View Full Version : Sportster Models
- fuel tank lift
- HD Newbie - Gearbox Help
- Struggling/frustrated
- Ignition module wiring diagram
- Wheel spacer orientation
- 2004 Carb'd swapping to 2012 1200 with FI...
- ‘77 xlh 1000 front brake upgrade
- Fuel Pump: Not Priming or Cycle dies mid ride
- 2018 Iron 1200 - Smoking Deal, but with a catch
- ADVICE:I BOTCHED KREEMING MY TANK
- Air cleaner recommendations
- Brand new TC Bros / Burley sportster / dirster build parts - brand new
- Brake light but no rear driving light
- Carb problems! 1971 Harley Sportsters
- Parasitic drain
- How hard/expensive to fix cracked left case?
- Sportster Handlebar upgrade question
- 07 custom 1200
- Help I.D. these grips- I want another set!
- So you got a Roadster. Now what are you gonna do with the rest of your life?
- ‘98 XL1200s Timing
- 2012 Harley XL 1200 Forty Eight fuel pump not priming
- Finding new peg inserts? HD OEM Forward rubber worn
- 2003 hugger
- 2002 1200S Check Engine Light
- 1999 xlh 1200c pinion shaft?
- Rear wheel hub spacers…
- stripped nut
- coil relocation details
- HARLEY'S LAST TRUE MILITARY MOTORCYCLE
- “48” Foot Pegs Gear Peg
- Nightster / Sportster trying to start without pressing button
- 06 sporty speedo
- Sportster gas tank failure from stunting
- High Idle When Hot
- 99 883 sporster
- Battery went dead on '05 1200 custom
- My 48
- Drag pipes
- 1995 1200 sportster crank no start
- Sportster clutch adjustment
- 2019 Harley Davidson iron 883 need help!!!
- XL1200c wobbly clutch basket.
- Sputters & backfires
- Burnt wires
- Roadster turn signal question
- (Possibly stupid) tailamp question for 2014 Sportster 1200C.
- CV Carb Fuel Tank Removal
- 99 883 hard to start
- We was "cool" ....sportster swingarm chops
- What's the best combo for a stage 1 complete setup for an 883
- 1958 Sportster XL 12V converssion
- New life for Patriot Defenders
- Headlight went dim
- 2024 Nightster rear led light question
- 08 Sportster 1200 EFI running extremely rich
- Loss of all power while riding
- Question on changing out the oval intake cover for a round one
- 1991 XLH 1200 performance gains
- 92 Sportster Seat mounting Help
- 2008 sportster custom
- Possible Exhaust Project
- Air✓Fuel✓Spark✓Compression✓Timing✓... No Start Still
- Speedometer, tach and dash cluster help, 2014 Forty Eight
- Front end bounce?
- Increased RPM at warm engine idle- 1991 XLH 1200
- HPI 51mm sportster throttle body
- Is this a lowering block?
- Sportster...1992.. cast mŕg wheels. I want to run a skinnier rear tire..
- Xlc 1200 Sportster ignition fuse blowing
- Help my bike won’t get hot back cillender
- Fork reflector change
- New Pipes and now stuttering and stalling
- Rear Taillight, Brake Light, Turn signal wiring help
- Hydraulic clutch conversion kit for 2024 Sportster 48?
- Can you add the Fuel level Sensor to a Sportster after the Digital speedo has married
- New Rider Recommendations
- New saddle for my Iron 1200.
- Stalling at Stop Signs
- No fire
- Dual disk brake ?
- Rear fender holes
- Help
- 1990 clutch basket/rotor replacement
- Rear shocks recommendations
- 2003 XL883R motor mount bolts
- Torx Bit Torque Adapter?
- Extended cable lengths for handlebars?
- Knocking sound at 2500 to 2900 ish rpms
- 2017 sporty possible ignition switch problem
- I recently got a sportster from my grandfather
- Sportster fork cap extension? 5 inch " are they safe ??
- Exhaust Stud hole misaligned
- R&R wheel and now no rear brake?
- Clutch issue with the 1200
- 2005 XL1200R Hot Start Issues
- Rear axle adjuster
- Am I screwed?
- Race tech springs vs stock
- Battery pole broken. Again!
- New to me 1992 sportster...
- 07 sporty 1200
- Help Action Planning Sportster Project
- 09 XL883L low mileage is idle normal/ticking
- Cleaning up the Carburetor
- 2011 sportster 883 engine swap to 2016 Milwaukee 107
- 2008 Sportster 883 fuse box cover
- 21" to 19" front wheel conversion
- 08 EFI Sportster rear misfire
- '13 48 - No Front Turn Signals
- Pathfinder 5 3/4" LED head light fitment
- port and polish
- Having trouble reinstalling OEM slip-on mufflers?
- Sportster shock fitment
- Dropped my 48, need help finding a replacement part
- not sure what to do in this case
- 1978 Sportster adding electric start
- Burning Oil
- Forward controls brake rod too short
- Front fork spring difficulty
- Tail light on, but does not change when braking
- Suspension upgrades for 2020 Iron 1200
- Need A Six Hole Derby Cover in Omaha Today
- High RPM at idle and riding
- 1997 Sportster w/6.4 miles - Value?
- Wire harness
- 2003 1200 sportster
- Recommend me a sprocket
- 03 100th Anniversary 1200C stock riser height?
- gear ratio
- 2011 Nightster Shock Torque Values
- Frame Mounted Sportster Seat - Options
- 2001 Sportster backrest
- Anyone recognize this windshield?
- Aftermarket LED rear tail light wiring/install
- The beast awakens, what a huge difference 👍
- Forty Eight stalling
- Front Upper motor mount in tension
- GoPro handlebar mount?
- Leaking Rocker Box 2007 sportster
- Air Cleaner Bracket
- Parts compatability....
- 1991 xlh 1200 Clearance Between Belt Pulley and Shock absorder
- 2017 XL 1200 Super Low
- Stock 883 vs 1200 factory exhaust
- 1990 XLH883 solenoid button
- Forty eight at highway speeds
- Minor leak
- Isolating parasitic draw
- Battery Shutoff
- Front Brake Lever replacement
- 13 XL1200C Further Forward Mid Controls
- 05 XL1200c vs 09 XL1200n forward controls
- Fuel Mixture Tool
- Problem with my Harley's RPM
- Getting Rid of Handlebar Controls
- Right Turn Signal Dead
- Wiring troubles
- backfire when idling, and low rpm
- Replica Screaming Eagle II Mufflers
- Rear Fender Mounts
- Ape height
- 1972 1000cc XLH Ironhead Build
- CV Carb Andrews N4 Cams
- cost to convert mid to forward controls
- Back firing breaking up and stalling
- Another weird oil issue
- passenger floorboards
- 2005 sportster making a ticking noise
- Springers
- 2005 sportster xl1200c bogging at 90-110
- 2005 sportster xl1200c Exhaust
- Exhaust Stud nightmare
- 1991 XLH 1200 Air Cleaner
- '82 Carb/Inlet question
- Fitting Vance and Hines exhausts.
- SuperBrace 5183-01,-02,-03, etc, all the same?
- Neutral Hard to Find/Skipping Over
- Idles only on choke - have video
- Garmin Vehicle
- 2003 sportster custom 1200
- Single seat 2005 sportster XL1200C
- The Tijuana Stage One
- 88 HD 883 LED bulb replacement?
- Is this an issue?
- 2016 XL 1200 custom cx Running light / brake light issue
- HD Mirrors?
- Turn Signal Button Cap Extensions
- FBD exhaust, any one ever heard of this company??
- 2002 Sportster 1200 Custom issues
- 1998 Sportster 883 Dies While Riding
- No Power
- 2013 Sportster Lights Won’t Turn Off
- XL1200CX handlebars
- Primary Oil Milkshake, How Bad Is It?
- Am I missing something? Why do slip ons/2-2 exhausts outperorm 2-1?
- Thunderheader Fitment
- 2006 sportster xl883c amazon carb
- Engine sputters and stalls above 50 mph
- Forward controls and oil filter location 1984 xlx
- 2020 Sportster Iron 1200 Wiring Questions
- handgrips getting my hands black
- Another seat question Please.
- Air filter cover replacement,
- 2015 XL1200C rear light replacement (69352-11A)
- 2012 SUPERLOW XL883L Wiring Question
- 1990 xlh 1200 nightmare.
- New guy
- 2000 sportster strange noises
- Seat for 1200 Custom, I know, I know........
- What is the width of the OEM sportster Engine Guard?
- 2016 XL 1200 intake and exhaust question and suggestions
- High rmp's on starting
- Sportster wont Idle after handgrip change?
- scary noises today
- Rear rocker cover
- 2000 sportster frisco tank
- Sportster Tanks with FI
- Screamin Eagle timing cover for sale
- 2002 xl1200c misfire
- Do I have S.E. IV?
- 2010 sportster 1200low rear shocks vs seat upgrade
- X-r 750 replica
- Electrical Schematic for 2004 883 or anything close needed
- The 1200 is dropping a cylinder when shut off and restarted
- Rear Brake caliber pad spring
- 97 evo motor won't start after repair
- Left Side Control Issues
- Cant get it right
- 89 Sportster front brakes seem lacking.
- Engine oil in the primary issue
- Starting issue after mods
- Where is the data port on my 2018 Sportster?
- 883 to 1200 kit experience or help!
- Knocking after adding oil
- Rejetting carb for exhaust
- 2003 sportster fuel tank conversion
- Back to the Fold
- 13 sportster kickstand ideas???
- Crossover Pipe
- Xlh 1000
- Why?
- Kick stand washer
- 1200N Black or Chrome Daymaker Headlight
- 2009 Sportster 1200xl low wont go past 25 mph
- Best fuel octane for Iron 883
- Rear wheel axel upgrade
- Cast alloy rims
- Fuel stabilizer
- New tires
