View Full Version : Sportster Models
- Convertor question
- Making slip ons ?
- 2014 xl1200c
- Best website for parts?
- 2014 48 Wire Tuck/Coil/Ignition
- My New Iron 883 - Keeping It Simple (photos)
- 2014 sportster 48
- Tank lift hight for wire tuck
- new seat?
- Handle bar and speedometer relocation project Need Help
- 2014 controls
- 2005 1200R: rear cylinder misfiring, erratic idle
- Seats, What years fits 94?
- Arlen Ness fairing for a forty eight
- 12" or 14" apes?
- Signal Dynamics load equalizer?
- 2001 Sportster no spark
- i HATE to shine
- Riser on Iron w/ stock bars
- rode a harley for the first time
- 06 custom wont start again...
- Rear lights upgrade
- New Rider: Thinking of Harley 48. How to go about it
- Lookie at what I made...
- closed loop, open loop
- changing front drive pully on 200 sporty
- Iron 883: Mid mount controls vs. reduced reach forward controls
- considering switching back to Dino oil for my engine. advice?
- Stock map for 2011 883N
- Fender Rivet removal
- Question for anyone running Shortshots+Heavy Breather+Harley Tuner+Harley Dyno tune
- Recoding my spare key??
- Can you help deterimine a value on this Salavage Nightster?
- Twin Falls to Lake Havasu
- What would you do first?
- Flushing gas tank.
- Sportster 48 Tank Swap- Controls and Mirrors Hitting Tank
- Rode the Sporty 883 for the 1st time !!
- sporty died on highway
- Seat = Sleepy man parts. No good!
- Iron 883 ,Night train or Night rod good for first bike ?
- Hand control wires
- fuel injector question for mods
- Help bike won't start
- Is removing the sprocket cover and belt guard dangerous?
- 1991 883 stuck in 5th
- Sportster Battery Source = Advance Auto
- Sportster at Sturgis
- Clicking valves
- Fourty Eight stock Solo Seat
- I got the iron 883
- Supertrapp 2X1 question
- My brand new iron wont start and turn on!
- placement of LED pods
- Have you Bought a Harley that Came with Extended Warranty?
- My winter project is done
- Crack Rocker Box Cover
- 48 laydown tail light
- RSD Prostep 4" bars
- Thoughts on this deal...09 1200 Low
- Dark custom derby and timing cover
- seafoam in the oil
- Stock air intake removal - help
- Trouble codes after wire tuck
- Exhaust questions
- 2013 48 what would you do?
- Cluthclite?
- Unity Headlight
- What if you Switch the ECM on a Sportster?
- Rear tire crap
- 2 Up Seat
- Does this 48 worth asking price?
- LAF's on my 2014 48.
- crankcase vent question
- 883 custom parts
- New 2012 Iron Owner With Seat Question
- Starter solenoid rebuild without removing starter question
- DK Shipping
- Exhaust Leaks
- just Curious... sprocket cover holes
- Align rear wheel
- Cam gear alignment sportster
- 05 883c solo
- Anyone in Los Angeles see the cafe Iron at Glendale HD?
- Help!
- A little Shock Help
- Any Deals Close to Atlanta?
- Bye bye PCV. Hello SESTP
- Sporty 48 with black forks
- 2009 Sporty not starting
- Iron 883 Mods...and thanks
- Later spokes, Hello 9 spokes
- Issue Bleeding Front Brakes
- Carbon fiber chopped rear fender
- Check those nuts & bolts!
- Free Multimeter at Harbor Freight!
- Most comfortable solo seat for xl
- Rear turn signal removal
- wanted: a stock 2014 AC for a 72
- Using LED turn signal for rear...any converter/conversion kit for brake light?
- Solo seat on my 1998 1200XLC sportser
- idle cable
- Vance and Hines Competition 2 or D&D Bobcat?
- Newbie Question. Sportster Sissy Bar Issue
- Looking at a 2001 sportster
- 03 shocks on an 05?
- Specific Seat Q for 2009 883 Iron
- Mustang Cafe Solo Seat Pleated?
- timing dots on cams
- 96 sporty battery issues
- 50th Anniversary Sportster Parts
- screwed up mixture screw
- 10" gutter punk shocks??
- 82hp 74tq good?
- 1200c riser question
- New Member, New build, Need help!
- Cycle shack
- Quarter fairing
- which front signal relocation
- New tank but is not the same.
- Baffles
- Ready for this season
- 48 Handlebar Opinions??
- Rubber Mount Headers on Rigid
- Do I really need to take the pipe off to put the passenger peg on?
- Can you Fit a Sportster in a Minivan?
- Urgent help!!
- Oil drained into to sump during winter break.
- Looking to use rear air shocks
- Radial sweepers
- New Here - 2011 Nightster pics
- Passed my test... painted my 883. Tips for riding it !
- Won't Idle when Hot
- timing might be off
- Sporty is locked up
- Which Sportster is Better Deal? Forty Eights
- No Baffles
- why different angles on throttle cables?
- Pipes and Air, now what tuner?
- How to Hook Up Aftermarket Horn
- 1991 sportster project
- Help Needed - 883, where does this go?
- Sportster front forks
- Painting the Iron 883 headlight cover
- Question about ECU/Fuel injection
- Power Commander + Fuel efficiency.
- Front spacers
- Trying to find sissy bar
- turn signal wont shut off
- Drunk jiffy stand
- sissy bar bag something cool
- Mini Speedo acting like Tach
- Returning to the fold, but need advice.
- FP3 Vance and Hines
- problem finding lizard light switch placement
- Rear brake
- advice on slip on's
- Numbered Anniversary Sportsters
- Anodizing Touch-Up
- Altenator 2011 Nightster
- First Sportster
- Replacing Speedometer on 2012 48, problems?
- First Harley 95 883
- 2014 exhaust removal?
- Can I remove this part?
- Tall guys: how to make sporty (48) more comfortable for back?
- 2014 48 Upgrades
- Anyone with SikPipes?
- 2012 Sporty 1200 questions....
- Tweaked the Sporty Again
- 1250 Start up
- 2014 Irons
- Need photo of right driver footpeg mount 1991
- Need help with engine VIN
- whats this worth??
- 48 = 170 Rear Tire
- Are Sportster Diecast Models Available?
- '09 1200 that has been sitting for a few years
- Need wiring diagram Superlow 883
- Front wheel wobble
- cracked oil hose? This isn't going to be a habit is it?
- took delivery today :)
- 10inch burley bars
- Installed whitewalls on my bike
- Baffle plug
- Need help!
- Is this an O-Ring Issue?
- What bars are on the XL1200T?
- Brake pads
- can I paint my fork tubes
- sportster side mount bags with pegs??
- New tail lights have 2 wires instead of 1
- tool bag mounting advice??
- highway pegs
- Sportster Replacement Tires
- front brake switch repair
- anyone running the ME888 Ultra?
- Need help w/ a kinda starting issue
- Just purchased my first Harley. Got home and noticed this leak.
- 2013 883 Iron Seat...... OUCH !!
- Extended Warranty = Not really worth it
- passanger seat bolt
- desperate need of help. big radius and auto tuner pcv
- 2014 Passenger Pegs
- Fell into a sportster deal.
- XL1200X 48 suspension
- bulky stock breather on 2014 48
- Long distance riding on sportster
- New project
- Is a Superlow better on the highway than an Iron?
- Chumps on a 2010 48?
- Buying 2014 Iron 883, what did you pay or get with your bike?
- Can 48 hop a curb?
- Z Bars- Picture request.
- Wire tuck question
- HD solo bag vs. LaRosa vs. Lick's?
- fender help
- LED Headlight for Sportster 1200
- Stone chip on rear fender
- Going back to shorter bars
- Steel braided cables
- Finally decided on a seat
- ride quality feed back 883
- Sundowner seat
- Air cleaner question
- putting a big radius on my 72
- Recommendations for 09 1200C
- 5th gear ratio
- License plate light.
- What would you call this 48?
- Opinions on Screamin' Eagle Stage 1 XL High-Flo K&N Air Filter Element-29400026
- Is scraping pegs dangerous?
- Pet Cock Threading
- sportster handlebar
- Pinched engine temp sensor wire
- Locking helmet to bike somehow
- sportster 883 highway riding
- Lincolnton NC , ?'s about MC
- Saddle Bags for Iron 883
- Anyone have the 30" Cycle Vision attitude stick?
- Any Experience with this Side Mount License Plate?
- Trading in the Nightster for a 2014 883 Superlow
- puttng some mods on my 07 sportster.
- Not vance and hines
- Dynojet Sportster ECU Tray
- Sundowner or nut up for a Mustang?
- detent clip/shift drum pin question
- Fork Clamp Mount to turn signal relocation
- V&H heat shield
