- Oil leak remains after repairs
- Problems with 2013 Forty Eight Sportster...
- 2008 sportster XL883L
- Murdered Out 1200 Roadster
- CV axle going bad??
- Harley Premium Ride Hand Adjustable Touring Shocks Low Profile
- Gas cap won't click over tank bib
- Getting the Project 48 Ready for the Hot Bike Tour
- Need help identifying a part
- Lowering Kit
- Where can I find a service manual?
- Speedometer
- Indian fender on 72
- Headlight Replacement
- 50% Chance of Rain: Ride or Not-Ride?
- 2016 883 Iron - Rear Fender Bolt Size
- Can I ride on this...
- Rear sets
- California exhaust
- Rush Slip-ons & X14IED on 2009 Sportster XL1200C
- What footpegs you using on 48 with offset clevis?
- Sportster 2014 XL883l -tipped won't start, stranded!
- what is Califonia highway minimum speed?
- Rear brake caliper removal on 99 sportster 1200 custom
- New 08' 1200 Low owner
- Miles before top end rebuild?
- Leaking breaking caliper.
- 2005 Sportster xl 1200c loud knocking
- bad solenoid -with soft copper contacs
- 1970xlch
- Cycle Shack pipe ID Help
- Luggage rack seat
- Conflicting Specs on 2004 883C
- Data Link Connector
- Vibration under load
- How tall are you???
- need input on air cleaner
- 2016 Roadster Exhaust Help
- XL-ViED Problems
- Air filter help
- Headlights and Gel Pads
- 1982 H-D Roadster Oil Pump Drive Gear search
- Fuel injection nightmare
- Vin / serial # issue confusion
- Big radius pipes/stock air/stock ecm maps for pcV on my sportster 48 2011
- Can I use a no-name brand headlight on my 2016 Iron 883?
- 2015 Iron 883 Exhaust Torque Specs
- 2005 xl883l Build
- Hammer 1250 kit
- fairing fitment question
- which fairing should I buy
- HD 48/2012 Engine and batery light's poped up
- Question for 72 owners, front wheel tire related.
- Are slip-on's damaging my 2016 Iron 883? [NEW MEMBER]
- cover keeps falling off
- single or double fire?
- Turn Signal Indicator
- Mid controls for 2016 48.
- Screaming Eagle Performance Air Cleaner
- Primary cover leak
- Oil leak '01 sportster
- GP3 Connector
- Budget hot rod sportster input
- Hard Hitting Hamer Powered Hugger
- Le pera with stock pillion pad on Forty Eight
- Extended Reach Forward Control
- Extended Forward Controls
- Thinking of buying a Forty Eight...
- Help! New to screwdrivers
- Bike shut off going 45!
- Stock Wiring With Mini-Apes
- Back to the lighter life.
- Help me choose a windshield please!
- Biltwell Clubman handlebars.
- V & H straight shots loud loud !!
- Short leg syndrome
- I need help!!!
- 3,000 miles and an update
- Roadster fairing options
- Seat or seat pad?
- Jets and more jets
- Roadster air box mod?
- What bike nearly tempted you to trade in the Sportster?
- Power Vision Question
- Commending DK Customs service
- Drive belt tension
- Engine died with no warning
- Do I need to buy a fuel pack ?
- I think im done with with my bolt on mods
- Tick
- Springer front end
- Stock Headpipes Diameter on 2014 Iron?
- Vance & Hines Big Radius 2 into 2 question!!!!
- Bike has evolved somewhat.
- Putting in my Rocker Lockers
- 2016 Iron 883 V&H Slip Ons Install Question
- Buddha's Bike
- Roadster 1200 Ecu flash
- Cheapskate fuel bottle
- water bottle
- Not another chick bike thread......
- shifter shaft
- 2016 48 Further Forward Mid Controls Questions
- Best spoked rims for 15 Iron 883? Direct fit.
- Newby w/oil leak question
- Anyone else had problems using iridium plugs?
- Help! Nightster running terribly after rebuild
- 87 octane or 93 octane
- 5 months... Finally got her back!
- Where to find Harley Parts and Prices
- Sportster rear fender Fitment.
- HP 1275 hits the strip
- 3.3 gallon tank badges
- Fastener Question
- No More oil!
- Rear turn signal not working
- My Sport is finished
- What could I be getting sprayed with?
- Battery replacement
- Starting problems and battery drain
- Incredibly Stupid Question: Custom Frame vs Evo engine
- Temporary cylinder down?
- Roadster query
- Good Stator or Bad?
- 73 sporty clutch wont disengage!!!
- Thinking about spring seat on 48... Comfy??
- New to me bike.
- IRON HEAD. Won't Hold and idle after hot start. PLEASE HELP!
- 48 with slip-ons. Tuner?
- Cafe style handle bars.
- Short Shots to loud
- windshield bag
- Trading in the 72
- Any bar suggestions
- New Member - Thunderheader Gasket Help
- 1200 Low..stock bars to 13" La Choppers
- new forum member and project
- Brakes and turn signals iron 883 09 help
- 94 883 Tail & Brake Light not working when running
- New Roadster risors
- Oil on Cooling Fins
- Fat Boy solid rear wheel on Sportster
- I just couldn't do it!
- looking to do my 48 with a springer front end
- Moto/Tracker Handlebars for Iron883
- 1994 Sportster 1200 Is This the Starter Relay?
- 1275 kit with BFH head porting heat cycle
- New exhaust for iron 883
- Grips - Seeking Inputs
- Shifting "clunk"
- Air cleaner knock offs
- Oil?
- 1990 sportster 883 with 1200 conversion/Blown engine What would you pay?
- 1994 Sportster-Starting and Sputtering Problem
- Extended Brakes for Sportster 883R dual brake
- New here and to Harley with a Roadster question
- Stretched Sportsters - needing encouragement - Please Post Pics
- new member here....needs parts
- 91/55 freeway in So Cal
- Bolt Do More Than The Obvious? (OTR)
- Extra bracket needed to mount had daylighter led to 2016 48?
- Screaming Eagle Clutch
- The wife's superlow...
- Whistle noise left side 15 iron
- Le Pera Maverick
- An actual comfy seat
- Review: Short Shots with four different baffle configurations
- Smoke
- How do these work?
- 2016 Roadster...couple of questions
- Air filter and cover: rubber vs rigid compatibility
- Normal or heavy duty shocks
- New cables when changing handlebars on Forty-Eight?
- Clutch Switch
- STarting point for pipes
- Bonneville salt flats looking good
- Busy Couple Of Days...
- Starting Issues
- Stop and plate light wiring
- Triumph wheel to Sportster?
- DIY Bar Knurls
- SHipping delay issues with JPcycles anyone?
- Is there a denim black engine guard?
- Forty Eight Siren Mod...
- burning oil
- Main Ignition Fuse Blowing
- recommendatins for improving comfort on nights tear 1200xl?
- Turn indicator light
- Had a Sportster once
- New Harley owner, NEED HELP
- Iron or Forty-Eight?
- Downside to ABS
- 1200C trans, oil.
- Gas in my oil
- Ignition Module Testing
- 77.5 cubic inch Xl
- Getting ready to use PowerVision. Wideband o2 sensors?
- 2014 883 High Idle problem
- 2005 XL1200R Brake Light Equivalent
- What I found inside the primary cover
- Need a Rear Fender solution
- Looking for help - storage options with passenger pegs
- Ignition Module bad?
- Does the tachometer / speedo...
- Help reading plugs? Rich? Way too rich? Other?
- V&H Competition series 2-1 any good?
- Nightster feels less torquey?
- 2016 883 Iron vibration issue
- Roadsters seat
- Fitment question: Solo seat from '14 XL Low to a '09 XL Custom
- Problem installing clutch side grip on 2016 Iron
- Need a Fork Brace
- Hammer 1250 drag racing
- Stock 12" bars
- Rear brake pedal adjustment
- 2007 Sportster 883C Battery Problem
- Sissy Bar on my 48... HELP!
- Roadster with a headlight fairing?
- Sagging engine mount?
- Primary noise & vibration
- Sportster 1 evil air intake
- Goodbye to the Sportie
- Highway Peg advice needed 883N
- Mirrors and RSD clip ons.
- Hella Sharp tones install
- Zipper's Top End Pics
- Gettysburg bike week
- Sportster Iron handlebar recommendations
- Nightster won't start
- The HD social scene
- What are stock cable lengths for 72 XL1200V
- Huge thank you to DK Custom Products!
- Fuse question.
- Biltwell Frisco bars
- Air / Fuel Ratio Question
- Low Rumble Exhaust - Suggestions...
- 1989 sportster 883/1200 lifters?
- One more down for the Chumps
- 883 to 1250 startup issue
- carb - what to do...
- Cafe Racer bars for the Roadster?
- Trip to the Outer Banks / Kitty Hawk NC. Any Thoughts?
- XL1200C brake upgrade question
- Does anyone have the Length Dimension of the Mid-Glide 11888 Wheel Bearing Spacer Sleeve?
- rear brake pads . iron 2014
- Should it really rattle like that?
- Replacing rear tire on a 2012 XL1200C
- Do I have a Starter or Battery issue
- How much blow-by is acceptable for a new engine?
- Thinking about motor rebuild
