View Full Version : Sportster Models
- Gear indicator in fifth gear disappears under full throttle
- Can’t get right!!
- issue with 06 1200
- ECM calibration: 171 vs 176.
- Deleting rear incandescent blinker for all in one led tail light.
- 1999 883Hugger Oil Leak
- Wind / high speed wobbles on 48
- Gas tank coatings advice
- 2011 Nightster 1200N stuck on Full Throttle
- 1995 Sportster 883 No Power
- Need help - 2022 Iron 883
- Rivet size on rear fender inner fender/deflector
- Cam Upgrade ignition question
- A real Harley .
- Fuel Moto Sportster Mapping
- 2019 sportster wont start
- Big Bore Kit
- 2011 - 1200C, adding exhaust - need a tune?
- Sportster Exhaust
- 2000 XL1200C handlebar and riser specs?
- Can anyone help a newbie?
- Air cleaner install from dealer - will they tune ECM?
- 2002 883 carb tuning question
- Street Cannons Part Number: 64900208A
- 07 Sportster Uneven Idle
- Moving on .
- 2019 Iron 1200 LOUD knocking after breakdown.
- Bassani Firepower vs Cobra RPT Slip on
- 1275 gettin some!
- Trying to find Vance & Hines #18005
- Speedometer doesn’t show my speed!
- Harness help
- Long ride on Sprtstr 2013 XL883
- 2014 sportster 1200c loses power after riding for 135 miles.
- stuck pop up oil cap on 2019 883
- Can you use a Dyna models 1996-2003 seat and sissy bar on a 2002 Sportster?
- Back brake and shifter
- Engine and Break oil
- Clutch barnett 883 Harley
- 2012 1200 Custom Left Signal Stays On.
- 2009 Sportster 1200L
- 99 sportster runs and idles until in gear
- Fork Oil? 10w? 20w? Other
- Can’t find cables for my sportster
- 1200C vs 1200 Super Low T Seating Position
- Chinese brand Shineray's V1200 motor, it looks very familiar
- Sportster 49mm forks
- The hardtail.
- 2011 Superlow vs 2008 883 Low question
- New to community, new to biking, ran into a problem already
- Sportster Header pipes....
- 2012 sportster 883 no start/partial crank
- '22 Lowrider S Instrumentation on '09 XR
- case bolt threads
- No current flow after 24 hours I removed battery
- Turn Signal/Tail light relocation
- color code
- 2004 model, TC88A, and aftermarket speedometers?
- 2014 Sportster motor swap years.
- 2000 Sportster 1200s to a 2000 sportster 1200CUSTOM
- What brand Shock is this?
- Ca 2020 sportster tune
- XLH1200 Sporty tach speedo probs
- Sportster XL1200C Speedo/Odometer dead
- Sportster dies after "engine brake"
- 2004 1200C Top Speed - Questions
- 2009 Sportster 1200 custom voltage and battery drain problem
- Sportster 883 throttle problem
- Connector under voes
- 07 sportster custom
- 2007 xl1200c p0113, p0118, p0123 cant fix the issue
- Help
- Brake Caliper swap
- 1957 Harley XLA
- b2112 ACC output shorted high
- Engine Swap moved to Sportster Models Section
- Ass
- Sportster Pipes 2013/2014 Differences TBR
- 2001 Sporster Custom XL Starting Problems
- 1995 Sportster 1200 rides rough.
- New to me 99 883C needs tires
- 2010 iron 883 showing p1001 & p1002 need help
- Forty Eight Front Fork Upgrade
- Non OEM wheel bearings
- Battery not charging
- Starter issue
- 2013 Harley Davidson Sportster seventy two Gas tanks
- I can see the finish line
- Throttle grip problems.
- Wire troubles
- 170 Rear on a 2001 Sporty
- carb leaks
- Sportster Problems
- 2007 Sportster 1200 Xl wont crank
- White exhaust port/ exhaust valves
- Split tanks question
- Harley oil change kit, o ring?
- Does anyone know what seat this is?
- New York State Inspection
- Foot Peg Question - Iron 1200 Forward Controls
- SportStr Xl883
- 1998 883 exhaust
- 2007 Sportster triple tree
- Figuring out max front tire size
- Shifter shaft/pawl hitting flywheel
- Installing SE air cleaner kit on XL883 2022
- 2006 1200C first start problem
- lights, yes, but no engine light and not starting
- 680 mile XLCR on BaT.
- AMF Inspired Tank Art
- 2022 48 Recommendations for Adjustable levers
- turn signal indicator hyperflashing
- 95 sportster 1200 knocking
- Sissy Bar Options
- Wiring harnesses on iron 883
- Oil on engine?
- 2003 turn signal issue
- Stalling after oil change
- Headlight wiring gremlin
- Gear Change And Speedo
- Sportster exhaust ?
- Question for anyone running a Super E/G
- 1989 Sportster 883 ignition upgrade
- Swingarm brakeline clamp fastener size
- Is it possible?
- Rear Fender Options
- Starter relay not activating
- 2022 Nightster Questions
- Fat boy ignition to sportster
- Accidentally added Power steering fluid in oil tank
- Original Roadster dirt build
- Nice build: Sportster Scrambler.
- Where did rumors of 48 and 883 being discontinued come from?
- Buying a 48
- 1990 883 Hugger problems
- Removing baffles on 21 iron 883
- Starting Issues on a 2007 1200XLC
- warm engine, high idle
- 1989: 883 hugger header diameter?
- Orange and White Wire
- Bolt on hammer performance kit question
- 1200 sportster back jug cold?
- My 1st Harley
- Sportster 1200 to end on 883 lower
- Dumb mistake, brass collar ID on Keihin CV carb
- Sportster Electrical/Security mode issue.
- Upgrade front caliper to later model
- Will this tank fir on my 2021 Iron 1200
- Sportster clutch release plate
- Hesitation/stalls while idling in neutral. Help! (09 Nightster)
- Sportster 1200 no start and grinding noise
- Sportster 883 2009 Carb Conversion support thread
- larger tank
- Putting a 2017 motor in a 2011
- Multiple issues
- 15 Sportster 48 losing power!
- Drilled stock pipe question
- Exhaust gaskets…..
- What is this?
- 2008 Nightster electrical gremlin
- 2008 Sportster 1200n ECM swap
- Throttle body and breather question
- 2012 Sportster lagging under 2000RPM
- Been a LONG time, new XL50 owner checking in!
- What is this part if mt carb and why is it leaking
- Need a Sissy Bar Medallion! Image provided
- Dyna Wheels on a Sporty?
- fuel valve leak
- 2008 Sportster 1200N Bad ECM??
- IAC valve problem.
- 1987 Sportster Carb Jetting
- 2020 iron 1200 Speed Sensor
- Troubleshoot turn signal not cancelling.
- Shifting issues after primary oil change
- 2002 883 Fuel Valve repair kit
- Mods Please Delete
- 99 sportster
- Bar ID help
- CONVERSION Update.
- Rear Cylinder Misfiring on 2013 1200 Custom
- First HD Sportster 883 Iron
- 2006 Sportster XL1200C Carburetor removal, throttle cables
- HD fob ??
- Spondon framed Sportster 1200
- 2009 1200XLC Front Tire options/sizes/question?
- Speedo back light has lost its mind, and mine as well lol
- 2009 nightster VH straight shots.. slip ons ?
- Looking for the best and brightest headlight off of amazon.com
- 2021 sportster 1200
- 2006 Sportster 1200 low cutting out/stalling
- 2007 Nightster wont start
- 03 sportster isn't running right AGAIN
- Sportster Full Ohlins Suspension
- Brake Lights Stuck ON (2010 883n Sportster) I've read the other threads and am still stumped.
- Rear Head
- Jagg Slimline Oil Cooler Instal
- Headlight highbeam intermittent 2006:Sportster
- Screamin' Eagle Stage 1 intake question (gasket location)
- Ride/handling Difference between 2006 and 2011 w/ wider tire
- New Nightster
- So this happened this morning…
- Burned my crank 🤦
- Touring on a Sportster
- Sportster wiring Help!
- Sportster Hardtail build
- Whats Going On With My Breather Bolt Threads?
- Replacing clutch spring plate, anything else to look at?
- Any ideas??
- 2010 Sportster 48 no neutral light
- Lay down tail light lens
- 2016 HD Sportster 48 (non-abs) front wheel washers orientation
- 2009 Sportster 1200 Low (ECM)
- Help with Bolt/Thread Size
- Nightster 975
- Breakdown fault finding - System Relay
- Wiring extension harness problem
- 2000 1200c luggage rack
- sportster wobble after adding a fairing
- Help: 883n 2019 Fork Oil Drain w/o Disassembly
- Sportster Ignition Fuse Blowing
- Selling a sportster
- Problem with rear turn signals (01 Sportster 1200xlc)
- Not starting - immobiliser or something else?
- Sportster for Trail riding and Fire Roads?
- Carb cough/hesitation accelerating
- Superlow Tire Question
- 2012 Sportster Custom cranking but not starting
- Carb Fireback??
- Reviving a 2001 HD Sportster XL 1200 Anniv Ed 8K Garage Sat Bike
- Timing cover swap
- Sportster 883xl 06’ problems
- Can't quit sportsters! Here's my "new" one
- Help
- Sportster head gasket search
- (00) Sportster - What tanks might fit?
- My new clutch cable for my iron 1200 doesn't fit. Please help.
- Petcock diaphragm leak
- Issues with installation crash bars
- Right Turn Signal stays on steady
- New to maintenance and wondering
- How tall of handlebars can you get with stock cables
- Mikuni slabside carb
- (93) Sportster Transmission Oil Change
- Passenger foot pegs needed
- Dumb question about bending metal. (Shifter Shaft)
- Looking for Mechanic in DMV (DC, Maryland, Virginia) are
- 2021 Sportster Service manual
- Rotor for Wilwood caliper
- Rear ended by another biker!
