View Full Version : Sportster Models
- march 1, 2011. sad day
- Riding 2 up with a heavier passenger?
- Rear brake lost its "bounce" after F/C install
- How do I get my bike in a magazine?
- Local 48 w/ custom/homemade suicide shift
- Passenger pegs
- Well if ur thinking of sanding your tank...
- After winter maintenance
- HELP! 6.5" Pullback Risers
- Passenger seat suggestions for the gf
- Front axle
- Tail light not working...
- help
- 2000 883C speed sencer (VSS)
- Broken stud in head
- 05 1200c and Joker Speedo wiring???
- Bike is going to make me poor
- passnenger peg mounts 04-up (black)
- Exhaust question for an Iron
- does not wanna idle!
- Clamps
- Melted microfiber cloth on my chrome heatshield...
- sportster forty eight drag bars
- 72 HD Sportster xlch 1000cc - My first Harley D.
- forward controls
- tank lift pics
- Before and After
- Doing some work need help
- Forks/Rim
- Hand controls for small hands
- cam gearcase cover
- Oil Change - 2003 883R Anniversary Edition
- Willie G Skull hand grips
- Removing Baffels?
- -2 Springer
- Rocker Box Gasket Failure Rate
- Down time
- Stock Dummy Lights and Joker Relo.
- 9", 10" or 11" Solo Pan Seat?
- Daytona Twin TEC 2 tuner? NEED HELP
- 1999 1200C bigger tank
- Grabbed a 07 Nightster
- Help!!!! sportster not reving up
- does a 2008 sportster have a "self adjusting primary chain"?
- '03 points cover on a 2010
- Rear Fender Removal...HELP!!
- Speedeometer Connectors
- Motorcycle over-pants
- Finally Happened......
- Tools required for bike-prep
- Springer Seat From Drag Specialties
- Few ?s
- Speedometer Connector Parts
- 1200 Custom risers
- Winter mods finished do you like or not
- solo bag for the right side?
- Need insight on engine light issue
- Debunking the maintenance myth
- Anyone having trouble with swingarm bushings because of struts
- nightster flame thrower!
- What are these struts?
- Top End Gasket Kit p/n 17049-04a - Confusing
- Scary lesson learned..
- strange leak?
- Introduction - No offense to the BT crowd.....
- 87 sportster speedo question?????
- Did this to my kid's Nightster
- Tank Lift, Drag Bars, coil relocate, Bike Won't start...
- first time oil change
- Bob on this!
- Did rocker cover gaskets, hope I did good!
- got my new bars
- Made a new set off brass struts today
- Replacing Rocker Box Covers
- Belt to chain conversion?
- Anybody using running boards?
- Hello... New here
- '06 1200c
- Rear trun signal relocation....what to do with the holes!
- New life for some old bars
- Nightster CHOP
- Last of the winter mods (i think)
- Lookin for a 48?
- Eagerly Awaiting Paint For The 48...
- forward controls?
- Idle Question
- HELP! Bike won't start!
- Help needed removing neck bearing
- New LED taillight
- Side mounted license plate frame.. Where to mount?
- bike dead
- It's almost that time
- heat shields for V&H 2:1
- Trouble with sissy bar side plates
- 2006 spotster custom tail light mod
- Finally!!!
- What size jets???
- cam/crank bearing inside diameters?
- Stock side mount license plate part #?
- Rush Slip-on Discoloration
- doing some work on a buddies sporty
- Need help with my 2000 XL1200 custom
- Harley LED headlight ----sucks!!
- Crusi'n or Brusi'n
- Fly screens?
- couple 16" ape questions
- A few new mods
- Sporty riders in Japan
- Tamarack 1.75 lowering blocks installed and 6k hid..
- Front brake lever v-clip
- La Rosa solo bag damages sidecovers?
- Asking price suggestions.
- seat choices
- MY '09 IRON 883 Sucking Gas a lot!
- Stage 1 Home Build - $310 (Pics)
- 21" front wheel
- Air intake/Air filter
- New Guy With Some Questions
- 48 with a 4.5 gallon tank.
- 2006 Yellow 1200c
- Tank suggestions?
- Clip-ons: Do I need to swap cables/wires?
- This has got to go.
- Finally did it!
- LED Headlamp
- When can you no longer call it a Sportster
- Lower Tire Pressures?
- Oil "Sweat"
- Can i run an XIED or do i need a tune with my pipes?
- Interesting slice of sportster history
- Question about My fuelpak !...
- Tank Sealer
- Just got my new 2011 nightster, 48 seat and LED headlamp
- 06 1200L suspension question
- Stock SPortster rear coil over shock as a solo seat spring.
- In which plant are forty eights built
- Forty eight rear fender reflector
- air filter and other modz
- Electrical Help with Sportster to Nightster fender
- bars help
- That Kind of Solo Seat?
- HID problem! Arghhh..
- Plug Wires and Coil, 2003 1200 XC
- 55 !
- Will these fit?
- Stage I kit
- Lowering a sporty
- Fork oil
- Help! Nightster wiring harness coil plug connection
- Now _that_ is a Sportster
- Need some guidence on timing issue I think
- Best/Cheapest Place Online to Order Pipes/Stage 1 Kit
- Run the Dragon's Tail in NC?
- Baking the tank
- Scuff Marks On Front Fender
- Foot Brake Light Switch
- Kuryakyn Hypercharger
- Wheel Question...Again
- Running a 150
- Nightster Tank Comparison
- 21" front wheel on an Iron
- Did I really need it?
- $15 do-it-yourself chameleon paint job
- frame internal wiring
- My version of a tank lift
- Gloss black flush mount gas cap
- Hesitation
- New to HD, looking for advice
- Do I NEED to take my bike for the 1000 mile service again?
- Motion alarm
- ISO quality analogue mini electronic speedometer with odometer??
- Rear Brake Help
- 1997 1200 ,kraftech frame swap
- Helmet
- 2011 wide front tire for 2008 1200custom
- Airbrushed Derby Cover
- EFI 3.3 tank capacity- an answer
- What to spend my tax return on?????
- 2008 sporty forks. 39mm or 41mm???
- Getting a new Sportster
- Winter progress...
- Voltage Regulator !
- changing carbs on a 1991 sporty - issues with throttle cable?
- 2 into 1 Exhaust Pictures
- Sportster 48 Pricing OTD
- Could anyone help me with my ironhead
- 04-11 Tank on a 03
- security lockout 2007 Sporty- help!
- SE Stage 1 Air Cleaner Kit Question
- Oil filters ???? Hiflo
- Handlebar risers questions
- Boom Audio Speakers and Zumo 665 ?
- dino to syn motor oil
- the reason I go to swap meets
- 2x Air Intakes NHRS query
- New to Forum from El Paso
- Long indicator stems
- Long Overdue Chop
- Saturday Afternoon Mods
- 2006 1200r
- UK Sportster Tracker Build
- 1200 upgrade vs. stage 1
- Should I clear coat my powder coated sliders?
- Got my first motorcycle!!!
- Nightster
- turn signals don't work, shorted out wiring???
- Bought a 1200C today
- Threw on some misc. items & performed one mod. today
- alarm will not stop !!!!!!!!
- Need some advice...
- ViED/XiED Install - Lot's of Pics
- Cable Lube
- Look what I did!! Part 2
- Evo sportster kick start
- state inspection stickers
- Part number for stock Forty-Eight seat?
- Custom seat
- power commander V question
- legal question
- idle speed
- Sportster and Chicago Show
- Big City Thunder Baffles
- Rustoleum COLORSHIFT. Fuel safe?
- Getting my 48 tank painted....Fuel Pump FYI
- Ever had any problems?
- Question About Screaming Eagle Air Cleaner for 1997 XL1200C
- Removing Military Stickers From Front Fork
- Back from the shop...pics.
- my 48 is FINISHED!!!
- Stage 1
- Cruise Control on an 08 Sportster Help..
- How can you guys ride bikes with drop-in lowering kits?
- NOS on 883's ?
- european LED signals
- Drag Bars on a 48??
- Will it fit?
- Windshield on my Forty-Eight
- Should I buy a 77 Sportster XLT???/
- Ok, take 2, how about 10" shocks and lowering blocks?
- bike will not start
- Kickstand question
- battery powered license plate bolts...?
- my first harley
- Problem with my fuelpak
- 2000 xl1200c... computer... what?
- Changing fork Oil,,,Or,,,
- Noisy tappin cover after oil change....
- 77 harley ironhead points
- Wire tuck under tank with no tank lift - My take
