View Full Version : Sportster Models
- Micro EFI Tuner
- Hardtail bolt on
- Sporty 1200C tank ideas.
- Differences in 3 bikes? 1200 custom, superlow, superlowT
- Cobra Fi2000 Power Pro
- Mid Glide conversion Fender?
- Ironhead Sportster vin help
- I went Alien Bandit
- 5 Speed Transmission Rebuild
- Loose baffle in SEII slip ons
- What are you guys using for stands?
- Superlow 1200T!
- Moblie 1 gear oil or mobile 1 vtwin
- New Tires, Whitewalls or no?
- 2000 sportster
- Tachometer Question
- What'd y'all do with your scoot today?
- Electrical problem
- 2016 Roadster: Modification help!
- Advice for bars I installed
- Sporty Bagger
- 2016 Roadster photo dump/build thread
- Tank rust
- Timer cover - 2015 XL1200C
- Major differences between '13 & '14 Forty Eights?
- Powervision/Sat Nav mounts with narrow bars?
- Exhaust for 883 Iron
- Can we just drop a stage 1 map without a tuner?
- Brake light question
- 2016 compatibility - Sportster mid controls
- red key light no turn signals
- Anyone with Cobra 3" Racepro Tip exhaust?
- Sparrow's 2006 883L Build
- 1985 Roadster XLS
- 08 Sportster have to be in neutral to start?
- Sportster 1200 Custom wheel swap - easier way
- iron 883 brake upgrade
- Idle air control problem
- 2007 sportster 883
- 2015 iron handlebar clamp
- Got me a 1200 Sport
- Flag bracket/mount for sportster
- Install time for a 1250 kit
- 1250 GoPro 10.16 ET
- Roadster home at last
- Forty Eight w/ drag bars - clutch and brake routing question
- Anyone running Samson hellraisers?
- Replace shocks for solid struts on 2016 883 Iron
- Mid Control Swap
- Helmet lock and caliper question
- Electrical light stays on
- 1200 upgrade
- Cam's '00 Sportster Build Thread
- Dead Spedo/Odometor
- Hammer 1250 runs 131.83mph
- 2016 Roadster exhaust options...
- brake pad life
- Might buy this bike, after leaking primary fixed
- 2008 Nightster coil relocation problems..
- Sportster 48 - swingarm bag and passenger pegs
- Sportster 48 Saddle Bags
- What would you ride if they didn't make a Sportster?
- Vibration after changing slip-ons
- Starting issues
- Sportster 48, mini headlight fairing
- 2016 Roadster test ride
- Cut stock air filter cover (pics)
- Sudden Catastrophic Transmission Failure?
- 2000 Buell S3T engine parts inter change?
- forward to mid controls
- got tank and fenders, now need sportster
- Tuning Question (I can hear the sighing already)
- PCV install - 3rd run, and limping?
- 2016 Iron883 - safe highway RPM
- Stock 72 tires tubeless?
- New seat is narrow - concern about water?
- '95 883 Progression/Retrogression Thread
- Need a little help with a 2003 1200
- Parts rolling in now
- 08 Nightster back fender fitment, help a newbie out 😉
- Timer Cover Fitment
- Help me pick a new seat
- First scuff
- Vance&Hines Big Radius
- Missing Teeth on Starter Ring Gear
- Wrap fender 21 in wheel
- finally found a 7" headlight grill
- fast idle
- Setting the idle the correct way.
- Replacing rocker box cover gaskets?
- Transmission problem for evo sportster common?.
- Handlebar Question
- 2015 rear axle nut size?
- Bar Question
- Help with engine codes
- Oil change tips
- TTI and blown head gaskets???
- Suggestions for a new seat?
- Found a piece of wire shorting out my front plug!!
- Switchgear retrofit?
- 48 Seat on a Nightster? Photo Wanted
- My Nightster got a new seat - Mustang Fastback for 3.3l
- Timing
- Phase 2 done
- It has to do with oil!
- Need input, possible intake leak
- help me find the right part
- Does 41 MPG sound ok?
- 15' Irom 883 Apes with ABS
- Handlebars
- Shotgun exhuast for my 48
- Primary chain inspection cover delima...
- No love for the 72?
- Repro vintage Sportster tank
- Oxygen sensor remove will Fuelpak FP3?
- can the ecu be flashed
- 2014 vs 2013 Sporster 1200 custom
- Further Forward Mids.
- My brake light is always on now.
- late model 1200 Custom handlebar question
- Odd noise coming from right rear...?
- Smoking Air Cleaner?
- changing handlebars
- XSFLOW-S1 vs SCREAMING EAGLE A/C with XiED
- 2016 Iron backrest/rack
- 2016 Iron 883
- Proud of the Grey Nightster Motor
- DK led h4 light
- Vances & Hines Short Shots
- who makes a 3 inch a/c?
- 2015 sporty 48 stock a/c mod
- Put money in my sportster or trade up
- 2016 Alumimum Heads
- Question for those of you with drag bars
- Starter relay click- help
- 1994 sportster 1200
- Thinking of getting back on a Sportster
- 2016 Sportster 48 tranny/shifting.
- Biltwell Flyer handlebars
- Need help!!! 2016 Iron 883
- Windshield for iron 883 with Z bars
- who makes circle air fliters?
- Which LED headlights will fit a Forty Eight?
- LED bulb turn signal/running light swap
- Who's voting for a Sportster S
- Storing Documents On A Sportster
- Fork slider question
- Iron seat on 48
- New plugs white already
- Springer Front End
- Engine vents?
- Stock Jet/s?
- Biltwell Chumps
- New Rider Update
- Fender Struts?
- Sportster a/c is it worth it?
- Change horn cover on a new 1200 Custom question
- Rocker cover Bolt issues
- Swingarm bag
- V&h or python slip ons
- Coil Relo - Plug cable switch-a-roo?
- Pinch bolt size
- Weigh in on 1250. NRHS or Hammer Perf?
- Finished my sportster build
- Bike Starting - Is this Normal?
- Shock Bolts
- New Roadster
- Exhaust help needed from DK
- How Stock is Your Bike (or how modified) Poll
- Wheel bearing question
- Painted the tins.
- Gas tank
- Need some guidance for a stupid mistake
- Shifter lever
- 2016 Sportster 72 tank swap
- Black Bettie
- Rear brake light issue/empty oil and no leak?
- 1979 Sporster Battery Cover
- Need slightly longer plug cable
- Battery Voltage Question
- Super Sport Windshield on 2015 1200c
- Progressive mono tunes 35-2514 install issue
- No spark!!
- Fng
- Harley Iron Oxygn sensor problems
- 2014 Iron 883 won't start - just backfires
- rear brake lights
- Camshaft madness
- wider tires on 2009 883R
- 2015 Sportster Iron Issues
- Quick clutch adjustment question
- Advices on superlow 1200t model
- New Roadster Pics
- 1994 Sportster 883XLH power loss problem
- swapping a 2014 forty eight fork with a 2016?
- PCV used? Missing anything
- Picture request.
- New pegs on wife's 1200c
- 2010 Exhaust on a 2006?
- 2015 hd 48 - idling
- found some nonsense while secret squirreling pipes
- Buddy's wrecked 2015 Iron 883
- Hello
- torque cones? yes? No? Doesnt Matter?
- Pic request
- Anyone on here change their oil at 2500 miles?
- Stock Pipes?
- Could it be the battery?
- RearWheel and Lower Fork Slider Swap
- Replacing tail light on 2016 1200 Custom
- Air cleaner question (RSD/PM)
- Fork alignment, with or without drill bit???
- Finally got my 2011 48
- 2013 XL1200C New Tire Help - Please...
- Loose Throttle
- Exhaust question
- Underneath the Seat
- 2016 Iron 883 turn signal indicator not working
- Getting tired of people telling me my 883 is a girls bike
- Feels like a flat but it's not a flat
- Identify the exhaust on my 72
- 132 hp!!!
- Sportster battery cover
- Foot pegs for XL1200T
- My 2013 48 New Mods
- Back brake issue on sportster
- HAMMER 1250 goes 10.1 at a buck 29
- Re-wiring and ignition help
- Vance & Hines slip ons
- Gonna try Modified baffle mod
- Highway cruising with 1250 conversion
- wheel resto
- 2015 Sportster Forty-Eight Saddlebags
- Iron 883 mirror flip
- Need help installing front wheel
- Sportster clutch issue...
- Torque loss and popping
- Black Denim
- New to the Harley world
- Pipes
- '16 48 reduced reach?
- Hey Guys please help!
- Help with front wheel fitting? Urgent please
- Brake like question
- New front tire what size
- Need help with jacking up the bike
- Lowering brackets
- Solo crash (no other vehicle involved) -- at fault?
- 883 Iron Wheel Options?
- New 2016 XL1200C Owner with questions
