View Full Version : Sportster Models
- NOx Info for '04 Sportster?
- LED turn signal conversion help!
- Wire tuck with no tank lift
- Sportsters from Daytona
- 2016 883 iron front caliber ?
- exhaust identification please
- help with code p0262
- 2017 exhaust on a 2005 883 custom?
- Sportster does when letting off the clutch
- Clutch Drag
- Getting a check engine light Iron 883
- Check engine light & P0132 error code
- 883 XLH 1990 Alternator Magnets
- Sportster belt issues
- Ham Can Backplate Mod for free flow
- PV Volt Guage
- Swingarm Axle
- 99 Sportster 1200 Issues
- Saddlebag options with quick detach sissy bar
- High Milage Tires For Sportster?
- Drag Bars on a 2017 48 questions!
- Oil Tank Fitment Issues
- How low do you run your oil
- Wich ignition mark with VOES disconnected
- Random no pressure in front brake
- Fork lock question
- 1989 sportster transmission question
- 2016 Sportster 883
- Help in choosing slip on exhaust
- Coil relocation/engine mount
- 2016 Sportster ECM Factory reset
- 2016 Sportster 72, running rich!!!!
- ‘99 1200 Cut Out Mid Ride, Now Shoots flames trying to start up
- forward controls
- 1987 XLH1100 Gas in Oil
- Installing new jiffy stand
- Which Sportster would you recommend
- Help identify Sportster
- Brake line length for 10" zbars?
- installing bobber seat on a 1999 Sportster
- Help with blowing main fuse issue.
- Destroyed baffle removal help
- rocker box fasteners 97 evo
- Sportster 1200 baffles removed
- Sportster will not go into neutral
- Motorcycle Covers
- Sportster “bug out” sissy bar
- Highway Pegs for Iron 2017
- Sportster Iron 883 Slip on Street Cannon Question !!
- I'm back, front fork kit 45400176 ? Worth it?
- Rejet a carb
- Push rods and tubes
- Question before buying a 99 Sportster
- My 96 Build. 10 Years In The Making
- Anyone fitted a springer front end to their Forty Eight
- Cable lenght question
- Mirror Recommendation
- 08 Nightster Build Thread 10" Mini Apes
- Sportster for a new to Harley
- First post..... of course for help
- 21" vs 19" Wheel
- 1200 custom build only sparks once?
- Turn signal extended switch cap replacement
- Iron 883 round filter mod
- Has anyone used this for a brake rod
- New used bike
- What Battery for a 2017 Iron 883?
- Forward Control Mount 2018
- Raising front suspension on a 2018 48
- Finally jump back in the game and bought a Sportster
- Laid down 2012 Sportster 1200 on left side, won't shift down
- click or tick noise with letting clutch out
- 1200 sporty. Fix&Flip? or Stunt build?
- Sportster 883 right blinker not working
- Thinking about a new seat set up
- Tuner near me?
- Brake pedal swap
- Reflector issue...
- 1999 883 swap
- Top end rebuild help - knicked piston head
- 2016 xl1200c sportster - slip on mufflers
- Air Cleaner Upgrade
- Speedo relocation
- Upgrading 2001 XLC1200 heads/ pistons
- Clutch Adjuster Screw Bearing keeps Failing?? 1994 Hugger
- Sportster 2014 883n
- Hollywood Bars & 7" Fatboy Headlamp
- single gauge pod with indicator light space for tbar
- 2018 Iron, New Handlebars
- Size of bolt holes in rear fender??
- Spring Seat VS Regular Seat
- New Sporty rider with questions
- "EBay" Detachable Sissy Bars
- Sportster in the shop again with electrical problems! Any thoughts on possible causes?
- Air shocks
- Speedometer Reset Push Button Failure
- Sportster forks
- Iron Forward Controls Replacement
- Cables
- Sportster easy pull clutch
- Current Member, New 2015 48 Owner
- need to know how much my bike is worth so i can sell it for money to move,
- Straight pipes on Sporty
- 1200 to 1650 conversions
- Is this Black Pin Stripe Vinyl?
- Saddleman seat
- How well does a 1200 Sportster do for 2 up riding?
- 2018 HD Sportster Iron 1200 Gas Millage
- Help! 35mm forks on a frame mount evo
- Bolt for rotating latches
- Pretty much have given up on Burley Brand
- Iron 883 Rear fender removal for a chop job
- Made my 2013 883 a hardtail
- Oil pressure/ oil pressure ports locations
- 2013 Sportster 1200C -- Switched wire?
- DIY QD hard bag mounts for Sportster
- Mid-Controls
- A not so sticky situation...
- Suggestions on Stage 1 Upgrade
- need to know how much my harley is worth so i can sell it to get money to move.
- Stage 1Upgrade
- New bars
- Bank Angle Sensor
- Spongy front brakes
- Fuelpack and 1200conversion
- Different length forks for sportsters?
- Phat Spark Plug Wires
- 1992 XLH wider tires than stock
- Shorter kickstand?
- starter brush holder
- Driver pegs
- Belt Adjustment
- Aftermarket speedo on 1999 sportster
- 2017 Iron 883 repair cost
- The "unstable" issue I cannot seem to cure
- Anyone swapped 39 to 49mm front end on 48?
- Screemin Eagle Performance II SE-585 cams for Sportster
- Derby cover removal - stripped heads
- Sportster Forward Controls
- Luggage rack load
- Sportster wiring issue
- New to me 89 xlh
- python slipon bracket/mounts for sportster
- Brake lines for 1996 Sportster xl1200s
- Poll
- Over fork tubes and new springs
- What do y'all use to make white walls WHITE 😁
- New Sportster Owner
- What’s cutting into my drive belt??
- rims
- I bought a Harley 1200 2005 and it needs work :-)
- Lost right side lights...help
- Black Headbolt Bridge
- Mech problem
- Getting a free 1987 883
- Are these Sporty Mufflers?
- crap, my 1100 mile 91 sporty needs a battery
- Progressive 412 Series Heavy-Duty Shocks
- Anyone looking for a Long Black oil filter for their Sportster?
- Detachable hard bags and sissybar
- I so freaking HATE!!! Wintertime
- Best tyre and rim sizes for convert
- Show me what you yours
- sprocket cover made by Figure Machine
- Chain conversion questions
- WTB beach bars?
- Engine won't shut off by main switch
- Difference in Clutch Kits?
- La Rosa Passenger Pillon
- Chrome?
- Rev limiter question
- chrome removal
- Fuel usages
- Sportster XL Low 2009 Evo 1200cc
- New sporty in the stable
- New to me XL1200V - 72
- 2000 screaming eagle factory 1200 carb upgrade
- Speedometer upgrade
- Gear Oil is totally okay for the primary/transmission...
- Carb jetting
- Please recommend the Twin Power Clutch Kit primary oil.
- Front fork cap thread size NEED HELP!
- Handlebar Options for Short Riders?
- Intermitent cut out
- Mustang Vintage Solo seat fitment question
- Carb is huffing and puffing white smoke?
- 2016 XL883N Iron upgrades
- 2011 thru 2016 XL1200C
- Max Hazan's Ironhead Powered Beach Cruiser
- Head bolt / cylinder stud thread problem
- V&H Straight Shots worth it?
- Can't get Sportster to go faster then 80 mph
- Rear Tire
- 2007 xl1200c T sport fairing install question
- Memphis Shades and Harley clip on fitment
- Installing a '97 rear fender on a 2000?
- Fork Tube Lengths
- Solo Seat Swap?
- V-Twin Manufaturing Stepped drag pipes and Bassani Pro Street
- Sportster solo seats
- Storage question
- Thrashin Supply Mid-bend on '14 Sporty
- Installed My Stage 1 Conversion Today
- Broken rear taillight
- Sportster intake and lowering kit.
- 2018 Iron, UGLY headlight brow
- Harley Sportster 2001 won’t start!
- Would 2014 Iron Front fork fit 2018 model?
- Front brake calliper
- Best Waterproof Stage 1 Air Cleaner?
- Questions about Sportsters
- 2019 race season is approaching!!!!!
- Show off your XL's
- New Sportster
- Potential move from a Triumph Bobber, need some advice..
- Lost rear wheel spacer.
- XR1200X tire options
- Passenger peg removal
- Poll: plate position
- Intro: New owner and new to forum
- replace spring on rear shock sportster
- 2015 SuperLow 883 forward controls
- Sportster Carb Coughing
- Energy One extra plate kit
- Different year coil?
- How Do I Remove Speedo But Retain Indicator Panel
- progressive rear shock bushings
- Where do you look?
- Iron head Engine Noise (normal)
- Fuel octane question
- Sportster tach kit from HD
- Air Filter / external breather question
- 883 iron
- What rear shock is this??
- 883 primary sporcket on 1200
- 98 Sportster shock bolt
- Cam identification help
- 2019 Sportster 48 key ignition (not smooth)
- interchangable parts 2007-2019 xl
- Rear controls on a 2018 48 xl1200x
- Sportster dual side exhaust
- Slop in brake pedal
- sportster engine or trani freeze
- Solid vs rubber mount
- Need torque specs for front drive sprocket nut
- Front springs question - Ricor
- Evo sportster 1250 big bore help?
- Speedo delete.
- Changing up to 180 / 200 rear....
- 883 conversión to 1200
