View Full Version : Sportster Models
- Just quit my job (bored). ICM relocate and new seat in the works.
- sportster 48 advice
- Bar and Shield Rear Axle Covers
- Rejetting the Carb
- Xr1200 ????
- Best (easiest install) Spring Saddle
- Where do these go???
- Polarized Sunglasses - - Did you know
- Led sled sporty
- How fast
- '06 1200 Custom short problem
- 1976 ironhead starter run on
- Priming the oil pump?
- Received my J&S jack today
- 67 Sportser 900 CC
- 1975 xlh sportster 1000
- 883-1200 conversion
- tank/fender compatibility
- Just wanted to share....
- How loud are V&H Big Radius 2 into 2?
- Attached to your bike
- Aftermarket Air Cleaner Question
- Mustang Seat w/ Back rest - wrist pain?
- Newbie
- Looking for solo seat
- Removing Front Running Lights
- Screaming Eagle A/C
- Re-jetted my 883L
- First post!! My Nightster
- Hey So. Cal. riders!
- paint work needed- oklahoma city?
- Fork Size...
- Air Cleaner Upgrade
- Fuel Map question?
- 2011 Sporster 1200 or 883
- PCV question
- 883 Iron with 29 tooth sprocket question
- Fine scratches
- Fuel tank ?
- Stator or Voltage Regulator?
- Help with fuel leaking, not running
- Down shifting
- Sportster replacement seat
- 2006 underseat ignition module relocation anyone?
- Valve troubles????
- Need Help How To Measure Speedometer Cable???
- Relocating speedometer to gas tank
- Wrapping my pipes today
- 2009 XL883L Trying to increase ground clearance
- New and Improved
- Anyone have pics of custom black cables...
- Sputtered Accelerations on my 2000 1200 Custom
- Part finding frustrations
- I picked up my 48...
- New from So. Cal.
- New 2011 Forty-eight and some questions
- Blinker issues?
- Power Clutch
- Gas mileage on my 883
- Chopper ridin Sin City to Austin, OKC, Colorado the Born Free in Cali
- Front Wobble - Superbrace
- Not another FuelPak/X14IED Thread!!!
- Redline
- 1000 Mile Ride - One Broken Clutch Lever
- traded my nightster
- Springer Solo Seat
- Forward controls?
- 88 Sportster 883 Won't Start
- MPG issues 07' 883C
- Iron 2 up seat washer ?
- 08 Nightster Backfiring through intake?
- Engine Noise has me concerned...
- Extending Brake Line on 09 1200
- 2008 Nightster fuel tank
- Emissions Control
- handle bar Help !!!
- Spring Seat Mount
- Im tired of Jane.
- 2012 883 iron in "ember red"
- strange symbol on cylinders
- Wrench help
- Okay, help. =X
- Looking for a Wrench in Edmonton
- fabrication help
- Dark Custom Iron 883 Cost
- All I Can Say Is Hell Ya
- 02 Sportster
- One more stupid question Timing cover
- timing cover advice
- Parts Compatibility between model years
- New lid
- My new ride
- tire pressure
- About oil change specific to 2003 sporty 883
- ECM relocated
- looking at the Sikpipes "Bagger" 2-into-1s
- 6-speed conversion
- handlebar help
- Is a 2011 nightster the right choice for me?
- Vancouver 883
- Homemade solo bag
- Air shocks installed on the 48
- My First Harley
- Lost front cylinder
- Trask Turbo Kit Anyone?
- Baffle swap question/advice
- Low buck rack for carrying stuff
- Which Mustang Seat For 1200C Sportster
- High Visibility Vest
- Front Tire Balancing
- Oil and Lubericants
- Power Commander Install
- High Flow
- Light is good
- Quarter-fairing Paint Matching
- New guy with Sporster project and I need some help! Please.
- My 2009 Iron
- Performance help please!!!
- New Sissy bar pics
- problem when putting my bars on
- need part number
- XR1200 Tach
- swingarm coverup
- Nightster Speedometer Relocation, Joker Machine Kit
- 2000 sportster running rich?
- Pegs
- clutch cable from a Street Glide
- CV carb problems - Help
- Do all progressive shocks do this?
- Haggling
- Battery? or
- 2up comfort on a Nightster - oxymoron?
- SB's not requiring signal relocation?
- 09 up street glide wheel
- new orleans?
- Haven't got the bike yet but already want to make changes
- brake lights acting funny
- After AC and Pipes, what next for more power?
- What size brake line for Iron 883 - 10" Z Bar Install
- From BCT Baffles back to SE II???
- New parts, and a question on Air Cleaners
- corrosion
- Flat Black Powder Coating
- My first bike, a 2000 Sportster
- Back doing better than the buke
- Terry terminal velocity efi tuner
- Primary Fluid Leval
- cheapest route to put 16" fat tire up front?
- Such a great feeling
- So I didn't break the screw, but stripped the case threads
- Only 5,000 miles on rear Dunlop
- Do you recommend the use of windshield on 48?
- That "misfire feeling"
- Speedo problem on my 48
- Looking for bike builder in Massachusetts
- Street Magic Triple Play
- I'm an Iron convert
- Rigid or Detachable Sideplates?
- sportster 1200
- shocks
- vance and hines 2 into 2 big radios
- Indy Shop vs Dealer Service
- Starter issues 2005 sportster 1200 Custom
- 48 Seat
- Oil cap issue
- wheel question
- Steering Damper or ? ?
- what jack do you use for your iron?
- Gas Mileage for 883 Custom (09)
- Good Deals?
- Functional luggage yet fitting for a sporster...
- What Is Involved To Convert To A Single Seat
- Knowledge Is power,,,
- Help - Strange 883 issue?
- Keep blowing fuses
- Rocker covers leaking AGAIN!!!!!!!
- Started it all.
- Basic mods for 883C
- Clutch Adjustment Question
- Changed My Oil Today First Time For Me A Big Thank You For This Forum
- Larger Rear Tire for 883C
- Is there already a Nightster thread?
- Heavy Breather on 883C
- Mid Control Sportster 1200C
- What is - X14iED
- Side license Plate Holder With Light
- Water Safety
- 77 Sportster Running Rough
- TINY-TINY Sportster seat
- soft tail rims on a Sporty
- Today, I hit a dog at 55 miles/hour
- Lowering seats for 03 Sportster 1200c
- Got an oil leak, help.
- 2009 sportster 1200 custom
- Frame Repair and/or hardtail
- Harley 883 shocks
- Best A/C for horsepower increase?
- ignition/coil quick question.
- Need help
- What Bars Are These?
- Metal cover on Nightster headlight hood.
- Attaching a Helmet
- Custom Paint?
- Exhaust upgrade for 48
- Hey guys give me some really good spark plug suggestions
- X14ieD's
- Need help
- Rubbed off?
- Need help troubleshooting
- how bad is the tracking/movement on the Avon Speedmasters on a Sportster?
- New HD Drag Bars
- Fork Reflectors
- Need held
- Tubless vs tube tires
- Wicked Awesome
- steering neck bearing adjustment
- Got My Bike Fixed
- Some lousy pictures of my new paint.....
- Iron or 883c help me decide
- Sporty is broke in!
- Intermittent HIGH IDLE
- I have done a search and still don't understand...
- Bye Guys!
- Aero, Airflow, Wind
- Anyone have highway pegs on their Sporty?
- Passanger perspective: Comfortable backrest?
- Fastener rust
- Best HP Performance Exhaust Upgrade for 2010 XL883N
- Another Vance and Hines question.
- Brake lights out again..at the end of my rope.. HELP PLEASE!!!!
- 48 pcm location
- 883l ?
- 883 front sprocket
- Moco Metalflake 48 Tank.
- 883????
- Sporty Project, Input Please...
- "06 1200 low oversteer problem
- Backrest question
- Alternative to the SE Super Tuner?
- need a new seat!
- Branch O'Keefe #5 head and piston mod any thoughts?
- Exhaust pipe question?
- Tire irons?
- A Little Smoke
- Project Cafe Bike - My Dad's old Ironhead
- oil change 2010 xl883l question
- Sportster Cables and Wiring
- Sportster Projects
- Drag Bar Help (48)
- Nightster Fender(not chop)
