
- Crossbones seat questions.
- Speedo and tac not working
- Softail classic
- 2000 Fatboy failed me
- Softail frames/struts
- 05 softail night train runs rough when hot and has hard time starting
- Front turn signal wiring harness
- Softail ignition switch wiring
- New Bars for 98 Heritage Springer
- New wheel for front of Deuce
- Rocker rear suspension upgrade.
- Air ride for an 08 heritage
- 08 Fatboy accessories power
- Right controls not working.
- Fork Fitment
- my softail springer 2003 injection troble
- Heritage wobble in the curves
- Exhaust ID (long shot)
- Best seat for low back pain?!
- Gas Tank/gauge not accurate on 09 Heritage Classic
- Un Screwed?
- Fatboy Saddle bags
- 2005 softail running light dont work
- 2008 Fat Boy
- Sport glide ‘18 front turn signal wires
- 14 in bars on an 07 heritage?
- ignition switch problem
- fishtail slip ons
- 13 Slim - Handlebar or riser - how tall without extensions
- 2011 Softail Deluxe FLSTN 8" mini ape upgrade.
- PCIII needs dyno?
- Light bar make?
- Exhaust swap
- Changing exhaust baffles
- Where can I get this clutch holder? Delux plastic zip tie?
- Speedometer 1997 fxstc
- Breakout with Legend Air Ride line placement
- 2005 Fat Boy FI anniversary addition cranks but won’t start
- Accel tc88 plug gap?
- Picked up an 02 Fatboy today.
- 2004 fat Boy EFI TC 88 Compensator sprocket upgrade help ??
- Lowering question
- Back fire through carb
- ‘15 floor boards
- LA Choppers Kage Fighters - 21' Sport Glide
- Progressive fork spring installation
- Flush mounted fuel cap LED's
- Transmission issues?
- Right Turn Signal Turns on Hazards PLEASE HELP
- Can I get Y'alls opinion?
- How much wind protection from Memphis Shades MEM7011 batwing fairting?
- Cobra RPT
- S&S 336 inlet conversion question
- Hmmm, what to put here....?
- JH Choppers Review
