View Full Version : Sportster Models
- Idle?
- Need help
- Will This Top Clamp Work?
- Shout out to Hammer performance.
- Iron 883's with Biltwell Moto bar
- So Far My 2016 48
- 48 shocks...2014 vs 2016
- Weird Idle Issue 1991 XLH
- 883 to 1200 vs. 1200
- New Guy having problems!!
- Headlight Fairing for the Forty Eight
- Couple of questions about installing bars from Iron 883 onto Superlow 883.
- 1980 Sportster engine
- Rotor installation
- Brake light always on - Please help
- Good News for a Change
- 2001 xl883 Brake Light Issue
- 200 Rear Tire Conversion!
- Looking for 04, 05, 06 Sportster Battery Cover
- 2010 Forty Eight Not Starting - Not Getting Fuel - Help
- Sportster tire rubbing turn signal but after lowering
- Batwing fairing with Quick Release clamps?
- How do I install rocker box cover uppers?
- 16 roadster 1200 Harley tune and Xied
- picture taker.
- Harley Iron stock seat for 2016-2017 question
- 2016-17 Harley Iron stock seat question.
- My HiFlow 587 and TTI Impression
- Is this a rear brake leak?
- Major Problems and unridable bike
- Led signals, resistors
- 2000 XLH883 will not start
- Hello From Ohio major problems
- Sputtering Sportster
- sportster starting issue
- Removing Big Sucker A/C.
- Help my 02 sportster won't start
- Hello! New User / Rider... Looking for upgrade advice
- XL1200N not starting
- 2011 Sportster gauge cluster light wire diagram?
- Brakes
- 99 just started stalling
- Rear lowering
- 2-up Burleys?
- Some new pics
- NC
- 09 Nightster clutch plate removal issue
- Unique a/c question
- Pitting or weird grime on wheels / forks
- Power Vision new install
- opinion from the masses
- Picked up my first Sportster!
- Front Fender Chop
- Quick seat fitment question before I buy.
- DK Custom Products!
- sportster saddlebag bracket installation
- Sportsters as starter bikes
- breather hose, totally dry?
- Custom question
- Brake Service
- Sportster Engine Swap Question
- Fixing transmission
- New to me 1200 sportster
- Bike parked outside in Tropical storm, wind probs?
- oil light, tinny sound
- Quest for scissor springs
- after 2 years, the 48 is done....probably.
- Question from noob about suspension (photo of my new Sportster included)
- O2 help plz
- started the 1250 project
- Seat part # for new Roadster
- petcock question
- Forward controls . getting made to measure.
- brake pads ..are 2013 the same as 2014
- POLL: ____ Vibration Preference? ____ 03-Earlier SOLID "EVO" vs. 04-later Rubber "EVO"
- a few pics
- What kind of Brake Pads do you use?
- Wiring Diagram
- Dummy lights
- Oil - transmission / crank - Changes?
- Sportser 883 iron headlamp
- Conversation with a girl who just bought a 883
- 2016 Sportster 48 mag wheel wide tire kits?
- quick question
- Rear brake stopped working out of nowhere
- Rear brakes squeal
- Baffles In or Out?
- My 2016 roadster 1200 so far
- Horn and speedometer relocation
- Cost of going big
- ow my back!!
- Weekend Ride on My Sporty
- modified roland sands diesel wheels for my 48
- Rookie AC question here regarding Figure Machine...
- need opinions hammer perf bike build
- 1991 Sportster Problems
- 2004 883 Front Cylinder Rocker Tap Tap Tap
- Roadster XL1200CX Engine guards ?
- '86 Transmission help needed!
- Exhaust pressure
- electronic flasher for aftermarket LED
- Ozarks by US 95
- 1200 Custom fuel overflow hose question
- 1965xlch wiring
- Biltwell Frisco Bars
- Oil Leak by Starter Motor
- Exhaust Questions
- Sportster loosing power when turning lights on HELP!!
- Hidden away in New Products 2017...
- 883 vs 1200 longevity
- Quick poll: Farthest distance bike purchase....
- The rear tyre beat m but will i be able to change the front myself?
- 1985 XLH Clutch
- Tire Paint
- Help Determining Gasket Needed
- Anyone with a roadster have baggers?
- 'Rough' Engine feel - 2016 HD 48
- Who is actively riding the oldest sportster?
- Airflow! V&H Vo2 Duke vs K&N 63-1126 vs DK Outlaw 636v
- Mid glide trees
- Did you feel a difference with a Stage 1 Intake/Exhaust?
- OTD price for 2016 iron 883 . To buy a not to buy
- 25,000 mile Maintenance for a Sportster.
- LED headlight Eagle Lights vs Scoot Lights
- What's my 48 worth?
- drive belt replacement
- Stock exhaust bracket
- 2010 nightster stalling
- Rain Gear Opinions Wanted
- stock jets
- WTF I'M Losing My Mind
- slip on exhaust
- First bike - is it a 1200?
- How to adjust shocks in a 2004 Sportster
- Switched out Speedo guage and Harley won't start
- Chain Conversion on a 2000 1200XLH
- Sportster exhaust stud broke HELP
- Rekluse EXP Clutch for Sportster
- HOW TO: Replace Jiffy Stand or Spring
- Whitewall question
- Slip on foam throttle/handlebar grips
- question about shifting - 2016 Forty-Eight
- What heat range plug in a 1250 conversion
- What do you think of this bike?
- easy clutch 2002 Sportster1200C
- ARE VH Short shot staggers fwd control compatible?
- Shocks on a Roadster
- Air filter questions!
- Ye old Iron...
- Sportster backfires, pops, and dies
- Sportster 883 Slip Ons
- slipstreamer
- NHTSA complaint filed today
- Master cylinder rebuild
- 03 sportster blinker
- Stripped Shock Bolt
- Intake seals for my sportster.
- 2004 Sportster xl1200R
- Footpeg Rubbers
- Iron Vs 48...New Vs Used
- Best Regulator for the Money? 2004 Sportster
- LED Bulbs
- Bitter Sweet Day...
- Any lower fork cover for 883 iron?
- 883 to 1200
- Pre 2003 Wrenching ....parts availability???
- S&S carb jetting for 1200
- Sportster 72 Battery Cover
- Anyone here with the Mustang Vintage Solo? Question for you.
- Help, What have the potholes done to my bike!!??
- 1991 xlh 1200 first of this model with 5 speed and belt drive?
- Harley Vets I need some help! Error codes P0151 P0152 & P0154
- Rear under fender LED tail light
- What is this hose?
- I'm having Scramster dreams
- Rocker Covers?
- Torx wrench size
- 2008 Nightster Sat For 3 Years, What service should I do next?
- Rear Running Light Tricky Problem
- Small Angled Bag Forward of Left Rear Shock = ??
- Roadster part number
- Battery charging during winter
- Harley Breakout speedo bracket on sportster
- Exhaust and air cleaner with no remap?
- Crankcase breather spitting oil
- 1998 Sportster Sport forward controls mount
- Bettery
- Torque Bit Size for Rear Shock Fasteners
- Roland Sands Turbine and V&H FP3 installed on 48.
- 2016 Roadster Did my 1000 mile service with Amsoil
- Japan Harley Sportster Crash
- Turn Signal, brake light, rear light replacement bulbs
- Back wheel off center
- 16 sportster 48 pricing
- Hello From Durham NC
- LAF Exhaust
- AC glass crazing?
- 1994 Sportster 1200 Sputters after Running OK for a Few Minutes
- Well Crap!
- A tank bag on 883? Any suggestions?
- Despite autotuning on PV my bike appears to be running lean?
- 16" Ape Handlebar Porn Request...
- Hello from Marysville Washington!
- Rough Crafts exhaust - Sportster
- 2016 Roadster 1000 mile service questions
- 1997 Harley Sportster 1200 Primary or Clutch noise help?
- O2 Sensor bypass and warming up bike...
- Pulley cover on 48
- Should I go for "S.E. Street Performance Tuner"?
- Suggestions on a 48 seat??
- Sportster acting up
- Oil leak remains after repairs
- Problems with 2013 Forty Eight Sportster...
- 2008 sportster XL883L
- Murdered Out 1200 Roadster
- CV axle going bad??
- Harley Premium Ride Hand Adjustable Touring Shocks Low Profile
- Gas cap won't click over tank bib
- Getting the Project 48 Ready for the Hot Bike Tour
- Need help identifying a part
- Lowering Kit
- Where can I find a service manual?
- Speedometer
- Indian fender on 72
- Headlight Replacement
- 50% Chance of Rain: Ride or Not-Ride?
- 2016 883 Iron - Rear Fender Bolt Size
- Can I ride on this...
- Rear sets
- California exhaust
- Rush Slip-ons & X14IED on 2009 Sportster XL1200C
- What footpegs you using on 48 with offset clevis?
- Sportster 2014 XL883l -tipped won't start, stranded!
- what is Califonia highway minimum speed?
- Rear brake caliper removal on 99 sportster 1200 custom
- New 08' 1200 Low owner
- Miles before top end rebuild?
- Leaking breaking caliper.
- 2005 Sportster xl 1200c loud knocking
- bad solenoid -with soft copper contacs
- 1970xlch
- Cycle Shack pipe ID Help
- Luggage rack seat
- Conflicting Specs on 2004 883C
- Data Link Connector
- Vibration under load
- How tall are you???
- need input on air cleaner
- 2016 Roadster Exhaust Help
- XL-ViED Problems
