PDA
View Full Version : Sportster Models
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299
  1. Front brakes upgrade for 21 inch front wheel.
  2. Clutch Adjustment
  3. Exhaust Baffles
  4. 2004 Sporters Custom 883 Cam Upgrade
  5. Oil Filter
  6. 02 883 Hugger—Turn Signal Issue
  7. Turn, Brake, Run Module issues
  8. Quick Release ?
  9. 2008 Sportster 1200 stumbles
  10. 1999 sportster totally dies after 20 minutes
  11. What's with the gap on the right side of the front axle?
  12. Fitting Dyna rear shocks on Sportster – spacer needed?
  13. Breather bolts in rocker boxes
  14. OH my What did I do?
  15. 2004 XL 883 TSSM Indicator Issues
  16. Rear fender and tanks question
  17. Traded in the 48
  18. 2016 Sportster 1200 Sumping Problem, need ideas
  19. Thunder Star 5 rim question
  20. XR1200 owners
  21. Redneck Springer Broke!
  22. Springer Fork Stops
  23. Not certain what to run in 1988 Sportster primary/ gearbox
  24. How to Clean these Wheels!
  25. S.E. Clutch
  26. O2 Sensor issues
  27. 2001 1200C flip bike
  28. Recommend Sportster for younger rider coming from another brand?
  29. Chrome Top Cover Behind Engine
  30. 3534B Breather Screw with smaller inlet holes???
  31. 2002 883 Hugger
  32. 16 inch front sportster wheel
  33. mileage
  34. 1982 sportster fxl wiring please help
  35. Spoked rims for 2016 Iron 883
  36. 2015 Harley Iron 883 (Sportster)
  37. Clutch options beyond extra plate kits
  38. Wiring Front Brake Lever
  39. Vulcanworks Axle Conversion
  40. forward controls on a standard Sportster
  41. 07 Custom key switch
  42. non-adjustable push rods - 03 XLH
  43. Tachometer On An 883
  44. speedo quit
  45. Reoplacing the ignition module on a 1998-2003 Sportster
  46. Sporty won't start unless I pull the plug wires a bit
  47. 1997 Sportster 883 XLH rear wheel and belt clearence issues
  48. New sportster for me!
  49. Led bulbs for blinkers (2001)?
  50. Todays mystery object !!
  51. Sinko 777
  52. Upgrades
  53. S&S Blue filter blues
  54. 2001 XL1200C Speedo connector
  55. 2014 XL1200T for sale at a dealer
  56. Bent wheel or bad bearing?
  57. OH, them damn Sportsters!!!!!
  58. Evo Sporty Electrical
  59. Fork Cartridges
  60. 100th Anniversary LED questions
  61. Need help troubleshooting fueling issues
  62. '07 Nightster axle torques?
  63. Sportster diagnostic code P1351
  64. Exhaust gaskets
  65. High RPM sputtering, 2005 model 1200C
  66. Dynatek ignition module on 1999 Sportster question
  67. Should my headlight be this friggin' hot?
  68. Sporty oil
  69. 2007 Sportster Regulator sadness
  70. Iron 883 value?
  71. Need help with neutral wire
  72. 2003 1200C Anniversary Sporty Issues - HELP!
  73. 2012 883IronXLN - Fuel pump not priming
  74. 2007 XL1200C bobbed rear fender
  75. Induction Module - HD Part #27200024
  76. 1995 xlh 1200 speedo sensor
  77. HD tach/speedo tank size change
  78. 2004 -2018 seat compatability
  79. Will a 2018 solo seat fit on 2004 1200XL ?
  80. Forty Eight steering head bearings
  81. 2000 Sportster XL1200C wheel swap
  82. 2002 Sporty 1200c
  83. 1989 Sportster xlh 883 hugger
  84. New Sporty Alert
  85. Most Valuable Sportster - Fun
  86. 2003 Sportster 883 backfires and starts running horrible at 60+ mph
  87. Clutch Slippage
  88. Can’t get shift pedal screw to stay tight!
  89. Muller Powerclutch clutch drag
  90. New progressive 412 oil rushing noise.
  91. No Spark
  92. Carb settings for a Mikuni TM40
  93. Fuel drip
  94. Muffler interconnect
  95. Service recommendations?
  96. Sportster rear shock side to side movement .
  97. Do I really need an oil change?
  98. TSM/TSSM replacements
  99. Upgrading Tail light and indicators to LED 3 in 1
  100. Driving Lights
  101. Oil coming out from a 1999 Sportster 1200 vent hose?
  102. Piston ring gap location
  103. 05 Speedo/Tach went dead
  104. Do not buy Smoke Muffler Exhaust!
  105. Sportster 883 to 1250 or 1275 hammer performance
  106. Can someone please tell where I can find a mounting kit for these
  107. Engine storage question
  108. 2020 Sportster Iron 1200 Disolored Fork Boots?
  109. Simple bike lift?
  110. 1969 Sportster 883
  111. What's this doodad?
  112. hi again
  113. Need some advice re: tuning
  114. 04 Sportster 883 Mileage 4.5g
  115. Sportster cam identification
  116. 2004 Rubber mount - Front engine head steady bracket bolts - can I use stainless ?
  117. Surprisingly leaking oil
  118. 2025 Distinguished Gentleman’s Ride is in the books
  119. help
  120. Please help 2006 Sportster xl low
  121. Tour pack cleaning - even possible?
  122. Harley Nighster full clutch disengagement
  123. Difference in Paint Job
  124. Vance and Hines Twin Slash 3" Slip Ons
  125. kickstand spring stud
  126. 2018 48 Appears to be Running Hot
  127. Engine serial number help
  128. Easy ride
  129. Best shocks for '16 Iron 883
  130. Kickstand length
  131. Saddles for 883 XL Evo 1999
  132. How Much Starter "Hang Time" is Normal?
  133. Shorter kick stand w/ Slammers
  134. 2011 nightster runs terrible, p0107 dtc
  135. Rattle from rockerbox
  136. 2003 sportster 883 100th anniversary rear fender
  137. OIL and FUEL lines
  138. Backfire
  139. 2020 Sportster Iron 1200
  140. XLCR 1000 VIN
  141. 2000 HD Sportster 1200 Custom (XL 1200C) Dual Gauges
  142. Help
  143. Fork Bushing Removal Question
  144. converting 2003 XL custom to mids, cotter pin?
  145. Sportster clutch cable
  146. 2000 Sportster XL 1200C
  147. 2003 Sportster 883 100th anniversary edition troubleshooting
  148. 2003 Sportster 883 100th anniversary edition troubleshooting
  149. Need Seat Recommendations
  150. Need help with oil hoses on 04 sportster
  151. Clutch Concerns
  152. Advice spark plugs Forty Eight 2014
  153. NOS Cycle Shack full exhaust needing mounts, or SE2 with mounts?
  154. Average engine lifespan on a Sportster
  155. 2006 XL1200 C no power to headlight
  156. Roadster digital display
  157. 2007 Bobbed Nightster
  158. 2004 sportster 1200 roadster
  159. 2015 Sportster. ECM Test
  160. a delivery boy’s bike?
  161. VSS issue maybe?
  162. 2011 forty eight front and rear wheel hub width
  163. Looking for a good set of apes preferably 14"- 16" any suggestions?
  164. This is sketchy as Hell and I love it.
  165. Adding Key ignition to factory keyless
  166. Intake manifold bolt length
  167. Sportster clutch issue
  168. Sportster 1200 EFI Auto choke no working.
  169. Switchback rims on a fat slider 48
  170. Found a good deal!
  171. 2006 Sportster 883C
  172. Carb qeustions
  173. 2003 xlh - gas tank bolt size
  174. 2004 road glide wheels fit forty eight?
  175. Will Road glide wheels fit a Sportie
  176. Dowel O-ring during cylinder install?
  177. Air filter identification help
  178. Cam installation
  179. Timing marks not adding up on 1200S 96’
  180. New battery advise for 2006 1200XL
  181. 2005 sports term 883 with carb issues
  182. Wreck! Totaled my Sportster
  183. Clunk in 1st Gear
  184. What is this on the frame?
  185. Brand New Screaming Eagle Clutch Slipping
  186. Sportster front fork model
  187. New to the harley sense
  188. Heat Shields for Bassani Radial Sweepers Exhaust – Harley Sportster
  189. 2015 48 suspension upgrades
  190. Sportster 1980
  191. Viking bags - biggest pain ever (long post)
  192. 2016 project bike fitment and fenders question??
  193. 2016 project bike fitment and fenders question??
  194. EZ Pass MC Transponder mounting idea - unproven as of yet
  195. '04 Sportster 1200 - Low-End Knock After High RPM Incident – Looking for Rebuild Advice
  196. Run Switch No Longer Runs
  197. 2016 XL 1200 New MAP, air intake and exhaust. What do you think
  198. Hi I have a naughty Sporty
  199. People without ABS on 883, is it completely absent from speedometer????
  200. 883 pops over but won’t stay running
  201. Looking for locking oil fill cap for sportster nightster
  202. XL vs XR driveline offset
  203. The issue with FP3 at low RPM is about to drive me crazy.
  204. Gut check with path forward - high compression, tick and oil burn
  205. Xl1200 exhaust/jet question
  206. Asked to help a friend sell her Sportster
  207. Sportster 48 Fork covers
  208. Found a '09 Nightster for sale
  209. Stainless replica headers?
  210. Sitting since 2016?
  211. Sportster Frame Compatibility
  212. Rear sprocket hardware
  213. Oil pressure gauge on 89 sportster? Help finding the correct fittings.
  214. 883 carb issue
  215. Wheel locked up
  216. 1995 SPORTSTER 883 HUGGER
  217. Brake pedal adjustment 2007 Sportster
  218. Sportster bags bracket
  219. XL1200c
  220. How to check front brake fluid level
  221. 2000 sportster 1200c starting question
  222. Should I buy a new motorcycle?
  223. Sportster Mag wheels - Best touch up colour?
  224. Rear taillight and turnsignal wire questions
  225. 1974 ironhead 4" over tubes
  226. Help with exhaust ID, intake and rear brake
  227. '13 XL883 Sundowner seat bracket too short?
  228. 2004 883 no left signal
  229. I'm Back With a 48
  230. Sportster motors
  231. Air intake for Sporty
  232. Belt position on rear pulley
  233. 09 XL883L potential project
  234. Help.... Oxidation
  235. 76 Spotster front seat bracket
  236. 2000 Sportster Indicator Lights Wiring
  237. 4 speed clutch proplems
  238. 96 sportster wired
  239. Highway pegs
  240. can bus
  241. 21x2.15" Cast Front Rim for 2002 XL1200C
  242. 2007 Sportster tires, cables
  243. 05 1200C Exhaust options
  244. which is better
  245. 2007 Sportster dual gauge wiring diagram
  246. 2017 Iron 883 won't start (error codes found after ECU flash)
  247. 17" rear rim for '07
  248. Can you read spark plugs?
  249. Loctite on cylinder studs?
  250. Lower handlebars.
