View Full Version : Sportster Models
- Rebuilding advise 2003 Sportster 1200C
- spring seat for 2006 883......HELP!!!
- Anybody ever wrap their slip-ons?
- Starter sound like rocks are inside when it cranks
- Gronk Mod Newer Sportster
- handlebars and cables for 72
- Wanted better/brighter brake lights...
- Screamin' Eagle ECM reflash advice
- Spent most of the day making a Frankenstein tail lamp
- Pics of Joker 4" Black Risers???
- minimizing vibration
- 48 vs. Nightster
- New to forum....
- Power Commander 3 Questions. Please Help!
- Front tire purchase, bought one last summer for $74 where did I find it?
- Difference in Aftermarket SHocks - Progressive
- If Battery Fails ?
- Looking for post on shocks from a while ago
- Need silly info.
- Tank lift on a 09 low
- Anyone?
- engine/clutch problem?
- Bag + Pegs? Fender swap? Peg Hardware?
- Rocker cover bolt size?
- pls help - what bars are these?
- my nightster
- Bought a 2009 XL1200C with 127 miles on it......
- Not happy with my Michelin Scorcher 31s
- Two Tone Nightster Tank On Seventy Two
- 1996 Sporty 1200 Custom Shuts off While driving
- Will 06 sporty seats fit 08 sportys?
- Sporty Driving Lights?
- Sportster 48 tank decal?? Where can I buy them?
- Who says you can't tour on a Sportster ?
- GaugeMods...has anyone here had this service done?
- Gronk Mod Fail.
- HD Passenger Pillion - Anyone have/use one?
- Iron brakes...?
- Barn Find
- Non Dimple Handlebars Installation..
- Squeaky Sportster
- 1996 883 Stock: What PSI reading should I be getting per cylinder?
- Dealer
- Harley 48 Throttle,Clutch & Brake Cable Inquiry
- new handle bars
- My Mods Thread - 2013 Forty-Eight
- I'm in love.
- 10 days waiting, now parts are here
- Electrical issues with my sporty help!
- 3inch risers 1inch pull back
- Iron upper belt guard
- First HD
- New Member New Bike (to me)
- Best way to install the shift shaft bushing
- guess what happened to me today
- which tuner
- 1990 883 speedo question
- Speedo Mount Ideas
- HD Swingarm Bag with LaRosa Fuel Canister?
- Rocker Box Covers - DIY or Dealer??
- Maps: Fuelmoto vs Dynojet
- Anybody "like" the Dunlop 401?
- 3.5" handle bar
- My Build Thread: 2007 Custom 883
- Sporty swing arm
- Finally got lost!
- Spark Plug Specs
- Heat Resistant Wire Cover
- Looking for 1982 Fender Emblem
- Front and rear break adivse,Wanted
- Hi Moved and lost My Oil sheets
- Where to purchase roadster fork?
- Brake light delete, turnsignal to brake Tristar module, I cant make it work ....
- 2013 sportster 48 speedo relocation
- What is this?
- Got my project Sporty!
- 48 - axle spacers
- 2012 sportster speedo/indicator plug diagram
- finally installed the springer on my nightster, but...
- sceaming eagle II baffel lost
- Second Miserable Summer - Carb? Something else?
- SE Clutch kit and soft clutch option?
- Need some advice
- XL883R TSSM replacement.
- removed upper and lower belt gaurds
- won't turn smooth
- best handle bar speakers for a guy with crappy hearing
- wraped patriot defender
- Problem with a brand new Saddlemen seat ‘explorer standard’
- I just found this under the seat.
- ***883 handlebar Help***
- North Carolina Sportster
- Seat help
- Just had 1000 mile service done! and WTF
- Opinions on 2011 xl1200 c build
- Help with LED stabilizer
- Soda straw mod
- 883 Conversion vs 1200 Forty Eight w/stage 1
- Iron Mod fever
- Sportster Solo seat Question
- Leaking Petcock
- 48 risers + Todds apes
- whats next?
- Maps for Education
- Starting issue
- Nightster purchase questions
- Iron love affair~
- Dealership giving me the run around on rejet?
- Speedo Stopped working!! Blown fuse 1999 Sportster 1200XL
- Stock Air Intake
- Went with the HiFlow 425 from DK
- Primary still
- Mustang Tuck n Roll seat anyone using this
- rear pulley questions,help please.
- Sportster service manual question
- Jet size recommendation.
- Joker speedo clamp.
- sportster iron stage 2 big bore
- Anyone know a 4.25 x 18 whitewall tire?
- New air cleaner!
- 48 Tank Logo
- Iron mpg
- Help w forward controls.
- auto tuner
- Tank Bag Installation
- is this normal??
- Some new gas caps to choose from
- What grips work with bar-end mirrors??
- Question about checking front end critical fasteners
- My first long ride. Vancovuer bc to kelowna through manning park.
- What Type of Gasoline Do You Use?
- Turn signals to running lights
- heel/toe shifter
- Need a little help
- 1200 to 1250 mod?
- Need Help installing Memphis Gauntlet Fairing on my iron 883
- New buyer
- whos got the highest mileage sportster?
- Had to drive in heavy rain today...
- I have a seal Leak (picture)
- Hearing a winding sound
- Mt. Rainier Photos
- Xieds + fuel pak
- Iron 883/1200 SE parts list..
- A little help?
- TSSM module dilemma, help!
- new 48 rim, is this normal
- '82 XLH1000 won't start
- need brake line help please
- breakers in UK
- Dippin My sporty... Tank removal
- Any suggestions on how to make my front end more comfortable?
- Exhaust or ac
- None mushroom helmet..??
- New Owner
- Cafe fairing install?
- Has anyone ever hot dipped/oil blacked parts in oil?
- Recommend a gear indicator
- Problem with K&N filter
- changing bars on 883 custom
- Run/Brake/Turn Module for 48
- Handle bar wobble at 30+mph
- 10" mini apes install on my nightster
- 09 Nightster Front Fairing HELP
- Additional settings for V&H fuelpak with short shots
- Buying a bike for Son and Daughter inlaw
- My 09 Nightstermachine
- sportster nightster and iron seats interchangeable?
- Iron Windshield?
- my 883 iron
- V&H exhaust without a tune
- Quick Q from a new 1200 rider... why are they considered underpowered on the highway?
- anyone tried these 3/4 helmets?
- fixing rear caliper on sportster
- Heat Wraps~?
- help my 1987 sportster
- Finally found her, 883/1200 Iron
- Can Someone reccomend a Clutch?
- Black Ape Pics on an Iron?
- Random cutting out
- Pullback risers
- Odd problem, thought appreciated
- New guy. Looking for referances
- Input on Intake and Tuner
- Spring 2013… almost final mods! (( 100+ pictures! 56K go cry! ))
- How do these new emblems look?
- Desert Sunset Pic with Ghost Rider
- I need help
- Shifter leak
- Nightrider AF-XiED?
- It always pays to think fast on a sporty
- Do I really need Premium gas in my EFI Sportster?
- Brake wires shorted all lights, speedo, and odometer
- 08 Sporty custom
- help with mid controls
- my 72 is ready
- Rush slip on and heat wrap smoke vid
- Gas tank
- Ladies and Gentlemen.....It's an honor.....
- My Orange Nighty!
- Forty Eight + HD solo bag + passenger pegs....it works!!
- starter running while bike running
- Best tires to go with
- Stator/clutch upgrade Combo
- 72 intake on a 48?
- Bolt-On 1250 Kit?
- rocker arm noise
- I need some help
- puddle of oil after running.
- 2007 sportster won't start
- Upgraded brake pedal.
- Cleaning Gray Powder Coated Covers
- Suicide shift
- New rear brake pedal!!! Check if out
- Went down on 3rd day with my "was" new bike :(
- best speakers for a sportster
- Widest tire on stock wheel?
- Biketober Fest
- Moving bars back?
- Help on intake
- Traded my 06'883C for....
- Forty-eight recent prices????
- Nightster wiring question: HELP! :-/
- Big Radius and 1200 conversion prices
- Connector Question
- Got The Gals Bike Comment @ The dealer
- Analog tach combo fuel gauge problem
- Oil Light on my 883 Iron
- Painted the Sporty
- Rear brake problem. Help ASAP
- Heavy vibration on throttle, tension adjustment??
- Thunder Torque INSERTS
- 2005 XL1200C starts but dies???Eletrical short???
- Underestimating the stock ham can air filter over open AC
- coil resistance help
- My Nightster Project
- Questions - Sissy Bar and Swing Arm Saddle Bags
- 2013 Iron 883 battery question
- 1990 Sportster engine oil question
- apes on a superlow?
- Rigid Mount Sporty Build
- Engine bogged down on heavey acceleration!!! Low fuel?
- Fuel starved in on position
- Looking for RSD Risers PLease Help
- custom clutch cable frustration
- Couple of questions before i attempt turn signal relocation..
- paint vs powder coating
- Sportster backfire
- Finally chopped and hard-tailed.
- Rider Peg Mounts?
