View Full Version : Sportster Models
- Fork Spring change on a 2012 XL1200X 48
- springer style solo seat for late model sportster
- How to make Quick Disconnect on HD Rigid Saddle Bags
- Need help with some Iron 883 add ons
- 1200 New Ignition Query
- Expert help haha
- Fork oil weight
- No Start / Spark Issue -- 2004 1200
- To Freeze or not to Freeze??
- Multi purpose backrest
- what is normal for a jiffy stand
- New park plus & wires, engine is now misfiring
- speedo from 14 for 09
- Went With Synthetic Oils
- 2003 Sportster Right Handlebar Control Switch Question
- Noob makes a noob mistake :)
- New member looking for info
- Fuel line size
- Possibly trading in my Forty Eight for a wide glide
- Exhaust Decision - Sampson or Cobra
- Took the plunge
- It's Sunday So why not a picture?
- Need Taller Gearing-2014 Custom 1200
- 4" over front end
- Sportster trouble
- tapping noise
- Upgrades for 2 up riding
- My previous 04' Sportster
- 1975 hd xlh1000 electric start
- Need an Opinion
- battery not charging
- Forward controls kit & 160 rear tire fitment?
- front forks bottom out too easy
- 2013 72 loose spokes
- Decal Removal
- 87 sportster docking hardware
- Question about High flow Air?!?
- Iron 883 ??
- XL50 dead start switch
- Picked her up today...
- Adjusting front controls..please help
- apes
- Fuel Light
- Sportster Ironhead Gas Tank
- Footpegs - Advice & Opinions please
- Newb/ bike backfiring :(
- 1200T exaust is glowing red hots WHY?
- $1.27 Rear Turn Signal relocation :)
- Checked the DTC codes can't find out what they mean.
- Finally got my bike back together!
- 48 fender bib anyone?
- Clutch won't engage after removing primary cover
- Charging system Question, 1975 Sportster
- New guy from Wisconsin
- From what motorcycle that parts come from?
- What's in your tool bag?
- help! locking gas cap issue
- battery removal
- Kick stand
- Need to extend the brake line on my 1200xl w/ dual disc
- Handlebar top clamp
- Struggling to find info on this issue. EFI Sportster cutting straight away.
- 48 seat with a 4.5 tank
- Easier clutch pull...
- Fork Oil Weight?
- Cool Motorcycle Decals !
- Bassani Road Rage 883-1200 switch
- 2012 Iron 883 Bogging while at low RPMs
- 60 hours to go!
- 2014 Sportster 48 Throttle Sticking
- My Sporty
- Rear axle nut after side licence plate holder.
- Help Please, Electrical Issues 1988 Hugger XLH
- Spark Plug Condition
- help
- 1200 custom
- What the clutch happened? HD MoCo can kiss my brass rivets!
- rear brake master cylinder
- New to the Forums with a question
- Annual sportster meetup Eastern TN
- Rear Pulley Vibrates loose, shearing bolts/hub
- Burly Slammer guys/gals...
- "New" Sporty
- S&S air cleaner fitment/ modification question.
- Biltwell Grips Fitment Question
- rear piston and cylinder questions
- Tight front brake after grip swap
- anyone want to help anot her rider out?
- Not Starting
- Newbie with a few questions!
- I want to see your mustang tank
- 13" Electra Glide Shocks
- moving my 2005 sportster speedo
- Help needed: 07 Sportster 883 stator
- NO SPARK: Custom Wire Help!
- 01 Sporty won't start..rode awesome last night??
- 7"Headlight for 48
- Chrome strip on gas tank
- Biltwell Zed vs. Keystone bars. Looking to pull the trigger soon
- randomly won't start almost like battery is dead
- bike shuts off while riding
- Ignition switch problem?
- 1967 Sportster info needed
- There is any "extra forward" controls ?
- Need Info/Advice On Diagnostic error code check
- rear brakes-2012 Iron
- 07 Sportster 1200 running rough P0118 code
- Highway Riding
- stock cam question
- Speedo bracket from speedo relo
- Is my Brakeline ok like this???
- Bike farts after kill switch
- 2015 Sportster 48 in Charcoal Pearl
- 250 miles too late to break in?
- Seriously Considering a 1250cc conversion. Your thoughts?
- if you have a 1250 kit installed and a carb..
- Forward control
- Bar identification help??
- Cast / Forged Wheels for a 2009 XL883L
- 09 Iron Road King Shocks
- Installing Screaming Eagle SP slip-ons. What do I really need?
- Nightster Crooked Handlebars
- extending forward controls
- Fork Bolts - Sporster 48
- New guy here with some Sporty questions
- 14 48 need some help
- New Roland Sands Turn Signals on My '90 Sportster,But...
- Is this a starter issue??? Need advisee
- Leaking Footrest On Primary Case.
- Help with a Compu Fire HDE-1
- My Forty Eight
- 1988 sportster 883 no spark, inspect my ignition sensor and rotor (pics)
- 1000 mile service.
- STOCK 2014 XL883L Supelow handlebars
- Rejetting
- New sporty
- Unimpressed with Mustang Low Tripper.. what next?
- Stock numbers for 48
- Flash tune before or after break-in?
- Backrest help
- Just ordered a hammer 1250 kit. Do i need a new clutch?
- What jack will fit under my Nightster?
- Sportster touring backrest and trunk/saddle bags
- 1200 Conversion help
- 883 cuts off when I brake hard
- new tires...what a huge difference
- Iron Fork Boots
- Sportster startup help!
- "72" Big sucker help
- Stupid confession - dead battery
- ok now for the brakes
- Wheel and Tire fitment help quick please
- & now the pipes....
- 2012 sportster 1200 windshield mounting help??
- breather oil leak
- Bullet directionals
- Front brake issue
- RSD Slants vs V&H sound
- Leasons Learned
- 09 Iron 883 - 1200 converted VIBRATIONS
- Fork Deflectors
- Inherited a HD but not a rider :(
- headlight
- Primary oil tranny oil clutch oil
- New Look for the Bike
- New handle bars
- 883 vs 48 new buyer advice
- 2014 Iron, the bike wont start
- Exhaust/Baffle?
- clutch cable snapped 2013 72 any known defect?
- New Rider
- Under Rear Fender Turn Signals/Tail Light LED - Where to Buy?
- Changing the seat
- Dyno Tuner in San Diego
- Just bought this 1200 Iron today
- Chopping Fender and changing brake light on Canadian Iron
- Side Mount License Plate
- Rough idle when hot.
- Noob Battery Question
- Concidering moving to a dyna wide glide
- HD mini apes.. don't like position of brake
- Purists beware, a 'can it be done?' thread is within, involving Honda parts...
- I didn't know I bought an electric/hybrid bike!
- I need a new wheels and maybe convert to chain drive
- 1st long ride on the Iron 883 (580 mile)
- Led replacement for brake/tail light bulb
- Vance and Hines VO2 Intake, can I add a breather?
- Iron forward controls
- Forward Control Options
- Wet sumping robbing hp
- fat rear tyre conversion (uk)
- Harley Site Pictures
- loctite nuts and bolts?
- Ever Shipped a bike?
- tips for first long ride
- oil blowback on my sportster
- Air filter washed one too many times..
- Yet another oil leak question...with pics
- knocking noise from what seems to be gas tank
- Rear brake/caliper/rotor issue
- INFO on Security System
- Sportster adj pushrods
- 1999 Sportster xl1200s tail light removal ?
- Shocks.. 'lower' and 'comfortable' mutually exclusive?
- 2014 883XL - Hard Start and Whiney EFI
- Oil Temp Gauge
- 2008 xlc seat on 2010 iron???
- 2012 nightster front end
- DELPHI troubles, again!
- Bearing Removal $11 DIY
- Auxiliary Forward Lighting ?
- '96 1200S - Need advice
- Clean slate on 2nd 48
- Burly or LAChopper cable kit for apes ?
- Ripped off battery terminal
- New Member with Blinker problem
- Where to buy new wheels for Nightster?
- Forty-Eight - Smoked turn signal confusion
- ??Saddlemen Renegade solo seat..
- iron 883 2014 Brake sensor failure
- My sportster iron (hopefully as fist time uploading a pic)
- My Neighbor
- 1983 sporster primary oil problem
- rocker gasket question
- Le Pera Villain on 14 Iron
- 180 rear tire conversion 48 - COMPLETE :)
- Certain years of Sportys to stay away from? Shopping used for the wife....
- 2003 Sporty - shift points? Lugging?
- Figured I'd ask in here
- Need Mirrors & Advice
- asking for carb info on my new to me 76' XLCH
- Clutch not disengaging completely??
- CrashBar/EngineGuard for ext forward controls
- 2009 Sportster Running Rough
- 2010 Sportster Parts Catalog not listing 48?
- 2014 Sportster 48 bar advice
- Troubleshooting...
- Buell engine in a XL
- Anyone down a chain conversion?
- Club styled out my bike
- Maintain engine paint
- Security system
- 2014 iron vs 48
- 05 Sporty's...used...anything bad on this year?
- 08 nightster pulls left.
- Throttle stuck
- 1983 xls sporster oil problem
- low fuel light comes on too early
- Biltwell Bottle Opener (2 Hole)
- Help with bars for 1200C
